Out Of Stock
Color imageCLASS MF743Cdw
IC MF743CDW
As low as $499.00 Regular Price $599.00
Out Of Stock
$100 Instant Savings
  • Print up to 28 ppm
  • Print up to 8-1/2" x 14"
  • 850-sheet maximum paper capacity
  • Three-year limited warranty standard
New
Return Policy
Color imageCLASS MF743Cdw Spec Sheet
MAIN UNIT
CORE FUNCTIONS
Print, Copy, Scan, Fax, Send (Lite)
ITEM CODE
3101C011
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5" Color Touch Panel
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection, NearField Communication
PAPER CAPACITY (LETTER, 20 LB. BOND)
300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 50-sheet Stack Bypass
Optional: 550-sheet Paper Cassette (Cassette Unit AF-1)
Maximum: 850 Sheets
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
75 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (10 Envelopes)
Stack Bypass: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (1 Envelope)
SUPPORTED MEDIA SIZES
Cassettes: A4, A5, B5, Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" x 5" to Max. 8.5" x 14")
Stack Bypass: Letter, Legal, Statement, Executive
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
Stack Bypass: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
WARM-UP TIME
From Power On: 13 Seconds or Less;
From Sleep Mode: 6.1 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 18.8" x 18.8" x 18.4" (478 mm x 478 mm x 467 mm)
Box: 23.7" x 18.9" x 23.2" (602 mm x 479 mm x 589 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 21.4" x 43.8" x 29" (544 mm x 1,112 mm x 736 mm)
Fully Configured: 21.4" x 43.8" x 34.1" (544 mm x 1,112 mm x 866 mm)
WEIGHT2
Unit: Approx. 64 lb. (29.0 kg)
Boxed Weight: Approx. 76.1 lb.(35 kg)
SUPPORTED OS
Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X v10.9.5 (or later)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED3
Up to 28 ppm (Letter); Up to 22.9 ppm (Legal)
FIRST PRINT-OUT TIME
Approx. 7.5 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
750 - 4,000 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II
DOUBLE-SIDED PRINTING
Automatic (Standard)
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES4
Apple® AirPrint,® Canon PRINT Business, Mopria™ Print
Service
COPY SPECIFICATIONS
COPY SPEED
FIRST COPY-OUT TIME (LETTER)
Platen: 9.5 seconds/11.1 seconds (BW/Color)
ADF: 9.9 seconds/11.8 seconds (BW/Color)
COPY RESOLUTION (dpi)
600 x 600
COPY SIZE
Platen: Up to Letter;
ADF: Up to Legal
MULTIPLE COPIES
Up to 999 Copies
MAGNIFICATION
25% - 400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
COPY FEATURES
Paper Setting, Favorite Setting, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPE
Single-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY
50 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
13-28 lb. Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book
PULL SCAN
ScanGear MF for TWAIN, and WIA
SCAN RESOLUTION (dpi)
Push Scan: Up to 300 x 600
Pull Scan: Up to 600 x 600
SCAN TO MOBILE DEVICES
SCAN SPEED (LETTER)
Single-sided: 14/28 ipm (300 x 600 dpi) (Color/BW)
Double-sided: 27/51 ipm (300 x 600 dpi) (Color/BW)
MEMORY MEDIA
Standard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATION
Email/Internet FAX (SMTP), SMB, FTP
ADDRESS BOOK
LDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION (dpi)
600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
COMMUNICATION PROTOCOL
File: FTP, SMB
Email/iFax:: SMTP, POP3, iFax (Simple)
FILE FORMAT
Standard: TIFF, JPEG, PDF (Compact, Searchable)
Optional: PDF (Encrypted, Digital Signature)
FAX SPECIFICATIONS
MODEM SPEED
Super G3: 33.6 kbps
G3: 14.4 kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION (dpi)
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Legal
FAX MEMORY
Up to 512 Pages
SPEED DIALS
Max. 281
GROUP DIALS / DESTINATIONS
Max. 299 Dials
SEQUENTIAL BROADCAST
Max. 310 Addresses
MEMORY BACKUP
Yes
FAX FEATURES
RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
NETWORK
Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication before SMTP
DOCUMENT
Standard: Secure Print
WI-FI® AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES) WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 1470 W
Standby: Approx. 20.5 W
Sleep Mode: Approx. 0.6 W
Typical Electricity Consumption (TEC) Rating: 0.31 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver1
FOOTNOTES
1 For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
2 Includes consumables.
3 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
4 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
5 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
Reviews
