Color imageCLASS MF8580Cdw
IC MF8580CDW
As low as $299.00
Out Of Stock
  • Copy
  • Cost & Energy Efficient
  • Ethernet
  • Fax 33.6 Kbps
  • Mac OS Compatible
  • Super G3 Fax
Show more
Main Unit Spec
Printer Specifications
Printer Type
Color Laser
Print Speed
Up to 10ppm (2-sided plain paper letter)1
Up to 21ppm (1-sided plain paper letter)1
First Print Time
14.3 seconds or less (letter)2
Printer Language
UFR II LT (Host-based), PCL6(5e,XL)
Print Resolution
Up to 1200 x 1200 dpi
(2400 x 600 dpi quality)
Maximum Print Size
Up to Legal
Duplex Print
Yes, Automatic
Print Modes
Watermark, Toner Save, Page Composer, Poster, Booklet
Print Memory
512 MB (Shared)
Copier Specifications
Copy Type
Color Laser
Copy Speed
Up to 21cpm (letter)
Duplex Copy Speed
Up to 10cpm (letter)
Copy Resolution
Up to 600 x 600 dpi
Original Type
Text/Photo/Map
Halftones
256 Levels
Warm-up Time
Approximately 23 seconds
First Copy Time
Black: Approx. 15.3 seconds (letter)3
Color: Approx. 16.0 seconds (letter)3
Recovery Time
Approximately 8 seconds
Maximum Number of Copies
99 copies
Duplex Copy/Bind Time
Yes
Reduction/Enlargement
25 - 400% in 1% increments
Zoom
Copy Size
Platen: Up to Letter
ADF: 5.5" x 5" to Legal
Copy Features
Collate
2 on 1
4 on 1
ID Card Copy
Frame Erase
Copy Memory
512 MB (Shared)
Fax Specifications
Modem Speed
Up to 33.6 Kbps (Super G3)4
Fax Resolution
Up to 406 x 391 dpi (super fine)
Transmission Time
JBIG (approx. 3 seconds)
Memory Capacity
Up to 512 sheets5
Speed Dials
181 coded dials
Group Dialing
199 destinations
Sequential Broadcasting
210 destinations
Duplex Fax
Yes (TX & RX)
Receive Modes
FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features
Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial
Activity Reports
Activity Result & Activity Management
pC Fax
Sending only
Fax Forwarding
FAX -> FAX, EMAIL, SMB
Scanner Specifications
Scan Type
Color Contact Image Sensor (CIS)
Color Depth
24-bit
Scan Resolution
Up to 600 x 600 dpi (optical)
9600 x 9600 (interpolated)
Scan Size
Duplex Scan
Yes
Compatibility
TWAIN, WIA
Output File Formats
PDF(Compact), PDF, JPEG, TIFF
Scan Features
Scan to USB
Pull Scan
USB and Network
Push Scan (Scan to pC)
USB and Network
Send Specifications
Scan to Email
Yes (PDF, Compact PDF)
Scan to SMB
Yes (JPEG, TIFF, PDF, Compact PDF)
Paper Handling Specifications
Standard Paper Source(s)
250-sheet cassette plus 50-sheet multipurpose tray6
Optional Paper Source(s)
250-sheet cassette6
Document Feeder
50-sheet duplex6
Paper Output
125 sheets (face down)
Paper Weight
16-58 lb. bond (cassette)
16-58 lb. bond (multipurpose tray)
Media Sizes
Letter, Legal, A4, A5, B5, B6, Statement, Executive
Media Types
Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope, Index, Color, Coated
Envelope Capacity
10 envelopes
Envelope Types
Com 10, Monarch, DL, C5, B5
Connectivity and Software Specifications
Standard Interface(s)
USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 b/g/n Wireless7
WiFi Access Mode
Infrastructure Mode
WiFi Authentication Methods
Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Modes
WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods
Push-button mode, PIN code mode
Mobile Functions
Canon Mobile Printing9, Google Cloud Print™10, Apple AirPrint™11
Network Functions
Print, Copy, Scan, Fax, PC Fax, Print/Scan to USB
Embedded Web Server (Remote UI)
Yes
Web Browser Support for Remote UI
Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher
Print Protocols
LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services
DHCP, BOOTP, RARP, Auto IP, Bonjour(mDNS), DHCPv6 (IPv6), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), ARP+PING, WINS (IPv4)
Network Management Protocols
SNMPv1, SNMPv3 (IPv4,IPv6)
OS Compatibility
Windows® 8, Windows 7, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Vista®, Windows Server 2003, Windows® XP, Mac® OS X 10.5.8 & up, Linux(Print only)
Cable Included
Power Cord (USB not included)
Bundled Software
Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Toolbox, Presto! PageManager
Environmental Specifications
Power Consumption
Max: Approx. 1,200W
During Operation: Approx. 450W
Standby: Approx. 23W
Energy Saver: Approx. 1W
Typical Energy Consumption
0.9kWh
General Specifications
Dimensions
17" (W) x 19.1" (D) x 18.9" (H)
Unit Weight (without/with cartridge)
63.1 lbs. (w/o cartridge)
68.3 lbs. (w/cartridge)
Package Weight
Approx. 81 lbs.
Cartridge Type
Cartridge 118 Black (Yields approximately 3,400 pages)
Cartridge 118 YMC (Yields approximately 2,900 pages)
*Yields based on ISO/IEC Standard
LCD Display
7-line QVGA Color LCD
Duty Cycle
Up to 40,000 pages per month
Department ID Management
Yes, Up to 300 IDs
Security
Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC
Languages
English, French, Spanish, Portuguese
Warranty
1 year limited exchange/carry-in warranty8 (Extended warranty available)
Color imageCLASS MF8580Cdw Compatible Products
Toner
Toner
Product Disclaimer
1. Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type and orientation of paper.
2. May vary depending on the output environment.
3. Letter size, after being restored from energy saver mode.
4. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
5. Based on ITU-T #1 Chart (standard mode).
6. Based on 20 lb. bond paper.
7. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
8. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
9. Requires Canon Mobile Printing app available free on the App store. Compatible with iPhone 5, iPhone 4S, iPhone 4, iPad mini, iPad 4, the new iPad, iPad 2, and the original iPad running OS 6.0.1 - 6.1.2
10. Requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or A Mac running OS 10.4.11 or later and USB cable required to perform firmware update.
11. AirPrint™ functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint™-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
12. User may be prompted to update device firmware depending on the purchase date of the unit. The firmware can be found by going to www.usa.canon.com/support and searching your model under Drivers & Software. For update instructions, see the document bundled into the firmware download.
