Colorado 1650 UVgel Printer
As low as $0.00
Out Of Stock
  • High production, all-in solution
  • Flexible UVgel 460 inks
  • Higher Speed, lower running cost
  • Jumbo Roll & Wallpaper Factory Capabilities
Main Unit Specs
Printing Method
UVgel piezoelectric inkjet
Printing modes
Gloss:
Max speed mode: 1,709 ft.2/hr.
High speed mode: 1,229 ft.2 /hr.
Production speed Mode: 861 ft.2/hr.
Production mode: 610 ft.2/hr.
Production quality mode: 570 ft.2/hr.
High quality mode: 430 ft.2/hr.
Superior mode: 290 ft.2/hr.
Specialty mode: 222 ft.2/hr.
FLXfinish+: 72 ft.2/hr.
Matte:
High Speed: 495 ft.2/hr.
Speed: 409 ft.2/hr.
Production: 333 ft.2/hr.
Quality: 290 ft.2/hr.
Specialty: 215 ft.2/hr.
Backlit: 215 ft.2/hr.
Backlit Density: 107 ft.2/hr.
Print resolution
Up to 1,800 dpi
Ink types
UVgel 460 ink, CMYK (1-liter bottles)
Ink color
CMYK
Ink packaging
2 x 1-liter ink bottle
Ink reservoir can accommodate up to 2.5 liters per ink color
Printheads
UVgel 415 printheads (two per color)
Automatic maintenance
PAINT constantly monitors and compensates for nozzle failures that can occur during printing
Automatic maintenance performed in seconds, daily
Refill ink while printing
Curing
UV LED with FLXfinish+, instant dry, low temperature
Media
Roll width
Up to 64" (1,625 mm)
Print margin
0.21" (5.3 mm)*
Roll weight
Up to 110 lb. (50 kg)
Roll diameter
Up to 8.7" (220 mm)
Media thickness
Up to 0.03" (0.8 mm)
Number of input rolls
2 rolls in PSO mode / 1 roll in PSI mode
Automatic roll-feeding and switching
Technologies
UVgel technology
Instant pinning and dot gain control
Low-temperature curing, suitable for thin and heat-sensitive media
High-precision color matching and consistency
Instantly dry
FLXfinish+ Technology
Gives you the choice between gloss or matte output on both smooth and structured media
Enables you to print on porous and uncoated materials
Size and weight
Printer dimensions (W x D x H)
119" x 43" x 52" (3,022 x 1,093 x 1,300 mm)
Printer weight
1,631 lb. (740 kg)
Software
Supported RIPs
ONYX Thrive, Caldera, EFI, PrintFactory, ColorGATE, ErgoSoft, Shiraz, AGFA, and API for third-party RIP vendors
