Colorado M-series
- Highly productive 64” Roll-to-Roll printer
- Flexible UVgel 460 inks
- FLXfinish+ mixed matte and gloss finish
- White ink without the worry
- Modular – grows with your business
Overview
Level Up Your Game with the Colorado M-series
Are you ready for next level productivity and creativity? With the NEW Colorado M-series printer, you can say ‘yes’ to more jobs, create stunning applications and reduce turnaround times. Its modular architecture allows it to grow with your business and is designed for low cost of ownership.
- The Power of UVgel Technology – create robust, fade, and scratch-resistant prints with excellent print quality.
- White Ink Without Worry – our NEW UVgel white ink developed just for the Colorado M-series printer, now brings you a next-level white ink that reduces the hassles associated with white ink.
- FLXfinish+ – print matte, gloss or mixed matte and gloss in one print, without varnish, or an additional printhead.
- Impressive Media Range – “WOW” your customers with an extended media range, including textured, transparent, colored, reflective, magnetic, heat sensitive media, and many more!
- Modular Design | Industrial Quality: Configure your own ideal Colorado M-series printer to your current business needs and easily upgrade features, speed, and inline finishing as your business grows.
Supplies
The key to completing a successful project is starting with the proper supplies. With Canon, you have access to genuine supplies that are engineered to work with your equipment.
Main Unit Specs |
Colorado M3 |
Colorado M5 |
| Printing | ||
| Printing Method | UVgel piezoelectric inkjet | UVgel piezoelectric inkjet |
| Printing Modes: Gloss | High Key: 1,195 ft2/hr Express: 840 ft2/hr Speed: 592 ft2/hr Production: 420 ft2/hr High Quality: 312 ft2/hr Premium: 237 ft2/hr Specialty: 215 ft2/hr |
High Key: 1,709 ft2/hr Express: 1,229 ft2/hr Speed: 861 ft2/hr Production: 610 ft2/hr High Quality: 427 ft2/hr Premium: 290 ft2/hr Specialty: 222 ft2/hr |
| Printing Modes: Matte** | Express: 388 ft2/hr Speed: 291 ft2/hr Production: 237 ft2/hr High Quality: 194 ft2/hr Specialty: 140 ft2/hr Backlit: 194 ft2/hr Backlit Density: 108 ft2/hr |
Express: 495 ft2/hr Speed: 409 ft2/hr Production: 333 ft2/hr High Quality: 290 ft2/hr Specialty: 215 ft2/hr Backlit: 215 ft2/hr Backlit Density: 108 ft2/hr |
| Printing Modes: Mixed Matte/Gloss** |
FLXfinish+: 75 ft2/hr | FLXfinish+: 75 ft2/hr |
| Printing Modes: Spot White 1 Layer** |
Express: 291 ft2/hr Speed: 237 ft2/hr Production: 194 ft2/hr High Quality: 140 ft2/hr Specialty: 129 ft2/hr |
Express: 388 ft2/hr Speed: 323 ft2/hr Production: 258 ft2/hr High Quality: 194 ft2/hr Specialty: 129 ft2/hr |
| Printing Modes: White Underflood/Overflood 2 Layers* |
Speed: 215 ft2/hr Production: 151 ft2/hr High Quality: 108 ft2/hr Specialty: 75 ft2/hr |
| Printing Modes: White 3 Layers** |
High Quality: 75 ft2/hr Specialty: 54 ft2/hr |
| Printing Modes: White 5 Layers** |
High Quality: 43 ft2/hr Specialty: 32 ft2/hr |
| Print Resolution | Up to 1,800 dpi | Up to 1,800 dpi |
| Print Resolution | Canon UVgel 460 ink | Canon UVgel 460 ink |
| Ink Color | CMYK / CMYKW**** | CMYK / CMYKW**** |
| Ink Packaging | 1 x 700ml ink bottle Ink Reservoir per ink color: 1.8 liter Can Refill while printing |
1 x 700ml ink bottle 2 x 1 liter ink bottle Ink Reservoir per ink color: 2.1 liter Can Refill while printing |
| Printhead | 4 or 5* UVgel 425 Printheads High frequency drop-on-demand piezo-electric printhead PAINT (Piezo Acoustic Integrated Nozzle Technology) Automatic Maintenance Curing: UV LED |
| Media | Roll Width: Up to 64” (1,625 mm) Print Margin: 0.21” (5.3 mm)2 Roll Weight: Up to 110 lbs (50 kg) Roll Diameter: Up to 8.7” (220 mm) Media Thickness: Up to 0.03” (0.8 mm) |
| Media Input | 1 roll or optional 2nd roll** Print Side Out Media Print Side In / Double Sided Media** Magnetic Media Kit** |
1 roll or optional 2nd roll** Print Side Out Media Print Side In / Double Sided Media** Magnetic Media Kit** Jumbo Roll Interface** |
| UVgel Technology | Instant pinning** and dot gain control Low temperature curing Scratch resistance Easy lamination, smooth ink film High precision color consistency Odorless and instant dry prints |
Instant pinning and dot gain control Low temperature curing Scratch resistance Easy lamination, smooth ink film High precision color consistency Odorless and instant dry prints |
| Certifications | Environmental and Safe Use: GREENGUARD Gold |
| Software | Supported Rips: ONYX Graphics, Caldera, EFI, PrintFactory, ColorGATE, ErgoSoft, Shiraz, AGFA, SAI PRISMA Applications: PRISMAguide XL PRISMA remote app PRISMAservice |
| External Modules | None | Jumbo Roll Loader X/Y Cutter Rewinder Jumbo Roll Rewinder |
| Interface | Ethernet (100/1,000 Mbit/s) | Ethernet (100/1,000 Mbit/s) |
| Dimensions | Printer W x D x H 3,020 x 1,095 x 1,300 mm | Printer W x D x H 3,020 x 1,095 x 1,300 mm |
| Weight | 750 kg | 750 kg |
| Working Environment | ||
| Operation Printer | 18 - 30°C (recommended 20 – 27°C), 20 - 80% RH (no condensation) | 18 - 30°C (recommended 20 – 27°C), 20 - 80% RH (no condensation) |
| Power | 0 W - Off, 250 W - Standby, 1.6 kW - Ready, 2.3 kW - Printing | 0 W - Off, 250 W - Standby, 1.6 kW - Ready, 2.3 kW - Printing |
| Consumption | 2 inputs, each 200-240V +/- 10%, 50/60 Hz, 16/6 A. | 2 inputs, each 200-240V +/- 10%, 50/60 Hz, 16/6 A. |
| Source | Printer is declared under Radio Equipment Directive (RED)- 2014/53/EU | Printer is declared under Radio Equipment Directive (RED)- 2014/53/EU |
| Regulatory Certification | ||
| Declaration of conformity | Compliant with EN62479, EN301 489-1, EN301 489-3, EN300-330 FCC Part 15 and RSS-210 certified (module) |
| Radio | IEC/EN/UL/CSA 62368-1 compliant Applicable marks: CE, TÜV-GS, C-UL-US, RCM | IEC/EN/UL/CSA 62368-1 compliant Applicable marks: CE, TÜV-GS, C-UL-US, RCM |
| Safety | Emission: Class A compliant according CISPR 32, FCC part 15 and ICES-003 Immunity: CISPR 35 compliant | Emission: Class A compliant according CISPR 32, FCC part 15 and ICES-003 Immunity: CISPR 35 compliant |
| EMCEnvironmental | WEEE, RoHS directive 2011/65/EU, REACH, CE | WEEE, RoHS directive 2011/65/EU, REACH, CE |
* Base unit requires 4 printheads, adding optional white module requires and additional print head for a total of 5 printheads
**Optional module
**** White ink is an optional module
Resources
Colorado UVgel Workflow Factories Brochure
05.19.25
29.5 MB
Why Upgrade to Colorado M-series
10.10.25
0.3 MB
Canon Colorado M-series Spec Sheet
03.02.26
0.4 MB
Colorado M-Series Consumables Guide
02.26.25
1.1 MB
Canon Colorado M-series Brochure
07.09.26
7.8 MB
