Colorado XL-series
- Highly Productive 11’ Roll-to-Roll and Hybrid Printer
- 2 inch Maximum Print Thickness
- Flexible UVgel 860 Inks
- White ink without worry
- Modular – grows with your business
Overview
All In! One Printer.
Powered by Canon’s exclusive UVgel ink technology, the Colorado XL-series printers offer outstanding speed, color vibrancy, and media versatility.
Faster Flexibles, Reliable Rigids
The Colorado XL-series 11-foot UVgel printers are designed for roll-to-roll and rigid large-format printing delivering stunning results on a wide range of flexible and rigid media.
Bigger, Faster, Wider—The UVgel Ink Advantage
The UVgel 860 ink formulation extends the benefits of UVgel technology to rigid media, enabling printing on both flexible and rigid substrates using a single ink set. Additionally, the enhanced UVgel 860 white ink builds on the proven performance of UVgel 460 white, helping to minimize some of the common challenges associated with white ink printing.
A Modular Hybrid Machine to Help Maximize Output
The Colorado XL-series can grow with your business, helping you maximize your printer investment. Choose your initial configuration; roll-to-roll or hybrid, with optional white and field-upgrade your device in the future as needs evolve.
Applications Designed for Growth
Empower your customers with the flexibility to print on a wide variety of roll-to-roll and rigid media. Whether it’s eye-catching graphics or signage that drives business, the Colorado XL-series delivers high-quality results with speed and precision—all from one powerful device.
KEY BENEFITS
UVgel 860 Ink
The ink delivers instantly dry, durable prints with a large color gamut and consistent color results. The inks help lower operating costs through reduced ink usage. Add optional UVgel white ink and print white graphics without the typical maintenance and cleaning issues associated with white ink.
UVgel 850 Printhead
The next-generation of Canon dual channel printheads make it possible to print in four colors at high speeds using only two printheads, with an optional third printhead for UVgel white ink.
TRIdrive Vacuum Belt System
The Colorado’s unique media transport system uses a unique third roller that not only helps maintain tension but can change its pitch to keep the belt running straight thus limiting side-to-side misregistration over long runs and costly rework.
Dynamic Motion Control (DMC)
DMC captures a snapshot of the media surface and dynamically moves the printhead positions in multiple directions to correct any deviations in media movement while printing. Combined with the TRIdrive system, DMC helps to reduce banding and achieve excellent image quality results at high print speeds.
Full-Beam Curing
Patented Full-Beam Curing technology, with its mirror-based system, helps to precisely calibrate and customize the UV curing for specific applications. It also provides curing of up to five layers of ink in a single pass across the full width of the media.
View Full Technical Specs PDF
Resources
Canon Colorado XL Data Sheet
04.22.26
0.7 MB
Canon PRISMAelevate XL Brochure
12.22.25
2.8 MB
Canon Colorado-XL Series Brochure
07.08.26
4.2 MB
