Colortrac SCi 42c Xpress Scanner
SCI42C SCANN
As low as $0.00
Out Of Stock
  • Large format stand alone scanning solution
  • SingleSensor CIS imaging technology
  • Scan images up to 42" and media up to 44" wide
  • Scan up to 13 inches per second for black and white
  • Scan up to 6 inches per second for color as 200 dpi
  • SmartWorks TOUCH software
Show more
SCi 42c Xpress
MANUFACTURER Colortrac
SCAN TECHNOLOGYSingleSensor
MAX SCAN WIDTH 42"
MAX MEDIA WIDTH44"
MAXMEDIA THICKNESS0.08" (2mm)
SCANNER OPTICAL RESOLUTION1200 dpi
MAX SCAN SPEED RGB 24-BIT COLOR (IN/SEC) @ 200 DPI 13
MAX SCAN SPEED GRAYSCALE 1-BIT MONO (IN/SEC) 8-BIT GRAYSCALE @ 200 DPI 6
SCANNER CONNECTION
USB3
SOFTWARE INCLUDED
SmartWorks TOUCH
SOFTWARE FEATURES
Scan, Copy, Print, Preview Edit, PDF, Multipage PDF
COLOR SPACES
sRGB
WINDOWS PRINTER DRIVER
PAPER PATH
Face-up, front entry, rear exit or rewind to front
Face-up, front entry with optional Document Return Guide
WEIGHT & DIMENSIONS (WxHxD)
Scanner: 58.4 lbs / 51.2 x 6.0 x 15 inches
Packed: 68.3 lbs / 56.8 x 9.3 x 20 inches
SUPPORTED WINDOWS OS
Windows 10 and Windows 8.2, 32-bit and 64-bit architectures
SmartWorks TOUCH
SCAN ONCE - PREVIEW EDIT WORKFLOW
SCAN TO PC OR USB STICK. TIFF, TIFF G4, PDF, JPEG
SCAN TO PDF/A
SCAN TO MULTIPAGE PDF
SCAN TO TIFF LZW, JPEG2000, PNG, PCX BMP, MULTIPAGE TIFF
SCAN TO DWF (AutoCAD®)
WHITE POINT, BLACK POINT, SKEW, BRIGHTNESS, SHARPEN, B&W THRESHOLD SIMPLE, B&W THRESHOLD ADAPTIVE, PREVIEW, BATCH SCANNING
CONTRAST
COPY TO PRINTER
NUMBER OF PRESETS
9
MAXIMUM SCAN LENGTH
JPEG and PDF formats are limited to 65,535 scan lines with scan length decreasing as dpi increases. Other formats are not length restricted but cannot exceed 4GB. Maximum scan lengths for compressed file formats such as PNG will be reached at smaller file sizes and are dependent on image compressibility.
COLOR SPACES
sRGB
SUPPORTED PRINTERS
Various Brands
