The Canon CX-G6400 card & badge printer is designed to easily produce customized photo-quality images on four-inch single-sided paper and CR80 size plastic cards with speed and efficiency.
CX-G6400 Card & Badge Printer
- Print up to 4" wide on inkjet paper or inkjet plastic media
- Dye-based inks for colorful graphics and vivid colors
- Fast first print out time: 12 seconds or less
- Up to 2,700 cards per hour
- Print resolution up to 1200 dpi
- USB and ethernet connectivity
In the box
OVERVIEW
ABOUT THE CX-G6400 CARD & BADGE PRINTER
WIDE VARIETY OF USES
Engineered for speed and capable of oversized high-quality output, the CX-G6400 printer is ideal to produce single-sided paper or CR80 size plastic cards in vibrant color. For concert badges, press passes, event badges, oversized passes, business cards, and envelopes, the printer can deliver the professional look needed in sectors like entertainment, hospitality, retail, administrative & support services, government and more. Printing cards on-demand allows users to print what is needed when it is needed, so there is no need to maintain a large inventory.
HIGH PERFORMANCE
The CX-G6400 printer is fast and can print up to 45 single-sided inkjet paper or inkjet plastic cards per minute, with a first-print-out time of approximately 12 seconds or less. With a feed hopper of up to 400 paper or plastic cards / 100 envelopes and the ability to refill while printing, performance is maximized.
EASY TO INSTALL AND USE
The CX-G6400 printer can easily be installed on a desktop or counter. The straightforward operation buttons make the printer simple to use. Also, the CX-G6400 uses inkjet printer cartridges that are easy to replace. Plus, it supports dual media printing, able to handle printing on inkjet plastic or inkjet paper.
OUTSTANDING PRINT QUALITY
The CX-G6400 printer produces professional-looking crisp and clear photo-quality images, with up to 1200 x 1200 dpi resolution, making text, images, and scan codes look sharp and crisp. The printer also uses dye-based inkjet printing, for vivid and vibrant color output.
CUSTOMER CARE
For investment protection, eCarePAK extended service plan options are available beyond the initial one-year advanced exchange limited warranty period. An eCarePAK can help save on costs associated with post-purchase maintenance and help maximize uptime throughout the product life.
Main Unit Spec
Printer
Business Card: 100 Cards/minute (6,000 Cards Per Hour (CPH)) 1
Plastic Card (CR80): 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
4"x6" Postcard: 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
Envelope: 28 Envelopes/minute
Length: 297.0 mm / 11.7"
Left/Right: 2.0 mm
Envelope: 0.24 - 0.48 mm / 9.45 - 18.9 mil
Plastic & Paper Card: 400 Cards
Envelope: 100 Envelopes
Inkjet Plastic Card: 2" x 3.5"
Custom Size: Paper/Plastic within Maximum Printable Size & Up to 30 mil"
Length: 49.0 - 300 mm / 1.9 - 11.8"
General
Ethernet (10/100/1000Base-T)
Operating: Approx. 135 W
Sleep Mode: Approx. 8.5 W or Less
Operating Noise (Max.): 58dB or less
Standby Noise: 35dB or less
Approx. 72,000 Cards1
Buttons/LEDs: 3 Buttons / 8 LEDs
Brochures
Canon CX-G6400 Card & Badge Printer Brochure
09.14.22
0.3 MB
Canon-CX-G6400-Service-and-Support-Brochure.pdf
11.29.22
3.3 MB
Canon CX-G6400 Card & Badge Printer Consumables Accessories Brochure
11.29.22
0.1 MB
Product Disclaimer
- Based upon standard business card print conditions with no image and print size of 2x3.5 inkjet coated matte business card, 7.5% Duty/Color, 1 sheets x 3 jobs/day x 2 days/month. Print speed based on click to drop, average print coverage, with USB connectivity, Cards Per Hour (CPH).
- With Standard condition: 7.5%Duty, Business card size:1 sheets x 3 jobs / day
- Operation can only be guaranteed on a PC with pre-installed Windows® 11 (64/32-bit), Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit).
- Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
- Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
- Printer weight measured excluding printhead or ink cartridges installed.
