DIGISUPER 80
XJ80X8.8
As low as $143,000.00
Out Of Stock
  • Simultaneously offers a maximum wide angle of 8.8mm and a high magnification of 80x for wider and longer-distance shooting
  • Incorporates an advanced image stabilizer for mitigating vibration of all kinds, as a standard function
  • Reduces shifts in angles of view caused by focusing to nearly zero. CAFS (Constant Angle Focusing System)
  • Support for Various Virtual Systems
Show more
Overview
The DIGISUPER 80 is an innovative HDTV field lens
The unparalleled quality offered by the DIGISUPER Series by Canon has made it a permanent fixture at sporting events around the world and a heavy favorite of professional camera operators. As one of Canon's leading lens series for broadcast use, the DIGISUPER line has introduced numerous technological innovations while capturing memorable scenes with the best possible quality, so that they may be enjoyed by future generations.
DIGISUPER 80
A common refrain has been to make field lenses wider and with higher magnification to convey the intensity and dynamism of the scene at hand, as well as to make our image stabilization feature more high-performance in order to film elegant video footage free of blurring.
Our answer to these needs is the DIGISUPER 80 (XJ80x8.8B). This next-generation Premium Field lens successfully offers both enhanced width and higher magnification by bringing together the very best of the technology Canon has developed over the last half-century, and also incorporates a more advanced version of Canon's reputed image stabilization feature as a standard function.
Features
Simultaneously offers a maximum wide angle of 8.8mm and a high magnification of 80x for wider and longer-distance shooting.
The XJ80x8.8B is capable of a maximum wide angle of 8.8mm (57.2° perpendicular angle of view), which is approximately 5% wider than previous long-zoom lenses. This enables the lens to pull back and fully capture the scene even in limited space, and also capture images that exhibit a stunning degree of intensity.
With high magnification boasting a zoom factor of 80x, the XJ80x8.8B allows any and all scenes, from a panoramic view of a stadium to the detailed expressions on players, to be taken with a single lens.
Incorporates an advanced image stabilizer, a formidable ally of cameramen everywhere for mitigating vibration of all kinds, as a standard function.
The image stabilizer feature by Canon has been faithfully used over the years at many of the world's highest-profile sporting events. With the XJ80x8.8B, a more advanced version of Canon's image stabilizer has been incorporated as a standard feature.
The image stabilizer significantly curbs vibration, particularly in the high frequency range. By successfully suppressing all kinds of vibration, such as that generated by wind and excited fans in the stands, the XJ80x8.8B's image stabilizer allows the capture of stable, clear video even at super-telephoto range. It also makes camerawork a comfortable endeavor by largely mitigating the "aftershock" phenomenon that occurs when an image moves after the camera operator stops panning.
Superior operability and tracking enables you to capture images exactly as you want to.
With its superior operability, the XJ80x8.8B makes nimble camerawork possible while also offering enhanced width and higher magnification despite no intrusive increases in physical lens size.
Moreover, the use of a high-speed CPU and high-resolution encoder, coupled with improvements in control algorithms, have yielded significant enhancements in handling subjects entering motion and subsequent tracking when zooming at super-slow speeds. The results are shots taken exactly as you intended to take them.
A 32-bit CPU calculates and controls the zoom when focusing to counteract "breathing" (phenomena where picture size/angle of view changes when focusing) and has almost zero zoom effect.
The XJ80x8.8B is equipped with high-performance zoom, focus, and iris encoders. With multiple support for encoder outputs, analog outputs, and serial outputs, the XJ80x8.8B can work with many kinds of virtual systems.
It easily adapts to existing virtual systems because it comes standard equipped with 20-pin lens interface.
Product
Image Composition
Optical Brightness
Scene Composition
Physical Attributes
Informational Documents
File Name
Broadcast & Cinema Lens Catalog - Spring 2026
Date
04.15.26
File Size
44.6 MB
DIGISUPER 80 Compatible Products
Lens Accessories
Lens Accessories
