DP-V2730
- 27” 4K HDR Display
- Canon HDR Toolkit
- Brilliant Image Quality
- Dual/Quad Display
- Remote Control/Multi-Display Link
- 12G-SDI Connectivity
In the box
Return Policy
Overview
With a 27-inch screen and 1,000 cd/mFootnote2 full screen peak brightness, the DP-V2730 4K reference display has a suite of award-winning monitoring tools such as a waveform monitor, pixel value check and configurable false color, driven by Canon’s latest processing platform for superb performance.
HDR Waveform Monitor/RGB Parade
Analyze the brightness of an image from left to right with a monitor scale supporting IRE, PQ, HLG and Log signals from multiple manufacturers.
Award-winning Advanced HDR Monitoring Tools
The DP-V2730 features Canon’s award-winning advanced HDR monitoring tools to assist in evaluating HDR content over every aspect of the displayed signal.
HDR False Color
Visually represents exposure and image clipping based on detailed and customizable color scales for IRE, PQ or HLG.
Range Check
Switches the display output to monochrome and enables users to specify a peak brightness level to easily identify areas that require adjustment.
Pixel Value Check/Chromaticity Diagram
Accurately examine the color and brightness values of a specific pixel. A CIE diagram is also displayed to illustrate the pixel color space location or overall gamut of the entire image.
Out of Gamut Display
Switches the display output to monochrome and highlights colors outside the selected color gamut. Users can select either ITU-R BT.709 or Native gamut.
HDR/ SDR Comparison
An advanced function that converts HDR content to SDR for side-by-side evaluation. This function can be used to compare original content alongside enabled User LUTs or CDLs.
HDR Histogram
A graphical representation of the brightness distribution in an image. This feature can also illustrate SDR and HDR brightness ranges.
Frame Luminance Monitor
An innovative tool that allows users to closely monitor changes in peak brightness over time when viewing video sequences.
Multi Information View
Utilize multiple HDR monitoring tools simultaneously without obstructing the displayed image.
Faithful HDR Color Reproduction
Canon’s cutting-edge brightness, detailed shadows and wide color gamut across the entire screen satisfies industry-recognized standards for mastering and color-grading HDR video content.Footnote1
Simultaneous Dual/Quad Display
View up to 4K in either Dual or Quad array from both SDI and HDMI signals, as well as individual Picture Profiles or User LUTs.
Versatile Connectivity
The DP-V2730 has an HDMI input and 12G-SDI Terminals (4x Inputs and 5x Outputs) capable of delivering 4K60P 4:2:2 10-bit or 4K30P 4:4:4 12-bit signals, ideal for seamless integration into multiple workflows.
Link the DP-V2730 to a computer, tablet or smartphone and multiple Canon Displays (via a LAN connection) with the Remote Control Web UI. This touch-optimized interface provides live image viewing, detailed signal information and direct control over inputs, monitoring tools and settings.
Built-in SDI Switcher
Use 4-way SDI input switching thanks to a MULTI-FUNC SDI Output* that supports workflow applications such as sending an output feed to a director’s monitor, external recorder or live streaming solution.
* Paid license required.
