Out Of Stock
EF-M 18-150mm f/3.5-6.3 IS STM
EFM18-150STM
As low as $499.99
Out Of Stock
  • Canon's first EF-M high zoom power lens covering a broad range of shooting scenes with a high zoom ratio of up to 8.3x (29-240mm equivalent).
  • Compact and lightweight design allows for easy portability.
  • Optical design helps provide excellent image quality across a broad zoom range comparable to the EF-S 18–135mm f/3.5–5.6 IS USM lens.
  • Maximum magnification of 0.31x at focal length 150mm.
  • Image Stabilizer effect at up to 4* stops of shake correction helps capture sharp images.
  • Combination IS is achieved when used with the EOS M5 digital camera for maximum image stabilization when shooting video.
Return Policy
View Full Technical Specs PDF
Main Unit Spec
Product Disclaimer
* Measured at the focal length of 150mm (35mm equivalent of 360mm), using the EOS M3 digital camera based upon CIPA (Camera & Imaging Products Association) standards.
