EOS 6D Mark II
- 26.2 Megapixel Full-frame CMOS Sensor.
- Optical Viewfinder with a 45-point All Cross-type AF System*.
- Dual Pixel CMOS AF with Phase-Detection & Full HD 60p.
- DIGIC 7 Image Processor, ISO 100-40000.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
For superb performance on the go, the Canon EOS 6D Mark II camera puts full-frame performance into a compact, fully featured DSLR. Its 26.2 Megapixel CMOS sensor and DIGIC 7 Image Processor help deliver amazing results even at expanded ISO settings, making it great for challenging low-light situations as well as landscape, portrait and event photography. The EOS 6D Mark II also features an impressive optical viewfinder with 45 all cross-type AF points*, fast and accurate Dual Pixel CMOS AF and a Vari-angle Touch Screen LCD for Live View operation which helps create unique angles. With the EOS 6D Mark II's speed to capture action and the versatility to create phenomenal photographs and Full HD 60p videos in numerous environments and lighting situations, the camera offers creative content makers a winning combination of advanced features in a portable package that's as fun as it is powerful.
View Full Technical Specs PDF
Type
Digital AF/AE single-lens reflex camera
SD/SDHC/SDXC memory cards
- SD speed class-compatible
- UHS speed class-compatible
- High-speed writing is supported when a UHS-I compatible SD card is used.
- Compatible with Eye-Fi cards.
- Multimedia cards (MMC) cannot be used (card error will be displayed).
Approx. 35.9 x 24.0mm (Full-frame)
Canon EF lenses (excluding EF-S and EF-M lenses)
Canon EF mount
Image Sensor
CMOS sensor (supporting Dual Pixel CMOS AF)
Approx. 26.2 megapixels
Approx. 5.67 µm square
Approx. 27.1 megapixels
3:2 (Horizontal: Vertical)
RGB primary color filters
Installed in front of the image sensor, non-detachable
- Self Cleaning Sensor Unit
- Removes dust adhering to the low-pass filter.
- Self-cleaning can be done automatically when the power is turned on or off (taking about 2 sec. as indicated on the screen) or manually (taking about 9 sec. as indicated on the screen).
- After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
- When you use Multi Shot Noise Reduction, “Clean now” cannot be selected.
- Dust Delete Data acquisition and appending
- The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
- The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
- Manual cleaning (by hand)
Recording System
Compliant to Design rule for Camera File system 2.0 and Exif 2.3
JPEG, RAW (14-bit Canon original)
3:2 Aspect Ratio
Large: 6240 x 4160
Medium: 4160 x 2768*
Small 1: 3120 x 2080
Small 2: 2400 x 1600
RAW: 6240 x 4160
mRAW: 4680 x 3120
sRAW: 3120 x 2080
4:3 Aspect Ratio*
Large: 5536 x 4160
Medium: 3680 x 2768
Small 1: 2768 x 2080
Small 2: 2112 x 1600
RAW: 5536 x 4160
sRAW: 2768 x 2080
16:9 Aspect Ratio*
Large: 6240 x 3504
Medium: 4160 x 2336
Small 1: 3120 x 1752
Small 2: 2400 x 1344
RAW: 6240 x 3504
sRAW: 3120 x 1752
1:1 Aspect Ratio
Large: 4160 x 4160
Medium: 2768 x 2768
Small 1: 2080 x 2080
Small 2: 1600x 1600
RAW: 4160 x 4160
sRAW: 2080 x 2080
- Values for Recording Pixels are rounded to the nearest 100,000.
- JPEG images are generated in the set aspect ratio.
- RAW images are generated in [3:2], and the set aspect ratio is appended.
File numbering can be set as follows:
- File numbering methods
- Continuous numbering
- The numbering of captured images continues even after you replace the card.
- Auto reset
- When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
- Manual reset
- Resets the file number to 0001, and creates a new folder automatically.
Possible
sRGB/Adobe RGB
- Auto
- Standard
- Portrait
- Landscape
- Fine Detail
- Neutral
- Faithful
- Monochrome
- User Defined 1-3
- In Basic Zone modes, “Auto” will be set.
- [Auto] is the default setting for [User Def. 1-3].
White Balance
- Auto (Ambience priority/White priority)
- Daylight
- Shade
- Cloudy*
- Tungsten light
- White fluorescent light
- Flash
- Custom (Custom WB)
- Color temperature
Option between ambience priority and white priority settings
Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Corrected in reference to the current WB modes color temperature.
Viewfinder
Eye-level SLR (with fixed pentaprism)
At approx. 21mm eyepoint
| Aspect ratio | 3:2 | Approx. 98% vertically/horizontally |
| 4:3 | Approx. 98% vertically/horizontally | |
| 16:9 | Approx. 96% vertically Approx. 98% horizontally |
| 1:1 | Approx. 98% vertically Approx. 97% horizontally |
Approx. 0.71x/33.3° (with 50mm lens at infinity, -1 m-1)
Approx. 21mm (at -1 m-1 from eyepiece lens center)
Adjustable from approx. -3.0 to +1.0 m-1 (dpt)
Fixed
Quick-return all-surface half mirror
Displayed with transparent liquid crystal
- AF point information
- Area AF frame
- Spot metering circle
- Electronic level (dedicated indicator)*
- Grid*
- Aspect ratio line
- Battery (remaining capacity)*
- Shooting mode*
- AF operation*
- Image quality (JPEG/RAW)*
- Drive mode*
- Metering mode*
- Flicker detection icon*
- Warning symbol
Provided with depth of field preview button
Autofocus
TTL secondary image-forming phase-difference detection system with AF-dedicated sensor
Up to 45 points (cross-type AF points: max. 45)
| AF Points and AF Patterns | AF Points (max.) |
| Dual cross-type AF points supporting f/2.8 and f/5.6 | 1 |
| Cross-type AF points supporting f/5.6 | 45 |
| AF points supporting f/8 | 27 (cross-type AF point 9) |
- The number of AF points, cross-type AF points and dual cross-type AF points varies depending on the lens used.
Conditions: One-Shot AF, at 73°F/23°C, ISO 100 (based on Canons testing standards and environment)
| AF Point | Brightness |
| One center AF point focusing supporting f/2.8 | EV -3 to 18 |
| One center AF point focusing supporting f/5.6 | EV -2 to 18 |
| Peripheral AF points focusing supporting f/5.6 | EV -0.5 to 18 |
Autofocus
- One-Shot AF
- Predictive AI Servo AF (AI Servo AF II)
- AI Focus AF
- Switches between One-Shot AF and AI Servo AF automatically.
- Manual focus
- Single-point Spot AF (Manual selection)
- Single-point AF (Manual selection)
- The checkmark cannot be removed from this option.
- Zone AF (Manual selection of zone)
- All the AF points are divided into nine focusing zones.
- Large Zone AF (Manual selection of zone)
- All the AF points are divided into three focusing zones.
- Automatic selection AF (45 points)
- Enable
- Disable
- IR AF assist beam external flash only
Exposure Control
7560-pixel RGB+IR metering sensor
63-zone (9 x 7) metering
- Evaluative metering (linked to all AF points)
- Partial metering (center, approx. 6.5% of viewfinder)
- Spot metering (center, approx. 3.2% of viewfinder)
- Center-weighted average metering
EV 1 - 20 (at 73°F/23°C, ISO 100)
- Creative Zone
- Program AE (shiftable)
- Shutter-priority AE
- Aperture-priority AE
- Manual exposure (including bulb)
- Basic Zone
- Scene Intelligent Auto (Program AE/ non-shiftable)
- Creative Auto
- Special Scene
- Portrait
- Group Photo
- Landscape
- Sports
- Kids
- Panning
- Close-up
- Food
- Candlelight
- Night Portrait
- Handheld Night Scene
- HDR Backlight Control
| Manual | ±5 stops in 1/3- or 1/2-stop increments* |
| AEB | ±3 stops in 1/3- or 1/2-stop increments |
Auto AE lock
- In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
Manual AE lock
- In the P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
- Enabled in all metering modes.
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
1/4000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.)
Soft-touch electromagnetic release
10-sec. delay, 2-sec. delay, continuous shooting (after 10 sec., 2 to 10 shots)
- With SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.060 sec.
- Time lag between simultaneous SW-1/SW-2 ON and start of exposure: approx. 0.250 sec.
- Time lag with the aperture stopped down by 3 stops or less from the open aperture. Excludes AF operation time.
External Speedlite
E-TTL II autoflash (evaluative flash metering and average flash metering)
Provided
- External flash control
- Flash firing, E-TTL II metering, Flash synchronization speed in Av mode, Flash mode, Radio transmission wireless functions, Optical wireless functions, Flash zoom, Shutter synchronization, Flash exposure compensation, Flash exposure bracketing and Clear settings.
- External flash Custom Function setting
- The setting options for both (1) and (2) will differ depending on the Speedlite used.
Drive System
- Single shooting
- High-speed continuous shooting
- Max. approx. 6.5 shots/sec.
- Maximum continuous shooting speed with 1/500 sec. or faster shutter speed, maximum aperture (varies depending on the lens), Anti-flicker shooting set to Disable, with a fully-charged Battery Pack LP-E6N and at room temperature (73°F/23°C).
- With the AF mode set to One-Shot AF and the Image Stabilizer turned off when using the following lenses: EF 300mm f/4L IS USM, EF 28-135mm f/3.5-5.6 IS USM, EF 75-300mm f/4-5.6 IS USM, EF 100-400mm f/4.5-5.6L IS USM.
- For anti-flicker shooting: max. approx. 5.6 shots/sec.
- Low-speed continuous shooting
- Max. approx. 3.0 shots/sec.
- In the Panning mode, the maximum speed is approx. 4.3 shots/sec.
- Silent single shooting
- Silent continuous shooting
- Self-timer: 10 sec./remote control
- Self-timer: 2 sec./remote control
- Self-timer: Continuous shooting (after 10 sec., 2 to 10 shots)
Live View Functions
Still photo shooting and video shooting
- Dual Pixel CMOS AF is possible with all EF lenses.
- Contrast AF is not provided.
- Manual focus
- Magnifying the image by 5x or 10x for manual focus possible.
Real-time metering with image sensor
- AE lock possible. The metering timer can be changed.
- Evaluative metering (315-zone)
- Partial metering (center, approx. 6.3% of Live View screen)
- Spot metering (center, approx. 2.7% of Live View screen)
EV 0-20 (at 73°F/23°C, ISO 100, evaluative metering)
- Off
- 3x3
- 6x4
- 3x3+diag
Provided
Provided (Mode 1 and 2)
Video Shooting
MP4
Video: MPEG-4 AVC / H.264
- Variable (averaged) bit rate
MOV
Motion JPEG (4K 29.97, time-lapse movies only)
ALL-I (FHD 29.97, time-lapse movies only)
- If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically.
- Movie shooting does not stop automatically even if the file size reaches 4GB. (When an SDXC card is formatted in exFAT, a movie will be recorded in a single movie file even if it exceeds 4GB.)
- Manual focus
Full range (0-255)
*1 ISO 20025600 will be set if Highlight tone priority is set to Enable.
*2 The maximum limit for ISO Auto can be set to ISO 6400, ISO 12800, H1 (ISO 51200) or H2 (102400).
*3 According to the settings for [Range for ISO Auto], Maximum limit and Minimum limit.
*4 Maximum limit settable within the range of ISO 40025600 for ISO Auto in Time-lapse movies.
LCD Monitor
TFT color, liquid-crystal monitor
3.0-inch (screen aspect ratio of 3:2)
Approx. 3.03 in./7.70cm diagonal (approx. 2.51 in./6.37cm width, approx. 1.67 in/4.25cm height)
Approx. 1.04 million dots
Approx. 100% vertically
Approx. 100% horizontally
(with aspect ratio of 3:2/JPEG Large/Fine)
Excluding when distortion correction is applied.
Adjustable to one of seven brightness levels
Clear View LCD II
- Anti-smudge coating applied.
- Anti-reflection coating not applied.
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Playback
- Single-image display
- No information display
- Basic information display
- Detailed shooting information display
- Basic shooting information
- Lens information and RGB histogram
- White balance
- Picture Style and sharpness
- Contrast, color saturation and color tone
- Color space and noise reduction
- Lens aberration correction
- GPS information
- Index display
- 4-image
- 9-image
- 36-image
- 100-image
Overexposed highlight areas with no image data will blink.
Brightness and RGB
Quick Control Function
Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback.
After selecting an item, you can select contents by operating the Main Dial.
Image Protection and Erase
- Single image (select image)
- Select range
- All images in a folder
- All images on card
- All found images (only during image search)
Except protected images
- Select image to erase
- Select range
Direct Printing
Images can be sent via Wi-Fi® to a PictBridge-compatible (Wireless LAN) printer and printed.
DPOF: Digital Print Order Format
Compliant to DPOF Version 1.1
Wi-Fi®
IEEE 802.11b/g/n
DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Approx. 15 m/49.2 ft.
*When communicating with a smartphone
*With no obstructions between the transmitting and receiving antennas and no radio interference
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 channels
Camera Access Point Mode and Infrastructure mode
Authentication method: Open system, Shared key, WPA/WPA2-PSK
Encryption: WEP, TKIP, AES
Images can be viewed, controlled, and received using a smartphone.
Remote control of the camera using a smartphone is possible.
Images can be sent to a smartphone.
Transferring one image, transferring selected images, transferring resized images
Images can be sent to and saved on Connect Station.
Remote control functions and image viewing functions of EOS Utility can be used wirelessly.
Images can be sent to a Wi-Fi® printer.
Images in the camera or links to images can be sent to registered Web services.
NFC
NFC Forum Type 3/4 Tag compliant (dynamic)
Bluetooth®
Bluetooth® Specification Version 4.1 compliant (Bluetooth® low energy technology)
GFSK modulation
GPS Functions
GPS satellites (USA), GLONASS satellites (Russia), Quasi-Zenith Satellite System
(QZSS) MICHIBIKI (Japan)
Mode 1, Mode 2
Latitude, Longitude, Elevation, Coordinated Universal Time (UTC), Satellite signal acquisition status
1 sec., 5 sec., 10 sec., 15 sec., 30 sec., 1 min., 2 min., 5 min.
GPS time data set to camera
One file per day, NMEA format
*Change in time zone creates another file.
*The log data saved in internal memory can be transferred to a card or downloaded to a computer as a log file.
Possible
Customization
28 Custom Functions settable with the camera
- Shutter button (halfway pressing)
- AF-ON button
- AE lock button
- Depth of field preview button
- Lens AF stop button
- SET button
- Main Dial
- Quick Control Dial
- Multi controller
- Up to six items from the menu items and the top-tier items of Custom Functions can be registered to each tab.
- Up to five My Menu tabs can be added.
| My Menu tab overall operations |
| My Menu tab detailed operations |
Interface
Hi-Speed USB (USB 2.0)
- For PC communication
- For Connect Station connection
Type C (Resolution switches automatically)
- Video is not displayed unless the video system is correctly set for the connected TV set, [NTSC] or [PAL].
3.5mm diameter stereo mini jack
- Directional Stereo Microphone DM-E1 or commercially available external microphone connectable.
Power Source
Battery Pack LP-E6N (or LP-E6) x 1
- With the AC Adapter + DC Coupler, AC power drive is possible.
- When the Battery Grip BG-E21 is used, two battery packs (LP-E6N or LP-E6) can be installed.
| Mode | Shooting Method | Battery | Temperature | Possible Shots (Approx.) |
| Camera body only | Viewfinder shooting | LP-E6N | At 73°F/23°C | 1200 |
| At 32°F/0°C | 1100 | |||
| Live View shooting | LP-E6N | At 73°F/23°C | 380 | |
| At 32°F/0°C | 340 | |||
| With Battery Grip BG-E21 |
Viewfinder shooting | LP-E6N x 2 | At 73°F/23°C | 2400 |
| At 32°F/0°C | 2200 | |||
| Live View shooting | LP-E6N x 2 | At 73°F/23°C | 760 | |
| At 32°F/0°C | 680 |
Automatic battery check when the power switch is turned ON. Displayed in 6 levels.
- Battery level can be checked on the LCD panel and in the viewfinder.
- 6 level indicator displayed in use with LP-E6N and LP-E6 and the display for other power sources will differ.
Power automatically turns off after the set time (1, 2, 4, 8 or 15 min.) of non-operation elapses.
Built-in secondary battery
When fully-charged, the date/time can be maintained for approx. 3 months
- Recharge time: approx. 8 hrs.
- To become capable to maintain the right date/time for 3 months after main battery power depletion.
Approx. 0.2 sec. (based on CIPA testing standards)
Dimensions and Weight
Approx. 5.67 x 4.35 x 2.94 in. (144.0 x 110.5 x 74.8mm)
- CIPA compliant.
Approx. 765g / 26.98 oz. (including battery and card)
Approx. 685g / 24.16 oz. (body only)
Operating Environment
32-104°F/0-40°C
85% or less
SDK / API Compatibility
Reviews
Product Disclaimer
* The number of AF points, cross-type AF points and Dual cross-type AF points vary depending on the lens used.
** Compatible with iOS® versions 8.4/9.3/10.2, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** Compatible with Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1.
^ Compatible with select smartphone and tablet devices (Android#8482; version 5.0 or later and the following iOS#174; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.0 or later and the Camera Connect App Ver. 2.0.40. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
^^ In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
^^^ Continuous shooting speed may vary depending on the shutter speed, the aperture, the lens being used, the battery charge and various camera settings.
