EOS C200B
- Standalone camera body
- Canon 8.85 Megapixel Super 35mm CMOS Sensor
- Fully Compatible with New and Existing Canon EF-Mount Lenses
- Dual DiG!C DV 6 Image Processors
- Dual Pixel CMOS AF Technology
- Internal 4K RAW Recording with New Cinema RAW Light
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
The EOS C200B Digital Cinema Camera comes as a standalone camera body, excluding the built-in electronic viewfinder, LCD monitor, handle and handgrip accessories that come with the EOS C200. This allows the user the flexibility to customize the camera with a wide range of accessories to fit their specific needs. The camera's small form factor allows it to be used in tighter spaces, and more easily attached to a gimbal or drone.
The camera can record internal 4K RAW to a CFast™ 2.0 card in our new Cinema RAW Light format without compromising detail, as well as 4K UHD and Full HD in MP4 format to SD cards. The 8.85 Megapixel Super 35mm CMOS sensor, 13 stops of dynamic range, Dual Pixel CMOS AF, full compatibility with Canon EF-mount lenses, and HDR capability help make the EOS C200B ideal for film, documentary and television production, corporate and event videography, and newsgathering. The camera's multitude of features helps deliver outstanding image quality, performance and versatility.
View Full Technical Specs PDF
Image Sensing Device
CMOS Sensor (single-panel) equivalent to Super 35mm
Approx. 9.84 megapixels (4206 x 2340)
Approx. 8.85 megapixels (4096 x 2160):
When 4096 x 2160 or 2048 x 1080 is selected as the resolution
Approx. 8.29 megapixels (3840 x 2160):
When 3840 x 2160 or 1920 x 1080 is selected as the resolution
RGB primary color filter (Bayer array)
Lens Mount
Canon EF mount
Exposure
(1) Manual exposure based on shutter setting, iris setting, ISO/gain setting, and ND filter setting
(2) Push auto iris control, auto iris control (light metering system selection/AE shift possible)
Speed, Angle, Clear Scan, Slow, or Off mode selected
Either 1/3 or 1/4 steps selected as speed increment
(1) Manual setting in 1/2-step increments, 1/3-step increments or fine possible
(2) Push auto IRIS control*
(3) Auto IRIS control*
* Lenses that support auto IRIS:
EF Lenses | Cinema Lenses |
EF-S 10-18mm f/4.5–5.6 IS STM | CN 7x17 KAS S/E1 |
EF-S 18–55mm f/3.5-5.6 IS STM | CN 20x50 IAS H/E1 |
EF-S 18–135mm f/3.5-5.6 IS STM | CN-E 18–80mm T4.4 L IS KAS S |
EF-S 55–250mm f/4-5.6 IS STM | CN-E 70–200mm T4.4 L IS KAS S |
EF-S 18–135mm f/3.5-5.6 IS USM | |
EF 24–105mm f/3.5-5.6 IS STM |
1 step, 1/3 step settings
[100* - 160 - 25600 - 102400*]
*When the sensitivity is expanded
Normal [-6dB* - -2dB - 42dB - 54dB*]
Fine: Setting in 0.5 dB step increments possible
5 density settings (2, 4, 6, 8*, 10* stops)
*When expansion is selected
Motorized drive
Focus Control / Assist
Dual Pixel CMOS AF Supported
Manual Focus, One-Shot AF, Continuous AF, AF-Boosted MF, Face Detection AF (only lenses that support AF functions can be used in any of these modes), Focus Guide
White Balance
AWB, Kelvin setting (setting range: 2000K to 15000K/-20CC to +20CC), Daylight, Tungsten, Set A, Set B)
System Frequency Selection
(1) 59.94 Hz mode (59.94P/29.97P/23.98P)
(2) 50.00 Hz mode (50.00P/25.00P)
(3) 24.00 Hz mode (24.00P)
Canon Log 3: 1600% (ISO 800 or above)
Canon Log/Wide DR: 800% (ISO 400 or above)
Video Formats
Video:
Codec: Cinema RAW Light
Resolution: 4096 x 2160
Bit Depth: 10 bit (59.94P/50.00P), 12 bit (29.97P/23.98P/25.00P/24.00P)
Bit Rate: 1 Gbps
Audio:
Linear PCM: 16-bit / 48 kHz / 4 channels
Video:
Codec: MPEG-4 AVC/H.264
Resolution: 3840x2160 / 1920x1080
Bit Rate: 150 Mbps (3840x2160), 35 Mbps (1920x1080)
Color Sampling: YCC420 8 bit
Audio:
MPEG-4 AAC-LC (16-bit / 48 kHz / 2 channels)
Linear PCM (16-bit / 48 kHz / 4 channels)
Video:
Resolution: 2048 x 1080
Bit Rate: 35 Mbps
Audio:
Recording Media
(1) CFast™ card (1 slot): RAW movies
Only CFast 2.0™; with VPG-130 is supported.
(2) SD card (2 slots): Recording of MP4 movies, photos (JPEG), custom pictures, menus and other data possible
Drop frame* or non-drop frame
Rec run, free run, regeneration
*In 59.94P/29.97P mode only
Slow motion recording, pre-recording, frame recording, interval recording
Relay recording, double slot recording
Custom picture setting, black balance adjustments, color bars, peaking display, zebra display, My Menu setting, fan, waveform monitor display, assignable buttons (1-17), key lock, marker display, enlarged display, custom display, peripheral illumination correction, GPS support (GP-E2), monaural microphone, and other functions
Playback
Playback operations:
Normal playback, fast forward (at speeds of ×5, ×15, ×60), fast reverse (at speeds of ×5, ×15, ×60), frame forward, frame reverse, rec review
Clip Display
3x4 (clip) index screen (RAW/MP4/Photo)
Terminals
Input only:
REMOTE terminal, MIC jack, INPUT terminals (2 sets)
Output only:
SDI terminal, HDMI OUT terminal, headphones jack, USB terminal, VIDEO terminal
Input/Output Control:
Ethernet terminal
Power Supply
14.4 V DC (battery pack), 16.7 V DC (DC-IN)
Image Processing Platform
Dual DIGIC DV 6
Related Accessories
Battery Charger (CG-A10/ CG-A20)
LCD Monitor (LM-V1)
LCD Attachment Unit (LA-V1)
Clamp Base (CL-V2)
Camera Grip (GR-V1)
Handle Unit (HDU-2)
OLED Electronic View Finder (EVF-V70)
Shoulder Support Unit (SU-15)
8-pin Remote Cable (RR-10/RR-100)
Rod Clamp (RD-1)
Compact Power Adapter (CA-CP200B)
Unit Cable (UN-5/UN-10)
Remote Controller (RC-V100)
GPS Receiver (GP-E2)
Shoulder Strap (SS-1200)
Tripod Adapter (TA-100)
Tripod Base (TB-1)
EF lens groups, EF cinema lens groups
Accessories designed for the EF lens group and EF cinema lens group
Weight and Dimensions
Approx. 5.7 x 5.7 x 5.4 in. (144 x 146 x 137mm)
Approx. 6.7 x 8.2 x 5.4 in. (169 x 209 x 137mm) [With mic holder unit attached]
Approx. 2.9 lb. (1335g)
