EOS C400 Body
As low as $8,799.00
In Stock
  • 6K Full-Frame Back-illuminated stacked CMOS sensor supports Full Frame 3:2, Super 35mm, and Super 16 modes
  • Triple-base ISO (800, 3200, 12,800)
  • Meets Netflix capture requirements and has been approved for use on Netflix productions.
  • Internal Cinema RAW Light, XF-AVC recording, and new XF-HEVC S, XF-AVC S formats
  • Adobe Frame.io Camera to Cloud in-camera activation and transmission of proxy files via wireless or wired Ethernet.
  • Built-in Mechanical ND Filters
  • Improved autofocus with Dual Pixel CMOS AF II
  • PL-RF Mount Adapter1 with Cooke/i Technology compatibility
  • Variety of interfaces, including Timecode and Genlock
  • Return video input and Ethernet, Wi-Fi control
  • Compact, lightweight, ergonomic body design
  • The August 2026 firmware update introduces Cinema Exposure Mode and Auto Exposure Ramping Compensation
  • Auto Exposure Ramping Compensation is available in August 2026 firmware update.
Show more
Overview
Innovation, versatility and imaging excellence all merge in the new EOS C400, the full-frame, RF-mount cinema camera tailored for boundless creativity.
The compact camera body is well-appointed and includes Canon's newly-developed 6K full-frame Back-Illuminated Stacked CMOS sensor, which supports a variety of sensor modes, including Full Frame 3:2, Super 35mm, and Super 16mm. The EOS C400 features 6K/60p Cinema RAW Light and 4K/120p internal recording along with Canon’s next-generation Dual Pixel CMOS AF II, among other outstanding features. Additionally, the EOS C400 has a variety of interfaces, including return input, Ethernet, and Wi-Fi, enabling control from various Canon and third-party devices.
The EOS C400 is the ideal fusion of both functionality and form, and seamlessly integrates into almost any production with its robust and compact design.
Features
6K Full-Frame Back-illuminated Stacked CMOS Sensor
The EOS C400 is the first Cinema EOS camera to feature the newly-developed, 6K back-illuminated stacked full-frame CMOS sensor, which offers exceptionally low noise. The sensor delivers faster read-out speeds than previous EOS sensors and when compared to a front-illuminated CMOS sensor, the sensor’s architecture provides improved sensitivity as it increases light capturing efficiency and improves 4K image quality with 6K oversamplingFootnote2.
CMOS Sensor
Full Frame 3:2 “Open Gate” Sensor Mode
By selecting Full Frame 3:2 from the Sensor Mode section of the main menu, you can shoot using the full area of the sensor and then use that information in post to crop and re-frame your footage to the aspect ratio of your choice. This is especially valuable when shooting with full-frame anamorphic lenses.
Sensor Mode Settings Menu
Super 35mmFootnote3 and Super 16 Crop Modes
The EOS C400 camera’s Full-Frame sensor is capable of capturing footage in both 17:9 and 16:9 formats, and supports the use of Super 35mm and Super 16mm lenses with the appropriate sensor crop modes.
Crop Modes Diagram
Anamorphic De-Squeeze
Anamorphic lenses have an elongated rear element that makes it possible to utilize flare and bokeh effects that cannot be achieved with ordinary lenses. The EOS C400 provides desqueeze magnification options, including OFF/2x/1.8x/1.5x/1.3x.
Triple-Base ISO (800, 3200, and 12,800)
Our newly-developed, full-frame 6K back-illuminated stacked sensor offers triple-base ISO, which allows the EOS C400 to deliver stunning imagery in a wide range of lighting conditions. With base ISOs of 800, 3200, and 12,800, you will be able to maximize the full dynamic range of the sensor in brilliantly lit or low-light shooting conditions.
Graph of ISO
Available ISO Range (When Using Canon Log 2 / Log 3, RAW)
Menu from Camera
Gamma Settings Set Value
Canon Log 2, Canon Log 3 or RAW Shooting Auto Selection
Base ISO 800
Base ISO 3200
Base ISO 12800
Canon 709, BT.709 Wide DR, PQ, HLG Auto Selection
Base ISO 400
Base ISO 1600
Base ISO 6400
BT.709 Standard Auto Selection
Base ISO 160
Base ISO 640
Base ISO 2500
Internal Cinema RAW Light, XF-AVC Recording and New XF-HEVC S, XF-AVC S Formats
The EOS C400 can record up to 6K 60P Cinema RAW Light with an additional three Cinema RAW Light recording modes, HQ, ST and LT also with 12-bit recording.
Other recording options include our standard XF-AVC codec which can record in 10-bit 4:2:2 with oversampling from the 6K sensor, creating rich detail and smooth imagery, at frame rates up to 120P, without the need for cropping the image from the sensor. For slow or fast motion recording, the C400 can support up to 4K 120P and 2K 180P.
Additionally, the C400 has two new recording codecs, XF-AVC S and XF-HEVC S. These formats feature an easy-to-manage naming system and folder structure, while recording in the familiar MP4 format and preserving metadata.
Distortion and Chromatic Aberration Correction During RAW Playback
The C400's July 2025 firmware release will support Distortion and Chromatic Aberration correction while playing back Cinema RAW Light clips on camera. This ensures productions can accurately review takes on-set without needing to offload the card to a computer first.
Format Codec Intra-frame / Long GOP Sampling Resolution Max. Bit Rate Slow & Fast Motion Max Frame Rate3
XF-AVC S H.264 / AVC Intra-frame 4:2:2 10-bit 4096 x 2160
3840 x 2160
1200Mbps (59.94P)
1000Mbps (50.00P)
120P
2048 x 1080
1920 x 1080
300Mbps (59.94P)
250Mbps (50.00P)
180P
Long GOP 4:2:2 10-bit 4096 x 2160
3840 x 2160
250Mbps (59.94P / 50.00P)
150Mbps (29.97P / 25.00P / 24.00P / 23.98P)
120P
2048 x 1080
1920 x 1080
50Mbps (59.94P / 50.00P / 29.97P / 25.00P / 24.00P / 23.98P) 180P
4:2:0 8-bit 4096 x 2160
3840 x 2160
150Mbps (59.94P / 50.00P)
100Mbps (29.97P / 25.00P / 24.00P / 23.98P)
120P
2048 x 1080
1920 x 1080
35Mbps (59.94P / 50.00P / 29.97P / 25.00P / 24.00P / 23.98P) 180P
4:2:0 8-bit (Proxy) 2048 x 1080 16Mbps / 9Mbps (59.94P / 50.00P / 29.97P / 25.00P / 24.00P / 23.98P) 60P
XF-HEVC S H.265 / HEVC Long GOP 4:2:2 10-bit 4096 x 2160
3840 x 2160
255Mbps (59.94P / 50.00P)
135Mbps (29.97P / 25.00P / 24.00P / 23.98P)
120P
2048 x 1080
1920 x 1080
4:2:0 10-bit 4096 x 2160
3840 x 2160
120P
2048 x 1080
1920 x 1080
4:2:0 10-bit (Proxy) 2048 x 1080 16Mbps / 9Mbps (59.94P / 50.00P / 29.97P / 25.00P / 24.00P / 23.98P) 60P
Camera-to-Cloud Collaboration
The camera has native compatibility with Frame.io’s Camera-to-Cloud (C2C) technology. This feature enables you to send proxy files immediately after recording internally, directly from the camera, for a faster and more secure path from production to post. The efficient proxy files don’t require additional processing or conversion, and are available to view, share, and edit remotely between teams in different locations.
Camera to Cloud
CFexpress Type B and SD Cards Slots
CFexpress and SD card slots on the EOS C400 allow for simultaneous recording even when shooting RAW. All recording options are recorded to the camera’s CFexpress slot with sub-recording and proxy options available on the SD card slot.
Record Various RAW Types to a CFexpress Card
CFexpress (Type-B)
Cinema RAW Light
  • High Quality: RAW HQ
  • Standard Quality: RAW ST
  • Light Recording: RAW LT
Simultaneous Recording to SD Card Also Possible During 6K RAW Internal Recording
SD USH-II
  • XF-AVC
  • XF-HEVC S (H.265 / HEVC)
  • XF-AVC S (H.264 / AVC)
  • Proxy (XF-AVC / XF-HEVC S / XF-AVC S)
EOS C400 - Card View
The C400’s compact mechanical ND filter assembly is specifically designed for the RF mount's short flange back. Buttons for direct control of ND filters are located on the right-hand side of the camera.
The C400 provides up to ten stops of ND filtration, allowing users to shoot in various lighting conditions. The use of ND filters allows a camera operator to adjust exposure while maintaining the depth of field.
ND Filter Density
Stop Transmittance Optical Density
0 1/1 0.0
2 1/4 0.6
4 1/16 1.2
6 1/64 1.8
8 1/256 2.4
10 1/1024 3.0
Improved Autofocus with Dual Pixel CMOS AF IIFootnote4
The C400 supports the next generation of Canon’s acclaimed Dual Pixel CMOS Autofocus, Dual Pixel CMOS AF II. The back-illuminated stacked sensor provides better light-capturing efficiency, widening the area of the sensor that can be used for AF.  Additionally, you can utilize AF while recording in slow or fast motion at speeds up to 4K 120P.
Person Running through a Field
EOS Intelligent Tracking and Recognition
With outstanding speed, precision, and wide AF range, Dual Pixel CMOS AF II uses the EOS Intelligent Tracking and Recognition (iTR AF X) algorithm, developed with deep learning technology, to enable high-performance subject detection. In addition to human eyes, face, and head, the camera can now detect the body of a person and follow them with high accuracy.​
Person Standing in a City
Tracking AF and Lens Focus Ring
Also added for the EOS C400, is the ability to combine Tracking AF with manual focus control. While Tracking AF is enabled, a user can adjust focus manually by using the lens focus ring. Once manual focus control is completed, the camera will maintain focus and Tracking AF will resume automatically.
Two Girls Coloring
AF Tracks Main Subject
MF Control Begins
Two Girls Coloring
Possible Subjects Shown During MF
MF Control Ends
Two Girls Coloring
AF Tracking Resumes on Selected Subject
Note: Photos and visuals are simulated images.
iTR AF X Animal Detection
iTR AF X Animal Detection detects the eyes, face, or the entire body of certain animals to enable highly accurate focusing and tracking not affected by subject size or face orientation.Footnote5
Mount Adapter PL-RF with Cooke / i Technology Compatibility
The Mount Adapter PL-RF unlocks a broad assortment of PL mount lenses for the EOS C400 cameras. The adapter is compatible with Cooke/i Technology’s metadata protocol which enables real-time output of lens metadata (focus/zoom/iris position, and other data in addition to lens model information). Additionally, the robust adapter features locking plates that attach to the camera with four screws for a secure and stable lens mount.
Mount Adapter PL-RF
Variety of Interfaces, Including Timecode and Genlock
The C400 has a diverse set of interfaces making it a versatile camera for film set and live broadcast productions.
A dedicated 12-pin LENS terminal for broadcast and cine-servo lenses, 12G-SDI (SDI OUT) and 3G-SDI (MON.) for monitor outputs, two mini-XLR audio inputs (INPUT 1 and INPUT 2), DIN connectors for Time Code (TC), Genlock and return video (G-LOCK/SYNC/RET), a full-size HDMI (HDMI OUT), built-in Wi-Fi, Ethernet and REMOTE terminal.
The December 2024 firmware upgrade adds a 1920x1080P output option for monitoring while recording at higher resolutions.
EOS C400 - Back View
EOS C400 - Side View
EOS C400 - Front View
Return Video Input, Ethernet, and Wi-Fi Control
The versatile C400 has specialized functions for live productions including a return video input that notifies operators which camera is currently being broadcast live.
The built-in Ethernet port enables Canon's IP-based remote control XC Protocol. XC Protocol helps to maximize operability and remote control of camera settings. Using the XC Protocol, the camera can be operated by Canon’s RC-IP1000 and RC-IP100 controllers, and XC Protocol-enabled third-party remote control panels (RCP) can remotely shade the camera.
Additionally, Canon’s Remote Control Camera Application (RCCA) can control camera settings as well as multiple cameras. The camera also features SRT protocol, enabling IP streaming of video and audio.
Compact, Lightweight, Ergonomic Body Design
The RF mount’s short flange back allows the EOS C400 body to be small and lightweight making the camera just as comfortable on a drone or a gimbal as it is on your shoulder, a tripod, or any configuration where compact size and light weight are important.
EOS C400 - On a Stand and Extra Screen
New LCD, Handle and Grip Design
The EOS C400 ships with a variety of beneficial accessories including a new LCD touch-screen monitor, camera grip and battery pack.
A new handle assembly with captive screws and Multi-function ShoeFootnote6 has been designed for the EOS C400. The new LCD attachment allows the camera operator to adjust the angle and distance of the LCD monitor to suit almost any shooting style including handheld and shoulder-mounted. The LCD monitor also employs the MC-5U, a USB-C cable connecting to the camera body.
EOS C400 - Screen Moving Example
EOS C400 - Screen Attached
The EOS C400 also has an ergonomic camera grip for operator comfort, with three additional assignable buttons. The grip can be articulated to achieve a range of shooting angles.
EOS C400 - Assignable Buttons 1 and 2
EOS C400 - Assignable Buttons 3
Enhanced Level 2 Display
The Peripheral Border Display, also known as Display Level 2, will be enhanced  to show Sensor Mode and Resolution, Recording Codec selected for each card slot, Custom Picture Gamma and color space, Digital Image Stabilization status, and the tilt and roll degrees of the electronic level.
Demo of Enhance Level 2 Display
Assignable Buttons
The December 2024 firmware update adds an enhancement to our 60 to 24p pulldown feature, designed with Houses of Worship in mind, that maintains exposure when changing frame rates with an assignable button. The EOS C400 update will also include camera/media switching via an assignable button.
Menu From Camera
Auto Clear Scan Mode
The Auto Clear Scan setting available in the camera is an automatic shutter mode setting that can detect the frequency of light sources between 50.0 Hz to 2011.2 Hz to help reduce or virtually eliminate the flickering in some LED walls.
Menu From Camera
Canon Multi-Camera Control App
The EOS C400 is compatible with the Canon Multi-Camera Control App for iPhone or iPad.
This app empowers camera operators to have control over recording start and stop, focus, zoom and iris, ND Filters, ISO, Shutter, White Balance, Custom Picture and more, all while viewing the image from the camera.
Multi-Camera Control App Demo
Additional Features in August 2026 Firmware Update
The August 2026 firmware update introduces Cinema Exposure Mode and Auto Exposure Ramping Compensation.
With Cinema Exposure Mode, the dynamic range will shift up into the highlights at each full-stop above the base ISO. This maximizes at two additional stops, therefore any ISO selection beyond two full stops from base ISO will maintain that 8.3 stops over value. Cinema Exposure Mode is accessible through the new Cinema Exposure Menu page within the camera’s Main Menu.
Auto Exposure Ramping Compensation is a counter-measure for iris ramping utilizing the metadata throughput of the lens to the C400, which then interprets how to compensate for the light-loss by adjusting the ISO or Gain. This feature will be available when using select cine-servo lenses.
View Full Technical Specs PDF
Main Unit Specs
Input/Output Terminals
Power/Other
Videos
Sort By:
Untitle Video
Since their introduction, The EOS C400 and EOS C80 cameras have been extremely popular with working professionals for their image quality and ease of use, and now they're getting an update! Join Sr. Product Marketing Specialist Alan Lewis to learn more about the latest firmware update for these cameras, which will be available for download in late-July.
Untitle Video
Cinematographer Jordan Pulmano talks about his experience using the EOS C400 on a three-spot broadcast campaign for the Ontario International Airport. The entire campaign was captured on the Canon EOS C400 with Canon Flex Zoom CN-E20-50mm T2.4 L F and CN-E45-135mm T2.4 L F.
Untitle Video
Go behind the scenes with Kody and Kyler McCormick of The Outbound Life as they share their experience in creating Mike Posner's music video for his song "Is It Just Me". Using the EOS C400, EOS C80, EOS R5 Mark II and various RF lenses they were able to bring this fun and playful vision to life!
Untitle Video
Learn more about the free firmware updates for our Cinema EOS cameras and XF605 camcorder. The firmware also includes an update to the Canon Multi-camera Control app, which will allow you to control up to four compatible cameras from a single iPad.
On Set with Rubidium Wu and the Canon EOS C300 Mark III
Untitle Video
Whodunit? Could it be the EOS C400 cinema camera? ​ “Scary Good,” a thrilling film project captured on the EOS C400 in collaboration with acclaimed cinematographer and Canon Explorer of Light Christine Ng. Discover how the EOS C400 empowers cinematographers to bring their stories to life with a versatile, all-in-one design. ​
Untitle Video
Take a look behind the curtain of “Scary Good” with acclaimed cinematographer, director, and Canon Explorer of Light Christine Ng. ​ From the powerful 6K full-frame back-illuminated stacked CMOS sensor, to breathtaking footage at a high frame rate 4K 120P, to mastering diverse shooting conditions with triple base ISO–see how Christine Ng uses the Canon EOS C400 to build a world of suspense and mystery. ​ “The Canon EOS C400 is going to perform really really well in every situation it's put under. As a DP I work in so many different genres, and now I have one tool that works across all of them.” - Christine Ng​. Video created by Canon Co-Lab Ambassador Ben Hagarty.
Case Study: Rubidium Wu, Filmmaker (Canon Cinema EOS Cameras and Cinema Lenses)
Untitle Video
You’ve never seen a Cinema EOS camera like this before! The new EOS C400 camera is well-appointed and includes Canon's newly-developed 6K full frame Back-Illuminated Stacked CMOS sensor. The EOS C400 features 6K/60p Cinema RAW Light and 4K/120p internal recording along with Canon’s next-generation Dual Pixel CMOS AF II, among other outstanding features. Additionally, the EOS C400 has a variety of interfaces, including return input, Ethernet, and Wi-Fi, enabling control from various Canon and third-party devices. The EOS C400 is the ideal fusion of both functionality and form, and seamlessly integrates into almost any production with its robust and compact design.
EOS C400 Body Compatible Products
Adapters, Chargers & Couplers Stations
Product Disclaimer
  1. Sold separately.
  2. When recording in XF-AVC, XF-HEVC S and XF-AVC S in full-frame sensor mode at a frame rate of 60p or lower.
  3. When frame rate exceeds 100P in Super 35mm mode, the angle of view is cropped at approximately 6%.
  4. Some lenses may not be compatible. When the AF frame is outside of the entire screen area, or when focus guide is displayed or the subject cannot be detected, focusing area is approximately 90% horizontal and 100% vertical.
  5. Animal detection may not be possible with some animals. Subjects that are not dogs or cats may be detected as animals in some cases.
  6. Handle assembly only for use with the C400.
