EOS C400 Body
- 6K Full-Frame Back-illuminated stacked CMOS sensor supports Super 35mm and Super 16 modes
- Triple-base ISO (800, 3200, 12,800)
- Meets Netflix capture requirements and has been approved for use on Netflix productions.
- Internal Cinema RAW Light, XF-AVC recording, and new XF-HEVC S, XF-AVC S formats
- Adobe Frame.io Camera to Cloud in-camera activation and transmission of proxy files via wireless or wired Ethernet.
- Built-in Mechanical ND Filters
- Improved autofocus with Dual Pixel CMOS AF II
- PL-RF Mount Adapter1 with Cooke/i Technology compatibility
- Variety of interfaces, including Timecode and Genlock
- Return video input and Ethernet, Wi-Fi control
- Compact, lightweight, ergonomic body design
- July 2025 firmware update adds: Display Level 2 enhancements; distortion and chromatic aberration correction during RAW playback; selecting subjects during Tracking Autofocus by using the lens focus ring; and other new features.
In the box
Overview
Innovation, versatility and imaging excellence all merge in the new EOS C400, the full-frame, RF-mount cinema camera tailored for boundless creativity.
The compact camera body is well-appointed and includes Canon's newly-developed 6K full-frame Back-Illuminated Stacked CMOS sensor. The EOS C400 features 6K/60p Cinema RAW Light and 4K/120p internal recording along with Canon’s next-generation Dual Pixel CMOS AF II, among other outstanding features. Additionally, the EOS C400 has a variety of interfaces, including return input, Ethernet, and Wi-Fi, enabling control from various Canon and third-party devices.
The EOS C400 is the ideal fusion of both functionality and form, and seamlessly integrates into almost any production with its robust and compact design.
Features
6K Full-Frame Back-illuminated Stacked CMOS Sensor
The EOS C400 is the first Cinema EOS camera to feature the newly-developed, 6K back-illuminated stacked full-frame CMOS sensor, which offers exceptionally low noise. The sensor delivers faster read-out speeds than previous EOS sensors and when compared to a front-illuminated CMOS sensor, the sensor’s architecture provides improved sensitivity as it increases light capturing efficiency and improves 4K image quality with 6K oversampling2.
Super 35mm3 and Super 16 Crop Modes
The EOS C400 camera’s Full-Frame sensor is capable of capturing footage in both 17:9 and 16:9 formats, and supports the use of Super 35mm and Super 16mm lenses with the appropriate sensor crop modes.
Anamorphic De-Squeeze
The December 2024 firmware update adds a 1.5x anamorphic de-squeeze display assist option, which will make it easier to see how your image will translate when shooting with anamorphic lenses.
Triple-Base ISO (800, 3200, and 12,800)
Our newly-developed, full-frame 6K back-illuminated stacked sensor offers triple-base ISO, which allows the EOS C400 to deliver stunning imagery in a wide range of lighting conditions. With base ISOs of 800, 3200, and 12,800, you will be able to maximize the full dynamic range of the sensor in brilliantly lit or low-light shooting conditions.
Available ISO Range (When Using Canon Log 2 / Log 3, RAW)
Internal Cinema RAW Light, XF-AVC Recording and New XF-HEVC S, XF-AVC S Formats
The EOS C400 can record up to 6K 60P Cinema RAW Light with an additional three Cinema RAW Light recording modes, HQ, ST and LT also with 12-bit recording.
Other recording options include our standard XF-AVC codec which can record in 10-bit 4:2:2 with oversampling from the 6K sensor, creating rich detail and smooth imagery, at frame rates up to 120P, without the need for cropping the image from the sensor. For slow or fast motion recording, the C400 can support up to 4K 120P and 2K 180P.
Additionally, the C400 has two new recording codecs, XF-AVC S and XF-HEVC S. These formats feature an easy-to-manage naming system and folder structure, while recording in the familiar MP4 format and preserving metadata.
Distortion and Chromatic Aberration Correction During RAW Playback
The C400's July 2025 firmware release will support Distortion and Chromatic Aberration correction while playing back Cinema RAW Light clips on camera. This ensures productions can accurately review takes on-set without needing to offload the card to a computer first.
Camera-to-Cloud Collaboration
The camera has native compatibility with Frame.io’s Camera-to-Cloud (C2C) technology. This feature enables you to send proxy files immediately after recording internally, directly from the camera, for a faster and more secure path from production to post. The efficient proxy files don’t require additional processing or conversion, and are available to view, share, and edit remotely between teams in different locations.
CFexpress Type B and SD Cards Slots
CFexpress and SD card slots on the EOS C400 allow for simultaneous recording even when shooting RAW. All recording options are recorded to the camera’s CFexpress slot with sub-recording and proxy options available on the SD card slot.
Record Various RAW Types to a CFexpress Card
CFexpress (Type-B) |
Cinema RAW Light
Simultaneous Recording to SD Card Also Possible During 6K RAW Internal Recording
SD USH-II |
The C400’s compact mechanical ND filter assembly is specifically designed for the RF mount's short flange back. Buttons for direct control of ND filters are located on the right-hand side of the camera.
The C400 provides up to ten stops of ND filtration, allowing users to shoot in various lighting conditions. The use of ND filters allows a camera operator to adjust exposure while maintaining the depth of field.
Improved Autofocus with Dual Pixel CMOS AF II4
The C400 supports the next generation of Canon’s acclaimed Dual Pixel CMOS Autofocus, Dual Pixel CMOS AF II. The back-illuminated stacked sensor provides better light-capturing efficiency, widening the area of the sensor that can be used for AF. Additionally, you can utilize AF while recording in slow or fast motion at speeds up to 4K 120P.
EOS Intelligent Tracking and Recognition
With outstanding speed, precision, and wide AF range, Dual Pixel CMOS AF II uses the EOS Intelligent Tracking and Recognition (iTR AF X) algorithm, developed with deep learning technology, to enable high-performance subject detection. In addition to human eyes, face, and head, the camera can now detect the body of a person and follow them with high accuracy.
Tracking AF and Lens Focus Ring
Also added for the EOS C400, is the ability to combine Tracking AF with manual focus control. While Tracking AF is enabled, a user can adjust focus manually by using the lens focus ring. Once manual focus control is completed, the camera will maintain focus and Tracking AF will resume automatically.
AF Tracks Main Subject
MF Control Begins
Possible Subjects Shown During MF
MF Control Ends
AF Tracking Resumes on Selected Subject
Note: Photos and visuals are simulated images.
iTR AF X Animal Detection
iTR AF X Animal Detection detects the eyes, face, or the entire body of certain animals to enable highly accurate focusing and tracking not affected by subject size or face orientation.5
Mount Adapter PL-RF with Cooke / i Technology Compatibility
The Mount Adapter PL-RF unlocks a broad assortment of PL mount lenses for the EOS C400 cameras. The adapter is compatible with Cooke/i Technology’s metadata protocol which enables real-time output of lens metadata (focus/zoom/iris position, and other data in addition to lens model information). Additionally, the robust adapter features locking plates that attach to the camera with four screws for a secure and stable lens mount.
Variety of Interfaces, Including Timecode and Genlock
The C400 has a diverse set of interfaces making it a versatile camera for film set and live broadcast productions.
A dedicated 12-pin LENS terminal for broadcast and cine-servo lenses, 12G-SDI (SDI OUT) and 3G-SDI (MON.) for monitor outputs, two mini-XLR audio inputs (INPUT 1 and INPUT 2), DIN connectors for Time Code (TC), Genlock and return video (G-LOCK/SYNC/RET), a full-size HDMI (HDMI OUT), built-in Wi-Fi, Ethernet and REMOTE terminal.
The December 2024 firmware upgrade adds a 1920x1080P output option for monitoring while recording at higher resolutions.
Return Video Input, Ethernet, and Wi-Fi Control
The versatile C400 has specialized functions for live productions including a return video input that notifies operators which camera is currently being broadcast live.
The built-in Ethernet port enables Canon's IP-based remote control XC Protocol. XC Protocol helps to maximize operability and remote control of camera settings. Using the XC Protocol, the camera can be operated by Canon’s RC-IP1000 and RC-IP100 controllers, and XC Protocol-enabled third-party remote control panels (RCP) can remotely shade the camera.
Additionally, Canon’s Remote Control Camera Application (RCCA) can control camera settings as well as multiple cameras. The camera also features SRT protocol, enabling IP streaming of video and audio.
Compact, Lightweight, Ergonomic Body Design
The RF mount’s short flange back allows the EOS C400 body to be small and lightweight making the camera just as comfortable on a drone or a gimbal as it is on your shoulder, a tripod, or any configuration where compact size and light weight are important.
New LCD, Handle and Grip Design
The EOS C400 ships with a variety of beneficial accessories including a new LCD touch-screen monitor, camera grip and battery pack.
A new handle assembly with captive screws and Multi-function Shoe6 has been designed for the EOS C400. The new LCD attachment allows the camera operator to adjust the angle and distance of the LCD monitor to suit almost any shooting style including handheld and shoulder-mounted. The LCD monitor also employs the MC-5U, a USB-C cable connecting to the camera body.
The EOS C400 also has an ergonomic camera grip for operator comfort, with three additional assignable buttons. The grip can be articulated to achieve a range of shooting angles.
Enhanced Level 2 Display
The Peripheral Border Display, also known as Display Level 2, will be enhanced to show Sensor Mode and Resolution, Recording Codec selected for each card slot, Custom Picture Gamma and color space, Digital Image Stabilization status, and the tilt and roll degrees of the electronic level.
Assignable Buttons
The December 2024 firmware update adds an enhancement to our 60 to 24p pulldown feature, designed with Houses of Worship in mind, that maintains exposure when changing frame rates with an assignable button. The EOS C400 update will also include camera/media switching via an assignable button.
Auto Clear Scan Mode
The Auto Clear Scan setting available in the camera is an automatic shutter mode setting that can detect the frequency of light sources between 50.0 Hz to 2011.2 Hz to help reduce or virtually eliminate the flickering in some LED walls.
Additional Features in July 2025 Firmware Update
Other additons to the July 2025 firmware update also include: the C400 is now able to output CV Protocol to multiple devices for virtual productions. Lens metadata can be utilized by compatible computers running our CV Metadata Extraction plugin, greatly enhancing usability in virtual set environments.
The number of look/lut files that can be registered has increased from 20 to 256 for the C400, along with the capability to pause Digital IS during recording.
Canon Multi-Camera Control App
The EOS C400 is compatible with the Canon Multi-Camera Control App for iPhone or iPad.
This app empowers camera operators to have control over recording start and stop, focus, zoom and iris, ND Filters, ISO, Shutter, White Balance, Custom Picture and more, all while viewing the image from the camera.
View Full Technical Specs PDF
Main Unit Specs
Input/Output Terminals
Power/Other
Videos
EOS C400 Body Compatible Products
Product Disclaimer
- Sold separately.
- When recording in XF-AVC, XF-HEVC S and XF-AVC S in full-frame sensor mode at a frame rate of 60p or lower.
- When frame rate exceeds 100P in Super 35mm mode, the angle of view is cropped at approximately 6%.
- Some lenses may not be compatible. When the AF frame is outside of the entire screen area, or when focus guide is displayed or the subject cannot be detected, focusing area is approximately 90% horizontal and 100% vertical.
- Animal detection may not be possible with some animals. Subjects that are not dogs or cats may be detected as animals in some cases.
- Handle assembly only for use with the C400.
