EOS C500 Mark II
- 5.9K Full Frame CMOS Sensor, with support for Super 35mm and Super 16mm crop modes
- User Changeable Lens Mounts which gives users freedom to use the lenses they desire
- Newly developed DIGIC DV 7 Image Processor, which powerfully processes high-resolution image data
- Canon Cinema RAW Light and XF-AVC Recording
- Proxy Recording
- Compatibility with EF and PL Lenses*
- Anamorphic Lens Support
- Electronic Image Stabilization
- Modular Design with four available Expansion Units allows a high level of connectivity and interoperability
- 4.3” LCD Touch screen Monitor LM-V2
- Dual Pixel CMOS AF with support for Touch AF and Face Detection AF
- Canon Log 2 and 3 Support
- 4 Channel Audio Recording
- Support for Custom User LUTs
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
In the box
- Canon EOS C500 Mark II 5.9K Full-Frame Camera Body (EF Mount)
- Canon GR-V1 Camera Grip
- Canon LM-V2 4.3" LCD Monitor
- Canon LA-V2 LCD Attachment Unit
- Handle Unit
- SS-1200 Shoulder Strap
- Battery Charger CG-A20
- CA-CP200 B Compact Power Adapter for Battery Charger
- AC Power Cable US for Battery Charger
- Canon BP-A60 Battery Pack For EOS C300 Mark II, C200, and C200B
- Canon UN-5 Unit Cable
- 1/4" Hex Wrench
- M3 Hex Wrench
- M4 Hex Wrench
- 1/4" Hex Socket Head Bolt
- M3 Hex Socket Head Bolt
- Bolt Stopper
- Microphone Holder Unit
- M4 Screw for Microphone Holder Unit
- Limited 1-Year Warranty
Overview
Impressive usability and imaging power combine in the EOS C500 Mark II, the customizable full frame cinema camera that’s built for creative freedom.
The lightweight body comes equipped with Canon's 5.9K full-frame CMOS sensor capable of over 15 stops of dynamic range. The newly developed DIGIC DV 7 Image Processor expands functionality and flexibility by enabling features such as 5.9K recording, internal recording of Canon Cinema Raw Light and Dual Pixel Autofocus.
The Cinema EOS C500 Mark II is the perfect expression of form and function, exceptionally adaptable to virtually any production with its modular design. Four expansion units and user changeable lens mounts enable operators to build their ideal cinema system. A firmware update provides even more versatility, with DPAF in slow and fast recording modes, as well as expanded card compatibility to now support VPG400-certified CFexpress 2.0 Type B cards.
Image Sensing Device
Full-frame / Super 35mm (crop) / Super 16mm (crop)(6062 x 3432):
CMOS Sensor with DAF Technology:
In the 59.94 Hz mode: 66 dB (Typical)
[Full size/3840x2160/29.97P. Canon Log2 Base Sensitivity ISO 800 (Dynamic Range 1600%)]
In the 50.00 Hz mode: 66 dB (Typical)
[Full size/3840x2160/25.00P. Canon Log2 Base Sensitivity ISO 800 (Dynamic Range 1600%)]
Canon Log 2: 1600% / 15+ stops (at ISO 800)
Canon Log 3: 1600% / 14 stops (at ISO 800) 02
59.94 Hz f/10 (2048x1080/59.94P) or f/14 (1920x1080/29.97P)
50.00 Hz f/11 (2048x1080/50.00P) or f/16 (1920x1080/25.00P) 01
All values for ISO 800, 2000 lux, and reflections rate or 89.9%
*Some lens specification may not enable these f-numbers
Approx. 20.8 Megapixels (6062 x 3432)
Approx. 18.69 Megapixels (5952 x 3140):
When 5952 x 3140, 4096 x 2160 or 2048 x 1080 is selected
Approx. 17.52 Megapixels (5580 x 3140):
When 3840 x 2160 or 1920 x 1080 is selected as the resolution :
Lens Mount
Canon EF mount with support for EF and EF-S lenses
Optional Interchangeable Mounts: PL and EF-C Locking
Exposure
(1) Manual exposure based on shutter setting, iris setting, ISO/gain setting and ND filter setting
(2) Push auto iris control, auto iris control
(Light metering system selection, shift possible)
Speed, Angle, Clear Scan, Slow, or Off mode selected
Either 1/3 or 1/4 steps selected as speed increment
Can be set to 1/2-stop, 1/3-stop or Fine
(1) Push auto iris control
(2) Auto iris control
Lenses that support Auto Iris:
EF Lenses | ||
EF-S 10-18mm f/4.5-5.6 IS STM | EF 24-105mm f/3.5-5.6 IS STM | EF 70-300mm f/4-5.6 IS II USM |
EF-S 18-55mm f/3.5-5.6 IS STM | EF-S 18-135mm f/3.5-5.6 IS USM | EF-S 35mm f/2.8 Macro IS STM |
EF-S 18-135mm f/3.5-5.6 IS STM | EF-S 18-55mm f/4-5.6 IS STM | EF 85mm f/1.4L IS USM |
EF-S 55-250mm f/4-5.6 IS STM | ||
COMPACT SERVO Lenses | ||
CN-E 18-80mm T4.4 L IS KAS S | ||
CN-E 70-200mm T4.4L IS KAS S | ||
CINE-SERVO Lenses | ||
CN7×17 KAS S/E1 | CN20×50 IAS H/E1 | |
CN7×17 KAS S/P1 | CN20×50 IAS H/P1 | |
ENG Broadcast Lenses 2/3" mount lenses which allow for 12-pin communication using B4 mount |
HJ14ex4.3B IASES | HJ18ex7.6B IASES | HJ24ex7.5B IASES |
HJ17ex7.6B IASE S | HJ22ex7.6B IASE S | CJ45ex9.7B IASE-V H |
CJ45ex13.6B IASE-V H | CJ24ex7.5B IASE S | CJ14ex4.3B IASE S |
CJ18ex7.6B IASE S |
1 step, 1/3 step settings
[*100 - 160 - 25600 - 102400*]
*When the sensitivity is expanded
ISO Speed Displays: Users can select from the following 2 display formats:
1-stop display | [100, 200, 400] 800, 1600, 3200, 6400, 12800, 25600, [51200, 102400] [---] Displayed when ISO extended range is ON. |
1/3 stop display | [100, 125, 160, 200, 250, 320, 400, 500, 640] 800, 1000, 1250, 1600, 2000, 2500, 3200, 4000, 5000, 6400, 8000, 10000, 12800, 16000, 20000, 25600, [32000, 40000, 51200, 64000, 80000, 102400] [---] Displayed when ISO extended range is ON. |
Gain (dB) Displays
Normal | [-6 dB, -3 dB, 0 dB, 3 dB, 6 dB, 9 dB] 12 dB, 15 dB, 18 dB, 21 dB, 24 dB, 27 dB, 30 dB, 33 dB, 36 dB, 39 dB, 42 dB, [45 dB, 48 dB, 51 dB, 54 dB] [---] Displayed when Gain extended range is ON. |
Fine | When the extended range is OFF: Can be set from 12 dB to 42 dB in 0.5 dB increments When the extended range is ON: Can be set from -2 dB to 54 dB in 0.5 dB increments |
The minimum sensitivity need to obtain the recommended dynamic range depends on the gamma curve. | ||
BT.709 Normal |
BT.709 Wide DR/HLG |
Canon Log 2 / Canon Log 3 / PQ |
ISO 160 (Gain -2 dB) and more |
ISO 400 (Gain 6 dB) and more |
ISO 800 (Gain 12 dB) and more |
Internal ND filters with 5 density settings (2, 4, 6, 8*, 10* stops)
*When expansion is selected
Focus Control / Assist
Dual Pixel CMOS AF (DAF), Manual Focus,
One-Shot AF, Continuous AF, AF- Boosted MF, Face Detection AF*
* Only lenses that support AF functions can be used in these modes
Available; displays focus status or unfocused status using the AF signal.
LCD Monitor
LM-V2 LCD Monitor
White Balance
AWB, Kelvin setting (setting range: 2000K-15000K), Daylight, Tungsten, Set (A/B)
System Frequency Selection
59.94 Hz mode: 59.94i/59.94P/29.97P/23.98P
50.00 Hz mode: 50.00i/50.00P/25.00P
24.00 Hz mode: 24.00P
If recording Is performed at a frame rate which is below the frame rate of the recording format, so-called "undercranking" shooting results, and a fast motion effect will be obtained. Conversely, if recording is performed at a frame rate which exceeds the frame rate of the recording format, so-called "overcranking" shooting results, and a slow motion effect will be obtained.
During Slow and Fast Motion Recording external timecode input is not permitted and Timecode output is disabled. If Timecode "Free Run" was specified before S&F is selected, the setting switches to "RecRun." No sound is recorded.
Resolution | Sensor Mode/Available Frame Rates | |
XF-AVC | 4096x2160/3840x2160 (810/410 Mbps) |
[Full Frame / Super 35 mm (Cropped)] 59.94P / 29.97P / 50.00P / 25.00P : 15 - 60 24.00P / 23.98P : 12 - 60 |
2048x1080/1920x1080 (310/160 Mbps) |
[Full Frame / Super 35 mm (Cropped)] 59.94P / 29.97P / 50.00P / 25.00P : 15 - 60 24.00P / 23.98P : 12 - 60 [Super 16 mm (Cropped)] 59.94P / 29.97P / 50.00P / 25.00P : 15 - 120 24.00P / 23.98P : 12 - 120 |
2048x1080 (35/24 Mbps) |
RAW | 5952x3140/4096x2160 | 59.94P / 29.97P / 50.00P / 25.00P : 15 - 60 24.00P / 23.98P : 12 - 60 |
2048x1080 | 59.94P / 29.97P / 50.00P / 25.00P : 15 - 120 24.00P / 23.98P : 12 - 120 |
Setting Frame Specifics are shown below:
59.94P: (15, 30, 44, 48, 52, 56, 60, 90, 120)
29.97P (15, 22, 24, 26, 28, 30, 32, 36, 40, 44, 48, 52, 56, 60, 90, 120)
23.98P/24.00P: (12, 16, 18, 20, 22, 24, 26, 28, 30, 32, 36, 40, 44, 48, 52, 56, 60, 72, 96, 120)
50.00P: (15, 25, 34, 38, 42, 46, 50, 54, 58, 60, 75, 100, 120)
25.00P: (15, 17, 19, 21, 23, 25, 26, 28, 30, 34, 38, 42, 46, 50, 54, 58, 60, 75, 100, 120)
Recording Media
Recording of movies (Cinema Raw Light/XF-AVC), custom pictures, metadata
CFexpress™ Card Recording Time |
Cinema RAW Light |
Intra-frame |
2.1 Gbps |
1Gbps |
250 Mbps |
810 Mbps |
410 Mbps |
310 Mbps |
160 Mbps |
512 GB |
30 minutes |
64 minutes |
256 minutes |
79 minutes |
156 minutes |
207 minutes |
401 minutes |
Media | Capacity (GB) |
SanDisk Extreme Pro | 512 |
Sony TOUGH | 512 |
ProGrade Digital COBALT | 650 |
Recording of movies (XF-AVC (proxy)), photos (JPEG), custom pictures, metadata, menus and other data
Compression Formats
(1) XF-AVC/ MPEG-4 AVC/H.264
(2) RAW: Cinema RAW Light
XF-AVC(CFexpress™ cards)
4096 x 2160 / YCC422 10 bit
3840 x 2160 / YCC422 10 bit
2048 x 1080 / YCC422 10 bit
1920 x 1080 / YCC422 10 bit
810/410/310/160 Mbps Intra-frame
XF-AVC Proxy (SD card)
2048 x 1080 / YCC420 8 bit
35/24 Mbps Long GOP
Cinema Raw Light (CFexpress™ cards)
12/10 bit
5952 x 3140
4096 x 2160 (cropped)
2048 x 1080 (cropped)
Operation
Drop frame* or non-drop frame
*Only in the 59.94 Hz mode
Rec Run, Free Run, Regeneration
Canon Log 3, Canon Log 2, Wide DR, Normal 1, HDR-PQ, HDR-HLG
Cinema Gamut, BT.2020 Gamut, DCI-P3 Gamut, BT.709 Gamut
BT.709, BT.2020, DCI, ACESproxy, HDR-PQ, HDR-HLG, HDR1600%, HDR400%, and 4 user uploadable
Other Features
Slow & Fast motion recording, pre-recording, relay recording, double slot recording, custom picture settings, color bar, peaking display, zebra display, My Menu settings, waveform monitor display, assignable buttons, key lock, marker display, enlarged display, custom display, control via browser remote, peripheral illumination correction, diffraction correction, built-in monaural microphone, fan control, geotagging and other functions
Playback
Normal playback, fast forward (at speeds of 5x), fast reverse (at speeds of 5x), frame forward, frame reverse, forward skip, reverse skip, rec review
3 x 4 (clip) index display (RAW, XF-AVC, XF-AVC proxy, photo index)
Clip metadata display, custom picture data display
Clip deletion
Terminal
MIC jack, INPUT terminal (1/2)*, REMOTE terminal (A)
* Digital input (AES/EBU standards) supported
HDMI, headphone jack, MON. terminal, SDI OUT terminal*, VIDEO terminal
* 12G-SDI supported
TIME CODE (in/out), Expansion System terminal, USB (for GPS units)
* For the EVF-V50, EU-V1 or EU-V2 Expansion Units
Power
DC IN 12V jack (DC 11.5V-20V), Battery terminal (DC 14.4V), DC 12-20V*
* When using a V-mount battery with the EU-V2 Expansion Unit
Maximum recording times with battery/power consumption. All values given are approximations only. CFexpress™ card single recording, using the LCD monitor LM-V2, MON. and SDI OUT terminals, and using EF50mm f/1.8 lens | |||||
Video Format |
Sensor Mode/ Resolution |
Bit Rate: Frame Rate |
Power Consumption Approx. (W) |
BP-A30 (3100 mAh) |
BP-A60 (6200 mAh) |
Continuous Recording Minutes |
RAW | Full size/ 5952 x 3140 |
2.1 GB: 59.94P/50.00P |
34.0 |
50 |
115 |
Super 16mm/ 2048 x 1080 |
250Mbps: 59.94P/50.00P |
28.0 |
60 |
150 |
XF-AVC | Full size/ 4096 x 2160 |
810Mbps: 59.94P/50.00P |
33.4 |
50 |
125 |
310 Mbps: 59.94P/50.00P |
28.0 |
60 |
150 |
Image Processing Platform
Related Accessories
Battery Pack BP-A30/BP-A60 (provided with camera)
Battery Charger CG-A10/CG-A20 (provided with camera)
Remote Controller RC-V100
Compact Power Adapter CA-CP200B (provided with camera)
Shoulder Strap SS-1200 (provided with camera)
Tripod base TB-1
Wireless Transmitter
GPS Receiver GP-E2
Unit Cable UN-5 (provided with camera)/UN-10 (sold separately)
Canon OLED Electronic View Finder EVF-V50/EVF-V70
Extension unit 1: EU-V1
Extension unit 2: EU-V2
EF Cinema Lock Mount Kit CM-V1
PL Mount Kit PM-V1
B4 Mount Adapter MO-4E/MO-4P
LCD Monitor LM-V2 (included)/LM-V1
LCD Attachment Unit LA-V2 (included)/LA-V1
Camera Grip GR-V1 (included)
Shoulder Support Unit SU-15
Shoulder Style Grip Unit SG-1
Clamp Base CL-V2
Rod Clamp RD-1
Handle Unit HDU-2
8-pin Remote Cable RR-10/RR-100
Canon EF/EF cinema lens group, Canon PL cinema lens group and accessories designed for these lenses
IP Streaming
Streams video to decoder transmission device or computer over the network
MPEG-4 AVC/H.264 8 bit
9 Mbps/4 Mbps (1920 x 1080)
59.94p/59.94i/50.00p/50.00i
MPEG-2 ACC-LC 2ch
256 Kbps
Wi-Fi® ,Ethernet
(1) UDP: Prioritizes transfer speed. Lost or lagging packets ignored.
(2) RTP: Standard system for sending videos and audio online. Lost or lagging packets ignored.
(3) RTP+FEC: Error correction (FEC) control during RTP transfer enables recovery of lost or corrupt packets on the receiving side.
(4) RTSP+RTP: Real-time data streaming control via RTSP (Real Time Streaming Protocol) and transfer via RTP. The receiving side can start or stop streaming.
Wi-Fi® Specifications
Follows the specifications of WFT
(1) WPS [Wi-Fi® Protected Setup] (push-button system, PIN code system)
(2) Manual Setup
(3) Search for Access Points
Open system, WPA-PSK, WPA2-PSK
WEP-64, WEP-128, TKIP, AES
Auto (automatic switching between DHCP and AutoIP), Manual
Weight and Dimensions (body only)
Approx. 6.0 x 5.8 x 6.6 in. (153 x 148 x 168mm)
Approx. 3.8 lb. (1750g)
