EOS C70 RF24–105MM F4 L IS USM LENS KIT
C7024105
As low as $5,599.00 Regular Price $5,999.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
Estimated ship date
$400 Instant Savings
  • Canon Super 35mm Dual Gain Output (DGO) Sensor, 16+ stops of Total Dynamic Range
  • DIG!C DV7 Image Processor
  • Canon Log 2 and 3, PQ, and HLG Recording
  • RF Mount
  • EF Lens Compatibility with Mount Adapter EF-EOS R 0.71x
  • Direct Touch Control
  • Meets Netflix capture requirements and has been approved for use on Netflix productions.
  • Compatibility with the RF17-120 CINE-SERVO lens, the new RF70-200 F2.8 L IS USM Z zoom lens and the RF24mm F1.4 L VCM and RF50mm F1.4 L VCM hybrid lenses; displays digital tele-converter icon when activated.
Show more
Return Policy
eos c70 logo
Canon EOS C70: Professional Cinema and Compact Design
PROFESSIONAL CINEMA. COMPACT DESIGN.
The Canon EOS C70 offers exceptional cinema capabilities in a compact package. Enjoy stunning images with a 4K Super 35mm DGO Sensor and all the built-in features you could ask for, including ND Filters, mini XLRs, direct touch rotatable LCD screen, Dual Pixel CMOS Autofocus, and excellent battery life. Making the EOS C70 even more powerful is compatibility with Canon's expanding line of high-performance RF Lenses.
EOS R5 C with RF27-70mm lens
IMPRESSIVE IMAGE QUALITY
Get smooth blacks and bold colors. The EOS C70’s Super 35mm DGO Sensor generates 16+ stops of total dynamic range and maintains low noise levels in order to prioritize saturation for bright areas and lower noise for darker areas.
stage with musicians
MORE BUILT-INS, LESS ADD-ONS, MAX VALUE
Start shooting from day one with all the built-ins you could ask for including ND filters for various lighting conditions, mini XLRs for professional audio recording, and dual SD card slots for simultaneous recording in different formats. Access it all with one hand on the direct touch rotatable LCD screen, allowing for on-the-spot changes while holding the camera.
crop view of C70 side buttons
SERIOUS CINEMA IN A SMALL PACKAGE
Control your dynamic range by choosing between Canon Log 2 or Canon Log 3 Gamma, and capture frame rates up to 120 fps in 4K or up to 180 fps in 2K CROP mode–all with electronic image stabilization. Enhance the EOS C70 further by synchronizing multi-camera productions via the built-in timecode port and adding Cinema RAW Light internal recording, Canon 709 Custom Picture Profile, XF-AVC Intra 4K 60p recording, and other new features via a free firmware upgrade.
top view of C70 on a tripod
BUILT TO BE TAKEN ANYWHERE
Designed to go where you go, the EOS C70's unibody design exhibits a compact form factor and a built-in ergonomic grip that makes handheld shooting easy and comfortable.
C70 with handle in front of black background
CANON’S RF SYSTEM & LEGENDARY LENSES
The EOS C70 is a cinema powerhouse all on its own and is engineered with a built-in RF mount for compatibility with Canon’s expanding line of high-performance RF Lenses.
For increased flexibility, the EOS C70 is also compatible with Canon’s line of award-winning EF lenses using the Mount Adapter EF-EOS R 0.71x. This maintains a similar full-frame angle of view on the Super 35mm sensor, but boosts the speed of the attached lens by an average of 1-stop.
crop of RF-EF mount adapter and EF 11-24mm lens on a C70
FEATURES
The EOS C70 features Canon's next generation Super 35mm Dual Gain Output (DGO) Sensor. This sensor is capable of a total dynamic range in excess of 16 stops and includes Canon’s exclusive Dual Pixel CMOS Autofocus technology.
wildlife
The DGO Sensor is an imaging system that generates high dynamic range and maintains low noise levels by reading out each photodiode with two different gains. It combines the two with a saturation prioritizing gain for bright areas, and a lower noise prioritizing gain for darker areas.
DGO sensor
Enhanced Clear Scan Mode
Clear Scan shutter mode helps reduce or virtually eliminate the flickering caused by some LED walls.
clearscan
The EOS C70 features Canon's DIG!C DV7 image processor that takes the extensive RAW information captured from the imaging sensor and processes it for output. DiG!C is also the engine behind features such as high frame rate recording, Dual Gain Output (DGO) Sensor, Dual Pixel Autofocus, HDR (PQ) output, Electronic Image Stabilization, and proxy recording.
digic dv7 image processor
The EOS C70 supports both Canon Log 2 and Canon Log 3 Gamma. In post-production, Canon Log is designed to reproduce the entire tonal range that the CMOS image sensor is capable of. Log workflows provide the user with higher dynamic range (16+ stops), more highlight and shadow retention, and more flexibility in color grading.
Canon Log 2 provides the largest dynamic range and image detail. However, while Canon Log 2 provides the most post-production flexibility and full dynamic range of the sensor, it typically requires more time in post and color correction.
For users looking for most of the benefits of a log workflow, but with shorter turnaround times, Canon Log 3 provides an alternative with only a slightly reduced dynamic range of 14 stops.
The EOS C70 also features HLG and PQ compliance with ITU-BT.2100 in Custom Picture (CP) presets, allowing users to record HDR footage instantly without grading.
eos c70
Canon 709 Custom Picture Preset
The Canon 709 CP preset features the same dynamic range as the Wide DR profile with great contrast. Canon 709 provides a rich, cinematic look to your footage right out of the box, with little to no processing or color grading, helping to save time in postproduction.
Adjustable Focus Guide Size
The EOS C70's Focus Guide feature offers two sizes - Normal and Large, which is approximately 2x bigger than the Normal option.
Focus Guide Size
Playback Marker
The camera screen displays a playback marker when in Media Mode.
Playback Marker
RF Mount
The EOS C70 is the first Cinema EOS camera engineered with a built-in RF mount making it compatible with Canon’s expanding line of high-performance RF lenses. The short flange distance helps to dramatically reduce body depth, resulting in a more compact design.
The latest firmware adds compatibility with the RF24-105mm F2.8 L IS USM Z lens and the RF Cinema Prime Series of lenses.
eos c70
Digital Tele-Converter
The digital tele-converter adds focal length versatility to the EOS C70. The feature allows a user to change the angle of view with image magnification options of 1.5x, 2x, 2.5x or 3x.
In addition to RF lenses, the EOS C70 offers tremendous flexibility by also being compatible with Canon's broad line of award-winning EF lenses thanks to the new EF - RF optical adapter, Mount Adapter EF-EOS R 0.71x. This adapter converts light transmission from full-frame to Super 35mm image format. It extends the angle of view and optical sensitivity, while seamlessly integrating with the camera’s optical corrections.
The adapter connects to the camera’s RF mount with additional support from two flanges that securely attach via four screws, making for a very robust connection. Once mounted, the adapter maintains a similar full-frame angle of view on the Super 35mm sensor, while boosting the speed of the attached lens by an average of 1-stop. The adapter also carries all EF information through to the RF contacts, so on certain lenses*, full DPAF, aberration and vignetting correction, and metadata will be available, working just as they do on a native EF mount.
EOS C70 with Mount Adapter EF-EOS R 0.71x
Other adapters that are compatible with EOS C70, include:
<p>Mount Adapter</p>
<p> EF-EOS R</p>
Mount Adapter
EF-EOS R
<p>Control Ring </p>
<p>Mount Adapter EF-EOS R</p>
Control Ring
<p>Mount Adapter </p>
<p>EF-EOS R</p>
Mount Adapter
EF-EOS R
with Drop-In Polarizing Filter A
<p>EF-EOS R</p>
Mount Adapter
EF-EOS R
with Drop-In Variable ND Filter A
*Canon plans to gradually expand the list of compatible lenses by providing free-of-charge firmware updates. EF lenses are still compatible with the camera, but Canon recommends that firmware updates be installed in order to effectively utilize functions which link the camera and lens. For a complete list of compatible lenses, please refer to the C70 Instruction Manual.
The December 2024 firmware update brings the EOS C70 compatibility with the following lenses:
  • RF70-200mm F2.8 L IS USM Z zoom lens
  • RF24mm F1.4 L VCM hybrid lens
  • RF50mm F1.4 L VCM hybrid lens
  • RF17-120mm CINE-SERVO lens
Waveform Monitor / Vectorscope
Users have the option to double the size of the on-screen waveform monitor and vectorscope and to adjust opacity (transparency) of the monitor, making it easier to see and adjust exposure while shooting. The vectorscope displays the custom picture color space along with the name for each color.
clearscan
The EOS C70 is equipped with Direct Touch Control which allows easy access to commonly used menu settings on the fully-rotatable LCD screen. Users will be able to simply touch the screen to start/stop recording, access file format and resolution, set ISO/Gain, color temperature and iris, and display important settings. Shooting settings that were once in various places of the menu can now be accessed with one hand, allowing for on-the-spot changes while holding the camera.
direct touch control
Compact, Uni-Body Design
The EOS C70 features a uni-body design that exhibits a compact form factor and an ergonomic built-in grip making handheld shooting easy and comfortable.
Built-in Mini-XLRS
The EOS C70 is equipped with two mini-XLR audio input terminals for professional audio recording. Additionally, manual audio control dials let users intuitively and quickly adjust the audio control.
Built-in Mini-XLRS
Built-in Neutral Density Filter System
The thin, motorized ND filter unit has been specifically designed for the RF mount's short flange back. It offers up to 10 stops of ND, allowing users to shoot in various lighting conditions.
neutral density filter system
Time Code Terminal
The EOS C70 includes a time code input/output terminal in the lower front of the body that makes synchronizing easier in multi-camera productions.
eos c70
Dual Pixel CMOS AF
Canon's Dual Pixel CMOS AF technology uses every pixel on the imaging sensor to detect focus and to capture actual image information, offering users high precision focusing and exceptional image quality.
eos c70
EOS iTR AF X
The EOS C70 is the first Cinema EOS camera to feature EOS iTR AF X, which includes a head detection algorithm developed with deep learning technology. In Face Detection mode, the AF works with this advanced algorithm to dramatically improve distance measuring and tracking reliability.
Image Alt Text
Face Detection AF in the EOS C70 makes it possible to select a subject via the RF lens’ control ring or camera dial. This allows you to make adjustments without having to change the position of your hands or take your eyes away from the shot. The firmware also enables Head Detection allowing the EOS C70 to detect a subject’s head even when looking backward, and changes the shape of the AF Frame based on the subject detected during tracking.
Eye AF
Eye AF detects and tracks the subject’s pupil for precise focusing. Eye Detection AF, Face Detection AF and Subject Tracking AF during Slow and Fast Recording allow for more accurate auto focus performance at accelerated frame rates.
Eye AF
Dual Pixel Focus Guide
The EOS C70 also features Dual Pixel Focus Guide, which is an innovative UI that gives users both front- and back-focus information, telling users if the focus position is in the back or the front, aiding in smooth pulls during manual focus.
Image Alt Text
Focus Meter
The focus meter allows you to select up to three separate focus points in your shot. Each selected point is identified by either a red, green, or blue mark on the viewfinder. When the selected point is in focus, the border of the viewfinder lights up in that color to easily let you know that you are in focus. This feature can only be used with lenses that support AF functionality.
Focus Meter
Electronic Image Stabilization with Coordinated Control
For the first time in a Cinema EOS camera, enhanced image stabilization is available with coordinated control. With an RF lens and the electronic IS in the EOS C70 , coordinated control optimizes hand-shake correction, resulting in better anti-vibration performance than the conventional EF lens and electronic IS together.
In addition, the EOS C70 adds Super 16 Digital IS, which stabilizes the 2K images by using the peripheral area around the center of the 4K sensor, to provide high performance stabilization.
eos c70
Auto ISO/Gain Control
The EOS C70 is the first Cinema EOS camera to feature Auto ISO and Gain Control. EOS C70 can automatically adjust sensitivity by utilizing the DGO sensor characteristics to switch gain smoothly, helping users concentrate on framing without worrying about aperture and other camera settings when moving from indoor to outdoor locations with significant changes in lighting.
eos c70
Assignable Functions
The camera offers the option of assigning functions to the selection dial on the back of the camera. These functions include shutter, iris, ISO/gain, white balance mode, and AF subject selection.
Remote Control Support
The EOS C70 features a remote terminal that allows users to control the camera with Canon's RC-V100 ("Remote A" connection). The multi-functional RC-V100 remote controller provides full access to all important functions, including start/stop, shutter/gain adjustments, zoom/focus/iris parameters, custom picture values, white balance, black gamma, and more.
Canon's IP-based XC protocol helps maximize operability and remote control of camera settings. Using the XC protocol, the camera can be operated by Canon’s RC-IP1000 or RC-IP100 control panels or via the Remote Control Camera Application (RCCA) over an Ethernet Network connection**. Additionally, XC Protocol-enabled third-party controllers (RCP) can control the C70.
The latest firmware (now available) adds a wireless smartphone control option with the release of the Canon Multi Camera Control App for iPhone or iPad.***
The Canon Multi Camera Control App provides the ability to control multiple cameras wirelessly from an iPhone or iPad via Wi-Fi****. The free app empowers you to have control over recording start and stop, focus, zoom and iris, ND Filters, ISO, Shutter, White Balance, and Custom picture control all while viewing the image from the camera.
** IP/Ethernet connectivity for XC protocol requires the use of USB network adapters.
*** Available for download on the Apple App Store.
**** Wi-Fi connectivity requires the use of a USB Wi-Fi adapter.
Please see the Technical Specifications for a list of tested Ethernet and Wi-Fi network adapters.
c70
Dual SD Card Slots with Various Recording Options
The EOS C70 has dual SD card slots for simultaneous recording in different formats, including 4K/HD and XF-AVC/MP4.
Image Alt Text *
High Frame Rate; 4K 120P and 2K CROP 180P
The EOS C70 is capable of ultra-high frame rates with its new chip design and powerful DiG!C DV7 processor. Frame rates up to 120 fps can be obtained in 4K, while 2K CROP mode provides even greater flexibility with speeds up to 180 fps. The EOS C70 supports Dual Pixel CMOS AF, even when shooting at high frame rates, keeping the camera in focus even when mounted on gimbals or drones. With the Firmware update 1.0.5.1, Eye AF, Face Detection AF and Subject Tracking AF are now available in Slow & Fast recording modes from 24p to 120p.
*V90 SD cards are recommended for Slow & Fast motion recording.
c70
Look File for Recording (User LUT)
The EOS C70 has a new option called Look File to import '.Cube' type 3D LUTs for use while recording. This function greatly improves the flexibility of EOS C70 in professional workflows.
A new viewing assist feature called CMT 709 provides the ability to see on-set how the video will look on a REC.709 monitor when recording in Canon Log 2 or Canon Log 3. This is a great starting point for any color grading, and facilitates making changes while filming, which reduces the need to "fix it in post."
eos c70
4K 60p Intra-frame Recording
XF-AVC Intra-Frame 60p records at a bit rate of 600Mbps and offers users a lightweight, high-quality codec that helps to minimize storage costs, speed up file transfer and record onto the C70's SD media. Proxy files can be named using the recommended “_Proxy” suffix, which enhances compatibility with non-linear editing systems.
Cinema RAW Light Internal Recording
Cinema RAW Light internal recording capabilities in the EOS C70 camera further enhances the recording capabilities of what's already a powerful digital imaging machine. This compact cinema camera can capture 12-bit Cinema RAW Light internally to compatible SD cards. Cinema RAW Light captures the widest dynamic range from the Dual Gain Output sensor (16+ stops total) and allows the most flexibility to grade captured content. Three quality settings of Cinema RAW Light are available: RAW HQ (high quality), RAW ST (standard quality), and RAW LT (light recording). All three modes are 12-bit regardless of frame rate. Lastly, Cinema RAW Light is compatible with Proxy and Double-Slot recording.
Frame and Interval Recording Modes
Frame and Interval Recording modes add even more recording flexibility to the EOS C70 camera by allowing easy creation of stop motion and time-lapse sequences when recording in the XF-AVC and MP4 formats. Frame recording is for stop motion capture, and every press of the record button captures a user-determined number of frames. Interval Recording sets the interval and number of frames to be captured for time-lapse sequences. Both recording modes help operators further tell their story in a more creative and inspiring form and are easy to use.
Imaging Sensor
Lens System
Exposure and Metering
Focus
Recording Selection
Recording / Codec
Audio
Features and Performance
LCD Monitor
Input/Output
Power
Accessories
Other
Reviews
Informational Documents
File Name
Cinema EOS Comparison Sheet
Date
03.24.23
File Size
5.3 MB
File Name
C70 Quick Start Guide
Date
11.04.22
File Size
17.6 MB
File Name
C70 Advanced Quick Start Guide.
Date
11.04.22
File Size
11.8 MB
Videos
Choosing between the EOS R5 C and EOS C70?
The EOS R5 C and EOS C70 Cinema Cameras combine a variety of features with outstanding performance to give you the shooting experience and results you need. If you need strictly video, the C70 might be your best option, and if you need both stills and video, you may connect more with the R5 C. Watch and learn about what each brings to the table to help you make your choice.
About the Camera and Films
Sort By:
Untitle Video
Learn more about the free firmware updates for our Cinema EOS cameras and XF605 camcorder. The firmware also includes an update to the Canon Multi-camera Control app, which will allow you to control up to four compatible cameras from a single iPad.
Untitle Video
New free firmware updates for Cinema EOS cameras and XA camcorders bring a host of features! In this video, Canon Sr. Specialist Paul McAniff will walk you through the bevy of updates to the EOS C500 Mark II, EOS C300 Mark III, EOS C70, and EOS R5 C cameras, as well as the XA75, XA70, XA65, XA60, and Vixia HF G70 camcorders.
Canon Customer Testimonial – University of Oregon
Untitle Video
At the University of Oregon’s School of Journalism and Communication, undergraduate and graduate students prepare for their futures with hands-on experiences, both in the field and in the classroom. Armed with an array of EOS C70 cinema cameras, the university is able to provide students with professional-grade equipment for their projects, which will enable them to seamlessly transition from the classroom to their careers. In this video, students and professors discuss their experiences with the cameras, and how Canon cameras are helping to bring their work to the next level.
On Set with Rubidium Wu and the Canon EOS C70
Untitle Video
Watch as filmmaker Rubidium Wu creates a horror film using the Canon EOS C70. When you're shooting with a small crew and on location, you need to get a lot of shots in a short amount of time and still produce a cinematic image. The EOS C70 offers exceptional cinema capabilities in a compact package perfect for this scenario.
Untitle Video
As dawn breaks over NYC, aerial photographer Paul Seibert and filmmaker Alex Geiger board a helicopter to capture New York in a way that’s never been done before. Their plan is to capture the city from 15,000’ above - a first-of-its-kind flight. Follow along as they bring us inside the helicopter with them, and detail how the Canon EOS R5 and Canon EOS C70 Cinema Camera paired with RF lenses, allowed them to focus on the task at hand, and capture razor-sharp images, and footage from new angles.
DP Christian Vazquez talks about his use of the EOS C70 on the short film Ourika
Untitle Video
Working on a tight schedule in tight quarters with a tight budget, DP Christian Vasquez wanted a camera setup that would allow his creative vision to break loose. In this video, Vasquez explains how the compact EOS C70 camera helped him bring the surrealistic ethereal look to life in the short film Ourika, which premiered at the 2023 Sundance Film Festival.
Canon EOS C70 Firmware Upgrade 1.0.5.1
Untitle Video
The new firmware upgrade for the EOS C70 will help to improve workflow and functionality for the content creation, live production, and documentarian markets. Feature upgrades include Eye Auto Focus (AF), Face Detection and Tracking During Slow and Fast Recording, XF-AVC 4K Intra-frame 60p, support for Canon’s IP-based XC Protocol, and more. Watch to learn more.
Untitle Video
The Canon EOS C70 offers exceptional cinema capabilities in a compact package. Enjoy stunning images with a 4K Super 35mm DGO Sensor and all the built-in features you could ask for, including ND Filters, mini XLRs, direct touch rotatable LCD screen, and Dual Pixel CMOS Autofocus, and excellent battery life.
Untitle Video
Developed with an idea of combining the Cinema EOS series with the EOS R series, the new EOS C70 offers exceptional image quality and professional video features in a compact and mobile form factor, perfect for documentary, news gathering, and corporate videos.
Untitle Video
Eye Of The Storm is a short cinematic piece about the life of Giulia Gartner, a world-renowned travel photographer from the Italian Dolomites, who used photography to pull her out of the darkest part of her life. Shot, Edited, Directed by Canon Co-Lab member Sam Newton on the Canon EOS C70. Developed with the idea of combining the Cinema EOS series with the EOS R series, the EOS C70 offers exceptional image quality and professional video features.
Untitle Video
Get a behind-the-scenes look at Canon Ambassador Sam Newton's film Eye of the Storm. Eye of the Storm is a short cinematic piece about the life of Giulia Gartner, a world-renowned travel photographer from the Italian Dolomites, who used photography to pull her out of the darkest part of her life. Shot over the course of 3 days in the Arctic Circle in Northern Norway, Eye Of The Storm was far from an easy film to put together. This is the behind-the-scenes on how Giulia’s story was brought to life.
Untitle Video
The EOS C70 packs a powerful punch in a small body, making it ideal for almost any production environment. When paired with either of Canon's COMPACT-SERVO lenses, you can choose traditional studio operation with optional zoom and focus demands, or you can use it handheld and have ENG-style control with the built-in lens servo control.
Untitle Video
The new firmware update for the EOS C70 4K Digital Cinema Camera implements sought after features such as Cinema RAW Light internal recording as well as Frame and Interval recording modes. The added features allow the EOS C70 to be better paired with the EOS C500 Mark II and EOS C300 Mark III workflows, and come as a direct result of end-user feedback from professionals.
Untitle Video
Jolade Olusanya, London-based writer, director and photographer has chosen the Canon EOS C70 to create this beautiful portrait video of poet, performer and author Sophia Thakur. The film is a visual companion to Sophia’s latest anthology "Give This Heart a Pen".
Untitle Video
Go behind the scenes of 'Give This Heart a Pen' documentary with Jolade Olusanya, London-based writer, director and photographer, who has chosen the Canon EOS C70 to create this beautiful portrait video of poet, performer and author Sophia Thakur.
Untitle Video
Learn about the compact, versatile and robust design of the EOS C70.
Untitle Video
Learn about the professional interface included in the EOS C70.
Untitle Video
Since its introduction, the EOS C70 4K Digital Cinema Camera has been the buzz of the industry, delivering stunning imagery in a compact body. Now, Canon’s first RF-mount cinema camera is getting even better, with a firmware update that adds functionality and improves performance.
Untitle Video
Learn the benefits of Canon’s innovative EF – RF optical adapter, the Mount Adapter EF-EOS R 0.71x.
Untitle Video
Hear what some of our customers have to say about the many ways in which the service and support provided by Canon has validated their purchasing decision.
Camera Tech Tips
Sort By:
Untitle Video
Senior Trainer Charles Zablan discusses the incredible AF capabilities of the EOS C70 cinema camera.
Untitle Video
Pro Market Specialist Peter Marr details the rock-solid image stabilization features of the EOS C70 camera.
Untitle Video
Senior Pro Market Specialist Jung-Jin Ahn shares tips on using the touch screen interface on the EOS C70 cinema camera.
Untitle Video
The versatility of the EOS C70 is improved even more when paired with a wireless adapter to enable remote control of camera settings via a smartphone or tablet.
Untitle Video
Pro Market Specialist Peter Marr talks about the powerful and compact solution provided by the EOS C70 camera and COMPACT-SERVO lenses.
Untitle Video
Senior Trainer Charles Zablan showcases the incredible versatility of the EOS C70 cinema camera, including multiple mounting options and the ability for shooting vertical video.
Untitle Video
Professional Market Specialist Dirk Fletcher shares tips for using the vertical video features of the EOS C70.
Untitle Video
Senior Pro Market Specialist Jung-Jin Ahn takes a walk through the input terminals of the EOS C70 camera.
EOS C70 RF24–105MM F4 L IS USM LENS KIT Compatible Products
Adapters, Chargers & Couplers Stations
Batteries & Grips
Mounting Accessories
