EOS M50 Mark II Content Creator Kit
EOSM50II CCK
As low as $899.99
Out Of Stock
  • 24.1 Megapixel (APS-C) CMOS sensor with ISO 100-25600 (H: 51200)
  • DIGIC 8 Image Processor with Auto Lighting Optimizer
  • Improved Dual Pixel CMOS AF and Eye Detection AF (Still/Movie Servo AF support)
  • 4K UHD* 24p and HD 120p** for Slow Motion
  • Vari-angle Touchscreen LCD Convenient for Vlogging and Various Composition
  • Convenient Vertical video, Touch Record Control, Movie Self-Timer Features for Content
Show more
Overview
Get the clarity and convenience you need to show off all your content with the EOS M50 Mark II Content Creator Kit.
The EOS M50 Mark II camera provides you with a high-performance and portable camera so you can use it practically anywhere and get the quality, high-resolution 4K or Full HD results to make you and your subjects look great. It also lets you easily vlog to share with your followers, friends and family; and supports vertical video to accommodate whichever social platforms you use. The included EF-M 15-45mm lens is compact to match the camera, and versatile so you can use in a variety of situations.
SHOW
OFF
ALL
YOUR
CONTENT
SHOW
OFF
ALL
YOUR
CONTENT
Man looking at EOS M50 Mark II Content Creator Kit
24.1 Megapixel (APS-C) CMOS Sensor
The EOS M50 Mark II features a powerful 24.1 Megapixel CMOS (APS-C) sensor that can capture high-resolution images and 4K videos. The large CMOS sensor utilizes a sophisticated light-capturing design, helping to shoot images and videos with reduced noise, delivering clear, detailed results even in low light. It also enables fast continuous shooting and fast autofocus for high-speed performance that helps you capture once-in-a-lifetime moments.
Chocolate chip cookies
Dual Pixel CMOS AF provides fast, accurate autofocus that helps you get the photo you want right as the moment happens. The EOS M50 Mark II features an expansive focus area of approx. 88% horizontal and 100% vertical^1. With the EOS M50 Mark II, you can easily capture your subject quickly with the improved Eye Detection AF – allowing you to shoot even when the subject is far away. Eye Detection AF can also be used when the subject's full body is in frame, to lock on the eyes from a further distance.
4K UHD* 24p Videos
With the help of the DIGIC 8 image processor, and the 24.1 Megapixel CMOS (APS-C) sensor, enjoy recording 4K movies at a frame rate of up to 24p for high definition, cinematic results. Recording at almost four times the resolution of Full HD, you can see your subject in stunning clarity. Beautiful time-lapse videos can be created in 4K simply and easily with the dedicated Time-lapse Movie mode.
4K logo
HD 120p** Videos
Ideal for smooth, slow-motion playback videos, HD movies can also be recorded at a high-frame rate of approx. 120 frames per second. Designed to capture fun, beautiful videos, the EOS M50 Mark II camera helps ensure you can see the unique expressions of your friends' or family's faces in close-up movies.
Young lady smiling at camera
Vertical Video
Ideal for the vlogger guru, the EOS M50 Mark II’s Vertical Video feature*1 allows you to mix up your shot length and angles to make your videos interesting and unique.
vertical video of waterfall
Movie Self-Timer with Touch Record Control
Enjoy creating videos without fumbling to get out of the shot or racing to get into the shot when you press the record button with the EOS M50 Mark II’s Movie-self timer function and [Touch Rec] icon. This feature allows you to select how many seconds (between 2 to 10 seconds) you will need before your video starts to record so you ensure you get the scene and subjects needed in the shot, for the shot.
Movie Digital Zoom
The EOS M50 Mark II supports movie digital zoom, which allows you to magnify the center part of the screen about 3-10 x*2, and shoot for a more intense, up-close look at the subject – not only with a single focal length lens attached, but also with a zoom lens, that may be combined with optical zoom.
Vari-angle Touchscreen LCD Convenient for Vlogging and Various Compositions
The EOS M50 Mark II camera features a 3.0-inch, 1.04 Megapixel Clear View LCD II Vari-angle Touchscreen LCD. Brightness is adjustable and its extensive flexibility makes it easy to compose and shoot from virtually any angle, making selfies simple and enabling the LCD to fold away when not in use. Touchscreen features include quickly changing settings, reviewing stills and videos, and even AF point selection.
Clean HDMI Output
Whether you're creating inspiring video clips or capturing special occasions, the advanced video capabilities of the EOS M50 Mark II camera can catch them in the quality they deserve. Video is smooth and richly detailed even when played back on a large-screen HDTV via the camera's HDMI output. It is even possible to choose movie output without any information displayed on your screen.
blueberries in a bowl
High-quality Webcam for Videoconferencing
Should you want to convert the EOS M50 Mark II camera into a high-quality webcam for your videoconferencing, simply connect the camera to a compatible laptop/desktop via the provided USB cable, download the free EOS Webcam Utility software and reach for the stars*1.
Fashion vlogger livestreaming
Live Streaming Capable***
Live streaming service*** from the EOS M50 Mark II camera to YouTube™ is now possible. Share must-see moments as they happen directly from the setting that you are in. Whether you are at a concert, or want to vlog your next beauty “how to” video, the compact sized EOS M50 Mark II can help ensure that your videos will have the cinematic image quality you desire.
Touch and Drag AF
In addition to the Touch and Drag AF feature, the [Tap to select for Face+Tracking] function now makes it fast and easy to select a focus point by simply tapping on the desired location on the LCD screen to instantly change it. The chosen AF point is then displayed in the camera's EVF for quick confirmation.
Touch and drag example
Connect easily to smartphones via Bluetooth®
Built-in Bluetooth® Capability
Bluetooth® pairing helps you connect the camera to compatible smart devices using the free Canon Camera Connect app. This low-energy wireless connection helps preserve battery life, while providing remote control of the camera. It also sends continuously updated GPS location data from your phone, letting you geotag what you've captured so you know precisely where you captured the photo.
Simply switch to a Wi-Fi connection to view and transfer images
Built-in Wi-Fi Capability
Enable wireless functions, such as file viewing and transfer, by connecting to Wi-Fi quickly and seamlessly, and exchange data with other Wi-Fi compatible Canon cameras. Using the Canon Camera Connect app, you can also transfer files to your mobile device to browse and share on social media. Built-in NFC capabilities help you connect directly to NFC-compliant Android devices by simply touching the NFC icon located on the camera.
image.canon Service
image.canon is a cloud service designed to ease your imaging workflow. Connecting the EOS M50 Mark II camera to the image.canon service will allow you to seamlessly upload all images and movies in their original format and quality, and access them from the dedicated app or through a web browser and automatically forward them to a computer, mobile device, and third-party services.
Silent Mode for Quiet Operation
Whether you are at your child’s school play or your newborn baby is sleeping, the EOS M50 Mark II camera’s Silent Mode helps you make sure that your camera doesn't startle your subject by enabling capture with virtually no shutter sound. This means you can shoot precious moments without worrying about distracting them.
Compact and Lightweight Tripod Grip
The Tripod Grip HG-100TBR is designed to help you capture fun, picture-perfect selfies at high and low angles with ease, as well as provide a stable base for shake-free videos, even when set to a vertical position while used as a tripod or if handheld. Its lightweight and compact design makes it ideal to take along for just about any activity planned.
Girl adjusting EOS M50 Mark II Content Creator Kit
Remote Control Shooting
With the Wireless Remote Control BR-E1, you can easily direct the action while your EOS M50 Mark II camera stays in the perfect shooting position – allowing you to take the perfect group shot with your friends, or record your next inspiring video from a distance of approximately 16 ft. in any direction.
Man holding remote control
Stereo Microphone DM-E100 Helps Achieve High-Quality Audio when Recording Videos
Paired with the EOS M50 Mark II camera, the compact and lightweight Stereo Microphone DM-E100 can help aspiring filmmakers and vloggers achieve high quality audio when recording video. To help remove unwanted sounds that are picked up, such as wind noise from air moving across the microphone, the microphone also comes with a Windscreen to help keep wind noise to a minimum.
Man using the stereo microphone DM-E100
View Full Technical Specs PDF
Type
Image Sensor
Recording System
Image Processing During Shooting
Autofocus
Exposure Control
Shutter
Flash Units
Drive, Self-timer System
Live View Functions
Video Shooting
Screen (Monitor)
Playback Functions
Post-processing of Images
Direct Printing
Custom Functions
Interface
Wi-Fi® (Wireless LAN)
Network Functions
Power Supplies
Dimensions and Weight
Operating Environment
Reviews
EOS M50 Mark II Content Creator Kit Compatible Products
Adapters, Chargers & Couplers Stations
Product Disclaimer
* Shooting at 23.98p is possible. Shooting takes place by cropping pixels from the center of the sensor. Contrast detection AF is used. 4K movies are cropped.
*1 The EOS Webcam Utility software utilizes the computer’s audio and does not support use of the Canon Stereo Microphone DM-E100 (included with the EOS M50 Mark II Content Creator Kit).
** AF is fixed. Playback is 1/4 slow motion playback (29.97p).
^ Compatible with iOS® versions 12.4/13.7, Android™ smartphone and tablet versions 6.0/7.0/7.1/8.0/8.1/9.0/10. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
^^Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen.or later) equipped with Bluetooth® version 4.1 or later and the Camera Connect App Ver. 2.5.10. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
