EOS R RF24-105mm F4-7.1 IS STM Lens Kit
$400 Instant Savings - Offer valid January 30, 2023 12:00 a.m. through February 26, 2023 11:59 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 50 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
Free Standard Shipping & Handling on Camera & Lens Products - Offer valid January 19, 2023 12:00 a.m. through March 31, 2023 11:59 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 50 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
- RF Mount Compatible with RF and EF/EF-S Lenses*.
- High Image Quality with 30.3 Megapixel Full-frame CMOS Sensor and DIGIC 8 Image Processor.
- Dual Pixel CMOS AF with 5,655 Manually Selectable AF Points**.
- 4K 30p with Canon Log and 10-bit 4:2:2 HDMI Output.
- Built-in EVF with 2.36 Million Dots, Touch & Drag AF.
- Sophistication in a Lightweight, Compact Size.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
For outstanding quality and convenience, all in one package, turn to the EOS R RF24-105mm F4-7.1 IS STM Lens Kit. Designed to deliver optical excellence, the EOS R features a 30.3 MP CMOS sensor, DIGIC 8 image processor and a maximum of 5,655 manually selectable AF point positions** providing incredible detail and clarity, even in low-light situations. Shoot stunning 4K video up to 30 frames per second (fps) or Full HD 1080p video up to 60 fps. Plus, when paired with the compact RF24-105mm F4-7.1 IS STM lens, which boasts smooth and quiet autofocusing in both still and video shooting, thanks to its leadscrew-type STM motor, and optical image stabilization with up to 5 stops of shake correction^, you’ll have the versatility at your fingertips to capture everything from portraits and landscapes, to everyday snapshots and more***.
Type
Digital single-lens non-reflex AF/AE camera
SD/SDHC/SDXC memory cards
- SD card speed class-compatible.
- UHS-I and II supported.
- Use of UHS-II microSDHC/SDXC cards with a microSD to SD adapter is not recommended. When using UHS-II supported cards, use SDHC/SDXC cards compatible with UHS-II.
- Eye-Fi cards not supported.Multimedia cards (MMC) cannot be used.
Approx. 36.0 x 24.0mm
Canon RF lens group (excluding EF, EF-S and EF-M lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Canon RF mount
Image Sensor
CMOS sensor (compatible with Dual Pixel CMOS AF)
Approx. 30.3 Megapixels
Approx. 5.36 µm square
Approx. 31.7 megapixels
3:2 (Horizontal:Vertical)
RGB primary color filters
Installed in front of the image sensor, non-detachable
- Self Cleaning Sensor Unit
- Removes dust adhering to the low-pass filter.
- At power off only / Enable / Disable. Performed automatically (taking about 3.0 sec. as indicated on the screen) or manually (taking about 9.0 sec. as indicated on the screen).
- After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
- When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
- Dust Delete Data acquisition and appending
- The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
- The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
- Not available with EF-S lenses, in cropped shooting or when distortion correction is applied.
- Manual cleaning (by hand)
Recording System
EXIF 2.3 (DCF2.0)
3:2 Aspect Ratio
Large/RAW/C-RAW: 6720 x 4480
Medium: 4464 x 2976
Small 1: 3360 x 2240
Small 2: 2400 x 1600
1.6x (Crop)
Large/RAW/C-RAW: 4176 x 2784
4:3 Aspect Ratio
Large/RAW/C-RAW: 5952 x 4480*
Medium: 3968 x 2976
Small 1: 2976 x 2240*
Small 2: 2112 x 1600*
16:9 Aspect Ratio*
Large/RAW/C-RAW: 6720 x 3776
Medium: 4464 x 2512
Small 1: 3360 x 1888
Small 2: 2400 x 1344
1:1 Aspect Ratio
Large/RAW/C-RAW: 4480 x 4480
Medium: 2976 x 2976
Small 1: 2240 x 2240
Small 2: 1600 x 1600
- Values for Recording Pixels are rounded to the nearest 100,000 or 10,000.
- For RAW and JPEG images, information outside the cropping area is not retained.
- JPEG images are generated in the set aspect ratio.
- RAW images are generated in [3:2], and the set aspect ratio is appended.
The following file numbers can be set:
- File numbering methods
- Continuous numbering
- The numbering of captured images continues even after you replace the card.
- Auto reset
- When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
- Manual reset
- Resets the file number to 0001, and creates a new folder automatically.
Possible
Selectable between sRGB and Adobe RGB
- Auto
- Standard
- Portrait
- Landscape
- Fine Detail
- Neutral
- Faithful
- Monochrome
- User Defined 1-3
- In Scene Intelligent Auto, [Auto] will be set automatically.
- [Standard] is the default setting for [User Def. 1-3].
White Balance
- Auto
- Day Light
- Shade
- Cloudy*
- Tungsten light
- White fluorescent light
- Flash
- Custom (Custom WB)
- Color temperature
Option between ambience priority and white priority settings.
Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Corrected in reference to the current WB modes color temperature.
Viewfinder
OLED color electronic viewfinder
Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint).
Coverage
At approx. 23mm eyepoint
Approx. 0.76 (with 50mm lens at infinity, -1 m-1)
Approx. 23mm (at -1 m-1 from the eyepiece lens end)
- AF point information
- Number of remaining multiple exposures
- HDR shooting
- Multiple-exposure shooting
- Dual Pixel RAW shooting
- Multi Shot Noise Reduction
- Digital Lens Optimizer
- AF method
- AF operation
- Drive mode
- Metering mode
- Anti-flicker shooting
- Shooting mode
- Scene icons
- AE lock
- Flash-ready
- Flash off
- FE lock
- High-speed sync
- Shutter speed
- Multi-function lock warning
- Aperture
- Lens information
- Exposure level indicator
- Exposure compensation
- Highlight tone priority
- ISO speed
- Possible shots
- Number of self-timer shooting
- Maximum burst
- Battery level
- Exposure simulation
- AEB
- FEB
- Still photo cropping
- Aspect ratio
- Auto Lighting Optimizer
- Picture Style
- White balance
- White balance correction
- Image Quality
- Bluetooth® function
- Wi-Fi® function
- Histogram
- Electronic level
Autofocus
Phase-difference detection system with image sensor (Dual Pixel CMOS AF)
Max. 5,655
When selected with cross keys.
EV -6 to 18 (f/1.2, at 73°F/23°C, ISO 100, One-Shot AF)
- One-Shot AF
- Servo AF
- Manual (Manual focus)
AF Point Selection and AF Operation
- Enable
- Disable
- LED AF assist beam only
- Focus range with the AF-assist beam is generally no more than 13.1 ft. / 4m (at f/5.6).
Exposure Control
- Evaluative metering (AF point-linked)
- Partial metering (approx. 6.1% of the area at the center of the screen)
- Spot metering (approx. 2.7% of the area at the center of the screen)
- AF point-linked spot metering not provided.
- Center-weighted average metering
EV -3 - 20 (at 73°F/23°C, ISO 100)
- Scene Intelligent Auto
- Flexible-priority AE
- Program AE (shiftable)
- Shutter-priority AE (Safety shift possible)
- Aperture-priority AE (Safety shift possible)
- Manual exposure
- Bulb
- Custom shooting mode C1, C2, C3
Manual Setting
Normal | ISO 10040000 (in 1/3-stop or whole-stop increments) |
Expanded | L: equivalent to ISO 50, H1: 51200, H2: 102400 |
- For [Highlight tone priority], the minimum ISO speed limit will be ISO 200 to 40000.
- ISO speed safety shift possible with Custom Function.
- All the expanded ISO speeds including those for movies are only “equivalent speeds.”
Auto
Shooting Mode | ISO Settings | |
No Flash | With Flash | |
Scene Intelligent Auto | ISO 10012800 | ISO 1001600 |
Fv/P/Tv/Av/M | ISO 10040000*1 | ISO 1001600*1 |
B | ISO 400 fixed | ISO 400 fixed |
*1 Depending on [Minimum] and [Maximum] of [ISO speed settings] or [Range for stills].
Exposure Compensation
- Auto AE lock
- The metering mode for AE lock after focus can be customized.
- Manual AE lock
- In the Fv, P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
- Enabled in all metering modes.
Shutter
Electronically controlled focal-plane shutter
- Electronic first curtain, mechanical second curtain
- Electronic shutter (slit rolling read out)
- Mechanical first and second curtain
1/8000 to 30 sec., bulb (total range of all shooting modes)
Soft-touch electromagnetic release
10-sec. delay, 2-sec. delay
Shutter Lag Time
External Speedlite
E-TTL II autoflash
±3 stops in 1/3- or 1/2-stop increments
Provided
The camera can set the following with EX series Speedlites:
- External flash control
- Flash firing, E-TTL II Flash metering, Slow synchro, Safety FE, Flash mode, Wireless function, Flash zoom, Shutter synchronization and Flash exposure compensation
- Flash Custom Function setting
- The setting options for both (1) and (2) will differ depending on the Speedlite used.
Drive System
- Single shooting
- High-speed continuous shooting
- Max. approx. 8.0 fps
- The conditions are attaining the maximum continuous shooting speed are as follows:
- Shooting with a fully charged battery in One-Shot AF mode at a 1/1000 sec. or faster shutter speed and maximum aperture (depending on the lens), at room temperature (73°F/23°C), with flicker reduction, Dual Pixel RAW shooting and Digital Lens Optimizer disabled.
- In One-Shot AF mode with Image Stabilizer off when using these lenses: EF 300mm f/4L IS USM, EF 28-135mm f/3.5-5.6 IS USM, EF 75-300mm f/4-5.6 IS USM, EF 100-400mm f/4.5-5.6L IS USM.
- The continuous shooting speed for high-speed continuous shooting may be lower, depending on conditions such as these: battery level, temperature, flicker reduction, Dual Pixel RAW shooting, shutter speed, aperture, subject conditions, brightness, AF operation, type of lens, use of flash and shooting settings.
- The maximum continuous shooting speed may be lower when using a cold battery in cold environments or when the battery level is low, at approx. 6.0 shots/sec.
- With Servo AF: Max. approx. 5.0 fps (shooting speed priority) [Silent LV shooting: Mode 1]
- With Servo AF, the maximum continuous shooting speed may become slower depending on subject conditions or the lens used. Also, the maximum continuous shooting speed will become slower when setting the [LV silent shooting] to [Disable].
- Low-speed continuous shooting (Tracking priority)
- Max. approx. 3.0 fps
- With Dual Pixel RAW: Max. approx. 2.2 fps
- High-speed continuous shooting not possible.
- Self-timer: 10 sec./remote control
- Self-timer: 2 sec./remote control
Live View Functions
Still photo shooting and video shooting
- Manual focus
- Magnified view possible by approx. 5x or 10x for manual focusing (not possible during movie shooting).
- Metering brightness range: EV -1 - 20 (at 73°F/23°C, ISO 100)
- AF point-linked evaluative metering
- For face detection with Face detection + Tracking AF.
EV -4 - 18 (at 73°F/23°C, ISO 100, One-Shot AF, with 29.97 fps)
- Off
- 3x3
- 6x4
- 3x3+diag
Video Shooting
MP4
Video: MPEG-4 AVC / H.264
- Variable (averaged) bit rate
ALL-I: Linear PCM*
IPB: AAC
*4K All-I recording requires an SD Memory card with a minimum write speed of 60MB/s.
Movie-recording Quality | SD Card | ||
4K (UHD) 3840 x 2160 |
29.97 fps 25.00 fps 24.00 fps, 23.93 fps |
ALL-I | UHS-II, Video Speed Class 60* or higher |
IPB | UHS-I, UHS Speed Class 3 or higher | ||
Full HD 1920 x 1080 |
59.94 fps, 50.00 fps | ALL-I | UHS-I, UHS Speed Class 3 or higher |
IPB | SD Speed Class 10 or higher | ||
29.97 fps, 25.00 fps 24.00 fps, 23.98 fps HDR movies |
ALL-I | UHS-I, UHS Speed Class 3 or higher | |
IPB | SD Speed Class 4 or higher | ||
29.97 fps, 25.00 fps | IPB Light |
HD 1280 x 720 |
119.9 fps, 100.0 fps | ALL-I | UHS-I, UHS Speed Class 3 or higher |
59.94 fps, 50.00 fps | ALL-I | Speed Class 10 or higher | |
29.97 fps, 25.00 fps HDR movies |
IPB | Speed Class 4 or higher |
* With Movie crop set to [Disable]. Movie digital IS set to [Disable].
- Manual focus
Full range (0 to 255)
Exposure control
Shutter Speed
ISO Speed (Recommended Exposure Index)
LCD Monitor
TFT color, liquid-crystal monitor
3.15-inch (screen aspect ratio of 3:2)
3.15 in./8.01cm diagonal (2.63 in./6.67cm width, 1.75 in./4.44cm height)
Approx. 2.10 million dots
Approx. 100% vertically/horizontally
Manually adjustable to one of seven brightness levels
Clear View LCD II
- Anti-smudge coating provided.
- Anti-reflection coating not provided.
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Playback
- Single image display
- No information display
- Basic information display
- Detailed shooting information display
- Detailed information
- Lens/Histogram information
- White balance information
- Picture Style information 1
- Picture Style information 2
- Color space/Noise reduction information
- Lens aberration correction information 1
- Lens aberration correction information 2
- Record of sent images
- GPS information
- IPTC information
- Index display
- 4-image index
- 9-image index
- 36-image index
- 100-image index
Display selection is available for Basic information display and Shooting information display.
The white areas with no image data will blink.
Image Protection and Erase
- Single image (select image)
- Select range
- All images in folder
- All images on card
- Image browsing and image search can be based on ratings.
- Ratings-based image selections also possible with DPP.
- All found images (only during image search)
Except protected images
- Select images to erase
- Select range
Direct Printing
Images can be sent via Wi-Fi® to a PictBridge-compatible (Wireless LAN) printer and printed.
DPOF: Digital Print Order Format
Compliant to DPOF Version 1.1
Customization
Customizable Buttons
Still Photo Shooting | Movie Shooting |
Shutter button | Multi-function button |
Movie button | LCD panel illumination button |
Multi-function button | MODE button |
LCD panel illumination button | AF-ON button |
MODE button | AE lock button |
AF-ON button | AF point selection button |
AE lock button | Lens AF stop button |
AF point selection button | Up key (cross keys) |
Lens AF stop button | Left key |
Up key (cross keys) | Right key |
Left key | Down key |
Right key | SET button |
Down key | |
SET button |
Customizable Dials
Main dial |
Wuick control dial |
Control ring |
Functions that Can be Assigned (Shooting) | Functions that Can be Assigned (Playback) |
ISO speed | Function shortcut |
White balance | Jump display |
Check focus/Display info. | |
Movie shooting | |
Flexible-priority AE | |
AF | |
User customization |
Interface
Equivalent to SuperSpeed USB (USB 3.1 Gen 1)
- For PC communication
- For WFT-E7 (Ver. 2) connection
- Shared with terminal for in-camera charging with the USB Power Adapter PD-E1.
- In-camera charging: although it is compatible with USB Type-C (5V/1.5A) equivalent, do not charge the camera other than with the USB Power Adapter PD-E1.
Type C (Resolution switches automatically) / CEC not compatible
- Images can be displayed through the HDMI output and on screen at the same time.
- Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
3.5mm diameter stereo mini jack
Power Source
Battery Pack LP-E6N (or LP-E6) x 1
- With the AC Adapter + DC Coupler, AC power is possible.
- When the Battery Grip BG-E22 is used, two battery packs (LP-E6N or LP-E6) can be installed.
- With the USB Power Adapter PD-E1, in-camera charging of LP-E6N is possible but LP-E6 cannot be charged. The USB Power Adapter PD-E1 is not compatible with powering the camera.
Automatic battery check when the power switch is turned ON.
Displayed in 6 levels. Battery level displayed on the LCD panel and in the viewfinder.
One of six levels displayed for LP-E6N and LP-E6.
The display for other power sources is different.
Power turns off after the set time of non-operation elapses.Display off
Available time options: 15 sec. / 30 sec. / 1 min. / 3 min. / 5 min. / 10 min. / 30 min.
Auto power off
Available time options: 30 sec. / 1 min. / 3 min. / 5 min. / 10 min.
Disable
Viewfinder off
Available time options: 1 min. / 3 min. / Disable
At least approx. 6 min. until auto power off while the [Date/Time/Zone] screen is displayed.
Built-in secondary battery
When fully-charged, the date/time can be maintained for approx. 3 months.
Recharge time: approx. 8 hrs.
The recharge time required to provide the above number of months with no battery pack installed.
Approx. 0.9 sec.
- Based on CIPA standards.
Dimensions and Weight
Approx. 5.35 x 3.87 x 3.32 in. / 135.8 x 98.3 x 84.4mm
Approx. 5.35 x 3.87 x 2.67 in. / 135.8 x 98.3 x 67.7mm (from grip to monitor)
Approx. 1.46 lbs. / 660g (including battery, SD memory card; without body cap)
Approx. 1.28 lbs. / 580g (body only; without battery, card or body cap)
Operating Environment
32-104° F / 0-40° C
Working Conditions
85° or less
SDK / API Compatibility
Reviews
Product Disclaimer
* Optional Mount Adapter EF-EOS R is required when using EF/EF-S lenses with the EOS R camera.
** Available AF points may decrease when shooting with AF cropping or in movie mode, or depending on camera settings or lens attached.
*** In order to use this lens with the EOS R or EOS RP camera, you must download and install the latest camera firmware from the Canon website.
^ Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 105mm using the EOS R camera.
