EOS R6 V Body
7250C002
As low as $2,499.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • First EOS V-Series camera equipped with a 7K/32.5MP full-frame CMOS Image Sensor and DIGIC X Image Processor.
  • Video-focused features include a vertical tripod mount and UI, a front record button, Power Zoom lever, tally lamp, and a full-size HDMI terminal.
  • In-Body Image Stabilizer system with 7.5 stops of shake correction in the center of the image for steady and stable video and photo imagery.Footnote1
  • Built-in active cooling fan system and a heat dissipating Magnesium-alloy chassis allow for long-form video recording.
  • Slow & Fast mode for time-warping recording in-camera.
Show more
Product Options: Body
Where to Buy
Discover the expanding lineup of PowerShot V and EOS V series cameras and see how the video focused features can improve your content.
VISIT NOW
One Camera, Many Stories.
A full-frame mirrorless digital camera for high-performance video for advanced creatives pioneering the next era of visual storytelling
Adding to the ever expanding line of PowerShot and EOS V-series cameras, the EOS R6 V Camera is the first full-frame EOS V series camera. It is designed for advanced videographers, cinematic social media content, vertical video productions and podcasts, livestreams, VR and more. It’s built for creative videographers seeking high-performance video with its 7K / 32.5MP resolution full-frame image sensor and includes a host of video creation features such as active cooling, an additional vertical tripod mount with vertical video UI, an additional front record button, Power Zoom lever, tally lamp, and a full-size HDMI terminal.
The camera features powerful resolutions and framerates including 7K RAW recording at 60p, 7K 30p Open Gate recording for post-production versatility, 4K 120p slow motion, and high-quality oversampled 4K at up to 60p. With Canon Log 2 color, in-body image stabilization, and powerful Dual Pixel CMOS AF II focusing, this is the camera you’ll want to use to tell your stories.
Where Creativity Levels Up
From solo shoots to bigger productions, the EOS R6 V delivers the performance and control that bring your ideas to life across formats, platforms, and environments.
Designed for the Way You Actually Capture
Full-Frame Video Performance
7K. 60fps. RAW.
Built for creators who want full control in post.
Capture 12-bit color, and razor-sharp detail with internal 7K 60fps RAW Light recording.
7K 30p Open Gate 3:2 Recording
One take. Reformat any aspect ratio.
Reframe seamlessly for vertical, horizontal, and everything in between.
DCI/UHD 4K 120p Recording
Capture impressive slow motion (5x on 23.98p timeline) video at DCI and UHD resolution.
Oversampled 4K FINE Recording at 60p
FINE recording mode unlocks high-image quality video for higher quality productions.
Stabilized. Always.
In-body image stabilization (IBIS) keeps your footage smooth, even when your hand isn’t.
Canon Log 2
Canon Log 2 delivers flexibility across changing lighting conditions without compromising dynamic range.
Video Features for Your Needs
Designed for Vertical Video
Native vertical mounting and UI make it easy to capture vertically without reconfiguring your setup.
Person Clicking Front Record Button
Front Record Button
A front-facing record button makes it easy to roll whether you’re behind the lens or in front of it.
Active Cooling System for Long-Form Recording
Built-in cooling keeps you rolling for up to 6 hours at 7K RAW / 7K ProRes so momentum stays intact for those longer productions.
Power Zoom Lever + REC Button
Smooth, precise zoom control built directly into the camera. Designed to work seamlessly with Canon's RF Power Zoom lens lineup, including the RF20–50mm Lens Kit. Ideal for a video-first capture.
Tally Lamp
A built-in tally lamp provides a clear visual indicator when recording, so there’s no second guessing on set.
Slow and Fast Mode
Easily capture slow-motion detail or speed things up, without needing complex post-production workflows.
EOS R6 V Side Panel with Full HDMI
Full-size HDMI
A full-size HDMI port ensures a stable, reliable connection for external monitors, streaming, and production workflows.
EOS R6 V with Screen Out
Vari-Angle LCD with Recording Emphasis
The vari-angle LCD gives you full flexibility to frame from any angle, with a clear recording display so you always know you’re rolling.
Color Mode Button
Quickly switch between color profiles to match your style, your project, or your environment.
Professional Tools. Built In.
Dual Recording: CFexpress + SD
Record simultaneously to two cards for added reliability or split formats for a more flexible workflow.
Advanced Dual Pixel CMOS AF II
Stay locked on your subject with fast, intelligent autofocus designed for movement, faces, and changing scenes.
AF for Close-up Demos
The popular SCN mode “Movie for close-up demos” autofocus is now available in all Creative Zone shooting modes.
Register People Priority
With Register People Priority autofocus, simply photograph a person2 and register them (up to 10) in-camera to enjoy highly accurate autofocus that prioritizes your most important subjects over other people in the scene.
False Color
Monitor your exposure with the same tools as found in Cinema EOS Cameras.
Waveform
The Waveform monitor shows the entire image’s luminance in graph form.
July 2026 Firmware Updates
EOS R6 V with Flash Attached
Support for External Flashes
Adds support for external flash functionality, which allows you to configure external flash control settings in the camera menu.
BR-E2 Remote Control
BR-E2 Bluetooth Remote Compatibility
Adds compatibility with the BR-E2 Bluetooth Remote on the EOS R6 V camera, allowing you to control power zoom/exposure with the remote lever and assign custom shortcuts (e.g., false color, zebras, self-timer, etc.) to two dedicated function buttons.
Support for Grid Display When Recording Video
Now viewable during active video recording (previously limited to standby mode) for real-time framing checks and perfect horizontal and vertical alignment.
Videos
Sort By:
Untitle Video
Meet Canon's first full-frame camera in the EOS V Series, built for advanced creatives pushing the boundaries of visual storytelling. With 7K Open Gate capabilities, In-Body Image Stabilization, and a vertical tripod mount, the Canon EOS R6 V packs high-performance video tools into a compact, handheld body. One camera. Many stories. Endless possibilities.
Untitle Video
Canon and Creator Camp present a short film series, captured on the all-new EOS R6 V and RF20-50mm F4 L IS USM PZ lens. In "Where Is My Lover?," director Elise Schatz brings a romantic musical comedy to life, exploring the highs, lows, and awkward realities of modern dating through a playful cinematic lens.
Untitle Video
Canon and Creator Camp present a new short film series captured on the all-new EOS R6 V and RF20-50mm F4 L IS USM PZ lens. In Jake Frew’s “Permanent Work In Progress,” we see the ever-changing skyline of New York City through the wonder of a child's eyes. Blending heartfelt storytelling with cinematic visuals, the film captures the magic of visiting a city that’s always evolving.
Untitle Video
Canon and Creator Camp present a new short film series captured on the all-new EOS R6 V and RF20-50mm F4 L IS USM PZ lens. In “Don't Doubt” from ByKody, we blur the line between superstition and reality. With retro-futuristic visuals, the film is a reminder than sometimes the impossible only exists until someone believes otherwise.
Untitle Video
Go behind the scenes of “Where Is My Lover?” and see how director Elise Schatz brought her romantic musical comedy to life using the all-new Canon EOS R6 V and Canon RF20-50mm F4 L IS USM PZ lens. From choreographed performances to dynamic handheld shots, discover how the film was captured with creator-first tools built for modern video storytelling.
Untitle Video
Step inside the making of “Permanent Work In Progress” as Jake Frew captures New York City through the lens of a child. Explore how the film blends cinematic movement, urban scale, and intimate perspective using the all-new Canon EOS R6 V and Canon RF20-50mm F4 L IS USM PZ lens.
Untitle Video
In “Don’t Doubt,” ByKody blends retro sci-fi with offbeat superstition to tell a story about belief, uncertainty, and the power of imagination. Go behind the scenes to see how the film was brought to life using the all-new Canon EOS R6 V and Canon RF20-50mm F4 L IS USM PZ lens -- tools built for today’s creators.
Untitle Video
Join Canon’s Brandon Chin as he takes us through the features of the first full-frame EOS V series camera from Canon.
Untitle Video
See the beauty of Japan captured with the EOS R6 V mirrorless camera and RF20-50mm F4 L IS USM PZ lens
Untitle Video
Are you ready to start your video adventures with the EOS R6 V mirrorless camera and RF20-50mm F4 L IS USM PZ lens?
View Full Technical Specs PDF
Type
Image Sensor
Video Resolutions
Recording System
Folder Name
White Balance
Viewfinder
LCD Screen
Playback
Autofocus
Exposure Control
Shutter
Drive Modes
Image Stabilization
HDR shooting
Video Recording
Audio
DPOF
Support for E.U. RED (European Union Radio Equipment Directive regulations)
Wi-Fi
Bluetooth
Live Streaming
External Interface
Power Source
Camera Body
Reviews
EOS R6 V Body Compatible Products
Adapters, Chargers & Couplers Stations
Product Disclaimer
  1. 7.5 stops at the center and 7.0 stops at the peripheral when shooting still photos and using the RF24-105mm F2.8 L IS USM Z. Based on the CIPA 2024 standards.
  2. Depending on the subject, animals may not be detected. Even subjects that are not dogs, cats, birds, or horses may be detected as animals.
  3. Depending on the subject, vehicles may not be detected. Even subjects that are not cars, motorcycles, trains, or aircraft may be detected as vehicles.
  4. Optical Image Stabilization available only with Canon IS (Image Stabilized) lenses.
  5. 40 FPS continuous still-image shooting (Continuous H+ Drive mode) depends upon camera settings; in some shooting conditions (slow shutter speeds, etc.), 40 FPS may not be possible.
  6. 7.5 stops shake-correction at center / 7.0 stops correction at periphery measured using Electronic shutter, based on CIPA 2024 standards for Yaw, Pitch and Roll correction, using Coordinated IS with Canon RF24–105mm F2.8 L IS USM lens (at 105mm zoom position).
  7. Register People Priority AF requires a test shot wehre subject’s head and face are unobstructed and clearly visible; not necessary for test shot to have subject looking directly into lens as long as both eyes are visible.
  8. CFexpress Type B cards, up to 8TB maximum, are compatible. Please note that if upgrading firmware using a CFexpress card, maximum card size for firmware updates is 2TB.
  9. Canon Light RAW video recording used at 50p/60p and higher FPS rates.
  10. Canon Camera Connect app available for compatible Android and iOS devices, from respective App stores.
  11. Waveform monitor, Zebra display, and False Color displays available in Shooting Info Display menu area, during video operation only.
  12. Movie magnification during recording not possible at frame rates higher than 60p in 4K DCI or UHD.
  13. ProRes™, Android™, and iOS™, and other brand names of third-party companies, are registered trademarks of those companies.
  14. Canon Content Transfer Professional app available for compatible Android and iOS devices. Full use of all app features requires a paid subscription.
  15. All specifications current, as of May 13, 2026.
  16. Previous Canon Battery Pack LP-E6N and LP-E6NH can be used, but with reduced performance, and loss of some camera functions. Original Canon LP-E6 battery pack cannot be used in EOS R6 V.
