Add to Cart
EOS R6
EOS R6 BODY
As low as $2,299.00
In Stock
Free Shoulder Bag 200ES
Free Standard Shipping & Handling
  • High Image Quality featuring a 20 Megapixel Full-frame CMOS Sensor.
  • DIGIC X Image Processor with an ISO range of 100-102400; Expandable to 204800.
  • High-Speed Continuous Shooting of up to 12 fps with Mechanical Shutter and up to 20 fpsElectronic (Silent) Shutter.
  • Dual Pixel CMOS AF II covering Approx.100% Area with 1,053 AF Areas.
  • Subject tracking of People and Animals* using Deep Learning Technology.
  • 4K up 60fps, 1080p up to 120fps^^^ 10-bit 4:2:2 with Canon Log or HDR PQ, Internal Recording in all Formats, with Auto Focus.
New
Return Policy
View Full Technical Specs PDF
Type
Image Sensor
Recording System
White Balance
Viewfinder
Autofocus
Exposure Control
Shutter
Image Stabilization (IS mode)
External Speedlite
Video Shooting
LCD Screen
Playback
Quick Control Function
Image Protection and Erase
Direct Printing
DPOF: Digital Print Order Format
Customization
Interface
Power Source
Dimensions and Weight
Operating Environment
Working Conditions
Reviews
Product Disclaimer
*Effectiveness varies depending on the subject. In some cases, dogs, cats or birds may not be detected, while some animals other than dogs, cats or birds may be detected.
** When combined with certain IS lenses such as the RF24-105mm F4 IS L USM, or when used with certain non-IS lenses as well.
*1In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
^1 Display may be grainier.
^2 When taking still photos. Actual coverage varies depending on the lens in use. Focus area will not be covered with the following RF lenses: RF600mm F11 IS STM, RF800mm F11 IS STM.
^3 When using f/1.2 lens under the following conditions: center focus point, room temperature, One-shot AF, ISO 100. This does not apply to RF lenses with DS (Defocus Smoothing) coating.
^ Compatible with iOS® versions 9.3/10.3/11.2-11.4/12.4/13.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0/10. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
^^ Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.1 or later and the Camera Connect App Ver. 2.5.10. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
