EOS Rebel SL3
Free Standard Shipping & Handling on Camera & Lens Products - Offer valid January 19, 2023 12:00 a.m. through March 31, 2023 11:59 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 50 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
- Lightest, Smallest EOS DSLR Camera*.
- High Image Quality with 24.1 Megapixel CMOS (APS-C) Sensor.
- Fast and Accurate Dual Pixel CMOS AF with Eye Detection AF.
- 4K Video, 4K Time-lapse Movie.
- Movie Digital IS
- Vari-angle Touch Screen, 3.0-inch LCD.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
Whether you’re a first time SLR user, an aspiring photo enthusiast, or someone looking to capture those amazing family moments, the Canon EOS Rebel SL3 can be the perfect companion. It’s the smallest and lightest EOS DSLR camera to date*, and is equipped with 4K recording capability, Canon’s Dual Pixel CMOS AF, and a vari-angle LCD for selfies and fun angles. Its 24.1 Megapixel (APS-C) CMOS Sensor combines with the powerful DIGIC 8 Processor for amazing performance and results, and the EOS Rebel SL3 even lets you channel your creativity with options like 4K Time-lapse movies and Creative Assist. Wherever you are and wherever you go, the EOS Rebel SL3 camera makes it simple to capture stunning photos and videos to view and share.
View Full Technical Specs PDF
Type
Digital AF/AE single-lens reflex camera with built-in flash
SD/SDHC/SDXC memory cards
- SD speed class-compatible
- UHS-I compatible
- High-speed writing is supported when a UHS-I compatible SD card is used.
- Compatible with Eye-Fi cards.
- Multimedia cards (MMC) cannot be used (card error will be displayed).
Approx. 22.3 x 14.9mm (APS-C)
Canon EF lenses (including EF-S lenses, excluding EF-M lenses)
Canon EF mount
Image Sensor
CMOS sensor (supporting Dual Pixel CMOS AF)
Approx. 24.1 megapixels
Approx. 3.72 µm square
Approx. 25.8 megapixels
3:2 (Horizontal : Vertical)
RGB primary color filters
Installed in front of the image sensor, non-detachable
- Self Cleaning Sensor Unit
- Removes dust adhering to the low-pass filter.
- Self-cleaning activated automatically (taking approx. 2 sec.) when power is turned on or off. Manual operation also possible (taking approx. 8 sec.).
- After the cleaning is performed, the camera will automatically restart (Power OFF to ON).
- When you use Multi Shot Noise Reduction, “Clean now” cannot be selected.
- Dust Delete Data acquisition and appending
- The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
- The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
- Manual cleaning (by hand)
Recording System
Compliant to Design rule for Camera File system 2.0 and Exif 2.31*
* Supports time difference information
JPEG, RAW (14-bit Canon original), C-RAW (Canon original)
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
RAW: 6000 x 4000
4:3 Aspect Ratio
Large: 5328 x 4000*
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600*
RAW: 6000 x 4000
16:9 Aspect Ratio
Large: 6000 x 3368*
Medium: 3984 x 2240*
Small 1: 2976 x 1680*
Small 2: 2400 x 1344*
RAW: 6000 x 4000
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
RAW: 6000 x 4000
* Indicate an inexact proportion.
- Multiple aspect ratios (1:1, 4:3, and 16:9) can be specified in Live View Shooting.
- Values for Recording Pixels are rounded off to the nearest 100,000th.
- JPEG images are generated in the set aspect ratio.
- RAW/C-RAW images are generated in [3:2], and the set aspect ratio is appended.
- File numbering methods
- Continuous numbering
- The numbering of captured images continues even after you replace the card.
- Auto reset
- When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
- Manual reset
- Resets the file number to 0001, and creates a new folder automatically.
Simultaneous recording is possible using a combination of RAW and JPEG/Large(Fine).
sRGB/Adobe RGB
- Auto
- Standard
- Portrait
- Landscape
- Fine Detail
- Neutral
- Faithful
- Monochrome
- User Defined 1-3
- In Basic Zone modes, [Auto] will be set for
and of the mode, and [Standard] will be set for other modes. - In Creative Zone modes, you can select or set the Picture Style.
- [Auto] is the default setting for [User Def. 1-3].
White Balance
- Auto (Ambience priority/White priority)
- Daylight
- Shade
- Cloudy*
- Tungsten light
- White fluorescent light
- Flash
- Custom (Custom WB)
Option between ambience priority and white priority settings
Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
* Corrected in reference to the current WB mode’s color temperature.
* Blue/amber and magenta/green correction can be set at the same time.
Viewfinder
Eye-level SLR (with fixed pentaprism)
Approx. 95% vertical/horizontal coverage (at approx. 19mm eye point and Large image size)
Approx. 0.87x/24.5° (with 50mm lens at infinity, -1 m-1)
Approx. 19mm (At -1m-1 from the eyepiece lens center)
Adjustable from approx. -3.0 to +1.0 m-1 (dpt)
Fixed
Quick-return half mirror
Spot metering circle, AF point activation indicator, AF point, ISO speed indicator, Focus indicator, Maximum burst, ISO speed, Highlight tone priority, Exposure level indicator, Exposure compensation amount, AEB range, Red-eye reduction lamp ON, Exposure compensation, Aperture, Shutter speed, Bulb exposure, FE lock, Busy, Built-in flash recharging, No card warning, Card error, Card full warning, error code, Flash exposure compensation, High-speed sync, FE lock / FEB in-progress, Flash-ready, Improper FE lock warning, AE lock, AEB in-progress, Warning icon
Provided with customized DISP button settings.
Autofocus
TTL secondary image-forming phase-difference detection system with AF-dedicated sensor
9 points
Center AF point is AF cross-type supporting f/5.6.
Center AF point is vertical line-sensitive supporting f/2.8.
Other AF points is vertical line-sensitive or horizontal line-sensitive AF supporting f/5.6.
With One-Shot AF, at 73°F/23°C, ISO 100
EV -0.5–18 (center AF point)
EV 0.5–18 (other AF points)
(Based on Canon’s testing standards and environment)
- Autofocus
- One-Shot AF
- AI Servo AF
- AI Focus AF
- Switches between One-Shot AF and AI Servo AF automatically.
- Manual focus
- Manual selection
- Auto selection
- Manually selectable in Basic Zone modes (except Special Scene Candlelight and Creative Filters Fish-eye effect and Miniature effect)
- Built-in Flash
- Not supported
- External Flash
- Infrared
- Intermittent firing
Exposure Control
63-zone metering sensor
- Evaluative metering (linked to all AF points)
- Partial metering (center, approx. 9.0% of viewfinder)
- Spot metering (center, approx. 4.0% of viewfinder)
- Center-weighted average metering
EV 1 - 20 (at 73°F/23°C, ISO 100, evaluative metering)
- Creative Zone
- Program AE (shiftable)
- Shutter-priority AE
- Aperture-priority AE
- Manual exposure (including bulb)
- Basic Zone
- Scene Intelligent Auto (Program AE/ non-shiftable)
- Special Scene
- Portrait
- Group Photo
- Landscape
- Sports
- Kids
- Close-up
- Food
- Candlelight
- Night Portrait
- Handheld Night Scene
- HDR Backlight Control
- Creative Filters
- Grainy B/W
- Soft Focus
- Fish-eye effect
- Water painting effect
- Toy camera effect
- Miniature effect
- HDR art standard
- HDR art vivid
- HDR art bold
- HDR art embossed
- Self Portrait
Manual Setting
Normal | ISO 100–25600 (in whole-stop increments) |
Expanded | ISO 51200 |
- When Highlight tone priority is set to [Enable] or [Enhanced], minimum ISO speed is ISO 200.
- Maximum ISO speed cannot be set to H (equivalent to ISO 51200).
Auto ISO Speed Settings
Shooting Mode | No Flash | Built-in Flash | External Flash | |
P | Program AE | ISO 100* 1–25600* 2 | ISO 100* 1–1600* 2 | ISO 100* 1–1600* 2 |
Tv | Shutter-priority AE | |||
Av | Aperture-priority AE | |||
M | Manual Exposure | |||
Bulb Exposure | ISO 400 | ISO 400 | ISO 400 | |
Scene Intelligent Auto | ISO 100–6400 | ISO 100-3200 | ISO 400–1600 | |
Special Scene | Portrait | ISO 100–6400 | ISO 100–1600 | ISO 100-1600 |
Smooth skin | ||||
Group Photo | ISO 100-3200 | |||
Landscape | ISO 100–1600 | Does not fire | Does not fire* 3 | |
Sports | ISO 100–6400 | ISO 400–1600 | ||
Kids | ISO 400–1600 | |||
Close-up | ||||
Food | ||||
Candlelight | Does not fire | Does not fire* 3 | ||
Night Portrait | ISO 100-800 | ISO 100-800 | ISO 100-800 | |
Handheld Night Scene | ISO 100-12800 | ISO 100–6400 | ISO 100-6400 | |
HDR Backlight Control | ISO 100-6400 | Does not fire | Does not fire* 3 | |
Creative Filters | Grainy B/W | ISO 100-6400 | ISO 100-1600 | ISO 100-1600 |
Soft Focus | ||||
Fish-eye Effect | ||||
Water Painting Effect | ||||
Toy Camera Effect | ||||
Miniature Effect | ISO 100-6400 | |||
HDR Art Standard | ISO 100-6400 | Does not fire | Does not fire* 3 | |
HDR Art Vivid | ||||
HDR Art Bold | ||||
HDR Art Embossed |
- ISO 200 when [Highlight tone priority] is set to [Enable] or [Enhanced].
- Varies depending on the maximum of [Max for Auto].
- Only the AF-assist beam fires.
Manual | ±5 stops* in 1/3- or 1/2-stop increments* |
AEB | ±2 stops in 1/3- or 1/2-stop increments |
- Auto AE lock
- In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
- Manual AE lock
- In the P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
- Possible with all metering modes.
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
- Electronic 1st curtain and mechanical 2nd curtain
Creative Zone: 1/4000 to 30 sec., bulb
* X-sync at 1/200 sec.
Basic Zone: 1/4000 to 1 sec.
Soft-touch electromagnetic release
10-sec. delay, 2-sec. delay, continuous shooting after 10 sec. (2 to 10 shots)
With SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.075 sec.
- Based on Canon testing standards.
- Time lag with the aperture stopped down by 3 stops or less from the open aperture.
- Release time lag will become longer for Live View shooting, Silent single shooting or Silent continuous shooting.
External Speedlite
E-TTL II autoflash (Evaluative, Average), FE Lock
- Flash exposure compensation for built-in flash and external Speedlite can be set from the camera.
Provided
The camera can set the following with EX series Speedlites:
- The actual setting options will differ depending on the Speedlite used.
- External flash control
- Flash firing, E-TTL II metering, Flash mode, Wireless functions, Flash zoom, Shutter synchronization, Flash exposure compensation, Flash exposure bracketing and Clear settings.
- The radio wireless flash functions can be set from the camera.
- External flash Custom Function setting
- The setting options for both (1) and (2) will differ depending on the Speedlite used.
Drive System
- Single shooting
- High-speed continuous shooting
- Max. approx. 5.0 shots/sec. (One-Shot AF and AI Servo AF)
- Maximum continuous shooting speed with 1/500 sec. or faster shutter speed, maximum aperture (varies depending on the lens), with a fully-charged Battery Pack LP-E17 and at room temperature (73°F/23°C).
- With the AF mode set to One-Shot AF and the Image Stabilizer turned off when using the following lenses: EF 300mm f/4L IS USM, EF 28–135mm f/3.5–5.6 IS USM, EF 75–300mm f/4–5.6 IS USM, EF 100–400mm f/4.5–5.6L IS USM.
- Silent single shooting
- Silent continuous shooting
- Max. approx. 2.5 shots/sec.
- Self-timer: 10 sec./remote control
- Compatible with Wireless Remote Controller BR-E1.
- Countdown is shown on the screen.
- Incompatible with accessories using the infrared transmission system as Remote Controller RC-6.
- 2 sec. self-timer
- Continuous shooting after 10 sec. self-timer (2 to 10 shots)
Image Recording | Image File Size (approx. MB) | Possible Shots(approx.) | Maximum Burst (approx.) | |
Standard | High-speed (UHS-I) | |||
Large (Fine) | 8.4 | 3601 | Full | Full |
Large (Normal) | 4.5 | 6618 | Full | Full |
Medium (Fine) | 4.6 | 6484 | Full | Full |
Medium | 2.6 | 11401 | Full | Full |
Small 1 (Fine) | 3.1 | 9691 | Full | Full |
Small 1 (Normal) | 1.8 | 16015 | Full | Full |
Small 2 | 1.8 | 16343 | Full | Full |
RAW | 27.2 | 1123 | 10 | 10 |
C-RAW | 15.8 | 1931 | 37 | 37 |
RAW + Large | 35.6 | 855 | 9 | 9 |
C-RAW + Large (Fine) | 24.2 | 1256 | 17 | 17 |
- The number of possible shots and maximum burst (standard) apply to a UHS-I compliant 32GB card base on Canon testing standards.
- The file size, number of possible shots and maximum burst vary depending on shooting conditions (aspect ratio of 3:2, subject, memory card brand, ISO speed, Picture Style, etc.)
- "Full" indicates that shooting is possible until the card becomes full.
Live View Functions
Still photo shooting and video shooting
- Dual Pixel CMOS AF
- Dual Pixel CMOS AF is possible with all EF and EF-S lenses.
- Contrast AF is not provided.
- Contrast detection*
* When recording 4K movies or 4K Time-lapse movies.
- Manual focus
- Magnifying the image by 5x or 10x for manual focus possible.
Real-time metering with image sensor
- AE lock possible. The metering timer setting can be changed.
- Evaluative metering (315-zone)
- Partial metering (center, approx. 6.0% of Live View screen)
- Spot metering (center, approx. 2.6% of Live View screen)
EV -2–20 (at 73°F/23°C, ISO 100, evaluative metering)
- Off
- 3x3
- 6x4
- 3x3+diag
Video Shooting
MP4
Video: MPEG-4 AVC / H.264
- Variable (averaged) bit rate
Video Recording Size and Frame Rates
NTSC | NTSC | Compression Method | Recording Format |
4K* 3840 x 2160 |
23.98 fps | IPB (Standard) | MP4 |
Full HD 1920 x 1080 |
59.94 fps | IPB (Standard) | |
29.97 fps | IPB (Standard) | ||
IPB (Light) | |||
HD 1280 x 720 |
HDR movie 1920 x 1080 |
4K* Time-lapse movie 3840 x 2160 |
29.97 fps | ALL-I | |
Full HD Time-lapse movie | 29.97 fps | ALL-I |
* The image is cropped around the center of the image sensor.
Time-lapse movie (MP4)
Item | Setting |
Time-lapse | Disable/ Scene 1 / Scene 2 / Scene 3 / |
Interval* | Minimum: 1 sec. Maximum: 60 min. |
Number of shots* | Minimum: 2 shots Maximum: 3600 shots |
Movie Recording Size | 4K / Full HD |
Auto Exposure | Fixed 1st frame Each frame |
Screen Auto Off | Enable/ Disable |
Beep as image taken | Enable/ Disable |
* Some limitations apply when Scene 1, Scene 2, or Scene 3 is used.
Continuous Shooting Time
Video Recording Size | Total Recording Time on Card (approx.) | File Size (approx.) | Bit Rate (approx.) | ||||
8GB | 32GB | 128GB | |||||
4K 3840 x 2160 |
23.98 fps 25.00 fps |
IPB (Standard) | 8 min. | 35 min. | 2 hr. 21 min. | Approx. 860 MB/min. |
Approx. 120 Mbps |
Full HD 1920 X 1080 |
59.94 fps 50.00 fps |
IPB (Standard) | 17 min. | 1 hr. 10 min. | 4 hr. 43 min. | Approx. 431 MB/min. |
Approx. 60 Mbps |
29.97 fps 25.00 fps |
IPB (Standard) | 35 min. | 2 hr. 20 min. | 9 hr. 23 min. | Approx. 216 MB/min. |
Approx. 30 Mbps |
IPB (Light) | 1 hr. 26 min. | 5 hr. 47 min. | 23 hr. 11 min. | Approx. 87 MB/min. |
Approx. 12 Mbps |
HD 1280 x 720 |
IPB (Standard) | 40 min. | 2 hr. 42 min. | 10 hr. 49 min. | Approx. 187 MB/min. |
Approx. 26 Mbps |
- Bit rate indicates video output only, audio is not included.
- File size and time indicates video output + audio.
- With [Digital IS: Disable] set.
- Contrast AF is not possible.
- Manual focus
- Magnifying the image by 5x or 10x for manual focus possible (not possible during movie shooting).
* In Basic Zone modes, exposure control is exerted as appropriate for the detected scene.
Full range (0-255)
Up to ±3 stops in 1/3- or 1/2-stop increments
LCD Monitor
TFT color, liquid-crystal monitor
3.0-inch (screen aspect ratio of 3:2)
Approx. 2.95 in./7.50cm diagonal (approx. 2.46 in./6.24cm width, approx. 1.64 in/4.16cm height)
Approx. 1.04 million dots
Approx. 170° vertically and horizontally
Adjustable to one of seven brightness levels
Clear View LCD II
- Anti-smudge coating not applied.
- Anti-reflection coating not applied.
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, and Japanese)
Playback
- Single-image display
- No information display
- Basic information display
- Detailed shooting information display
- Basic shooting information
- Lens information and RGB histogram
- White balance
- Picture Style and sharpness
- Contrast, color saturation and color tone
- Color space and noise reduction
- Lens aberration correction
- GPS information (when GPS Receiver is used)
- Index display
- 4-image
- 9-image
- 36-image
- 100-image
With detailed information display, overexposed highlight areas with no image data will blink.
Brightness and RGB
Quick Control Function
Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback.
After selecting an item, you can select contents by operating the Main Dial.
Image Protection and Erase
- Single image (select image)
- Select range
- All images in a folder
- All images in a card
- All found images (only during image search)
- RAW/C-RAW images and movies cannot be specified for printing.
Except protected images
- Select image to erase
- Select range
Direct Printing
Images can be sent via Wi-Fi® to a PictBridge-compatible (Wireless LAN) printer and printed.
DPOF: Digital Print Order Format
Complies to DPOF Version 1.1
Wi-Fi®
IEEE 802.11b/g/n
DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Approx. 10 m/32.8 ft.
*When communicating with a smartphone or tablet
*With no obstructions between the transmitting and receiving antennas and no radio interference
Frequency: 2412–2462 MHz
Channels: 1–11 channels
Camera Access Point Mode and Infrastructure mode
Authentication method: Open system, Shared key, WPA/WPA2-PSK
Encryption: WEP, TKIP, AES
Images can be viewed, controlled, and received using a smartphone.
Remote control of the camera using a smartphone is possible.
Images can be sent to a smartphone.
Not supported.
Images can be sent to and saved on Connect Station.
Remote control functions and image viewing functions of EOS Utility can be used wirelessly.
Images can be sent to a Wi-Fi® printer.
Images in the camera or links to images can be sent to registered Web services.
NFC
Not supported.
Bluetooth®
Bluetooth® Specification Version 4.1 compliant (Bluetooth® low energy technology)
GFSK modulation
Customization
11 Custom Functions settable with the camera
Functions can be assigned to the following control parts:
- Shutter button (halfway pressing)
- AE lock button
- SET button
- DISP button
- [AF point selection / Magnify button] and [AE Lock / Reduce / Index button] can be switched.
- Shutter button functions during movie recording can be set.
Up to six items from the menu items and the top-tier items of Custom Functions can be registered to each tab.
Up to five My Menu tabs can be added.
My Menu tab overall operations |
My Menu tab detailed operations |
Interface
Hi-Speed USB (USB 2.0)
- For PC communication
- For Connect Station connection
Type C (Resolution switches automatically)
- Video is not displayed unless the video system is correctly set for the connected TV set, [NTSC] or [PAL].
3.5mm diameter stereo mini jack
- Directional Stereo Microphone DM-E1 connection
Power Source
Battery Pack LP-E17 x 1
- With the AC Adapter AC-E6N and DC Coupler DR-E18, AC power operation is possible.
Mode | Shooting Method | Battery | Temperature | Possible Shots (Approx.) | |
AE 100% | AE 50% / FA 50% | ||||
Camera Body Only | Viewfinder Shooting | LP-E17 | At 73°F/23°C | 1630 | 1070 |
At 32°F/0°C | 1520 | 1020 | |||
Live View Shooting | At 73°F/23°C | 350 | 320 | ||
At 32°F/0°C | 330 | 300 |
- Using a fully charged LP-E17.
- Based on CIPA testing standards.
Automatic battery check when the power switch is turned ON. Displayed in 4 levels.
Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses.
* Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc.
Built-in secondary battery When fully-charged, the date/time can be maintained for approx. 3 months
- Recharge time: approx. 8 hrs.
- To become capable to maintain the right date/time for 3 months after main battery power depletion.
Approx. 0.2 sec. (based on CIPA testing standards)
Dimensions and Weight
Approx. 4.82 x 3.65 x 2.75 in. (122.4 x 92.6 x 69.8mm)
- CIPA compliant.
Black
Approx. 15.84 oz. / 449g (Including battery and card)
Approx. 14.18 oz. / 402g (Body only)
White Approx. 15.91 oz. / 451g (Including battery and card)
Approx. 14.25 oz. / 404g (Body only)
Operating Environment
32-104°F/0-40°C
85% or less
SDK / API Compatibility
Reviews
