EOSR7 18-150
- Newly developed High Image Quality 32.5 megapixels APS-C sized CMOS sensor.
- DIGIC X Image Processor with a native ISO range of 100-32000, expandable to 512008.
- Dual Pixel CMOS AF II covering approximately 100% width and height5 with up to 651 zones down to EV -5.0.
- High speed shooting 15fps mechanical9,3, 30fps high speed electronic shutter3,10 and RAW Burst Mode with ½ second pre-shooting.
- Subject tracking inherited from the R3 with people, animal, and vehicle detection.
- 5-axis in-body Image Stabilization with auto-level technology11.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Type
Digital single-lens non-reflex AF/AE camera
DIGIC X
SD card
- SD card speed class-compatible.
- Compatible with UHS-II
- Eye-Fi cards and Multimedia cards (MMC) are not supported.
Canon RF-S/RF lens group (excluding EF, EF-S and EF-M lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Canon RF mount
Image Sensor
CMOS sensor (compatible with Dual Pixel CMOS AF)
Approx. 32.5 megapixels
Approx. 22.3 x 14.8 mm
Approx. 3.2 µm square
Approx. 34.4 megapixels
3:2 (Horizontal: Vertical)
RGB primary color filters
Installed in front of the image sensor, non-detachable
- Self Cleaning Sensor Unit
- Removes dust adhering to the low-pass filter.
- At power off only / Enable / Disable. Performed automatically (taking about approx. 2 sec. as indicated on the screen) or manually (taking about approx. 7 sec. as indicated on the screen).
- After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
- When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
- Dust Delete Data acquisition and appending
- The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
- The dust coordinate data appended to the image is used by the EOS Canon Digital Professional Software to automatically erase the dust spots.
- Not available in focus bracketing, RAW burst mode, or multiple-exposure shooting.
- Manual cleaning (by hand)
Recording System
Compliant to Design rule for Camera File system 2.0 and Exif 2.31*.
*Supports time difference information.
Still: JPEG, HEIF, RAW, Dual Pixel RAW, Raw Burst, C-RAW (CR3);
Movies: ALL-I*, IPB, IPB Light
* Time-lapse movies only
(1) 1 shot only
(2) Every shot
(1) Focus Bracketing
(2) Interval Timer
(3) Bulb Timer
(4) Multi-Shot NR
3:2 Aspect Ratio
Large/HEIF/RAW: 6960 x 4640
Medium: 4800 x 3200
Small 1: 3472 x 2320*
Small 2: 2400 x 1600
4:3 Aspect Ratio
Large: 6160 x 4640*
Medium: 4256 x 3200*
Small 1: 3072 x 2320*
Small 2: 2112 x 1600*
RAW: 6960 x 4640
16:9 Aspect Ratio
Large: 6960 x 3904*
Medium: 4800 x 2688*
Small 1: 3472 x 1952*
Small 2: 2400 x 1344*
RAW: 6960 x 4640
1:1 Aspect Ratio
Large: 4640 x 4640
Medium: 3200 x 3200
Small 1: 2320 x 2320
Small 2: 1600 x 1600
RAW: 6960 x 4640
- Values for Recording Pixels are rounded to the nearest 100,000th.
- RAW/C-RAW images are generated at 3:2, with information added about the specified aspect ratio, and JPEG images are generated at the specified aspect ratio.
- These aspect ratios (M / S1 / S2) and pixel counts also apply to resizing.
The following file numbers can be set:
File numbering methods
- Continuous numbering
- The numbering of captured images continues even after you replace the card.
- Auto reset
- When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Selectable between sRGB and Adobe RGB
- Auto
- Standard
- Portrait
- Landscape
- Fine Detail
- Neutral
- Faithful
- Monochrome
- User Defined 1-3
White Balance
- Auto (Ambience priority/White priority)
- Day Light
- Shade
- Cloudy1
- Tungsten light
- White fluorescent light
- Flash
- Custom2 (Custom WB)
- Color temperature
2Setting method options include [Custom White Balance] and [Shoot to set WB].
Option between ambience priority and white priority settings.
Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
- Corrected in reference to the current WB mode's color temperature.
- Blue/amber and magenta/green shift can be set at the same time.
Viewfinder
OLED color electronic viewfinder; approx. 2.36 million dots resolution
Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 22mm eyepoint).
Approx. 1.15x / Approx. 33 degrees (with 3:2 display, an 50mm lens at infinity, -1 m--1)
Approx. 22mm (at -1 m-1 from the eyepiece lens end)
Approx. -4.0 to + 2.0 m-1 (dpt)
Autofocus
Dual Pixel CMOS AF
AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%*
Stills: Max. 651 zones (31 x 21)
Movies: Max. 527 zones (31 x 17)
EV -5 to 20 (f/1.2 lens*, center AF point, One-Shot AF, at room temperature, ISO 100)
* Except RF lenses with a Defocus Smoothing (DS) coating.
Full HD 29.97fps : EV -3.5 to 20
With an f/1.2 lens*, center AF point, One-Shot AF,at room temperature, ISO 100
AF Method |
Whole area AF |
Spot AF |
1-point AF |
Expand AF Area (Above, below, left and right/Around) |
Expand AF Area: Around |
Flexible Zone AF 1,2,3 |
* Available with [AF Area] set to Whole area AF
- Applies when an RF or RF-S lens without a focus mode switch is attached.
- When lenses with a focus mode switch are attached, the setting on the lens takes precedence.
Exposure Control
Real-time metering with image sensor (384 [24x16 zone metering])
- Evaluative metering
- Partial metering (approx. 6.0% of the area at the center of the screen)
- Spot metering (approx. 3.0% of the area at the center of the screen)
- Center-weighted average metering
Still Photo Shooting : EV -2 to 20 (at room temperature, ISO 100)
Movie Recording: EV 0 to 20 (at room temperature, ISO 100)
Available ISO speeds; user-set
Normal | ISO 100-32000 (in 1/3- or 1-stop increments) |
Expanded | H (equivalent to ISO 51200) |
- For [Highlight tone priority], the settable ISO speed range will be ISO 200 to 32000.
- Expanded ISO cannot be set for HDR mode or during HDR PQ shooting.
User-defined ISO range - still photo shooting
ISO Speed Range | ISO Speed |
Minimum | L 100 - 32000 (in 1-stop increments) |
Maximum | ISO 200 - H (51200) (in 1-stop increments) |
* Expanded ISO speeds are noted as being "equivalent" to these speeds.
User-defined Auto ISO range - still photo shooting
Auto Range | ISO Speed |
Minimum | ISO 100-25600 (in 1-stop increments) |
Maximum | ISO 200-32000 (in 1-stop increments) |
ISO Auto details in still photo shooting
Shooting Mode | No Flash | Using Flash | ||
Variable control of maximum ISO Auto limit for E-TTL | Compatible lens | Incompatible lens | ||
Creative Zone | P | ISO 100*1*2-32000*2 | ISO 100**1*2-6400*2 | ISO 100**1*2-6400*2 |
TV | ||||
AV | ||||
M | ||||
B | ISO 400*3 | ISO 400*3 | ISO 400*3 | |
Basic Zone | A+ | ISO 100-6400 | ISO 100-6400 | ISO 100-1600 |
SCN | Varies by shooting mode | |||
Creative Filters | Varies by shooting mode |
*1 ISO 200 when [Highlight tone priority] is set to [Enable] or [Enhanced].
*2 Varies depending on [Maximum] and [Minimum] of [Auto range].
*3 If outside the setting range, changed to the value most close to ISO 400.
Photo | Movie | |
Manual | ±3 stops in 1/3- or 1/2-stop increments | |
AEB | ±3 stops in 1/3- or 1/2-stop increments |
- Auto AE lock
- The metering mode for AE lock after focus can be customized.
- User-applied AE lock
- In the Fv, P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
- Enabled in all metering modes.
Shutter
- Mechanical
- Electronic 1st-Curtain
- Electronic Shutter (1st and 2nd curtain - silent*)
* A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated.
* In electronic shutter shooting under conditions such as flash firing by other cameras or with fluores-cent lighting or other flickering light sources, a strip of light or banding due to the brightness difference may be recorded in the image.
When [Mechanical] or [Elec. 1st- curtain] is set: 1/8000-30 sec, bulb
When [Electronic] is set: 1/16000-30 sec.
Mechanical Shutter: 1/250 sec.
Elec. 1st-curtain: 1/320 sec.
Soft-touch electromagnetic release
10-sec. delay, 2-sec. delay
Mechanical Shutter | Electronic 1st Curtain | Electronic shutter | |
Shutter-release time
lag
*Measured with shutter button pressed fully from half-pressed
position
Approx. 99ms | Approx. 50 ms | Approx. 50 ms |
Based on Canon testing standards.
Image Stabilization (IS mode)
In-body IS operation can be selected when using a non-IS lens.
- Always on
- Only for shot
External Speedlite
Ambience priority, standard, flash priority
Canon EX- and EL-series Speedlites
- Evaluative (Face Priority)
- Evaluative
- Average
Mechanical Shutter | Electronic 1st curtain |
1/250-30 sec. auto | 1/320-30 sec. auto |
1/250-1/60 sec. auto | 1/320-1/60 sec. auto |
1/250 sec. (fixed) | 1/320 sec. (fixed) |
Provided for EX- and EL-series Speedlites
- E-TTL each shot
- E-TTL 1st shot
Drive System
HDR Shooting - Still
Disable / Enable
* Can be used in conjunction with Auto Lighting Optimizer.
Recording format | Bit depth | Color sampling method | HDR specification |
HEIF | 10 bit | YCbCr 4:2:2 | Rec. ITU-R BT.2100 (PQ) |
MP4 | 10 bit | YCbCr 4:2:2 | Rec. ITU-R BT.2100 (PQ) |
Video Shooting
Click here to view full specifications PDF
LCD Screen
TFT color, liquid-crystal monitor
3.0-inch (screen aspect ratio of 3:2)
Approx. 1.62 million dots
Approx. 100% vertically/horizontally
Manually adjustable to one of seven brightness levels
- Anti-smudge coating applied.
- Anti-reflection coating not applied.
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Playback
Item | Still Photo | Movie |
Magnify zoom display | 1.5x-10x (5 levels) | - |
AF point display | Yes | - |
Grid display | Off / 3x3 / 6x4 / 3x3+diag | - |
Rating | OFF / 1 to 5
Stars Select images / Select range / All images in folder / All images on card / All found images |
Image Search | Search conditions Rating / Date / Folder / Protect / Type of file |
Protect | Select images / Select range / All images in folder / Unprotect all images in folder / All images on card / Unprotect all images on card / All found images / Unprotect all found images | |
Cloud RAW image processing | Supported | - |
RAW image processing | Supported | |
RAW Burst processing | Supported | |
HEIF -> JPEG Conversion | Supported | - |
Cropping | Supported | - |
The white areas with no image data will blink.
Brightness and RGB
Quick Control Function
The Quick Control screen is accessed by pressing the Quick Control button during still photo shooting.
Image Protection and Erase
- Single image (select image)
- Select range
- All images in a folder
- All images on card
- Image browsing and image search can be based on ratings.
- Ratings-based image selections also possible with DPP.
- All found images (only during image search)
Except protected images
- Select images to erase
- Select range
- All images in folder
Direct Printing
Not supported
DPOF: Digital Print Order Format
Compliant to DPOF Version 1.1
Wi-Fi@
IEEE 802.11b/g/n
DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n/a/ac)
Frequency: 2412 to 2462 MHz Channels: 1 to 11 channels
Connection Method | Authentication | Encryption | |
Encryption | Key Format and Length | ||
Camera Access Point | WPA2/ WPA3-Personal | AES | ASCII 8 characters |
Open | Disable | ||
Infrastructure | Open | WEP |
Disable | |||
Shared key | WEP | Same as WEP above | |
WPA-PSK WPA2-PSK WPA3-Personal |
TKIP AES |
1-127 characters |
Images can be viewed, controlled, and received using a smartphone.
Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
Images can be sent to a smartphone.
Firmware can be downloaded and saved to a card in the camera using Camera Connect.
The camera can be controlled via Wi-Fii® using EOS Utility.
Supported.
Still photos (RAW, C-RAW, HEIF, and JPEG) and movies (MP4) can be uploaded to image.canon server album.
With the image.canon server, images can be sent to social media or a photo album link can be sent (by the image.canon specifications).
Still RAW photos can be transferred to image.canon for RAW development using Deep Learning technology resulting in clearer images without losing detail through the reduction of noise, false color, moiré and jagged lines.
*This feature requires a paid subscription (service begins July 25, 2022).
Bluetooth®
Bluetooth Specification Version 4.2 compliant (Bluetooth low energy technology)
GFSK modulation
Customization
Customizable Dials
Still photo | Movie | |
Shutter button (half-press) | Yes | - |
Movie shooting button | Yes | - |
Multi-function ( |
Yes | Yes |
ISO speed button | Yes | Yes |
AF-ON button | Yes | Yes |
AE lock (<*>) button | Yes | Yes |
AF point button | Yes | Yes |
DOF preview button | Yes | Yes |
Lens function ( |
Yes | Yes |
Cross keys: Up button | Yes | Yes |
Cross keys: Left button | Yes | Yes |
Cross keys: Right button | Yes | Yes |
Cross keys: Down button | Yes | Yes |
Set button | Yes | Yes |
Multi-controller | Yes | Yes |
Main dial |
Quick control dial |
Control ring |
- Up to six top-tier menu items and Custom Functions can be registered.
- Up to five My Menu tabs can be added.
My Menu tab overall operations |
My Menu tab detailed operations |
Interface
Equivalent to Superspeed PLus USB (USB 3.2 Gen 2)
- For PC communication
- Terminal type: USB Type-C
- Shared with terminal for in-camera charging with USB Power Adapter PD-E1.
- In-camera Charging: Equivalent to USB type-C (5 V/1.5 A), but use should be restricted to USB Power Adapter PD-E1.
HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
- Images can be displayed through the HDMI output and on screen at the same time.
- Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
Provided
3.5mm diameter stereo mini jack
Remote Switch RS-60E3 type terminal supported
Compatible with the Wireless Remote Control BR-E1
Compatible with infrared remote controls such as Remote Controller RC-6
Supported
Power Source
LP-E6NH/LP-E6N/LP-E6*
- With the AC Adapter AC-E6N + DC Coupler DR-E6, AC power is possible.
- With the USB Power Adapter PD-E1, in-camera charging of LP-E6NH is possible.
Automatic battery check when the power switch is turned ON.
Displayed in 6 levels on top LCD panel.
- Battery level can be checked on the LCD panel and in the viewfinder.
Battery Info display in Set-up Menu: - Type of power source used.
- Remaining capacity (percentage of battery charge remaining).
- Recharge performance: (3-level display of battery's ability to hold a charge)
Approx. 0.4 sec.
- Based on CIPA testing standards.
Dimensions and Weight
Approx. 5.20 x 3.56 x 3.61 in. / 132.0 x 90.4 x 91.7 mm
- Based on CIPA standards.
Approx. 1.1 lbs (18.70 oz) Body Only
Approx. 1.3 lbs (21.59 oz) With battery,and memory card
Operating Environment
32-104° F / 0-+40°C
85% or less
Reviews
DEFINITIONS
Throughout this Contract, the following capitalized words have the stated meaning:
"Accidental Damage From Handling", "ADH": refers to accidental damage from handling, meaning such damage resulting from unintentionally dropping the Covered Product or liquid spillage. "Administrator": the entity responsible for administrating benefits to You in accordance with the Service Contract provisions, conditions and exclusions, who is Canon U.S.A., Inc., One Canon Park, Melville, NY 11747-3036. "Claim": a demand for payment in accordance with this Contract sent by You to the Administrator or Us. "Commercial Use": any non-residential use; including rental, business, educational and institutional, but not including heavy industrial use. "Contract Purchase Receipt": the receipt document (paper or e-mail) provided to You by the Administrator or Retailer as proof of Your Contract purchase that indicates the Term, Deductible, and date in which the Service Contract was purchased; which must be attached to and forms part of this Service Contract. "Failure": the mechanical or electrical breakdown of Your Product to perform its intended function including defects in materials or workmanship and normal wear and tear; occurring during normal use of the Product. "Original Purchase Price": the amount paid by You for the covered Product(s); excluding any applicable taxes and/or fees, as evidenced on Your sales/Canon purchase documentation. "Power Surge": damages to the Product resulting from an oversupply of voltage to Your Product while properly connected to a surge protector approved by the Underwriter's Laboratory Inc. (UL), but not including damages resulting from the improper installation or improper connection of the Product to a power source. "Product(s)": the item(s) which You purchased and is covered by this Service Contract. "Retailer": the seller that has been authorized by Us to sell this Service Contract to You. "Service Contract", "Contract": this document detailing all coverage provisions, conditions, exclusions and limitations for this Contract that has been provided to You upon purchase completion from Our Retailer. "Term": the period of time shown on Your Contract Purchase Receipt which represents the duration in which the provisions of this Service Contract are valid. "We", "Us", "Our," "Obligor," "Provider": the party or parties obligated to provide service under this Service Contract as the service contract provider, Northcoast Warranty Services, Inc., 800 Superior Avenue E., 21st Floor, Cleveland, OH 44114; (Florida Residents: this Service Contract is an agreement between You and Technology Insurance Company, Inc., License No. 03605, 59 Maiden Lane, 43rd Floor, New York, NY 10038). . "You", "Your": the purchaser/owner of the Product(s) covered by this Service Contract.
PRODUCT ELIGIBILITY
This Service Contract covers Products purchased as new or factory-refurbished and manufactured for use in the United States, which, at the time of Product purchase, included a Canon USA, Inc. limited warranty valid in the United States providing minimum coverage of one (1) year parts and labor. The original Service Contract must be purchased within ninety (90) days of purchase of Your Product. Purchase of this Service Contract is not required to purchase the Product or to obtain financing for the Product. Coverage outlined in this Service Contract only applies to Products not covered under any other insurance warranty, guarantee and/or service contract providing the same benefits as outlined herein. Products must be purchased from a Retailer, and be solely intended for personal use, and not intended for Commercial Use or for resale. Accessories, external peripheral devices and/or add-on options are not covered under this Service Contract.
RENEWAL
Subject to this section, Your original Service Contract can be renewed. The renewal must be purchased no sooner than ninety (90) days prior to expiration date of the original Service Contract Term and not after such date. In no event, however, will the combined Term of your manufacturer's Limited Warranty, original Service Contract and any Service Contract renewal period exceed the maximum coverage time period of five (5) years from date of Product purchase. Coverage during the renewal period will be governed by the then current version of the Service Contract Terms & Conditions which must be agreed to in order for the renewal period to become effective. To renew Your Service Contract, sign into Your Canon Account at usa.canon.com to view your eligible products or call 1-833-CAREPAK (1-833-227-3725).
YOUR RESPONSIBILITY
PRODUCT PROTECTION: If damage or breakdown of the Product is suspected, You should promptly take reasonable precautions in order to protect against further damage.
SERVICE CONTRACT TERM
EFFECTIVE DATE OF COVERAGE:
- Damage resulting from Power Surge or Accidental Damage from Handling ("ADH"): Coverage for damages to Your Product resulting from Power Surge or Accidental Damage From Handling, begins on the date of Product purchase or delivery (if different from Product purchase date), and continues for the Term shown on Your Contract Purchase Receipt.
- Failure resulting from Mechanical/Electrical Breakdown: Coverage for Failure of Your Product resulting from mechanical or electrical breakdown as described in the definition of "Failure" begins upon expiration of the shortest portion of the manufacturer's original parts and/or labor limited warranty and continues for the remainder of Your Term.
WHAT IS COVERED – GENERAL
In accordance with the SERVICE CONTRACT TERM described above, We agree to procure the necessary services to restore Your Product to standard operating condition at Our discretion, which may result in a replacement of Your originally covered Product in lieu of repair services, if Your Product experiences a Failure or damage from Accidental Damage From Handling ("ADH") or Power Surge.
If provided to You, a replacement product may be a new or refurbished product of equal or similar features and functionality, but not necessarily the same model. Please refer to the LIMIT OF LIABILITY section for full details regarding Product replacements.
IMPORTANT: COVERAGE DESCRIBED IN THIS SERVICE CONTRACT WILL NOT REPLACE OR PROVIDE DUPLICATIVE BENEFITS DURING ANY ACTIVE MANUFACTURER'S LIMITED WARRANTY PERIOD. DURING SUCH PERIOD, ALL PARTS, LABOR, ON-SITE SERVICE AND/OR SHIPPING COSTS COVERED BY THAT LIMITED WARRANTY ARE THE SOLE RESPONSIBILITY OF THE MANUFACTURER (WHO IS CANON U.S.A., INC.) PARTS USED TO REPAIR OR REPLACE YOUR PRODUCT MAY BE NEW, USED, REFURBISHED, OR NON-ORIGINAL MANUFACTURER PARTS THAT PERFORM TO THE FACTORY SPECIFICATIONS OF YOUR PRODUCT. Where applicable, technological advances may result in a replacement product with a lower selling price than Your original Product, and no refunds will be made based on the replacement product cost difference.
This Service Contract is valid for repairs or replacement within the United States of America, its territories or Canada.
ADDITIONAL BENEFITS INCLUDED IN YOUR PLAN
In addition to coverage for a Failure, Your Contract also provides coverage for:
- ACCIDENTAL DAMAGE FROM HANDLING (ADH): labor and/or parts required to repair Your Product, or at Our sole discretion, replacement of Your original Product in lieu of repair in consideration of sudden and unforeseen ADH.
- COMPLIMENTARY CUSTOMER SUPPORT: During your Service Contract Term and upon validation of CarePAK coverage with an active Canon Account, Your Contract includes agent-assisted support, for all CarePAK eligible Products, via phone at 1-833-CAREPAK (1-833-227-3725) or email at carepakplus@cits.canon.com.
- NO LEMON GUARANTEE: Within any consecutive twelve (12) month period, if Your Product has three (3) repairs covered under Your Contract for the same problem and a fourth (4th) repair is required for the same problem and considered covered under Your Contract, We will replace Your Product with one of like kind and quality, but not necessarily same model, or, at Our sole discretion, provide You with reimbursement equal to the fair market value of the Product as determined by Us based upon the age of the Product and subject to the LIMIT OF LIABILITY section. Any repair services performed while Your Product is under its manufacturer's warranty or in association with ADH are not considered to be qualifying service repairs under this benefit.
- CANON MAINTENANCE SERVICE FOR CAMERAS AND EF/RF LENSES: You are entitled to one (1) Canon Maintenance Service (CMS) procedure per covered Product per year for each year of coverage during the coverage period. This service includes 18-point Digital SLR Maintenance Service and/or 11-point EF/RF Lens Maintenance Service. The CMS service benefit for each Product is not transferable to any other Product. For more details on the service, please visit usa.canon.com/maintenance.
DEDUCTIBLE
There is no Deductible required to obtain service on Your Product under this Service Contract.
OBTAINING SERVICE
IN ORDER FOR A CLAIM TO BE CONSIDERED, YOU WILL NEED TO FIRST CONTACT THE ADMINISTRATOR FOR APPROVAL AND A REPAIR AUTHORIZATION NUMBER. IMPORTANT: THE SUBMISSION OF A CLAIM DOES NOT AUTOMATICALLY MEAN THAT THE DAMAGE OR BREAKDOWN TO YOUR PRODUCT IS COVERED UNDER YOUR SERVICE CONTRACT. THE ADMINISTRATOR MUST VALIDATE AND PROVIDE YOU WITH APPROVAL (I.E. A REPAIR AUTHORIZATION NUMBER) FOR YOUR SUBMITTED CLAIM PRIOR TO ANY BENEFITS BEING CONSIDERED UNDER THIS CONTRACT.
THIS SERVICE CONTRACT MAY NOT PROVIDE ANY COVERAGE IF YOU MAKE UNAUTHORIZED REPAIRS. Upon validation of CarePAK coverage, Canon will make commercially reasonable efforts to service and ship Your repair or replacement within five (5) business days after you receive the No Charge Repair Acknowledgement correspondence via email and subject to availability of parts or replacement Product. Note that business days are Monday through Friday, 9am-5pm, and exclude Canon observed holidays, and any periods where unavailability is due to circumstances beyond Canon's control.
If You need to file a Claim under this Service Contract or verify Your coverage, call the Administrator's Customer Care Center at 1-833-CAREPAK (1-833-227-3725). To expedite service, please have Your Contract Purchase Receipt readily available. The Administrator will confirm Your Service Contract coverage and collect any additional information necessary from You and about Your covered Product. When You receive authorization for service on Your Product under this Contract, You will also receive further instructions on how to obtain such service. In general:
- If Your covered Product is a camera, video, lens, flash, projector or binoculars, You can also arrange for service under this Contract online by visiting the Administrator's Product Repair Page at www.usa.canon.com/support.
- If Your covered Product is a printer, scanner or multifunction printer, the Administrator is unable to authorize service for these particular products through its website; You must call the Administrator's Customer Care Center at 1-833-CAREPAK (1-833-227-3725) to initiate service.
Please do not take or return Your Product to the Retailer or ship Your Product anywhere unless the Administrator instructs You to do so. If You are instructed by the Administrator to transport or ship Your Product, be sure to include the following with Your Product:
- (1) a copy of Your Contract Purchase Receipt;
- (2) a brief written description of the problem You are experiencing with the Product; and
- (3) a prominent notation of Your repair authorization number that the Administrator gave You.
Please use caution when transporting and/or shipping Your Product as directed by the Administrator, as We are not liable for any freight charges or damages due to improper packaging by You or Your representative.
If Your Term expires during the time of an approved Claim, Your coverage under the Contract will be extended until the date in which Your approved Claim in progress has been fulfilled completely in accordance with the terms and conditions of this Service Contract.
LIMIT OF LIABILITY
During the Term of Your Service Contract, the maximum amount that We are obligated to pay for services in connection with all Claims pursuant to this Service Contract is:
- One (1) Product replacement for a covered Claim for ADH damage (in which Your replacement product is ineligible for continued coverage under Your original Contract); OR
- Two (2) Product replacements for covered Claims for Power Surge or Failures (in which Your replacement products are automatically covered under Your original Contract for the remainder of Your Term).
Once the first limit has been met, Our obligation under this Contract is considered fulfilled in its entirety and coverage ends.
NEITHER WE NOR THE ADMINISTRATOR NOR THE RETAILER SHALL BE LIABLE FOR ANY INCIDENTAL OR CONSEQUENTIAL DAMAGES; INCLUDING BUT NOT LIMITED TO: PROPERTY DAMAGE, LOST TIME OR LOST DATA RESULTING FROM THE FAILURE OF ANY PRODUCT OR EQUIPMENT, FROM DELAYS IN SERVICE OR THE INABILITY TO RENDER SERVICE, OR RESULTING FROM THE UNAVAILABILITY OF REPAIR PARTS/COMPONENTS. NEITHER WE NOR THE ADMINISTRATOR NOR THE RETAILER SHALL BE LIABLE FOR ANY AND ALL PRE-EXISTING CONDITIONS KNOWN TO YOU; INCLUDING ANY INHERENT PRODUCT FLAWS.
WHAT IS NOT COVERED (GENERAL EXCLUSIONS)
THIS SERVICE CONTRACT DOES NOT COVER:
- LOSS OF OR DAMAGE TO THE COVERED PRODUCT RESULTING FROM: ABUSE (MEANING THE INTENTIONAL TREATMENT OF THE COVERED PRODUCT IN A HARMFUL, INJURIOUS, MALICIOUS OR OFFENSIVE MANNER WHICH RESULTS IN ITS DAMAGE AND/OR FAILURE), MISHANDLING, IMPROPER PACKAGING BY YOU, ALTERATION, COLLISION WITH OR OF ANOTHER OBJECT, ELECTRICAL CURRENT FLUCTUATIONS (OTHER THAN THAT WHICH IS EXPLICITLY DEFINED AS POWER SURGE IN THE DEFINITIONS SECTION), FAILURE TO FOLLOW OPERATING, MAINTENANCE OR ENVIRONMENTAL INSTRUCTIONS PRESCRIBED IN THE COVERED PRODUCT'S MANUFACTURER OWNER'S MANUAL OR SERVICE PERFORMED BY ANYONE OTHER THAN A SERVICER AUTHORIZED BY CANON.
- SERVICE, REPAIR OR REPLACEMENT NECESSITATED BY THE USE OF PARTS OR SUPPLIES (OTHER THAN THOSE SOLD BY THE COVERED PRODUCT'S ORIGINAL MANUFACTURER) WHICH DAMAGE THE COVERED PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS.
- SERVICE, REPAIR OR REPLACEMENT OF THE COVERED PRODUCT IF ITS SERIAL NUMBER OR MANUFACTURER DATING HAS BEEN ALTERED OR REMOVED.
- SERVICE, REPAIR OR REPLACEMENT OF ANY COVERS, LIDS OR TRIM PARTS, OR OF ANY CONSUMABLE ITEMS; INCLUDING WITHOUT LIMITATION: INK CARTRIDGES, INK TANKS AND DISPOSABLE PRINT HEADS.
- PREVENTIVE MAINTENANCE.
- SERVICE, REPAIR OR REPLACEMENT OF ANY OTHER ITEM, EQUIPMENT OR SOFTWARE THAT MAY BE INCLUDED WITH OR CONNECTED TO THE COVERED PRODUCT.
- ON-SITE OR IN-HOUSE SERVICE OR REPAIR OF THE COVERED PRODUCT.
- ANY ITEM THAT IS PURCHASED OUTSIDE OF THE UNITED STATES OF AMERICA.
- SERVICE, REPAIR OR REPLACEMENT OF A COVERED PRODUCT OUTSIDE OF THE UNITED STATES OF AMERICA, ITS TERRITORIES OR CANADA.
- PRE-EXISTING CONDITIONS INCURRED OR KNOWN TO YOU (MEANING A CONDITION THAT, WITHIN ALL REASONABLE MECHANICAL OR ELECTRICAL PROBABILITY, RELATES TO THE MECHANICAL FITNESS OF THE COVERED PRODUCT BEFORE ISSUANCE OF THIS SERVICE CONTRACT).
- COSMETIC DAMAGE (MEANING DAMAGES OR CHANGES TO THE PHYSICAL APPEARANCE OF THE PRODUCT THAT DOES NOT IMPEDE OR HINDER THE PRODUCT'S NORMAL OPERATIONAL FUNCTION; SUCH AS SCRATCHES, ABRASIONS, OR CHANGES IN COLOR, TEXTURE, OR FINISH), RUST, CORROSION, WARPING, BENDING OR EXPOSURE TO WEATHER CONDITIONS.
- ANY KIND OF MANUFACTURER RECALL OR REWORK ORDER ON THE COVERED PRODUCT THAT THE MANUFACTURER IS RESPONSIBLE FOR PROVIDING, REGARDLESS OF THE MANUFACTURER'S ABILITY TO PAY FOR SUCH REPAIRS.
- BREAKDOWN OR DAMAGE THAT IS COVERED UNDER ANY OTHER INSURANCE, WARRANTY, GUARANTEE AND/OR SERVICE CONTRACT PROVIDING THE SAME BENEFITS AS OUTLINED IN THIS SERVICE CONTRACT.
- ANY ACCESSORIES, EXTERNAL PERIPHERAL DEVICES AND/OR ADD-ON OPTIONS.
- ANY CLAIM THAT HAS NOT BEEN PRIOR AUTHORIZED BY THE ADMINISTRATOR OR US.
- ANY LOSS ARISING OUT OF THE UNAUTHORIZED ACCESS OR USE OF ANY SYSTEM, SOFTWARE, HARDWARE, OR FIRMWARE, OR ANY MODIFICATION, REPROGRAMMING, DESTRUCTION, OR DELETION OF DATA OR SOFTWARE BY ANY MEANS.
YOU ARE RESPONSIBLE FOR BACKING UP ALL SOFTWARE AND DATA ON A REGULAR BASIS AND PRIOR TO COMMENCEMENT OF ANY REPAIR. THIS SERVICE CONTRACT DOES NOT COVER RESTORATION OF SOFTWARE OR DATA, OR DATA RETRIEVAL TO/FROM YOUR COVERED PRODUCT, AND WE ARE UNABLE TO TRANSFER SUCH SOFTWARE OR DATA TO ANY REPLACEMENT DEVICE THAT MAY BE PROVIDED TO YOU. IN NO EVENT SHALL WE BE RESPONSIBLE FOR THE RESTORATION OF SOFTWARE OR DATA, OR FOR RETRIEVING DATA FROM YOUR PRODUCT. IF YOUR CAREPAK PLUS COVERAGE INCLUDES CANON IMAGE RECOVERY FULFILLED BY SEAGATE® RESCUE SERVICE ("IMAGE RECOVERY"), PLEASE NOTE THAT IMAGE RECOVERY TERMS AND CONDITIONS ARE SEPARATE AND INDEPENDENT FROM CAREPAK PLUS, AND CAN BE FOUND AT USA.CANON.COM/CAREPAK-PLUS.
IF YOUR PRODUCT EXPERIENCES AN OCCURRENCE THAT IS EXCLUDED FROM COVERAGE UNDER THIS SECTION, OR IN THE EVENT OF A SERVICE INCIDENT WHEREIN THERE IS A "NO PROBLEM FOUND" DIAGNOSIS FROM OUR AUTHORIZED SERVICER, THEN YOU MAY BE RESPONSIBLE FOR ALL COSTS IN ASSOCIATION WITH SUCH SERVICE INCLUDING ANY SHIPPING AND/OR ON-SITE SERVICING COSTS.
OUR RIGHT TO RECOVER PAYMENT
If You have a right to recover against another party for anything We have paid under this Service Contract, Your rights shall become Our rights. You shall do whatever is necessary to enable Us to enforce these rights. We shall recover only the excess after You are fully compensated for Your loss.
CANCELLATION
You may cancel this Service Contract at any time by informing the Administrator of Your cancellation request. If such request is within thirty (30) days of the purchase of this Service Contract, You will receive a one hundred percent (100%) refund of the Service Contract purchase price paid by You, less the amount of any Claims paid by Us. If such request is made after thirty (30) days of the purchase date of this Service Contract, You will receive a pro-rata refund of the Service Contract purchase price paid by You, less the amount of any Claims paid by Us and less an administrative fee not to exceed ten percent (10%) of the Service Contract purchase price, or twenty-five dollars ($25.00), whichever is less. In no event will any imposed administrative fee exceed twenty-five dollars ($25.00).
We may only cancel this Service Contract for the following reasons:
- 1) non-payment of the Service Contract fee by You;
- 2) material misrepresentation by You to Us; or
- 3) substantial breach of duties by You under this Service Contract in relation to the covered Product or its use.
If We cancel this Service Contract, We must provide written notice to You at least fifteen (15) days prior to the effective date of cancellation. Such notice will be sent to Your current address in Our file (email or physical address as necessary), with the reason for and effective date of such cancellation. If We cancel this Service Contract, You will receive a pro-rata refund based upon one hundred percent (100%) of any unearned Service Contract fee paid by You, minus any Claims paid by Us.
NOTICE: These CANCELLATION provisions apply to the original purchaser of this Service Contract only.
GUARANTY
This is not an insurance policy; it is a service contract. We have obtained an insurance policy to insure Our performance under this Service Contract. Should We fail to pay any Claim or fail to replace the Product covered under this Service Contract within sixty (60) days after the Claim has been submitted, or in the event You cancel this Service Contract, and We fail to refund any unearned portion of the Service Contract price, You are entitled to make a direct claim against the insurer, Wesco Insurance Company, at 866-505-4048 or 59 Maiden Lane, 43rd Floor, New York, NY 10038.
TRANSFERABILITY
If You are the original purchaser of this Service Contract and wish to transfer coverage under this Service Contract to a different owner, You may initiate a one-time transfer of ownership by calling the Administrator at 1-833-CAREPAK (1-833-227-3725). You will be required to provide Your registration number located on Your Contract Purchase Receipt and a copy of Your Product purchase receipt (if provided separately). Transferability is determined at Canon's discretion, as approved by Us, and may not be available with all Products. The CANCELLATION provisions apply to the original purchaser of this Service Contract only.
ENTIRE AGREEMENT
This Service Contract, including the terms, conditions, limitations, exceptions and exclusions, and Your Contract Purchase Receipt, constitute the entire agreement between Us and You and no representation, promise or condition not contained herein shall modify these items, except as required by law.
SPECIAL STATE REQUIREMENTS
Regulation of service contracts may vary widely from state to state. Any provision within this Service Contract which conflicts with the laws of the state where You live shall automatically be considered to be modified in conformity with applicable state laws and regulations as set forth below. The following state specific requirements apply if Your Service Contract was purchased in one of the following states and supersede any other provision within Your Service Contract terms and conditions to the contrary.
Alabama: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract. Any refund may be credited to any outstanding balance of Your account and the excess, if any, returned to You.
Arizona: WHAT IS NOT COVERED (GENERAL EXCLUSIONS) is amended to include: Only unauthorized product repairs, modifications or alterations performed after the effective date of the Service Contract are excluded.
Arkansas: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
OBTAINING SERVICE is amended to include: If You need to file a claim under this Service Contract, You must contact the Administrator at 1-833-CAREPAK (1-833-227-3725) to obtain a repair authorization number prior to having any repairs made to Your Product. If a repair or replacement occurs when the Administrator's office is closed, You may follow these claims procedure without prior authorization. However, You must call the Administrator as soon as reasonably possible. Failure to call in and report the claim will result in non-payment.
California: CANCELLATION is amended as follows: This Service Contract may be cancelled by You for any reason, including, but not limited to, the Product covered under this Service Contract being sold, lost, stolen or destroyed. If You decide to cancel Your Service Contract, and Your cancellation notice is received by the Administrator within thirty (30) days and You have made no claims against the Service Contract, You will be refunded the full Service Contract price; or if Your Service Contract is cancelled by written notice after thirty (30) days from the date You received this Service Contract, You will be refunded a pro-rated amount of the Service Contract price, less any claims paid, less an administrative fee of ten percent (10%) of the Service Contract price or twenty-five dollars ($25), whichever is less. If a cancellation refund is not paid or credited within thirty (30) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid.
The following disclosure statement is added to this Service Contract: Canon U.S.A., Inc., (License No. S-5067) is the Service Contract Administrator and Northcoast Warranty Services, Inc. (License No. SA-19178) is the Obligor for this Service Contract.
Colorado: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
Connecticut: The following disclosure statement is added to this Service Contract: In the event of a dispute with Administrator, You may contact The State of Connecticut, Insurance Department, P.O. Box 816, Hartford, CT 06142-0816, Attn: Consumer Affairs. The written complaint must contain a description of the dispute, the purchase or lease price of the Equipment, the cost of repair of the Equipment and a copy of the warranty Service Contract.
CANCELLATION is amended as follows: You may cancel Your Service Contract if the covered Equipment is sold, lost, stolen, or destroyed.
District of Columbia: CANCELLATION is amended as follows: If Your refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, We will add an extra ten percent (10%) to Your due refund for every thirty (30) days the refund is not paid by Us.
Florida: The definition of "We", "Us", "Our", "Obligor", "Provider" is deleted and replaced with the following: "We", "Us", "Our", "Obligor", "Provider": Technology Insurance Company, Inc., License No. 03605, 59 Maiden Lane, 43rd Floor, New York, NY 10038. This Service Contract is between the Provider, Technology Insurance Company, Inc. (License No. 03605) and You.
CANCELLATION is amended as follows: You may cancel Your Service Contract by informing the selling dealer or the Administrator. In the event the Service Contract is canceled by You, return of the premium shall be based upon ninety percent (90%) of the unearned pro-rata premium less any claims that have been paid or less the cost of repairs made on Your behalf. In the event the Service Contract is canceled by the Administrator or Provider, return of the premium shall be based upon one hundred percent (100%) of the unearned pro-rata premium less any claims that have been paid or less the cost of repairs made on Your behalf.
GUARANTY is deleted and replaced with the following: This is not an insurance policy, it is a Service Contract.
The following disclosure statement is added to this Service Contract: The rates charged to You for this Service Contract are not subject to regulation by the Florida Office of Insurance Regulation.
Georgia: WHAT IS NOT COVERED (GENERAL EXCLUSIONS) is amended to include: Only unauthorized product repairs, modifications or alterations performed after the effective date of the Service Contract are excluded.
CANCELLATION is amended as follows: The Provider may not cancel this Service Contract except for fraud by You, material misrepresentation by You, or nonpayment by You. Notice of such cancellation will be in writing and given at least thirty (30) days prior to cancellation. If You cancel this Service Contract within thirty (30) days of the purchase of this Service Contract and have not incurred any claims, You will receive a one hundred percent (100%) refund of the Service Contract purchase price paid by You. If such request is made after thirty (30) days of the purchase date of this Service Contract, You will receive a pro-rata refund of the Service Contract purchase price paid by You, less any claims that have been paid or less the cost of repairs made on Your behalf, and less an administrative fee not to exceed ten percent (10%) of the pro-rate refund amount or twenty-five dollars ($25.00); whichever is less.
The following disclosure statement is added to this Service Contract: This Service Contract will be interpreted and enforced according to the laws of the state of Georgia.
Hawaii: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
Illinois: The following disclosure statement is added to this Service Contract: Covered items must be in place and in good operating condition on the effective date of coverage and become inoperative due to normal wear and tear after the effective date of this Service Contract. This Service Contract does cover failures resulting from normal wear and tear.
Indiana: The following disclosure statements are added to this Service Contract: Your proof of payment to the Retailer for this Service Contract shall be considered proof of payment to the insurance company which guarantees Our obligations to You. This Service Contract is not insurance and is not subject to Indiana insurance law.
Maine: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
Maryland: CANCELLATION is amended as follows: No cancellation fee shall apply. If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
Massachusetts: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
Minnesota: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
Missouri: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract. If Your cancellation request is made more than thirty (30) days from the date of purchase, You will receive a pro-rata refund of the Service Contract purchase price. No cancellation fee will apply. In no event will claims paid be deducted from any refund.
Nevada: The following disclosure statement is added to this Service Contract: If You are not satisfied with the manner in which We are handling your claim, You may contact the Nevada Insurance Commissioner toll-free at (888)-872-3234.
CANCELLATION is amended as follows: Any reference to Administrative Fee is deleted and replaced with the term Cancellation Fee. If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not processed within forty-five (45) days, a penalty of ten percent (10%) of the Service Contract price will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract. The Provider of this Service Contract may cancel this Service Contract within seventy (70) days from the date of purchase for any reason. After seventy (70) days, the Provider may only cancel this Service Contract for non-payment by You, fraud or material misrepresentation by You in obtaining the Contract, or in presenting a Claim, or a substantial breach of duties by You relating to the Covered Product or its use if it occurred after the effective date of the Contract and it substantially and materially increased the service required under the Contract. If the Provider cancels Your Service Contract You will be entitled to a pro-rata refund of the unearned Service Contract fee, no cancellation fee will be deducted. If Your Service Contract was financed, the outstanding balance will be deducted from any refund. In no event will claims be deducted from any refund.
OBTAINING SERVICE is amended to include: This Contract will not cover any unauthorized or non-manufacturer recommended modifications to Your Product, or any damages arising from such unauthorized or non-manufacturer recommended modifications. However, if Your Product is modified in a manner that is not recommended by the manufacturer of Your Product, this Contract will continue to provide any applicable Coverage that is not related to the unauthorized or non-manufacturer recommended modification or any damages arising there from, unless such Coverage is otherwise excluded by the terms of this Contract.
New Hampshire: The following disclosure statement is added to this Service Contract: In the event You do not receive satisfaction under this Service Contract, You may contact the New Hampshire Insurance Department at, 21 South Fruit Street, Suite 14, Concord, NH 03301, 603-271-2261.
New Jersey: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid.
New Mexico: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within sixty (60) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract. The Provider of this Service Contract may cancel this Service Contract within seventy (70) days from the date of purchase for any reason. After seventy (70) days, the Provider may only cancel this Service Contract for: Non-payment, discovery of fraud or material misrepresentation by You in obtaining the Contract or in presenting a Claim, or discovery of either of the following: an act of omission, or violation of any condition of the Contract if it occurred after the effective date of the Contract.
New York: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within thirty (30) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
North Carolina: CANCELLATION is amended as follows: Any cancellation fee shall not exceed the lesser of ten percent (10%) of the pro rata refund amount or twenty-five ($25.00) dollars. We may cancel this Service Contract only for non-payment of the purchase price of the Service Contract or a direct violation of the Service Contract by You.
Oklahoma: The following disclosure statement is added to this Service Contract: The Service Warranty Association is Northcoast Warranty Services, Inc., Oklahoma Identification # 44200963. This is not an insurance contract. Coverage afforded under this service warranty is not guaranteed by the Oklahoma Insurance Guaranty Association.
CANCELLATION is deleted in its entirety and replaced with the following: If You cancel this service warranty within the first thirty (30) days and no claim has been authorized or paid within the first thirty (30) days, We will refund the entire service warranty contract purchase price. If You cancel this service warranty after the first thirty (30) days, or have made a claim within the first thirty (30) days, return of the provider fee shall be based upon ninety percent (90%) of the unearned pro-rata provider fee less the actual cost of any service provided under the service warranty contract. If We cancel this service warranty, return of the provider fee shall be based upon one hundred percent (100%) of unearned pro-rata provider fee less the actual cost of any service provided under the service warranty contract.
Oregon: OBTAINING SERVICE is amended as follows: If You need to file a claim under this Service Contract, You must contact the Administrator at 1-833-CAREPAK (1-833-227-3725) to obtain a repair authorization number prior to having any repairs made to Your Product. If You reasonably determine that You have a Covered Failure when the Administrator's office is closed and You choose to have Your Product repaired, You are responsible for paying for the repair. You must then call the Administrator during the next available regular business hours, or as soon as reasonably possible, so that the Administrator may determine whether there was a Covered Failure. Failure to call in and report the claim may result in non-payment. If the Administrator determines that there was a Covered Failure, then We will pay You in accordance with the terms and conditions of this Contract.
The following disclosure statement is added to this Service Contract: If the purchase of this Contract was financed, any outstanding balance due to the finance company will be deducted from any due refund and paid to the finance company instead of You. The refund amount paid to the finance company may be less than the Contract purchase price financed if claims have been paid by Us.
South Carolina: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract.
The following disclosure statement is added to this Service Contract: If You have any questions regarding this Service Contract, or a complaint against the Obligor, You may contact the South Carolina Department of Insurance at 1201 Main Street, Suite 1000, Columbia, South Carolina 29201, (803) 737-6160.
Texas: The definition of Administrator is amended to add the following: Canon, USA, Inc. Service Contract Administrator No. 330.
The following disclosure statement is added to this Service Contract: If You have any questions regarding the regulation of the Service Contract Provider or a complaint against the Obligor, You may contact the Texas Department of Licensing & Regulation, 920 Colorado, P.O. Box 12157, Austin, Texas 78711, (800) 803-9202.
CANCELLATION is amended as follows: You may return this Service Contract within thirty (30) days of the date of purchase of this Service Contract. If this Service Contract is cancelled within the first thirty (30) days, We will refund the entire Service Contract charge, less claims paid. If this Service Contract is cancelled after the first thirty (30) days, You will receive a pro-rata refund less a twenty-five dollar ($25) cancellation fee and less claims paid. A ten percent (10%) penalty per month will be added to a refund that is not made within forty-five (45) days of Your cancellation request to the provider. You may apply for reimbursement directly to the insurer if a refund or credit is not paid before the 46th day after the date on which the Service Contract is canceled. These provisions apply only to the original purchaser of the Service Contract. If We cancel this Service Contract, We shall mail a written notice to You at the last known address held by Us before the fifth day preceding the effective date of cancellation. The notice will state the effective date and the reason for the cancellation. However, prior notice is not required if the reason for cancellation is nonpayment of the provider fee, fraud or a material misrepresentation by the Service Contract Holder to the provider or the provider's administrator, or a substantial breach of duties by the Service Contract Holder relating to the covered product or its use. If We cancel this Service Contract, no cancellation fee shall apply.
Utah: The following disclosure statement is added to this Service Contract: Coverage afforded under this Service Contract is not guaranteed by the Property and Casualty Guaranty Association.
CANCELLATION is amended as follows: We may only cancel this Service Contract for material misrepresentation, nonpayment by You or a substantial breach of duties by You relating to the covered property or its use. If We cancel this Service Contract for non-payment, such cancellation will be effective ten (10) days after the mailing of notice. If We cancel this Service Contract for material misrepresentation of a substantial breach of duties, such cancellation will be effective thirty (30) days after mailing of notice. This Service Contract or warranty is subject to limited regulation by the Utah Insurance Department. To file a complaint, contact the Utah Insurance Department. HOW TO FILE A CLAIM section is amended as follows: If You need to file a claim under this Service Contract, You must contact the Administrator at 1-833-CAREPAK (1-833-227-3725) to obtain a repair authorization number prior to having any repairs made to Your Product. If a repair or replacement occurs when the Administrator's office is closed, You may follow these claims procedure without prior authorization. However, You must call the Administrator as soon as reasonably possible. Failure to call in and report the claim will result in non-payment.
Virginia: The following disclosure statement is added to this Service Contract: If any promise made in the Contract has been denied or has not been honored within sixty (60) days after your request, you may contact the Virginia Department of Agriculture and Consumer Services, Office of Charitable and Regulatory Programs at http://www.vdacs.virginia.gov/food-extended-service-contract-providers.shtml to file a complaint.
Washington: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within thirty (30) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract. In the event We cancel this Service Contract, We will mail a written notice to You at Your last known address at least twenty-one (21) days prior to cancellation with the effective date for the cancellation and the reason for cancellation.
The following disclosure statement is added to this Service Contract: What is Not Covered from coverage are limited to those expressly stated under the "WHAT IS NOT COVERED (GENERAL EXCLUSIONS)” section above.
GUARANTY is amended to include: You may file a claim directly with Wesco Insurance Company at any time, at 59 Maiden Lane, 43rd Floor, New York, NY 10038 or 866-505-4048.
The following disclosure statement is added to this Service Contract: The State of Washington is the jurisdiction for any civil action in connection with this Contract.
Wisconsin: The following disclosure statement is added to this Service Contract: THIS CONTRACT IS SUBJECT TO LIMITED REGULATION BY THE OFFICE OF THE COMMISSIONER OF INSURANCE.
CANCELLATION is deleted and replaced with the following: You may cancel this Service Contract at any time. We may only cancel this Service Contract for material misrepresentation by You, nonpayment by You or a substantial breach of duties by You relating to the covered property or its use. If We cancel this Service Contract, We shall mail a written notice to You at Your last known address at least five (5) days prior to cancellation. The notice shall state the effective date of the cancellation and the reason for the cancellation. If We cancel for any reason other than nonpayment, then We shall refund one hundred percent (100%) of the unearned pro rata provider fee, less any claims paid and less a cancellation fee not to exceed ten percent (10%) of the Contract purchase price paid.
If this Service Contract is canceled within thirty (30) days of the date of purchase and no claims have been paid, the Administrator shall return one hundred percent (100%) of the purchase price paid and the Service Contract shall be void. The right to void the Service Contract applies only to the original purchaser of the Service Contract. If the refund is not paid or credited within forty-five (45) days after return of the Service Contract to Us, We shall pay a ten percent (10%) per month penalty of the refund amount outstanding, which We shall add to the amount of the refund.
For service Contracts canceled subsequent to the period stated in the preceding paragraph or if a claim has been made under this service Contract within such period, We shall refund one hundred percent (100%) of the unearned pro rata provider fee, less any claims paid and less a cancellation fee not to exceed ten percent (10%) of the Service Contract purchase price paid.
If You request cancellation due to a total loss of Your Product which is not covered by a replacement under the terms of Your Service Contract, the Administrator shall return one hundred percent (100%) of the unearned pro-rata Service Contract purchase price paid, less claims paid. Unauthorized repairs may not be covered.
GUARANTY is amended to include: Our obligations under this Service Contract are insured under a service contract reimbursement insurance policy. Should We fail to pa any claim or fail to replace the Product covered under this Service Contract within sixty (60) days after You provide proof of loss or, in the event You cancel this Service Contract and We fail to refund the unearned portion of the Service Contract Purchase Price or, if the Provider becomes insolvent or otherwise financially impaired, You are entitled to make a direct claim against the insurer, Wesco Insurance Company, at 1-866-505-4048 or 59 Maiden Lane, 43rd Floor, New York, NY 10038 for reimbursement, payment or provision of this Service Contract.
Wyoming: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract. If We cancel this Service Contract, We shall mail a written notice to You at Your last known address at least ten (10) days prior to cancellation. The notice shall state the effective date of the cancellation and the reason for the cancellation. Prior notice is not required if the reason for cancellation is nonpayment of the provider fee, a material misrepresentation by You to the provider or a substantial breach of duties by You relating to the covered product or its use.
For questions about this Service Contract or to obtain a copy of these terms & conditions, log onto the Administrator's website at www.usa.canon.com/carepak-plus or call 1-833-CAREPAK.
DEFINITIONS
"Accidental Damage From Handling", "ADH": refers to accidental damage from handling, meaning such damage resulting from unintentionally dropping the Covered Product or liquid spillage. "Administrator": the entity responsible for administrating benefits to You in accordance with the Service Contract provisions, conditions and exclusions, who is Canon U.S.A., Inc., One Canon Park, Melville, NY 11747-3036. "Claim": a demand for payment in accordance with this Contract sent by You to the Administrator or Us. "Contract Purchase Receipt": the receipt document (paper or e-mail) provided to You by the Administrator or Retailer as proof of Your Contract purchase that indicates the Term, Deductible, and date in which the Service Contract was purchased, which must be attached to and forms part of this Service Contract. "Failure": the mechanical or electrical breakdown of Your Product to perform its intended function including defects in materials or workmanship and normal wear and tear; occurring during normal use of the Product. "Original Purchase Price": the amount paid by You for the covered Product(s); excluding any applicable taxes and/or fees, as evidenced on Your sales/Canon purchase documentation. "Power Surge": damages to the Product resulting from an oversupply of voltage to Your Product while properly connected to a surge protector approved by the Underwriter's Laboratory Inc. (UL), but not including damages resulting from the improper installation or improper connection of the Product to a power source. "Product(s)": the item(s) which You purchased and is covered by this Service Contract. "Retailer": the seller that has been authorized by Us to sell this Service Contract to You. "Service Contract", "Contract": this document detailing all coverage provisions, conditions, exclusions and limitations for this Contract that has been provided to You upon purchase completion from Our Retailer. "Term": the period of time shown on Your Contract Purchase Receipt which represents the duration in which the provisions of this Service Contract are valid. "We", "Us", "Our," "Obligor," "Provider": the party or parties obligated to provide service under this Service Contract as the service contract provider, Northcoast Warranty Services, Inc., 800 Superior Avenue E., 21st Floor, Cleveland, OH 44114; (Florida Residents: this Service Contract is an agreement between You and Technology Insurance Company, Inc., License No. 03605, 59 Maiden Lane, 43rd Floor, New York, NY 10038). "You", "Your": the purchaser/owner of the Product(s) covered by this Service Contract.
PRODUCT ELIGIBILITY
This Service Contract covers Products purchased as new or factory-refurbished and manufactured for use in the United States, which, at the time of Product purchase, included a Canon USA, Inc. limited warranty valid in the United States providing minimum coverage of one (1) year parts and labor. The original Service Contract must be purchased within ninety (90) days of purchase of Your Product. Purchase of this Service Contract is not required to purchase the Product or to obtain financing for the Product. Coverage outlined in this Service Contract only applies to Products not covered under any other insurance warranty, guarantee and/or service contract providing the same benefits as outlined herein. Products must be purchased from a Retailer, be solely intended for professional, educational, or institutional use, and not intended for personal or industrial use, resale, or rental. Accessories, external peripheral devices and/or add-on options are not covered under this Service Contract.
RENEWAL
YOUR RESPONSIBILITY
If provided to You, a replacement product may be a new or refurbished product of equal or similar features and functionality, but not necessarily the same model. Please refer to the LIMIT OF LIABILITY section for full details regarding Product replacements. IMPORTANT: COVERAGE DESCRIBED IN THIS SERVICE CONTRACT WILL NOT REPLACE OR PROVIDE DUPLICATIVE BENEFITS DURING ANY ACTIVE MANUFACTURER'S LIMITED WARRANTY PERIOD. DURING SUCH PERIOD, ALL PARTS, LABOR, ON-SITE SERVICE AND/OR SHIPPING COSTS COVERED BY THAT LIMITED WARRANTY ARE THE SOLE RESPONSIBILITY OF THE MANUFACTURER (WHO IS CANON U.S.A., INC.) PARTS USED TO REPAIR OR REPLACE YOUR PRODUCT MAY BE NEW, USED, REFURBISHED, OR NON-ORIGINAL MANUFACTURER PARTS THAT PERFORM TO THE FACTORY SPECIFICATIONS OF YOUR PRODUCT. Where applicable, technological advances may result in a replacement product with a lower selling price than Your original Product, and no refunds will be made based on the replacement product cost difference.
This Service Contract is only valid for repairs or replacement within the contiguous United States, plus Alaska and Hawaii.
DEDUCTIBLE
OBTAINING SERVICE
THIS SERVICE CONTRACT MAY NOT PROVIDE ANY COVERAGE IF YOU MAKE UNAUTHORIZED REPAIRS. Upon validation of CarePAK coverage, Canon will make commercially reasonable efforts to service and ship Your repair or replacement within five (5) business days after you receive the No Charge Repair Acknowledgement correspondence via email, and subject to availability of parts or replacement Product. Note that business days are Monday through Friday, 9am-5pm, and exclude Canon observed holidays, and any periods where unavailability is due to circumstances beyond Canon's control.
- You can also arrange for service under this Contract online by visiting the Administrator's "Request Product Repair Page" at www.usa.canon.com/support.
Please do not take or return Your Product to the Retailer or ship Your Product anywhere unless the Administrator instructs You to do so. If You are instructed by the Administrator to transport or ship Your Product, a prepaid shipping label will be provided. Be sure to include the following with Your Product:
LIMIT OF LIABILITY
NEITHER WE NOR THE ADMINISTRATOR NOR THE RETAILER SHALL BE LIABLE FOR ANY INCIDENTAL OR CONSEQUENTIAL DAMAGES; INCLUDING BUT NOT LIMITED TO: PROPERTY DAMAGE, LOST TIME OR LOST DATA RESULTING FROM THE FAILURE OF ANY PRODUCT OR EQUIPMENT, FROM DELAYS IN SERVICE OR THE INABILITY TO RENDER SERVICE OR RESULTING FROM THE UNAVAILABILITY OF REPAIR PARTS/COMPONENTS. NEITHER WE NOR THE ADMINISTRATOR NOR THE RETAILER SHALL BE LIABLE FOR ANY AND ALL PRE-EXISTING CONDITIONS KNOWN TO YOU; INCLUDING ANY INHERENT PRODUCT FLAWS.
- LOSS OF OR DAMAGE TO THE COVERED PRODUCT RESULTING FROM: ABUSE (MEANING THE INTENTIONAL TREATMENT OF THE COVERED PRODUCT IN A HARMFUL, INJURIOUS, MALICIOUS OR OFFENSIVE MANNER WHICH RESULTS IN ITS DAMAGE AND/OR FAILURE, INCLUDING BUT NOT LIMITED TO LOSS OR DAMAGE RESULTING FROM STUNTS OR SPECIAL EFFECTS EMPLOYED IN FILM, TELEVISION, OR THEATRE PRODUCTIONS, PRACTICAL, MECHANICAL, OR VEHICULAR STUNTS, AND/OR EXPLOSIONS OR OTHER PYROTECHNICS).
- LOSS OF OR DAMAGE TO THE COVERED PRODUCT RESULTING FROM: MISHANDLING, IMPROPER PACKAGING BY YOU, ALTERATION, COLLISION WITH OR OF ANOTHER OBJECT, ELECTRICAL CURRENT FLUCTUATIONS (OTHER THAN THAT WHICH IS EXPLICITLY DEFINED AS POWER SURGE IN THE DEFINITIONS SECTION), FAILURE TO FOLLOW OPERATING, MAINTENANCE OR ENVIRONMENTAL INSTRUCTIONS PRESCRIBED IN THE COVERED PRODUCT'S MANUFACTURER OWNER'S MANUAL OR SERVICE PERFORMED BY ANYONE OTHER THAN A SERVICER AUTHORIZED BY CANON.
- SERVICE, REPAIR OR REPLACEMENT OF ANY COVERS, LIDS OR TRIM PARTS, OR OF ANY CONSUMABLE ITEMS.
- SERVICE, REPAIR OR REPLACEMENT OF A COVERED PRODUCT OUTSIDE OF THE CONTIGUOUS UNITED STATES OF AMERICA, ALASKA, OR HAWAII.
YOU ARE RESPONSIBLE FOR BACKING UP ALL SOFTWARE AND DATA ON A REGULAR BASIS AND PRIOR TO COMMENCEMENT OF ANY REPAIR. THIS SERVICE CONTRACT DOES NOT COVER RESTORATION OF SOFTWARE OR DATA, OR DATA RETRIEVAL TO/FROM YOUR COVERED PRODUCT, AND WE ARE UNABLE TO TRANSFER SUCH SOFTWARE OR DATA TO ANY REPLACEMENT DEVICE THAT MAY BE PROVIDED TO YOU. IN NO EVENT SHALL WE BE RESPONSIBLE FOR THE RESTORATION OF SOFTWARE OR DATA, OR FOR RETRIEVING DATA FROM YOUR PRODUCT. IF YOUR CAREPAK PRO COVERAGE INCLUDES CANON IMAGE RECOVERY FULFILLED BY SEAGATE® RESCUE SERVICE ("IMAGE RECOVERY"), PLEASE NOTE THAT IMAGE RECOVERY TERMS AND CONDITIONS ARE SEPARATE AND INDEPENDENT FROM CAREPAK PRO, AND CAN BE FOUND AT USA.CANON.COM/CAREPAK-PRO.
CANCELLATION
We may only cancel this Service Contract for the following reasons:- 1) non-payment of the Service Contract fee by You;
NOTICE: These CANCELLATION provisions apply to the original purchaser of this Service Contract only. If the purchase of this Contract was financed, any outstanding balance due to the finance company will be deducted from any due refund and paid to the finance company instead of the Holder.
GUARANTY
TRANSFERABILITY
ENTIRE AGREEMENT
Connecticut: The following disclosure statement is added to this Service Contract: In the event of a dispute with Administrator, You may contact The State of Connecticut, Insurance Department, P.O. Box 816, Hartford, CT 06142-0816, Attn: Consumer Affairs. The written complaint must contain a description of the dispute, the purchase or lease price of the Product, the cost of repair of the Product and a copy of the warranty Service Contract.
GUARANTY is amended as follows: If We fail to pay or to deliver service on a claim within sixty (60) days after proof of loss has been filed, or in the event You cancel this Service Agreement and We fail to issue any applicable refund within sixty (60) days after cancellation, You may file a claim against the insurer, Wesco Insurance Company at 59 Maiden Lane, 43rd Floor, New York, NY 10038, by calling 1-866-505-4048.
CANCELLATION is amended as follows: This Service Contract may be cancelled by the Service Contract Holder if the Device covered under this Service Contract is returned, sold, lost, stolen or destroyed.
YOUR RESPONSIBILITY is amended to include: It is Your responsibility of the to follow the manufacturer's specifications for the use and care/maintenance of the covered Product.
Georgia: CANCELLATION is amended as follows: Any cancellation fee shall not exceed ten percent (10%) of the pro rata premium refund due or twenty-five dollars ($25.00) whichever is less. In no event will any claims incurred or paid be deducted from any refund. The Provider may only cancel this Service Contract for fraud by You, material misrepresentation by You, or nonpayment by You. If We cancel this Service Contract, no cancellation fee shall apply and We shall provide written notice to You at the last known address held by Us at least thirty (30) days preceding the effective date of cancellation. The notice will state the effective date and the reason for the cancellation. The lienholder may only cancel this Contract for non-payment if they hold a power of attorney.
WHAT IS NOT COVERED (GENERAL EXCLUSIONS) is amended to include: Only unauthorized product repairs, modifications or alterations performed after the effective date of the Service Contract are excluded. PRE-EXISTING CONDITIONS – The "Pre-Existing Condition:" definition is deleted and replaced with: Conditions that were caused by You or known by You prior to purchasing this Service Contract. The following disclosure statement is added to this Service Contract: This Service Contract will be interpreted and enforced according to the laws of the state of Georgia.
Hawaii: CANCELLATION is amended as follows: If You request cancellation of this Service Contract within thirty (30) days of the purchase date of the Service Contract and the refund is not paid or credited within forty-five (45) days after Your cancellation request to Us, a ten percent (10%) penalty will be added to the refund for every thirty (30) days the refund is not paid. This provision applies only to the original purchaser of the Service Contract. YOUR RESPONSIBILITY is amended to include: It is Your responsibility to follow the manufacturer's specifications for the use and care/maintenance of the covered Product.
Illinois: The following disclosure statement is added to this Service Contract: Covered items must be in place and in good operating condition on the effective date of coverage and become inoperative due to defects in materials or workmanship, or normal wear and tear, after the effective date of this Service Contract.
Indiana: The following disclosure statement is added to this Service Contract: This Contract is not insurance and is not subject to Indiana insurance law.
GUARANTY is amended as follows: Your proof of payment to the Retailer for this Service Contract shall be considered proof of payment to the insurance company which guarantees Our obligations to You. If We fail to perform or make payment due under this Contract within sixty (60) days after You request the performance or payment, You may request the performance or payment directly from the insurer that issued the provider's Service Contract reimbursement policy, including any applicable requirement under the Contract that the provider refund any part of the cost of the Contract upon cancellation of the Contract.
WHAT IS NOT COVERED (GENERAL EXCLUSIONS) is amended as follows: The "Pre-Existing Condition" definition is deleted and replaced with: conditions that were caused by You or known by You prior to purchasing this Service Contract.
Utah: The following disclosure statement is added to this Service Contract: Full payment will be received for the purchase price of this Service Contract at the time of purchase.
The following disclosure statement is added to this Service Contract: This Service Contract or warranty is subject to limited regulation by the Utah Insurance Department. To file a complaint, contact the Utah Insurance Department. Coverage afforded under this Service Contract is not guaranteed by the Property and Casualty Guaranty Association.
GUARANTY is amended as follows: Should the provider fail to pay or provide service on any claim within sixty (60) days after proof of loss has been filed, the contract holder is entitled to make a claim directly against the Insurance Company.
CANCELLATION is amended as follows: We may only cancel this Service Contract for material misrepresentation by You, nonpayment by You or a substantial breach of contractual duties by You relating to the covered property or its use. If We cancel this Service Contract for material misrepresentation or a substantial breach of contractual duties, such cancellation will be effective thirty (30) days after mailing of notice. If We cancel this Service Contract for non-payment, such cancellation will be effective fifteen (15) days after the mailing of notice. The notice will state the effective date and the reason for the cancellation.
OBTAINING SERVICE is amended as follows: If You need to file a claim under this Service Contract, You must contact the Administrator at 1-833-CAREPAK (1-833-227-3725) to obtain a repair authorization number prior to having any repairs made to Your Product If You reasonably determine that You have a Covered Failure when the Administrator's office is closed and You choose to have Your Product repaired, You are responsible for paying for the repair. You must then call the Administrator during the next available regular business hours, or as soon as reasonably possible, so that the Administrator may determine whether there was a Covered Failure. Failure to call in and report the claim will result in non-payment. If the Administrator determines that there was a Covered Failure, then We will pay You in accordance with the terms and conditions of this Contract.
Virginia: If any promise made in the Contract has been denied or has not been honored within sixty (60) days after your request, you may contact the Virginia Department of Agriculture and Consumer Services, Office of Charitable and Regulatory Programs at http://www.vdacs.virginia.gov/food-extended-service-contract-providers.shtml to file a complaint.
For questions about this Service Contract or to obtain a copy of these terms & conditions, log onto the Administrator's website at www.usa.canon.com/carepak-pro or call 1-833-CAREPAK.
One Canon Park
1-[800-OK-Canon]
www.usa.canon.com/support Terms and Conditions for All U.S. States Besides Oregon
- The terms and conditions below apply to all U.S. states with the exception of Oregon. Please click here to review the separate terms and conditions for the state of Oregon.
THIS IS NOT A CONTRACT OF INSURANCE.
- Subject to the limitations set forth in "Service Limitations" below, CUSA agrees to repair or replace, without charge, any defective part in your Covered Product with a new, rebuilt, or different part during the Term of the eCarePAK, provided such part is the same as, or functionally comparable to, the defective part removed. Any parts that are replaced will become the property of CUSA. Replacement of parts will not extend the Term of the eCarePAK. Likewise, if CUSA should replace the Covered Product, the original Covered Product will become the property of CUSA. Coverage under the eCarePAK will automatically transfer to the replacement product but will not extend the Term.
- The eCarePAK is valid only for service of a Covered Product purchased and used in the United States. The eCarePAK is not transferable to another Covered Product except as provided in paragraph 1 above.
- For Oregon and Montana Residents only: This Extended Protection (Service) Plan is insured by a contractual liability insurance policy issued to Canon U.S.A., Inc. by Sompo Japan Insurance Company of America (“Sompo Japan”), 11405 N. Community House, Suite 600, Charlotte, NC 28277, 704-759-2200.
- For Oregon residents only: Should CUSA fail to perform under this eCarePAK within sixty (60) days, you may contact Sompo Japan for recourse
- For Virginia residents only: If any promise made in the Contract has been denied or has not been honored within 60 days after your request, you may contact the Virginia Department of Agriculture and Consumer Services, Office of Charitable and Regulatory Programs at http://www.vdacs.virginia.gov/food-extended-service-contract-providers.shtml to file a complaint.
1-800-423-2366
1-800-OK Canon
Contact your Dealer
- Advanced Exchange Program: CUSA may elect to service your Covered Product through its Advanced Exchange Program. Under the Advanced Exchange Program, a defective Covered Product will be exchanged for a comparable refurbished Covered Product on an expedited basis, usually by the next business day (or longer if your ship-to address is determined by Canon to be a rural or remote location). You will be required to provide a ship-to location (street address only) for the replacement product. You may be required to sign a form to guarantee the return of the defective unit and provide a valid credit card authorization. If you do not return your defective Covered Product to CUSA by the date and in the manner specified by CUSA, CUSA may cancel your eCarePAK and invoice you for the full replacement cost of a new Covered Product, or charge your credit card for this cost.
- Service Provider: In the event that CUSA's technical troubleshooting cannot resolve your problem, CUSA may elect to send a Service Provider to your location in an expedited manner to facilitate the repair of your Covered Product.
- ASF Program (Carry In/): Under CUSA's ASF Program, the defective Covered Product is repaired by an ASF and then returned to you. The CUSA representative will direct you how to obtain the name and phone number of the ASF nearest to you. You must contact the ASF to schedule the repair. DO NOT INCLUDE ANY OTHER ITEMS WITH THE COVERED PRODUCT. Covered Products will be repaired and returned to you without charge by the ASF.
- Loss of or damage to the Covered Product due to abuse, mishandling, improper packaging by you, neglect, alteration, electric current fluctuation or accident; improper use, including failure to follow operating, maintenance or environmental instructions prescribed in the operator's manual; use of the Covered Product with non-compatible computers, peripheral equipment or software; or repair performed by other than a service representative qualified by CUSA.
- Service necessitated by the use of parts or supplies (other than those distributed by CUSA) which damage the Covered Product or which cause abnormally frequent service calls or service problems.
- Service of the Covered Product if it has been modified or altered in any way (including any alteration or removal of serial numbers or identification marks).
- Service, repair or replacement of any covers, lids, or trim parts, or any consumable items, including without limitation, toner and/or ink cartridges, ink tanks and printheads.
- Preventative maintenance and or inspections.
- Service, repair or replacement of accessories or options for the Covered Product, or of any equipment or software not distributed by Canon which may be used with, or be connected to, the Covered Product.
- Service, repair, or replacement of any Covered Product purchased or used outside of the United States.
- Place the printer on its stand with your assistance.
- Load media on to the printer.
- Fill ink tanks.
- Produce a test print to ensure that the printer is installed and operating within specifications.
- Upon your request, connect the printer to a network (i.e. Ethernet connection). You must have a live Ethernet connection to your network, as well as an Ethernet cable, at the time of your request. If not, an additional visit to connect the printer to your network will need to be scheduled when both of these requirements have been met. This additional visit will incur a fee.
- Place the imagePROGRAF printer on its stand with your assistance.
- Load media on to imagePROGRAF printer.
- Produce a test print to ensure that the imagePROGRAF printer is installed and operating within specifications.
- Place the Colortrac scanner on its stand with your assistance.
- Install, at a basic level, the computer and monitor.
- Connect the Colortrac scanner to the imagePROGRAF printer and produce a test scan to ensure that the imagePROGRAF printer and Colortrac scanner are connected and operating within specifications.
- Place the scanner in its designated location with your assistance.
- Install replacement rollers if they are not already factory installed.
- Install additional accessories (if applicable).
- Connect scanner and perform a test scan to ensure that scanner is operating within specifications.
- Installation technicians may, in their sole discretion, refuse to install Covered Products that are incompatible, are, or appear to be, damaged, are inappropriate for installation, exhibit signs of excessive wear or are deemed unsafe. Covered Products which are not new, or are damaged, will be documented before the installation begins. You may be subject to additional charges should the installation technician conclude that the proposed installation is unsafe and therefore cannot be completed.
- A pre-existing power outlet(s) must be accessible in order to install your Covered Product.
- Installation services are only available in the 50 United States and the District of Columbia. Extra charges may apply in the event special travel is required to reach the installation site.
- Extra charges may apply in the event additional work is necessary to complete the installation, including, but not limited to, carpentry, electrical work, floor covering modifications, moving of furniture, or additional wire, parts and/or accessories.
- Carefully review your installation needs, your installation plans and the accessories and hardware you have and/or need to facilitate and complete the installation.
- CUSA and/or Canon authorized service provider will contact you to schedule your installation appointment. Cancellations or rescheduling of scheduled installation appointments must be made no later than twenty four (24) hours prior to your appointment to avoid additional charges. Cancellation requests are not valid until confirmed by CUSA and or Canon Authorized service provider.
- You must ensure that the Covered Product(s) to be installed, the installation site, and the hardware and accessories required to facilitate and complete your installation, are prepared and ready prior to the arrival of the installation technician. You may be subject to an additional charge for failure to prepare the Covered Product, the installation site, or the required hardware and accessories prior to the arrival of the installation technician.
- You must move or rearrange furniture to provide accessibility and a safe, adequate work space for the installation technician.
- You must provide a sufficient amount of power, power sources, power cords and, if applicable, surge protectors that are readily available to the installation technician and/or safely accessible to the installation site. The installation technicians will not move or install AC power sources or feeds of television signals from cable, satellite or other sources.
- You must dispose of the packaging materials and trash following the installation. Although the installation technicians will clean up the work site, it is your responsibility to arrange for the final disposal of any packaging materials or trash related to the installation.
- Training is only provided during the time of installation.
- Training on the general operation of the scanner component of the imagePROGRAF iPF MFP.
- Training on the Canon software and drivers included with the scanner.
- Training on scanner preparation, maintenance and errors on scanner.
- CUSA reserves the right to refuse or limit any Training Services if you fail to satisfy any minimum requirements for such Training Services as published or provided to you by CUSA prior to the start of such Training Services.
- CUSA reserves the right to refuse, limit, or cancel any Training Services if, in the opinion of CUSA, you display unreasonable behavior or are deemed by CUSA to be violent, abusive, or disruptive. In such cases, no refunds will be paid.
- Ownership of all copyright and other intellectual property rights in the training material supplied by CUSA, or its authorized service provider, including any documentation, data, technical information and know-how provided to you as part of the Training Services, remains vested in CUSA, its authorized service provider(s), or the owner of such materials, as applicable. All such information will be held by you in confidence and will not be disclosed or copied to third parties, without the express written permission of CUSA.
- Perform physical inspection on the internal, external and functionality of the scanner.
- Perform necessary cleaning routine of the interior and exterior body of the scanner.
- Install new user replaceable rollers.
- Document maintenance statistics.
- Perform test scans after preventative maintenance is complete and ensure that Scanner is operating within specifications.
- Only customers under warranty or eCarePAK coverage can purchase or receive Preventative Maintenance.
- Scheduling a Preventative Maintenance is the sole responsibility of the customer and will expire upon expiration of the warranty or eCarePAK.
- CUSA will provide Preventative Maintenance only during normal business hours of operation, Monday through Friday, 9AM-5PM local time excluding holidays.
- CUSA will schedule the Preventative Maintenance within five business days of when the customer contacts CUSA's Technical support Center.
- If the unit is not in working condition, the Preventative Maintenance will be delayed and a break/fix call will be opened.
- The terms and conditions below apply to Oregon only. Please click here to review the separate terms and conditions for all U.S. states besides Oregon.
- For Oregon and Montana Residents only: This Extended Protection (Service) Plan is insured by a contractual liability insurance policy issued to Canon U.S.A., Inc. by Sompo Japan Insurance Company of America ("Sompo Japan"), 11405 N. Community House, Suite 600, Charlotte, NC 28277, 704-759-2200.
- For Oregon residents only: Should CUSA fail to perform under this eCarePAK within sixty (60) days, you may contact Sompo Japan for recourse.
1-800-423-2366
1-800-OK Canon
Contact your Dealer
- 3. ASF Program (Carry In/): Under CUSA's ASF Program, the defective Covered Product is repaired by an ASF and then returned to you. The CUSA representative will direct you how to obtain the name and phone number of the ASF nearest to you. You must contact the ASF to schedule the repair. DO NOT INCLUDE ANY OTHER ITEMS WITH THE COVERED PRODUCT. Covered Products will be repaired and returned to you without charge by the ASF.
- Fill ink tanks.
- Connect the Colortrac M40 scanner to the imagePROGRAF printer and produce a test scan to ensure that the imagePROGRAF printer and Colortrac M40 scanner and Colortrac scanner are connected and operating within specifications.
- Training on the SmartWorks MFP Software.
Product Disclaimer
- When using RF lenses that support coordinated control with camera in-body IS. Testing performed at a focal length of 150mm using the RF-S18-150mm F3.5-6.3 IS STM lens and the EOS R7 camera.
- Continuous shooting speed may be slower due to factors such as anti-flicker shooting, aperture value, or battery life.
- Not available when Dual Pixel RAW is enabled .
- Only when using lenses supporting up to 30 shots/sec.
- Only when a lens supporting 90% H x 100% W focusing area is attached and the camera is set to Whole-area AF, or when subjects are detected with AF area modes other than Whole-area AF. May not be possible to move AF points to the edge of the focusing area under select scene and subject conditions.
- Auto level not available when using electronic 1st curtain shutter mode.
- Video may stop due to battery level, card capacity, or internal temperature.
- For still images.
- Continuous shooting speed is slower with anti-flicker shooting.
- Not available when using electronic 1st curtain shutter mode.
- Manual focusing is also possible with the focus mode switch to [AF] depending on the settings of lens electronic MF and electronic full-time MF.
