FAXPHONE L190
FP L190
As low as $219.99 Regular Price $290.99
4 interest free payments of $55.00 with
klarna Pay Later
Paypal Pay Later
In Stock
  • Print up to 26 ppm
  • Up to 512 sheets of memory capacity
  • Duplex fax, print and copy
  • Super G3 Fax
Show more
Printer Overview
Designed for small offices where fax capability is a priority, the Canon FAXPHONE L190 balances speedy performance and minimal maintenance.
The FAXPHONE L190 has fax, print and copy functions, prints up to 26ppm and has a 1 year limited warranty.
GENUINE Products. Maximum Results.
Canon GENUINE ink and toner are engineered to achieve optimal performance with Canon printers. The exceptional design results in better operational success and end results, including higher yields, outstanding output and greater consistency, vibrancy, reliability and performance.
Photo of a desk with people at laptops exchanging printed papers.
Main Unit Spec
Printer Specifications
Printer Type
Monochrome Laser
Print Speed
Up to 16ppm (2-sided plain paper letter)Footnote1
Up to 26ppm (1-sided plain paper letter)Footnote1
First Print Time
6 seconds or less (letter)Footnote2
Printer Language
UFR II LT (Host-based)
Print Resolution
Up to 600 x 600 dpi
(1200 x 600 dpi quality)
Maximum Print Size
Up to Legal
Duplex Print
Yes
Print Modes
Watermark, Toner Saver, Page Composer
Print Memory
128 MB (Shared)
Copier Specifications
Copy Type
Monochrome Laser
Copy Speed
Up to 26 cpm (letter)
Duplex Copy Speed
Up to 16cpm (letter)
Copy Resolution
Up to 600 x 600 dpi
Original Type
Text, Text/Photo, Text/Photo+, Photo
Halftones
256 Levels
Warm-up Time
Approximately 13.5 seconds
First Copy Time
Approximately 8.7 secondsFootnote3
Recovery Time
Approximately 2 seconds
Maximum Number of Copies
99 copies
Duplex Copy/Bind Time
Yes / Book, Calendar
Reduction/Enlargement
25%, 50%, 64%, 78% 129%, 200%, 400%
Zoom
25 - 400% in 1% increments
Copy Size
Platen: Up to Letter
ADF: 5.5" x 5" to Legal
Copy Features
Collate
2 on 1
4 on 1
ID Card Copy
Copy Memory
128 MB (Shared)
Fax Specifications
Modem Speed
Up to 33.6 Kbps (Super G3)Footnote4
Fax Resolution
Up to 200 x 400 dpi (super fine)
Transmission Time
JBIG (approx. 3 seconds)
Memory Capacity
Up to 512 sheetsFootnote5
Speed Dials
40 one-touch speed dials
200 coded dials
Group Dialing
239 destinations
Sequential Broadcasting
250 destinations
Duplex Fax
Yes
Receive Modes
FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features
Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial
Activity Reports
Activity Result & Activity Management
pC Fax
Sending only
Fax Forwarding
Yes
Paper Handling Specifications
Standard Paper Source(s)
250-sheet cassetteFootnote6
Document Feeder
50-sheet duplexFootnote6
Paper Output
100 sheets (face down)
Paper Weight
16-43 lb. bond (cassette)
Media Sizes
Letter, Legal, A4, A5, B5, B6, Statement, Executive
Media Types
Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope
Envelope Capacity
20 envelopes
Envelope Types
Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s)
USB Device 2.0 Hi-SpeedFootnote7
OS Compatibility
Windows® 8, Windows 7, Windows Vista®, Windows XP, Mac OS X 10.5.8 and up
Cable Included
Power Cord, Phone Cable (USB not included)
Environmental Specifications
Power Consumption
Max: Approx. 1,110W
During Operation: Approx. 520W
Standby: Approx. 4.5W
Energy Saver: Approx. 1.3W
General Specifications
Dimensions
18.6" (W) x 17.5" (D) x 14.1" (H)
Unit Weight (without/with cartridge)
30.0 lbs. (w/o cartridge)
31.3 lbs. (w/cartridge)
Package Weight
Approx. 40.6 lbs.
Cartridge Type
Cartridge 128 (Yields approximately 2,100 pages)
Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display
5-row backlit LCD
Duty Cycle
Up to 10,000 pages per month
Languages
English, French, Spanish, Portuguese
Warranty
1 year limited exchange/carry-in warrantyFootnote8 (Extended warranty available)
Reviews
Brochures
File Name
FAXPHONE L190 Spec Sheet
Date
06.05.23
File Size
2 MB
FAXPHONE L190 Compatible Products
Paper
Paper
Product Disclaimer
  1. Copy/print speeds are measured based on internal testing using letter size paper copied/printed with 100% copy/print ratio to original on one-sided paper. Internal testing involved continuously copying/printing the same one page of content on plain paper (copy speed is tested by copying on the platen glass). Copy/print speeds may vary depending on paper type, paper size or paper feeding direction. The device may automatically pause or slow down in order to adjust printer condition such as controlling temperature of a certain unit or limiting impact to image quality during continuous copying/printing.
  2. May vary depending on the output environment.
  3. Letter size, after being restored from energy saver mode.
  4. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
  5. Based on ITU-T #1 Chart (standard mode).
  6. Based on 20 lb. bond paper.
  7. USB 2.0 Hi-Speed requires Windows® 7, Windows Vista®, Windows XP/2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v. 10.2 to 10.2.6 operating systems, the printer/scanner will operate at USB 1.1 specifications.
  8. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
