FPA-5510iX Stepper
FPA-5510iX steppers provide large-field device imaging
without stitching adjacent fields
FPA-5510iX steppers adopt a high-NA, 1/2 reduction projection lens to deliver 0.5 um resolution across a large 50 mm x 50 mm exposure field. The FPA-5510iX is suitable for products requiring large field exposure such as *MEMS devices and image sensors that can require a larger field than Front-End-Of-the-Line (FEOL) lithography exposure area (26mm x 33mm) and can avoid pattern **stitching that is disadvantageous from the viewpoint of image quality & productivity. The ability to expose large fields in a single exposure provides the FPA-5510iX with a big advantage.
*MEMS: "Micro Electro Mechanical Systems" or MEMS are devices with a micron level mechanical structures that integrate sensors, actuators and electronic circuits.
**Stitching exposure: A method of increasing exposure field
size by connecting two or more adjacent exposure regions. The positional
accuracy and alignment of the adjacent exposure regions directly affects the
yield.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Overview
FPA-5510iX steppers deliver stable performance with proven
FPA-5510 Platform
FPA-5510 platform steppers have already been adopted for
both Frontend & Backend processing, boasting high utilization rates and
reliability. FPA-5510iX steppers build upon this platform to offer the same
Cost of Ownership benefits as earlier FPA-5510iZ & FPA-5510iV steppers.
FPA-5510iX steppers are compatible with an extensive list of
optional functions
FPA-5510iX steppers can be also configured with available
options to enable alignment and productivity optimization.
Available options include WB-OAS (WideBand-OAS) System that
provides a wide range of alignment illumination modes for process optimization.
By covering the band from the visible light to the infrared light, stable
alignment is available through all RGB layers of a color filter process. WB-OAS
wavelengths also enable alignment to marks on the backside of silicon wafers in
a BackSide Illumination (BSI) process.
Overlay can be further improved with the optional EAGA
(Enhanced Advanced Global Alignment) function that provides field by field
overlay measurement and compensation that allows the stepper to compensate for
nonlinear overlay errors.
To improve productivity, the optional OCCS (Oxygen
Concentration Control System function) can be applied to reduce the oxygen
concentration in the area between a wafer and the projection lens. In this
low-oxygen environment, it is possible to increase the reaction sensitivity
(speed) of some photoresists to reduce required exposure doses, thereby
improving throughput.
View Full Technical Specs PDF
Main Unit Specs
(diam. 70.7 mm max)
Extended AGA (EAGA)
Wide-Band OAS (WB-OAS)
Pellicle Particle Checker
Chemical Filtering
Resist Outgassing Unit
PC Remote Console
Online Functions (GEM2, GEM0304)
