FPA-5550iX Stepper
Discontinued
FPA-5550iX steppers adopt a high-NA, 1/2 reduction projection lens to deliver 0.5 um resolution across a large 50 mm x 50 mm exposure field. The FPA-5550iX is suitable for production of full-field image sensors and advanced augmented reality displays that are larger field than Front-End-Of-the-Line (FEOL) lithography exposure fields (26mm x 33mm) and FPA-5550iX steppers can help avoid pattern stitching of adjacent fields that can directly affect yield.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Overview
- FPA-5550iX steppers deliver stable performance for a variety of applications
- FPA -5550iX utilizes the same projection lens used by its predecessor FPA -5510iX stepper (released in September 2015) that enable 0.5μm resolution
- FPA-5550iX manufacturing processes have been refined to ensure high-quality, stable production of projection lenses to meet the demand expected for semiconductor lithography systems
- Wide exposure field of 50 x 50 mm allows high-resolution single exposure of full-frame image sensors, next-generation displays for augmented reality displays
- FPA-5550iX alignment system allows process optimization
- Wafer alignment scope that can read wider variety of alignment marks that are placed on silicon wafers to ensure layer-to-layer overlay accuracy
- Dark-field alignment mark illumination using scattered and diffracted light is available in addition to conventional bright-field direct mark illumination to enhance mark contrast and measurement accuracy
- Expansion of the usable alignment illumination wavelength ranges and adoption of an area sensor for multi-pixel measurement can help reduce measurement signal noise the system can detect and measure low-contrast alignment marks FPA-5550iX alignment system allows process optimization
- FPA-5550iX stepper options support advanced process optimization
- Through-Silicon Alignment (TSA) option enable users to use infrared light source to perform front-to-back overlay of alignment marks on the backside of silicon wafers. TSA is a requirement for the manufacturing of backside-illuminated sensors and through-silicon via application
- Canon’s Lithography Plus solution option (released in September 2022) can enable FPA-5550iX operators to monitor the condition of the lithography system and perform analyses to maintain quality control and utilization
View Full Technical Specs PDF
Main Unit Specs
(diam. 70.7 mm max)
Extended AGA (EAGA)
Wide-Band OAS (WB-OAS)
Pellicle Particle Checker
Chemical Filtering
Resist Outgassing Unit
PC Remote Console
Online Functions (GEM2, GEM0304)
