FPA-6300ES6a
Discontinued
The
FPA-6300ES6a KrF single-stage lithography system is designed for the mass
production of Dynamic Random Access Memory (DRAM), flash and other memory
devices; logic devices such as microprocessors for personal computers; color
filters and other imaging sensors and image-processing devices.
Based on
technologies cultivated through the field-proven FPA-6000 series, Canon's FPA-6300ES6a DUV scanner achieves high throughput and high overlay accuracy to
effectively respond to the advanced needs of chip manufacturers seeking reduced
cost of ownership.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Overview
High-Productivity Scanner
- DUV
scanner incorporates reticle stage and wafer stage designs that help reduce
wafer handling, alignment and exposure processes times
- FPA-6300ES6a
scanners realizes throughput of more than 200 wafers per hour* when available
options are applied.
*12-inch wafers, 98 shots, with Throughput
Upgrade applied
High-Accuracy Scanner
- FPA-6300ES6a
Scanners employ highly sophisticated stage-control and alignment scope technologies
and precise temperature and distortion control to make possible an overlay
accuracy of 5 nm**
- Advanced
0.86NA projection optical system and a wide range of options support demanding
and robust device production
** with Overlay Upgrade applied
High-Reliability Scanner
- FPA-6300ES6a
platform provides substantial improvements in terms of base durability and
maintenance requirements, as well as reduced install times and increased system
uptime and availability***
- FPA-6300ES6a
options and upgrades further improve overlay accuracy and productivity,
offering scalability to support next-generation semiconductor manufacturing.
*** Compared with FPA-6000ES6a scanner
View Full Technical Specs PDF
Main Unit Specs
* Overlay Upgrade Required
