FPA-8000iW Stepper
Discontinued
The FPA-8000iW i-line stepper is designed for advanced Panel-Level Packaging (PLP) applications is the first Canon Semiconductor Lithography system supporting manufacturing using large panel substrates.
FPA-8000iW panel steppers employ
proprietary projection optical systems designed to provide 1.0 μm resolution
across a wide 52 x 68 mm exposure field. The FPA-8000iW helps enable PLP cost
reduction and package scaling by providing high-productivity panel processing
with a large exposure field and high resolution.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Overview
FPA-8000iW i-line stepper for
large panel substrates up to 515 x 515 mm
- Wide
exposure field (52 x 68 mm or 55 x 55 mm).
- High
resolution of 1.0 μm is available across the wide exposure field.
- High
resolution and wide exposure field combine to provide high-productivity and
further miniaturization, a larger device size and cost reduction for
semiconductor packaging.
Supports high-productivity
packaging on large substrates
- In
response to packaging processes that use panel substrates, Canon developed a
new stepper platform capable of handling large 515 x 510 mm panel substrates.
Severe warpage is also common in large panel substrates and the new platform
and panel-feeding system can overcome up to 10 mm of panel warpage. The
FPA-8000iW can help customers realize high-productivity and efficiency for PLP
production of large packages.
Achieves a resolution of 1.0
μm to enable advanced packaging
- Canon's
original projection optical system supports a wide 52 x 68 mm exposure field
while achieving 1.0 μm resolution, which is the finest resolution among
packaging exposure systems that support panel substrate processes*. As a
result, advanced packaging technology such as Panel Level Packaging can
innovate to provide high integration and flexibility in electronic system
design.
*Among same-class i-line steppers. With flatness equal to silicon wafer. Based on a December 10, 2018 Canon survey.
† Prices
and specifications subject to change without notice. Actual prices are
determined by individual dealers and may vary.
