GPS Receiver GP-E2
Free Standard Shipping & Handling on Camera & Lens Products - Offer valid January 19, 2023 12:00 a.m. through March 31, 2023 11:59 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 50 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
- Rugged and lightweight design
- Records location information (longitude, latitude, elevation, direction, and universal coordinated time (UTC) as EXIF information to images when shooting
- Can act as a standalone GPS logger
- On-board electronic compass
- Camera time can be synched by the built-in atomic clock
- Uses a conveniently replaceable AA battery as its power source so no energy is drawn from the camera's battery
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
For simple and accurate recording of time and location information, Canon's compact GPS Receiver GP-E2 is the perfect complement to the EOS System. The GP-E2 records location information such as longitude, latitude, elevation, direction and Universal Coordinated Time (UTC) as EXIF data, while also serving as an electronic compass on camera or off. Versatile connectivity options include USB and hot shoe connections with the EOS 5D Mark III and the EOS-1D X (USB connection only with the EOS 7D); smart design and rugged construction ensures reliability plus the ability to be used as a standalone GPS recorder. The newest GPS system designed specifically for the EOS system, the GP-E2 is an ideal tool for photographers on the move.
Type
GPS logging accessory
- Automatic geotagging when shooting supported by EOS-1D X and later cameras (EOS 5D Mark III and EOS 7D: supported with a firmware update)
- Manual geotagging after shooting (from logging information) supported by all EOS DIGITAL cameras When the EOS 7D is used with the GP-E2 the following restrictions will apply:
a)geotagging function will not work for movies while recording
b)geotagging features will not work for movies when using the Map Utility
c)electronic compass information and automatic time setting is not available
d)transmission via the hot shoe is not possible
GPS
1575.42 MHz (L1 band)
* L1 band: Frequency allocated for civilian use. Other frequencies include the L2 band (military use) and L5 band (high-precision civilian use).
Every 1, 5, 10, 15, or 30 seconds, or every 1, 2, or 5 minutes
Shown on the GPS indicator (red)
Before signal acquisition: Fast blinking
Signal acquired: Slow blinking
Not Supported
Digital Compass
Direction calculated using a triaxial geomagnetic sensor and triaxial acceleration sensor
Logging
NMEA-0813
- Images can be geotagged using Map Utility with log files.
- Log files can be converted to KMZ files using Map Utility. Routes the camera has traveled can be viewed in Google Earth or other map software by loading the KMZ files.
GPS Modes
Location information (latitude, longitude, altitude, direction, and UTC time) is automatically added to images EXIF information when taking pictures.
- Location information (latitude, longitude, altitude, and UTC time) is recorded on GPS Receiver GP-E2 at the specified interval. - Location information (latitude, longitude, altitude, direction, and UTC time) is automatically added to images Exif information when taking pictures.
Supports the following operations when GPS Receiver GP-E2 is connected to a computer and Map Utility is used to access GPS Receiver GP-E2s log files. - Import logs to the computer
- Delete logs
- Manually geotag shots without GPS information by adding
location information (latitude, longitude, altitude, and UTC time) to image EXIF information
- View a route of where the camera has traveled on a map
- Produce KMZ files from log files
- Update EOS 7D firmware
Time Adjustment
Set GPS time data on the camera
* Requires signal acquisition from four or more satellites.
1. High-precision time adjustment: ±TBA sec.
* Margin of error relative to UTC time.
* High-precision time adjustment is only available for EOS-1D series cameras (EOS-1D X or later).
2.Normal time adjustment: ±1 sec.
1.Auto update: After satellite reception when the GPS Receiver GP-E2 is turned on
2.Immediate updating
Interface
For direct camera connection
For connection via dedicated interface cable
* Transmission via cable is used if the GPS Receiver GP-E2 is attached to the hot shoe and connected by cable
Power Supply
One AA/LR6 Alkaline Battery (NiMH and lithium batteries supported)
At normal temperature (23°C/73°F)
*Battery life when using AA/LR6 alkaline batteries.
*Less recording time will be available when logging under unfavorable positioning conditions.
Indicated by the battery check lamp (red)
- Level OK: Slow blinking
- Low battery: Fast blinking
- Replace battery: Off
Operating Environment
32 to 104 °F / 0 to 40 °C
85% or less
Dimensions
Approx. 2.1 x 2.9 x 1.7 in. / Approx. 54.3 x 72.9 x 44.2 mm
*According to CIPA guidelines
Approx. 81 g/ Approx. 2.86 oz.
Reviews
Product Disclaimer
*The EOS 5D Mark III and EOS 7D require a firmware upgrade to be compatible with the GPS Receiver GP-E2, which will be available soon.
†When the EOS 7D is used with the GP-E2 the following restrictions will apply: a) geotagging function will not work for movies while recording; b) geotagging features will not work for movies when using the Map Utility; c) electronic compass information and automatic time setting is not available; d) transmission via the hot shoe is not possible.
