imageCLASS D1650
Discontinued
Offer valid October 4, 2026, 12:05 a.m. through October 17, 2026, 11:50 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 50 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
Offer valid October 1, 2026, 12:05 a.m. through October 31, 2026, 11:50 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 50 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Streamline your experience with MyCanon Account!
Product registration information for this product will be added to your Account when your items ships.
In the box
- imageCLASS D1650 Product
- Canon Genuine Toner 121 (Yields approximately 5,000 pages, ISO / IEC Standard)
- Power Cord
- Phone Cable
- User Software DVD - ROM
- Getting Started Guide
- Warranty Card
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See our Return Policy for complete information.
Return Policy
Printer Overview
Designed for small to mid-size workgroups, the imageCLASS D1650 balances speedy performance, minimal maintenance, and the ability to expand paper capacity for busy groups. A 5" color touchscreen delivers an intuitive user experience and can be customized by a device administrator to simplify many daily tasks. A legal-sized platen glass accommodates diverse scanning and copying needs.
The D1650 has print, scan, copy and fax functions, prints up to 45ppmFootnote1 and has a 3 year limited warranty.Footnote4
Learn more about the D1650 and how it can fit into your workspace.
5" Color Touchscreen
Organize your homescreen to access the features you use the most.
Mobile Connectivity
Print on-the-go with Canon PRINT Business, Apple AirPrint® and Mopria® Print Service.
Excellent Service and Support
Canon's friendly and knowledgeable Customer Service team provides expert assistance for every level of experience.
Application Library: Easy to Use, One Touch Solution
Discover how easy it is to use Application Library on the D1600 series. Customize your home-screen to access the functions you use the most. Finally, a printer that's programmable to meet your needs.
PERFORMANCE
Compact Design
Consider how your device will fit in your workpace.
Expandable Paper Capacity
Generous paper capacity allows you to save time and refill paer less often.
One Pass Scan
Scan your 2-sided documents more quickly and keep them in order.
GENUINE Products. Maximum Results.
Canon GENUINE ink and toner are engineered to achieve optimal performance with Canon printers. The exceptional design results in better operational success and end results, including higher yields, outstanding output and greater consistency, vibrancy, reliability and performance.
Canon's Automatic Replenishment Service
Auto Replenishment Service detects when your supplies are running low and a new ink or toner order is automatically placed and shipped to you. You only pay for what you need, when you need it.
Main Unit Spec
Main Unit
Maximum: 2,300 Sheets
Optional (up to three): 550-sheet Paper Cassette (Paper Feeder PF-C1)
Stack Bypass: Thin, Plain, Recycled, Color, Thick, Bond, Label, Envelope (10 Envelopes)
Stack Bypass: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL
Custom (Min. 3" x 5" to Max. 8.5" x 14")
Stack Bypass: 16 lb. Bond to 53 lb. Bond (52 to 199 g/m2)
From Sleep Mode: 4 Seconds or Less
For full configuration options and dimensions, please refer to this document.
Fully Configured: 24.0" x 39.6" x 60.9" (634 mm x 1005 mm x 1547 mm)
Boxed Weight: Approx. 54.0 lb. (24.8 kg)
Print Specifications
PS: 136 Fonts
Copy Specifications
Scan Specifications
Double-sided: 26/70 ipm (300 dpi) (Color/BW)
Send Specifications
Optional: PDF (Encrypted, Digital Signature)
Fax Specifications
G3: 14.4 kbps
Security Specifications
Optional: Encrypted PDF, User and Device Signatures
Wi-Fi Access Point: WPA2-PSK (AES)
Environmental Specifications
Humidity: 20 to 80% RH (no condensation)
Standby: Approx. 17 W;
Sleep Mode: Approx. 0.9 W;
Typical Electricity Consumption (TEC) Rating: 0.47 kWh
Reviews
Brochures
imageCLASS D1650 Compatible Products
Product Disclaimer
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Wireless performance may vary based on terrain/distance between printer and wireless network clients.
- Canon PRINT app is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit usa.canon.com/mobile-app. Please see the respective websites for Apple® AirPrint® and Mopria® Print Service for compatibility and additional information.
- Warranty program is subject to certain conditions and restrictions. See warranty card for details.
- For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
