imageCLASS LBP113w
IC LBP113W
As low as $159.00
Out Of Stock
  • Print up to 23 ppm
  • Print up to 8-1/2" x 14"
  • 150-sheet maximum paper capacity
  • Standard one-year warranty
New
Return Policy
imageCLASS LBP113w Spec Sheet
imageCLASS LBP113w
MAIN UNIT
CORE FUNCTIONS
Standard: Print
ITEM CODE
2207C004
CONTROL PANEL
5-Line
MEMORY
256 MB
STANDARD INTERFACE CONNECTION
USB 2.0 x1 (Device) High-Speed, Wi-Fi 802.11b/g/n,
Wi-Fi Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 150 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 150-sheet Paper Cassette
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard: 50 Sheets
SUPPORTED MEDIA TYPES
Cassette: Plain, Recycled, Thick, Bond, Label, Envelope (One Envelope)
SUPPORTED MEDIA SIZES
Cassette: Letter, Legal, Statement, Executive, Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassette: 16 lb. Bond to 43 lb. Bond (60 g/m2 to 163 g/m2)
WARM-UP TIME
From Power On: 15 Seconds or Less
From Sleep Mode: 1.6 Seconds or Less
DIMENSIONS (W x D x H)
Standard: 14.8" x 11.5" x 8.8"
(376 mm x 291 mm x 222 mm)
WEIGHT
Machine Only: Approx. 12.1 lb. (5.5 kg)
Boxed Weight: Approx. 18.1 lb. (8.2 kg)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED1
Up to 23 ppm (Letter); Up to 18 ppm (Legal)
FIRST PRINT-OUT-TIME
Approx. 6.3 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
150 - 1500
PRINT RESOLUTION (dpi)
Up to 600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II LT
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES2
Apple® AirPrint,® Canon PRINT Business, Mopria™ Print
Service
OPERATING SYSTEM
UFR II/PCL: Windows® 7/ Windows 8.1/ Windows 10/ Windows Server 2008/ Windows Server 2008 R2/ Windows Server 2012/ Windows Server 2012 R2/ Windows Server 2016, Mac OS X v10.8.5 (or later)
SECURITY SPECIFICATIONS
NETWORK
Standard: IP Address Filtering, TLS Encrypted Communication, SNMP V3.0, IPv6
WI-FI® AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:4.1 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 850 W;
Standby: Approx. 3.4 W;
Sleep Mode: Approx. 0.4 W;
Typical Electricity Consumption (TEC) Rating: 0.17 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver3
FOOTNOTES
1 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
2 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
3 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
Reviews
