imageCLASS LBP162dw
IC LBP162DW
As low as
$199.00
Out Of Stock
- Print up to 30 ppm
- Print up to 8-1/2" x 14"
- 250-sheet maximum paper capacity
- Standard one-year warranty
Need to order more than 10?
Learn More
Need help making a purchase? Contact a Sales Expert at 800-385-2155>
Return Policy
imageCLASS LBP162dw Spec Sheet
imageCLASS LBP162dw | |
MAIN UNIT | |
TYPE | Black and White Laser Single Function |
CORE FUNCTIONS | Standard: Print |
CONTROL PANEL | 5-line LCD |
MEMORY | 256 MB |
STANDARD INTERFACE CONNECTION | USB 2.0 x1 (Device) High-Speed, 10/100/Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection |
PAPER CAPACITY (LTR, 20LB BOND) | Standard / Maximum: 250 Sheets |
PAPER SOURCES (LTR, 20LB BOND) | Standard: 250-sheet Paper Cassette, One-sheet |
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | Standard: 50 Sheets |
SUPPORTED MEDIA TYPES | Cassette / Bypass: Plain, Recycled, Thick, Bond, |
SUPPORTED MEDIA SIZES | Cassette / Bypass: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14") |
SUPPORTED MEDIA WEIGHTS | Cassette / Bypass: 16 lb. Bond to 43 lb. Bond (60 gsm to 163 g/m2) |
WARM-UP TIME | From Power On: 15 Seconds or less From Sleep Mode: 1.6 Seconds or less |
DIMENSIONS (W x D x H) | Standard (Desktop): 14.9" x 16.2" x 9" (371 mm x 404 mm x 225 mm) |
INSTALLATION SPACE (W x D x H) | Standard (Desktop): 18.5" x 24.3" x 14.3" (471 mm x 618 mm x 363 mm) |
WEIGHT | Machine Only: Approx. 15.4 lb. (7 kg) Boxed Weight: Approx. 19.8 lb. (9 kg) |
PRINT SPECIFICATIONS | |
PRINTING METHOD | Laser Beam Printing |
PRINT SPEED3 | Up to 30 ppm (Letter); Up to 24 ppm (Legal) |
FIRST PRINT-OUT-TIME | Approximately 6 seconds |
RECOMMENDED MONTHLY PAGE VOLUME | 250 - 2,500 Pages |
PRINT RESOLUTION (dpi) | 600 x 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II LT, PCL®6, PCL®5e |
DOUBLE SIDED PRINTING | Automatic (Standard) |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES4 | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service |
FONTS | PCL: 45 Fonts |
OPERATING SYSTEM | UFR II/PCL: Windows®7 / Windows 8.1 / Windows 10 / Windows Server2008 / Windows Server2008 R2 / Windows Server2012 / Windows Server2012 R2 / Windows Server2016 Mac OS X v10.8.5 (or later) |
SECURITY SPECIFICATIONS | |
NETWORK | Standard: IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 |
WI-FI AUTHENTICATION METHODS | Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES) Wi-Fi Access Point: WPA2-PSK (AES) |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86º F Humidity: 20 to 80% RH (no condensation) |
POWER REQUIREMENTS | AC 120-127 V:4.0 A, 60 Hz |
POWER CONSUMPTION | Maximum: Approx. 1060 W Standby: Approx. 3.1 W Sleep Mode: Approx. 0.5 W Typical Electricity Consumption (TEC) Rating: 0.30 kWh |
STANDARDS | ENERGY STAR® Qualified, Rated EPEAT Silver1 |
FOOTNOTES | |
1 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. 2 Warranty program is subject to certain conditions and restrictions. See warranty card for details. 3 Print speed is based on internal testing. Print speed may vary depending on the number of copies selected as well as the settings for size, type, and orientation of paper. 4 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information. |
Reviews
