imageCLASS LBP237dw
LBP237DW
As low as $349.00
Out Of Stock
  • Print up to 40 ppm
  • Print up to 8-1/2" x 14"
  • 900-sheet maximum paper capacity
  • Standard one-year warranty
Show more
Printer Overview
Designed for small businesses, the Canon imageCLASS LBP237dw printer balances speedy performance, minimal maintenance, and the ability to add an optional paper tray. A 5" color touchscreen delivers an intuitive user experience and can be customized by a device administrator to simplify many daily tasks.
The LBP237dw prints up to 40ppm and has a 1 year limited warranty.
Learn more about the LBP237dw and how it can fit into your workspace.
Image Alt Text
FEATURES
Mobile Connectivity
Print and scan from your compatible mobile device through the free Canon Print Business app.Compact Design
Excellent Service and Support
Canon's friendly and knowledgeable Customer Service team provides expert assistance for every level of experience.
Screen
Application Library: Easy to Use, One Touch Solution
Discover how easy it is to use Application Library on the LBP237dw. Customize your home-screen to access the functions you use the most. Finally, a printer that's programmable to meet your needs.
PERFORMANCE
Photo with lines marking the dimensions of the printer.
Compact Design
Consider how your device will fit in your workplace.
Printers with expandable paper features
Expandable Paper Capacity
Generous paper capacity allows you to save time and refill paper less often.
GENUINE Products. Maximum Results.
Canon GENUINE ink and toner are engineered to achieve optimal performance with Canon printers. The exceptional design results in better operational success and end results, including higher yields, outstanding output and greater consistency, vibrancy, reliability and performance.
Photo of a desk with people at laptops exchanging printed papers.
imageCLASS LBP237dw Brochure
imageCLASS LBP237dw
MAIN UNIT
CORE FUNCTIONS
Standard: Print
ITEM CODE
5162C004
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5" Color Touch Panel
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0, High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n,Wi-Fi¿ Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 350 Sheets
Maximum: 900 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 100-sheet
Multipurpose Tray Optional: 550-sheet Paper Cassette (Cassette Unit-AH1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard: 65 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Thick, Bond
Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Multipurpose Tray: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIME
From Power On: 14 Seconds or Less
From Sleep Mode: 4 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 17.2" x 14.7" x 12.3" (438 mm x 373 mm x 312 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 17.3" x 34.4" x 12.3" (438 mm x 874 mm x 312 mm)
Fully Configured: 17.3" x 34.4" x 17.4" (438 mm x 874 mm x 443 mm)
WEIGHT
Machine Only: Approx. 20.3 lb. (9.2 kg)
Boxed Weight: Approx. 28.7 lb. (13.0 kg)
OPERATING SYSTEMS
UFR II/PCL/PS: Windows¿ 10/8.1, Windows Server 2019/2016/2012 R2/2012/Mac OS X (10.11 or later)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED4
Up to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST PRINT OUT TIME
Approx. 5.4 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
750 - 4,000 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, PCL®5
DOUBLE-SIDED PRINTING
Automatic (Standard)
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES
Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service1
Print documents to or from DropBox, Google Drive, or OneDrive5
FONTS
PCL: 93 Fonts
PRINT FEATURES
Secure Watermark, Header/Footer, Page Layout, Two-sided Printing, Mixed Paper Sizes, Orientations, Toner Reduction, Poster Printing, Print Date, Collating, Grouping, Page Border6, Booklet Printing6
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
DATA
Standard: Verify System at Startup
NETWORK
Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6
DOCUMENT
Standard: Secure Print
WI-FI AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode:
WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:5.9 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 1300 W
Standby: Approx. 8.5 W
Sleep Mode: Approx. 0.9 W
Typical Electricity Consumption (TEC) Rating: 0.33 kWh
STANDARDS
ENERGY STAR® Qualified, Currently Rated EPEAT Silver2
CONSUMABLES
TONER
Cartridge 057 Black, Standard - Yields up to 3,100 Pages
Cartridge 057 Black, High Capacity - Yields up to 10,000 Pages
Brochures
File Name
Date
06.05.23
File Size
1.4 MB
imageCLASS LBP237dw Compatible Products
Rollers, Feeders & Cassettes
