imageCLASS LBP247dw
LBP247DW
As low as $378.99
4 interest free payments of $94.75 with
klarna Pay Later
Paypal Pay Later
Out Of Stock
FREE Standard Shipping
  • Wireless Single Function (Print Only)
  • Print up to 42 pages per minute
  • Uses Toner 070 / 070 High-Capacity Toner
  • 250-sheet Standard Cassette, 100-sheet Multipurpose Tray, Expandable Paper Capacity up to 900-sheets using optional Paper Cassette AH-1
  • Auto 2-sided Printing
  • Large 5" Color Touchscreen for easy navigation
  • Quick First Print Out Time (FPOT) of approximately 5 seconds
  • ENERGY STAR® Certified, EPEAT Silver
  • 1 Year Limited Warranty
Show more
Overview
imageCLASS LBP247dw - Front View
imageCLASS LBP247dw Logo
Black & White Wireless, Duplex Laser Printer
The LBP247dw black and white laser printer is designed for small office and can print up to 42 pages per minute.
imageCLASS LBP247dw - Printer Features
1. 2-Sided Black & White Duplex Printing
2. 5-Inch Color Touch LCD For Easy Navigation
3. USB Flash Drive Port
4. 100-Sheet Multipurpose Tray
5. 250-Sheet Cassette Tray
6. Print Up To 42 Pages Per Minute (PPM)
7. 550-Sheet Paper Tray (Optional)
Features
Easy WiFi Setup
Connect your printer to a wireless network in four simple steps:
  • STEP 1: PRESS WIRELESS LAN
Actual display screen may vary.
Easy WiFi Setup
  • STEP 2: SELECT NETWORK
Easy WiFi Setup
  • STEP 3: ENTER ENCRYPTION KEY / PASSWORD
Easy WiFi Setup
  • STEP 4: FINALIZE
imageCLASS LBP247dw - WiFi Setup Step 1
imageCLASS LBP246dw - WiFi Setup Step 2
imageCLASS LBP246dw - WiFi Setup Step 3
imageCLASS LBP246dw - WiFi Setup Step 4
Fast Scan Speeds
Get the job done quickly with your first print out in 5 seconds* and print speeds of 42 pages per minute.*
* Approximate values
imageCLASS LBP247dw - Person Using Paper Feeder to Scan
Customizable 5-Inch Color Touchscreen
Organize your home screen to access the features you use the most.
imageCLASS LBP247dw - Person Using Direction Buttons
Cloud Connectivity
Print documents directly from cloud storage external webpages such as Dropbox, Google Drive, or OneDrive.
imageCLASS LBP247dw - Demoing Cloud Connectivity
LBP247dw uses Canon Genuine Toner 070 / 070 H Black
High capacity toner option keeps up with your printing needs and limits toner replacement interruptions.
Canon Genuine Toner 070: Yields 3,000 pages
Optional Canon Genuine Toner 070 H: Yields 10,200 pages
imageCLASS LBP246dw - Toner 070 and 070 H Side by Side
USB Flash Drive Connectivity
Print directly from your USB Flash Drive.
imageCLASS LBP247dw - Person Plugging in a USB Flash Drive
Maximize Productivity
Expandable paper capacity allows for large print jobs:
  • 250-Sheet Cassette Tray
  • 100-Sheet Multipurpose Tray
  • Optional 550-Sheet Cassette Tray AH-1 (Sold Separately)
imageCLASS LBP247dw - All Compartments Open
Mobile Connectivity
Print on the go using your compatible device.
imageCLASS LBP247dw - Person Holding Mobile Phone In Front of Printer
Printer Dimensions
The LBP247dw is designed to fit in your home or workspace.
imageCLASS LBP247dw - Dimensions
Main Unit Specifications
Model Name
imageCLASS LBP247dw
Functions
Print
Print Speed
Up to 42 ppm (Letter)
Approx. 4.9 Seconds (Letter)
Print Resolution
Up to 1200 x 1200 dpi
Print Memory
1 GB (RAM)
Printer Language
UFR II, PCL5/6
Network Security
Authentication Standard: Department ID Authentication. Network Standard: TLS1.3, IPSec support, IEEE 802.1X authentication, SNMPv3, IP Address Filtering, Configure ON/OFF settings for network application functions, Job Log Conceal Function, Restricted access to the printer's storage media, Verify System at Startup
Connectivity
USB 2.0, High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, WiFi® Direct Connection
Operating Systems
Windows®10 / Windows®11 / Windows®Server2012 / Windows®Server2012 R2 / Windows®Server2016 / Windows®Server2019 / Windows®Server2022 / macOS 10.13 (or later)
Paper Capacity
Standard: 250-sheet Paper Cassette, 100-sheet Stack Bypass (Multipurpose Tray), Optional: 550-sheet Paper Cassette (Cassette Unit-AH1)
Min / Max Paper Size
Standard/Optional Cassette: Min. 4.1" x 5.8" to Max. 8.5" x 14". Stack Bypass (Multipurpose Tray): Min. 3" x 5" to Max. 8.5" x 14"
USB Direct Print
JPG, TIFF, PDF
Display Panel
5 Inch Color Touch Screen
Print Volumes
750-4,000 RMPV (Recommended Monthly Print Volume)
Energy Consumption
Approx: 1180 W (Max.), 6 W (Standby), 0.1 W (Sleep Mode)
ENERGY STAR Certified
Yes
EPEAT
Silver
Box Dimensions
20.5" (W) x 18.8" (D) x 14.6" (H)
Box Weight
28.7 lbs.
Unit Dimensions
17.2"(W) x 14.7"(D) x 12.3"(H)
Unit Weight
20.1 lbs.
Note
Specifications are subject to change without notice. All viewscreen and output images are simulated.
Reviews
Brochures
File Name
imageCLASS LBP246dw/LBP247dw Brochure
Date
02.24.25
File Size
1 MB
imageCLASS LBP247dw Compatible Products
Paper
Paper
Product Disclaimer
  1. Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
  2. Wireless performance may vary based on terrain/distance between printer and wireless network clients.
  3. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit usa.canon.com/mobile-app.
  4. Warranty program is subject to certain conditions and restrictions. See warranty card for details.
  5. AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
  6. Mopria® Print Service, available for free at the Google Play Store, requires a compatible Android 4.4 or later smartphone and tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network. Learn More.
