Out Of Stock
imageCLASS LBP351dn
LBP351DN
As low as $1,199.00
Out Of Stock
  • Print up to 58 ppm (BW)
  • Print up to 8-1/2” x 14”
  • 3,600-sheet maximum paper capacity
  • Black-and-White
  • Compact
  • User-Friendly
New
Return Policy
Main Unit Spec
Printer Specifications
Printer Type
Monochrome Laser Single Function Printer
Print Speed
Up to 58 ppm (1-sided plain paper, letter), Up to 38ppm (2-sided plain paper, letter)1
First Print Time
7.2 seconds or less (letter)2
Printer Language
UFR II, PCL 5c/e, PCL6, PS, PDF, XPS
Print Resolution
600 x 600 dpi,
1,200 x 1,200 dpi equivalent dpi
Maximum Print Size
Up to Legal
Duplex Print
Yes
Print Modes
Toner Saver, Booklet, Poster, Watermark
Print Memory
1 GB
Direct Print from USB
Print File format: JPEG, TIFF, PDF, XPS
Paper Handling Specifications
Standard Paper Source(s)
500-sheet cassette, 100-sheet multipurpose tray3
Optional Paper Source(s)
500-sheet cassette (PF-B1), 450-sheet custom media cassette (CM-A1), 1,500-sheet paper deck (PD-G1), 75-sheet (or 200-postcard) feeder (EF-A1)3
Paper Output
Output tray (face down): Approx. 500 sheets
Paper Weight
16-32 lb. bond (plain paper, 500-sheet standard cassette, optional 500-sheet cassette, optional 1,500-sheet paper deck, optional 450-sheet custom media cassette), 16-36 lb. bond (plain paper, 100-sheet multipurpose tray)
Media Sizes
500-Sheet Standard Cassette: Letter, Legal, A4, A5, B5, Executive.
Optional 450-Sheet Custom Media Cassette*: Letter, Legal, A4, A5, A6, B5, Statement, Executive.
Optional 500-Sheet Cassette: Letter, Legal, A4, A5, B5, Executive.
Optional 1,500-Sheet Paper Deck: Letter, Legal, A4.
*Optional Custom Media Cassette can only be inserted into the standard cassette cavity and will work in place of the standard cassette to accommodate small media sizes 4" x 5.8" to 6.7" x 11.1"
Media Types
Plain, Heavy, Bond, Label, Envelope, Postcard
Envelope Capacity
75 envelopes (Optional Envelope Feeder)
Envelope Types
Com 10, Monarch, C5, DL
Connectivity and Software Specifications
Standard Interface(s)
USB Device High-Speed 2.0, 10/100/1000 BASE-T Ethernet (Network)
Mobile Functions
Canon PRINT Business4, Apple® AirPrint®5, Mopria Print Service6
Network Functions
Print
Embedded Web Server (Remote UI)
Yes
Web Browser Support for Remote UI
Microsoft Internet Explorer 7.0 or later, Safari 9.0.3
Print Protocols
LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services
Bonjour(mDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols
SNMPv1, SNMPv3 (IPv4,IPv6)
OS Compatibility
Windows® 10, Windows 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012 R2, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac® OS X 10.5.8 & up
Cable Included
Power Cord (USB not included)
Bundled Software
Printer driver
Environmental Specifications
Power Consumption
During Operation: 820 W or less,
During Standby: 20 W or less,
Energy Saver Mode: 1 W Wired / 2 W USB
Typical Energy Consumption
0.78 kWh
General Specifications
Dimensions
LBP350 Series: 16.4 inches (W) x 20.9 inches (D) x 17.3 inches (H)
Stand Type T: 24 inches (W) x 25.5 inches (D) x 4.7 inches (H)
Cabinet Type T1: 24 inches (W) x 25.5 inches (D) x 17.3 inches (H)
For full configuration options and dimensions, please refer to this document.
Unit Weight (without/with cartridge)
54 lbs. (w/o cartridge),
57.8 lbs (w/cartridge)
Package Weight
Approx. 67.3 lbs
Cartridge Type
Cartridge 039 Black (Yields approximately 11,000 pages)
Cartridge 039 High Black (Yields approximately 25,000 pages)
*Yields based on ISO/IEC Standard
LCD Display
5 Line LCD Panel
Duty Cycle
Up to 250,000 pages per month
Department ID Management
Yes, Up to 300 IDs
Security
IEEE802.1x, SNMPv3, IPSEC, IPv6
Languages
English, Spanish, French, Portuguese
Warranty
1 Year Onsite Service (Extended warranty available)7
N/A10
Other Features:
EPEAT Silver Rating
Product Disclaimer
1. Copy/print speeds are measured based on internal testing using letter size paper copied/printed with 100% copy/print ratio to original on one-sided paper. Internal testing involved continuously copying/printing the same one page of content on plain paper (copy speed is tested by copying on the platen glass). Copy/print speeds may vary depending on paper type, paper size or paper feeding direction. The device may automatically pause or slow down in order to adjust printer condition such as controlling temperature of a certain unit or limiting impact to image quality during continuous copying/printing.
2. May vary depending on the output environment.
3. Based on 20 lb. bond paper.
4. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
5. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
6. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
7. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
