Add to Cart
imageCLASS LBP6230dw
IC LBP6230DW
As low as $169.00
In Stock
  • Print up to 26ppm
  • Print up to 8.5" x 14"
  • 250-sheet maximum paper capacity
  • One-year standard warranty
New
Return Policy
Main Unit Spec
Printer Specifications
Printer Type
Monochrome Laser
Print Speed
Up to 16 ppm (2-sided plain paper letter)3
Up to 26 ppm (1-sided plain paper letter)3
First Print Time
Approximately 6 seconds4
Printer Language
UFR II LT (Host-based)
Print Resolution
Up to 600 x 600 dpi (2400 x 600 dpi quality), 1200 x 1200 equivalent
Duplex Print
Yes
Print Modes
Collate, Poster, Booklet, Watermark, Toner Saver, Page Composer
Print Memory
64 MB
Paper Handling Specifications
Standard Paper Source(s)
250-sheet cassette plus 1-sheet multipurpose tray5
Paper Output
100 sheets (face down)
Paper Weight
16-43 lb. bond (cassette)
16-43 lb. bond (multipurpose tray)
Media Sizes
Letter, Legal, A4, A5, B5, Executive
Media Types
Plain Paper, Heavy Paper, Transparency, Label, Index Card, Envelope
Envelope Capacity
Multipurpose Tray: 20 sheets
Stack Bypass: 1 sheet
Envelope Types
Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s)
USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 b/g/n Wireless1
WiFi Access Mode
Infrastructure Mode
WiFi Authentication Methods
Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Modes
WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods
Push-button mode, PIN code mode
Mobile Functions
Canon Mobile Printing2
Embedded Web Server (Remote UI)
Yes
Web Browser Support for Remote UI
Internet Explorer 7.0 or higher, Safari 3.2.1 or higher
Print Protocols
LPD (IPv4,IPv6), RAW (IPv4,IPv6), WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services
(IPv4) RARP, BOOTP, DHCP, DNS, Dynamic DNS, Multicast DNS, WINS (IPv6) DHCP, DNS, Dynamic DNS, Multicast DNS
Network Management Protocols
SNMPv1(IPv4,IPv6), SNMPv3(IPv4,IPv6), SLP(IPv4,IPv6)
OS Compatibility
Windows 8.1, Windows 7, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Vista®, Linux, Citrix (FR2 and later)
Cable Included
Power Cord, USB Cable
Bundled Software
Canon Drivers, Network Setup Tool
Environmental Specifications
Power Consumption
Max: 930W or less
During Operation: Approx. 400W
Standby: Approx. 1.4 W (USB/Wired)
Approx. 2.1W (Wireless)
Energy Saver: Approx. 0.9 W (USB/Wired)
Approx. 1.6 W (Wireless)
Typical Energy Consumption
0.27 kWh/w
General Specifications
Dimensions
14.9" (W) x 11.5" (D) x 9.6" (H)
Unit Weight (without/with cartridge)
15.4 lbs. (w/o cartridge)
16.7 lbs. (w/ cartridge)
Package Weight
Approx. 19.8 lbs.
Cartridge Type
Cartridge 126 (Yields approximately 2,100 pages)
Single Cartridge System
*Yields based on ISO/IEC Standard
Duty Cycle
Up to 8,000 pages per month
Warranty
1 year limited exchange/carry-in6
(Extended warranty available)
Reviews
Product Disclaimer
1. Wireless performance may vary based on terrain and distance between printer and wireless network clients.
2. Requires Canon Mobile Printing app, available free on the App StoreSM and Google Play; compatible with iPhone 5S, iPhone 5C, iPhone 5, iPhone 4S, iPhone 4, iPad Air, iPad 4, iPad 3, iPad 2, Original iPad, iPad mini, and iPad mini Retina running OS 5.1 - 7.1.1. Supports Android Tablets and Phones running OS 3.0 - 4.4
3. Copy/print speeds are measured based on internal testing using letter size paper copied/printed with 100% copy/print ratio to original on one-sided paper. Internal testing involved continuously copying/printing the same one page of content on plain paper (copy speed is tested by copying on the platen glass). Copy/print speeds may vary depending on paper type, paper size or paper feeding direction. The device may automatically pause or slow down in order to adjust printer condition such as controlling temperature of a certain unit or limiting impact to image quality during continuous copying/printing.
4. May vary depending on the output environment.
5. Based on 20 lb. Bond Paper.
6. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
