imageCLASS MF236n
IC MF236N
As low as $149.00 Regular Price $199.00
Out Of Stock
$50 Instant Savings
  • Print up to 24 ppm
  • Print up to 8-1/2" x 14"
  • 250-sheet maximum paper capacity
  • One-year limited warranty
New
Return Policy
Main Unit Spec
Printer Specifications
Printer Type
Monochrome Laser
Print Speed
Up to 24ppm (1-sided plain paper letter)1
First Print Time
6 seconds or less (letter)2
Printer Language
UFR II LT (Host-based)
Print Resolution
Up to 600 x 600 dpi
Maximum Print Size
Up to Legal (8.5 x 14 inches)
Print Modes
Watermark, Page Composer, Toner Saver
Print Memory
256 MB (shared)
Copier Specifications
Copy Speed
Up to 24ppm (letter)
Copy Resolution
Up to 600 x 600 dpi
Original Type
Text/Photo, Text, Photo
Halftones
256 Levels
Warm-up Time
14 seconds or less from power on
First Copy Time
Approximately 9 seconds3
Recovery Time
Approximately 2 seconds
Maximum Number of Copies
Up to 999 copies
Reduction/Enlargement
25-400% in 1% increments
Copy Size
Platen: Up to 8.5 x 11, Feeder: Up to 8.5 x 14
Copy Features
Memory Sort, 2 on 1, 4 on 1, ID Card Copy
Copy Memory
256 MB (shared)
Fax Specifications
Modem Speed
Up to 33.6 Kbps (Super G3)4
Fax Resolution
Up to 200 x 400 dpi (ultra fine)
Transmission Time
Approx. 3 seconds per page
Memory Capacity
Up to 256 pages5
Speed Dials
Up to 4 one-touch speed dials, up to 100 coded dials
Group Dialing
103 destinations
Sequential Broadcasting
114 destinations
Receive Modes
FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features
Fax forwarding*, Dual Access, Remote Reception, PC Fax (sending only), Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Fax Activity / Result Reports, Fax Activity Management Reports
*Fax Forwarding to another registered fax number from memory.
Memory Backup
Yes
pC Fax
Sending only
Scanner Specifications
Scan Type
Color Contact Image Sensor (CIS)
Color Depth
24-bit
Scan Resolution
Up to 600 x 600 dpi (optical)
Scan Size
Platen / Feeder: Up to Legal
Compatibility
TWAIN, WIA, ICA
Scan Features
Push Scan, Pull Scan: USB and Network
Paper Handling Specifications
Standard Paper Source(s)
250-sheet cassette plus 1-sheet multipurpose tray, 16-43 lb. (bond, plain paper)6
Document Feeder
35-sheet Auto Document Feeder6
Paper Output
100 sheets (face down)
Media Sizes
Letter, Legal, Executive, Statement
Media Types
Plain, Color, Recycled, Heavy, Bond, Label, Envelope
Envelope Capacity
1 (multipurpose tray)
Envelope Types
Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s)
USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (network)
Mobile Functions
Canon PRINT Business7, Apple® AirPrint®8, Mopria™ Print Service9
Network Functions
Print, PC Fax, Scan
Web Browser Support for Remote UI
IE 7.0 or higher, Safari 3.2.1 or higher
Print Protocols
LPD, RAW, WSD-Print (IPv4,IPv6), IPP, IPPS
TCP/IP Set of Application Services
Bonjour(mDNS),DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6)
Network Management Protocols
SNMPv1/SNMPv3 (IPv4,IPv6), HTTP/HTTPS, SNTP
OS Compatibility
Windows® 10, 8.1, 8, 7, Windows Vista®,Windows Server® 2012, 2012 R2, 2008, 2008 R2, 2003, 2003 R2, Mac OS 10.6.8 or later
Cable Included
Power Cord, Phone Cable (USB not included)
Bundled Software
Printer driver, Fax driver, Scanner driver, MF Scan Utility, Address Book Tool
Environmental Specifications
Power Consumption
Approx: Operation: 420 W, Standby: 5.1 W, Energy Saver: 1.1 W (USB), 1.3 W (wired)
General Specifications
Dimensions
15.4"(W) x 14.7"(D) x 14.2"(H)
Unit Weight (without/with cartridge)
25.4 lbs. w/o cartridge, 26.7 lbs. w/ cartridge
Cartridge Type
Cartridge 137 (Yields approximately 2,400 pages), Single Cartridge System *Yields based on ISO/IEC Standard
LCD Display
Tiltable, Touch LCD
Duty Cycle
Up to 15,000 pages per month, RMPV (Recommended Monthly Print Volume): 500 - 2,000 pages
Security
IP/MAC address filtering, IEEE802.1x, SNMPv3, HTTPS/IPPS
Languages
English, Japanese, French, Spanish, German, Italian, Portuguese, Simplified Chinese, Traditional Chinese, Korean
Warranty
1 year limited exchange/carry-in warranty11 (extended warranty available)
Reviews
Product Disclaimer
1. Copy/print speeds are measured based on internal testing using letter size paper copied/printed with 100% copy/print ratio to original on one-sided paper. Internal testing involved continuously copying/printing the same one page of content on plain paper (copy speed is tested by copying on the platen glass). Copy/print speeds may vary depending on paper type, paper size or paper feeding direction. The device may automatically pause or slow down in order to adjust printer condition such as controlling temperature of a certain unit or limiting impact to image quality during continuous copying/printing.
2. May vary depending on the output environment.
3. Letter size, after being restored from energy saver mode.
4. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
5. Based on ITU-T #1 Chart (standard mode).
6. Based on 20 lb. bond paper.
7. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
8. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
9. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
10. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
11. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
