Backorder
imageCLASS MF269dw Value Pack
IC MF269DWVP
As low as $369.00
Backorder
  • Print up to 30 ppm
  • Print up to 8-1/2" x 14"
  • 250-sheet maximum paper capacity
  • Two-year Limited Warranty and Two High-Yield Toner Cartridges Included
New
Return Policy
imageCLASS MF269dw Value Pack Spec Sheet
MAIN UNIT
FUNCTIONS
Print/Scan/Copy/Fax
CONTROL PANEL
6-line LCD
MEMORY
256 MB
STANDARD INTERFACE CONNECTION
USB Device 2.0 High-Speed, 10/100 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n, Wi-Fi Direct Connection
PAPER INPUT / OUTPUT CAPACITY (LETTER, 20 LB. BOND)
250/50 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
250-sheet Paper Cassette, 1-sheet Stack Bypass
SUPPORTED MEDIA TYPES
Cassette/Bypass: Plain, Recycled, Thick, Bond, Label, Envelope
SUPPORTED MEDIA SIZES
(CASSETTE, STACK BYPASS)
Cassette/Bypass: Letter, Legal, Statement, Executive;
Envelope: COM10, Monarch, C5, DL; Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassette/Bypass: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIME
From Power On: 15 Seconds or Less;
From Sleep Mode: 1.6 Seconds or Less
DIMENSIONS (W x D x H)
15.4" x 16.0" x 14.8" (390 mm x 405 mm x 375 mm)
WEIGHT (MACHINE ONLY / BOXED WEIGHT)
29.7 lb. (13.5 kg)/39.6 lb. (18.0 kg)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEEDS2
Up to 30 ppm (Letter); Up to 24 ppm (Legal)
FIRST PRINT-OUT TIME
Approx. 5.1 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
250 - 2,500 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II-LT, PCL®6, PCL®5e
TWO-SIDED PRINTING
Automatic (Standard)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES3
Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service
OPERATING SYSTEMS (PRINT / SCAN)
Windows® 10/8.1/7, Windows Server® 2016/ 2012 R2/ 2012/ 2008 R2/ 2008; Mac OS 10.8.5 and Up.
Drivers Available For Download From www.usa.canon.com/support
COPY SPECIFICATIONS
COPY SPEED
FIRST COPY-OUT TIME (LETTER)
8 Seconds or Less
COPY RESOLUTION (dpi)
Up to 600 x 600
COPY SIZE
Platen: Up to Letter;
ADF: Up to Legal
PRESETS
Magnifications: 25% - 400% (1% Increments)
Reductions
: 25%, 50%, 64%, 78%
Enlargements
: 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE
Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY (20 LB. BOND)
50 Sheets
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
Single-sided Scanning: 13 - 28 lb. Bond (50-105 g/m2)
Two-sided Scanning: 16 - 28 lb. Bond (60-105 g/m2)
SCAN RESOLUTION (dpi)
600 x 600
SCAN TO MOBILE DEVICES
SCAN SPEED (LETTER) (IPM)
Single-sided (Color/BW): 7.7/11.6
Two-sided (Color/BW): 2.4/4
SEND SPECIFICATIONS
DESTINATION
Email (SMTP), SMB, Super G3 FAX
ADDRESS BOOK
Local (50)
SEND RESOLUTION (dpi)
300 x 300
COMMUNICATION PROTOCOL
File: SMB; Email: SMTP, POP3
FILE FORMAT
TIFF, JPEG, PDF (Compact, Searchable)
FAX SPECIFICATIONS
MODEM SPEED
Super G3: 33.6 kbps
G3: 14.4 kbps
RESOLUTION (dpi)
200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Letter
FAX MEMORY
Up to 256 Pages
SPEED DIALS
Max. 104
GROUP DIALS / DESTINATIONS
Max. 50 Dials
SEQUENTIAL BROADCAST
Max. 114 Addresses
FAX FEATURES
Rx Mode, Resolution, Two-sided Original, Density, Sharpness, Duplex Fax
SECURITY SPECIFICATIONS
NETWORK
IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP
WI-FI® AUTHENTICATION METHODS
WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER CONSUMPTION
Maximum: Approx. 1080 W or Less;
Average: Approx. 340 W;
Sleep Mode: Approx. 0.7 W;
Typical Electricity Consumption (TEC) Rating: 0.9 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver1
FOOTNOTES
1 For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
2 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
3 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
4 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
5 Replacement model may be new or refurbished quality.
Reviews
Product Disclaimer
* Two-year period assumes approximately 342 pages of printing per month in accordance with ISO/IEC 19752 (Letter/A4) using the two toner cartridges provided in box. Printing in excess of these amounts will result in toner lasting a shorter duration.
