imageCLASS MF465dw
Discontinued
- Wireless 4-in-1 (Print | Copy | Scan | Fax)
- Print up to 42 pages per minuteFootnote1 (BW)
- Uses Toner 070 / 070 High-Capacity Toner
- 250-sheet Standard Cassette, 100-sheet Multipurpose Tray, Expandable Paper Capacity of up to 900-sheets Using Optional Cassette AH-1
- 50-sheet Duplex (2-sided) Automatic Document Feeder (ADF)
- Auto 2-sided Printing, One-Pass 2-sided Scanning
- Large 5" Color Touchscreen for easy navigation
- Quick First Print Out Time (FPOT) of approximately 5 seconds
- ENERGY STAR® Certified, EPEAT Silver
In the box
Overview
Black & White All-in-One Laser Printer
The MF465dw has print, scan, copy, and fax capabilities and can print up to 42 pages per minute.
Compatible Toners
Features
Easy WiFi Setup
Connect your printer to a wireless network in four simple steps:
- STEP 1: PRESS WIRELESS LAN
Actual display screen may vary.
Easy WiFi Setup
- STEP 2: SELECT NETWORK
Easy WiFi Setup
- STEP 3: ENTER ENCRYPTION KEY / PASSWORD
Easy WiFi Setup
- STEP 4: FINALIZE
Fast Scan Speeds
Scan with ease using the 50-Sheet 2-sided Auto Document Feeder scanning both sides of the document in a single pass at speeds up to 100 images per minute (ipm) in Black and 80 images per minute (ipm) in Color.
Fast Printing Speeds
Get the job done quickly with your first print out in 5 seconds*, print speeds of 42 pages per minute* and auto 2-sided printing.
* Approximate values
Customizable 5-Inch Color Touchscreen
Organize your home screen to access the features you use the most.
Cloud Connectivity
Print or scan documents directly to or from cloud storage external webpages such as Dropbox, Google Drive, or OneDrive.
MF465dw Uses Canon Genuine Toner 070 / 070 H
High capacity toner option keeps up with your printing needs and limits toner replacement interruptions.
Yields 3,000 pages*
Optional Canon Genuine Toner 070 H
Yields 10,200 pages*
* Approximate page yield
Maximize Productivity
Expandable paper capacity allows for large print jobs:
- 250-Sheet Cassette Tray
- 100-Sheet Multipurpose Tray
- Optional 550-Sheet Cassette Tray AH-1 (Sold Separately)
Printer Dimensions
The MF465dw is packed with features and is also designed to fit in your home or workspace.
USB Flash Drive Connectivity
Print and scan directly from the printer using your USB Flash Drive.
Mobile Connectivity
Print and scan on the go using your compatible mobile device.
Compatible with Windows, Mac, Chromebook
Main Unit Specifications
Reviews
Brochures
imageCLASS MF462dw and MF465dw Brochure
03.03.25
1 MB
imageCLASS MF465dw Compatible Products
Product Disclaimer
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Wireless performance may vary based on terrain/distance between printer and wireless network clients.
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit usa.canon.com/mobile-app.
- Warranty program is subject to certain conditions and restrictions. See warranty card for details.
- AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
- Mopria® Print Service, available for free at the Google Play Store, requires a compatible Android 4.4 or later smartphone and tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network. Learn More.
