imageCLASS MF465dw II - All in One, Wireless, Duplex Laser Printer
7188C006
Special Price $329.99 Regular Price $540.99
4 interest free payments of $82.50 with
klarna Pay Later
Paypal Pay Later
In Stock
  • Wireless, Duplex 4-in-1: Print, Scan, Copy, Fax
  • Print up to 42 ppm
  • Easy Wireless Setup
  • 5-inch Touchscreen
  • Mobile Device Printing
Show more
Auto Replenishment Service to get ink and toner when you need it: Do not Enroll
*By enrolling to Auto Replenishment Service, you automatically agree to the terms and conditions.
Add an eCarePAK Extended Service Plan for added coverage. Learn More
Where to Buy
Overview
Designed for small / home offices and hybrid work environments, the imageCLASS MF465dw II model balances speedy performance and minimal maintenance. The MF465dw II is easy to set up and has a customizable, 5" touchscreen that delivers an intuitive user experience. The MF465dw II has fast print speeds of approximately 42 pages per minuteFootnote1 to keep up with your business. The MF465dw II uses high quality Canon Genuine Toner 070 / 070 H, for bold, crisp output your business can count on. Toner 070 yields approximately 3,000 pages and Toner 070 High-Capacity yields approximately 10,200 pages. The MF465dw II offers a plain paper capacity of up to 250 sheets in the standard cassette, 100 sheets in the multipurpose tray, and expandable paper capacity of up to 900 sheets using optional cassette AH-1 which holds up to 550 sheets. The 2-sided, automatic document feeder (ADF) holds up to 50-sheets and scans both sides of your document in a single pass using the one-pass scan function, which helps save you time. Easily connect wirelesslyFootnote2 from computers or mobile devices. Print using a variety of mobile apps, including the Canon PRINT appFootnote3 using your compatible mobile device.
imageCLASS MF465dw II Front View on a Desk
1. Automatic Document Feeder: Holds up to 50 sheets, and scans both sides of your document in 1 pass
2. Customizable, 5" Color Touchscreen
3. USB Device Printing Slot
4. Generous Paper Capacity: Holds up to 250 sheets
Features
Easy Wi-Fi Setup
Connect your printer to a wireless network in four simple steps.
Step 1: Press WI-FI Settings
Easy Wi-Fi Setup
Step 2: Select Network
Easy Wi-Fi Setup
Step 3: Enter Encryption Key / Password
Easy Wi-Fi Setup
Step 4: Finalize
Person Using Touchscreen on imageCLASS MF465dw II
Fast Scan Speeds
Scan with ease using the 50-sheet, 2-sided Auto Document Feeder scanning both sides of the document in a single pass at speeds up to 100 ipm in black and 80 ipm in color.
Fast Printing Speeds
Get the job done quickly with your first print out in 5 seconds1, print speeds of 37 pages per minute1 and auto 2-sided printing.
Customizable, 5-inch, Color Touchscreen
Organize your home screen to access the features you use the most.
USB Flash Drive Connectivity
Print and scan directly from the printer using your USB flash drive.
Person Placing Paper to be Scanned
Person Retriving Paper from imageCLASS MF465dw II
Person Inserting USB to imageCLASS MF465dw II
MF465dw Uses Canon Genuine Toner 070/070 H
High capacity toner option keeps up with your printing needs and limits toner replacement interruptions.
  • Toner 070 High Capacity Up to 10,200 pages
  • Toner 070 Up to 3,000 pages
imageCLASS MF465dw II Next to Toner Boxes
Mobile Connectivity
Print on-the-go with Canon PRINT app, Apple® AirPrint® and Mopria® Print Service.
Person Connecting Mobile Phone to imageCLASS MF465dw II
Printer Dimensions
The MF465dw II is packed with features and is also designed to fit in your home or workspace.
imageCLASS MF465dw II with Dimensions
Main Unit Specifications
Model Name
Functions
Print Speed
Up to 42 ppm (Letter)
Document Feeder
50 Sheet Duplex
First Print Out Time
Approx. 4.9 Seconds (Letter)
Print/Copy Resolution
Up to 1200 x 1200 dpi
Scan Resolution
Up to 600 x 600 dpi
Print/Copy Memory
1 GB (Shared)
Printer Language
UFR II, PCL6, PCL5, Adobe® PostScript 3®
Network Security
IP/MAC Address Filtering, IPSEC, TLS 1.3, SNMP V3.0, IEEE 802.1X, IPv4/IPv6, SMTP Authentication, POP3
Connectivity
USB 2.0 High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g/n
Operating Systems
Windows® 11 / 10 / 8.1 / Windows®Server2012 / 2012 R2 / 2016 / 2019 / 2022, Mac OS X (10.11 or later)
Paper Capacity
250-Sheet Standard Cassette, 50-sheet Duplex Automatic Document Feeder, 100-Sheet Multi-Purpose Tray
Min / Max Paper Size
Standard / Optional Cassette: 4.1 x 5.8 to 8.5 x 14 Inches / Multipurpose Tray: 3 x 5 Inches to 8.5 x 14 Inches
Secured Counter
Yes
USB Direct Print
JPG, TIFF, PDF
Display Panel
5 Inch, Color Touch LCD
Print Volumes
750-4,000 RMPV (Recommended Monthly Print Volume)
Energy Consumption
Approx: 1250 W (Max., w/o Accessories), 0.9 W (Standby), 0.1 W (Sleep Mode)
ENERGY STAR Certified
Yes
EPEAT
Silver
Box Dimensions
22.4" (W) x 21.5" (D) x 14.8" (H)
Box Weight
48.5 lbs.
Unit Dimensions
16.6" (W) x 18.1" (D) x 14.8" (H)
Unit Weight
34.4 lbs.
Reviews
Brochures
File Name
imageCLASS MF462dw II / MF465dw II Brochure
Date
10.22.25
File Size
2 MB
imageCLASS MF465dw II - All in One, Wireless, Duplex Laser Printer Compatible Products
Toner
Toner
Product Disclaimer
  1. Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
  2. Wireless performance may vary based on terrain/distance between printer and wireless network clients.
  3. Canon PRINT app is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
