Out Of Stock
imageCLASS X MF1238 II
ICX MF1238II
As low as $499.00
Out Of Stock
  • Print up to 40 ppm (BW)
  • Scan up to 70/26 ipm (300 dpi) (BW/Color, duplex)
  • Print up to 8-1/2” x 14”
  • 900-sheet maximum paper capacity
  • Black-and-White
    • Multifucntion
    • Compact
    • User-Friendly
    New
    Return Policy
    MAIN UNIT
    CORE FUNCTIONS
    Standard: Print, Copy, Scan, Send, Fax
    PROCESSOR
    Canon Custom Processor
    CONTROL PANEL
    Color Touch Panel
    MEMORY
    1 GB
    STANDARD INTERFACE CONNECTION
    USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
    PAPER CAPACITY (LETTER, 20 LB. BOND)
    Standard: 350 Sheets
    Maximum: 900 Sheets
    PAPER SOURCES (LETTER, 20 LB. BOND)
    Standard: 250-sheet Paper Cassette, 100-sheet
    Multipurpose Tray Optional: 550-sheet Paper Cassettes (Cassette Unit-AH1)
    PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
    Standard: 65 Sheets
    SUPPORTED MEDIA TYPES
    Cassettes: Thin, Plain, Recycled, Thick, Bond
    Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
    SUPPORTED MEDIA SIZES
    Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
    Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
    SUPPORTED MEDIA WEIGHTS
    Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2 )
    Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2 )
    WARM-UP TIME
    From Power On: 14 Seconds or Less
    From Sleep Mode: 4 Seconds or Less
    DIMENSIONS (W x D x H)
    Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm)
    INSTALLATION SPACE (W x D x H)
    Standard (Desktop): 17.9" x 34.8" x 26.2" (553 mm x 983 mm x 664 mm)
    Fully Configured: 17.9" x 34.8" x 31.3" (453 mm x 883 mm x 795 mm)
    WEIGHT5
    Unit: Approx. 35.8 lb. (16.2 kg)
    Boxed Weight: Approx. 45.9 lb. (20.8 kg)
    OPERATING SYSTEM
    UFR II/PCL/PS: Windows® 7/Windows 8.1/ Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/Windows Server 2012 R2/ Windows Server 2016/Mac OS X v10.8.5 (or later)
    PRINT SPECIFICATIONS
    PRINTING METHOD
    Laser Beam Printing
    PRINT SPEED (BW)6
    Up to 40 ppm (Letter); Up to 32 ppm (Legal)
    FIRST PRINT OUT TIME
    Approx. 5.3 Seconds
    RECOMMENDED MONTHLY PAGE VOLUME
    750 - 4,000 Pages
    PRINT RESOLUTION (dpi)
    600 x 600
    STANDARD PAGE DESCRIPTION LANGUAGES
    UFR II, PCL®6, PCL®5, Adobe PostScript 3®
    DOUBLE-SIDED PRINTING
    Automatic (Standard)
    DIRECT PRINT
    Available from USB Memory (JPEG, TIFF, PDF)
    PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1
    Apple® AirPrint®, Canon PRINT Business, Mopria™ Print Service, uniFLOW Secure Mobile Printing7
    FONTS
    PCL: 93 Fonts
    PS: 136 Fonts
    PRINT FEATURES
    Secure Print, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations
    COPY SPECIFICATIONS
    COPY SPEED
    FIRST-COPY-OUT TIME (LETTER)
    Approx. 6.2 Seconds
    COPY RESOLUTION (dpi)
    600 x 600
    COPY SIZE
    Platen: Up to Letter
    ADF: Up to Legal
    MULTIPLE COPIES
    Up to 999 Copies
    MAGNIFICATION
    25% - 400% (1% Increments)
    PRESET REDUCTIONS
    25%, 50%, 64%, 78%
    PRESET ENLARGEMENTS
    129%, 200%, 400%
    COPY FEATURES
    Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
    SCAN SPECIFICATIONS
    TYPE
    Single-Pass Duplexing Automatic Document Feeder
    DOCUMENT FEEDER PAPER CAPACITY
    50 Sheets (20 lb. Bond)
    DOCUMENT FEEDER SUPPORTED MEDIA SIZES
    Legal, Letter, Statement
    DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
    Single and Double-sided scanning: 13-28 lb. Bond (50-105 g/m2 )
    PLATEN ACCEPTABLE ORIGINALS
    Sheet, Book
    PULL SCAN
    ScanGear MF for TWAIN, WIA, and ICA
    SCAN RESOLUTION (dpi)
    300 x 600, 600 x 600
    SCAN-TO-MOBILE DEVICES
    SCAN SPEED (LETTER) (BW/COLOR)
    Single-sided: 13/38 ipm (300 x 300 dpi) (Color/BW)
    Double-sided: 26/70 ipm (300 x 300 dpi) (Color/BW)
    MEMORY MEDIA
    Standard USB Memory (JPEG, TIFF, PDF)
    SEND SPECIFICATIONS
    DESTINATION
    Email/Internet FAX (SMTP), SMB, FTP, Super G3 FAX
    ADDRESS BOOK
    LDAP (50)/Local (300)/Speed Dial (281)
    SEND RESOLUTION (dpi)
    600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
    COMMUNICATON PROTOCOL
    File: FTP, SMB
    Email/iFax: SMTP, POP3, iFax (Simple)
    FILE FORMAT
    Standard: TIFF, JPEG, PDF (Compact, Searchable)
    Optional: PDF (Encrypted, Digital Signature)
    FAX SPECIFICATIONS
    MODEM SPEED
    Super G3: 33.6 Kbps
    G3: 14.4 Kbps
    COMPRESSION METHOD
    MH, MR, MMR, JBIG
    RESOLUTION (dpi)
    400 x 400, 200 x 400, 200 x 200, 200 x 100
    SENDING/RECORDING SIZE
    Statement to Legal
    FAX MEMORY
    Up to 512 Pages
    SPEED DIALS
    Max. 281 Dials
    GROUP DIALS/DESTINATIONS
    Max. 299 Dials
    SEQUENTIAL BROADCAST
    Max. 310 Addresses
    MEMORY BACKUP
    Yes
    FAX FEATURES
    RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax
    SECURITY SPECIFICATIONS
    AUTHENTICATION
    Standard: Embedded Universal Login Manager, Department ID Authentication
    Optional: uniFLOW, uniFLOW Online
    DATA
    Standard: Verify System at Startup
    NETWORK
    Standard: IP/MAC Address Filtering, IPSEC, TLS 1.3, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
    DOCUMENT
    Standard: Secure Print, High Compression PDF, Searchable PDF
    Optional: Encrypted PDF, User and Device Signatures
    WI-FI AUTHENTICATION METHODS
    Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
    Wi-Fi Access Point: WPA2-PSK (AES)
    ENVIRONMENTAL SPECIFICATIONS
    OPERATING ENVIRONMENT
    Temperature: 50 to 86º F
    Humidity: 20 to 80% RH (No Condensation)
    POWER REQUIREMENTS
    AC 120-127 V:6.5 A, 60 Hz
    POWER CONSUMPTION
    Maximum: Approx. 1330 W
    Standby: Approx. 10 W
    Sleep Mode: Approx. 0.9 W
    Typical Electricity Consumption (TEC) Rating: 0.34 kWh
    STANDARDS
    ENERGY STAR® Qualified, Currently rated EPEAT Silver3
    CONSUMABLES
    TONER
    Toner T08 Black - Yields 11,000 Pages
    Reviews
    Product Disclaimer
    1. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
    2. Please reference user manuals for details on settings available to export.
    3. For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
    4. Subscription to a third party cloud service is required, and subject to third party terms and conditions.
    5. Includes consumables.
    6. Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
    7. Requires optional uniFLOW Online/uniFLOW
    8. Attachment kit required.
    9. Ask Dealer for reader compatibility information.
    10. Limited warranty program is subject to certain conditions and restrictions. See warranty card for details.
