imagePROGRAF GP-4000
GP-4000
As low as
$0.00
Out Of Stock
- 44" Large Format printer
- 10-Color pigment based ink plus Fluorescent Pink ink
- Hits 99% of the colors in the PANTONE FORMULA GUIDE solid coated
- Intelligent media handling
- Color calibration
Need to order more than 10?
Learn More
Need help making a purchase? Contact a Sales Expert at 800-385-2155>
Return Policy
Main Unit Specs
Printer Type
10-color pigment ink plus Fluorescent Pink Ink
Number of Nozzles
Total: 18,432
All colors: 1,536 nozzles
Nozzle Pitch
600 dpi x 2
Non-firing nozzle detection and compensation
Print Resolution (Up to)
2400×1200dpi (Max)
OS Compatibility
32bit: Windows® (Vista/7/8, 8.1/10)
64bit: Windows 7, Windows 8.1, Windows 10Windows Server 2008R2 , Windows Server 2012/2012R2Windows Server 2016 , Windows Server 2019
Mac (OS X 10.10.5~OS10.11), (OS 10.12~macOS 10.14)
Standard Interfaces
USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
USB Thumb Drive
USB Thumb Drive
Ink Droplet Size
Minimum 4 picoliter
Ink Capacity
160ml, 330ml, or 700ml per color
Ink Type
10 Pigment color basedplus Fluorescent Pink Ink
Color Set
Photo Black, Matte Black, Cyan, Magenta, Yellow, Green, Gray, Red, Orange, Violet + Fluorescent Pink
Hard Drive
500 GB
Media Width
Cut Sheet - 6”- 44”
Roll Feed - 6”- 44”
Roll Feed - 6”- 44”
Media Thickness
Roll: 0.07 - 0.8 mm (2.8 - 31.5mil)
Maximum Roll Print Length
Roll Feed - 59 (18 meters)**
Maximum Media Roll Diameter
6.7” or less (170mm)
Borderless Printing Width
All Sizes
Paper Feed Method
Roll Feed: One Roll, Front-loading, Front Output
Manual Feed: Front-loading, Front Output
Languages
Swift Graphic Raster (SGRaster)
Noise Level Approx
Operation: 49 dB (A) or less
Accoustic Power: 6.6 Bels or less
Physical Dimensions
46” (H) x 63” (W) x 39” (D)
Weight
approx. 274 lbs
Power Source
AC 100-240V(50-60Hz)
Power Consumption
Maximum: 99 W or less
Standby 2.0 W or less
Power Off: 0.3 W or less
Operating Environment
Temperature: 59 - 86°F
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
- Print Head (PF-10)
- Maintenance Cartridge (MC-30)
- Ink Tanks 160ml, 330ml, 700ml
Software Included
Professional Print & Layout, Quick Utility Toolbox, Accounting Manager, Device Management Console, Media Configuration Tool, PosterArtist Lite (PC only), PosterArtist (Available for purchase, PC only), Printer Driver Extra Kit (Free Layout and Advanced Preview), Direct Print Plus (PC only), Free Layout Plus (PC only)
Product Disclaimer
* In major aqueous pigment large-format inkjet printer manufactures (excluding sublimation transfer systems). As of 09/27/2021, (Canon research)
- Should read as follows: As of September 27, 2021, according to professional services performed by Pantone under License Agreement between Canon, Inc. and Pantone LLC.
- PANTONE PASTELS & NEONS GUIDE Coated color gamut coverage rate is 97% for GP-4000/2000 when using Photo Paper Pro Platinum with imagePROGRAF printer driver at [Poster/Photo (Fluorescent)] [Highest] (600dpi).
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
- Professional Print & Layout software is compatible with Adobe Photoshop CS5/CS6/CC/CC (2014)/CC (2015), 2019 or later, Adobe Photoshop Lightroom 3/4/5/6, and Canon Digital Professional 3.12 or later.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
