imagePROGRAF PRO-1000
0608C002
Discontinued
The imagePROGRAF PRO-1000 is no longer available, but you can find similar products below.
Wide Format Professional Inkjet Photo Printer
Similar models to the imagePROGRAF PRO-1000
Overview
Professional photographers openly share what they need, want, and even don't want in a printer. Like stunning black and white prints with deep blacks and detailed gradations. A wide color gamut that accurately reproduces even the most difficult colors. And at Canon, we listen. Introducing the Canon imagePROGRAF PRO-1000. A 17" wide format professional printer with an 11-Color plus Chroma Optimizer ink system that does it all. Arguably one of the best printers we’ve ever engineered. Distinguished by a bold red line.
imagePROGRAF
Features
ANTI-CLOGGING TECHNOLOGY
The FINE print head institutes a tubular ink delivery system. This generates faster print speeds and reduces the possibility of clogging. Additionally, ink ejection conditions are precisely checked with sensors, and if a clog is detected, another nozzle automatically provides backup. In addition to preventing wasted prints due to clogging, this also reduces the frequency of which nozzle cleaning is required.
  • SMARTER NOZZLES - Engineered with 18,432 nozzles and sensors that continuously monitor status and deliver optimum results.
imagePROGRAF
AIR FEEDING SYSTEM
The Canon Air Feeding System prevents each page from skewing for accurate ink placement, regardless of paper type. A series of openings located on top of the platen vacuum-grip the paper as it feeds through the printer. The Air Feeding system creates a printing environment that keeps a consistent height between the print head and the media being used. Variances in height can occur due to paper curl or variations in temperature and humidity. A consistent level surface leads to remarkable ink droplet accuracy and improved image quality.
  • AIR FEEDING SYSTEM - A series of openings located on top of the platen vacuum-grip the paper as it feeds through the printer.
  • SKEW CORRECTION - Skew Correction function guarantees that all types of paper, including thick fine art type papers, can be fed without the need for reprints.
Air Feeding System Example
LUCIA PRO INK SYSTEM
The LUCIA PRO 11-color plus Chroma Optimizer ink system satisfies the demands of the most critical photographer or graphic artist. Denser droplet placement provides a broader color gamut and improved gloss uniformity for superb glossiness and anti-bronzing. Incredibly accurate color reproduction, outstanding image clarity, and enhanced detail in darker areas distinguish each print. On fine art papers, higher black density renders even the finest shadow detail, for a print that becomes a work of art.
  • 11-INK SYSTEM PLUS CHROMA OPTIMIZER - Utilizing new pigment ink with modified compositions and new colors, LUCIA PRO INKS have enabled a broader color gamut and greater shadow detail reproduction in dark areas.
  • Increased density of ink on the paper improves color gamut.
  • Even light reflection contributes to improved glossiness and image clarity.
  • Contributes to anti-bronzing on glossy paper.
  • LUCIA PRO INKS
LUCIA 11-Color Ink Cartridges
BLACK DENSITY AND DARK SHADOW AREAS
Deep blacks, which make the image crisp, and precise gradation can be attained across all media types. On glossy media, light reflection off of a printed image is stabilized by the Chroma Optimizer and the newly formulated Photo Black ink. Overall, your images will enjoy an enhanced dynamic range.
  • CORE TECHNOLOGIES - The print head, ink and image processing engine mounted on the imagePROGRAF PRO-1000 provide high levels of image quality and productivity.
Example of Light Reflection on Printed Image
WIDE COLOR GAMUT
A new ink system adopts 11-color inks and Chroma Optimizer ink. This system helps you achieve an improvement in color-reproduction, image clarity, and enhanced darker areas. It faithfully reproduces colors and dark areas crucial for printing works of art. The newly formulated blue and magenta inks will help recreate the finest details when printing nightscapes and sunsets.
Color Gamut
NO SWITCHING OF BLACK INKS
On other printers, switching from Matte Black to Photo Black consumes a significant amount of ink and time. The imagePROGRAF PRO-1000 is designed to work seamlessly when changing media types. Matte Black and Photo Black inks have their own dedicated nozzles, so no switching is necessary. You can print on fine art paper then glossy paper with no worries, no changes, and no waste.
Black Ink Cartridges
FAST PHOTO PRINTING
At the heart of the imagePROGRAF PRO-1000 is a 1.28" wide print head. Expanding the printing area by 50% with each movement of the print head, print speeds are drastically improved. This increases your productivity through efficient high-speed printing.
  • L-COA PRO - This high-precision control engine performs the high-speed processing of massive volumes of image data, generates the printing data, and controls the optimal ink layout for the purpose of achieving high resolution prints. It represents the brain of the imagePROGRAF PRO-1000.
Bottom of Ink Cartridge
PRINT STUDIO PRO V 2.0 PLUG-IN
This powerful plug-in software provides professional photographers with intuitive printing solutions. New functions added provide enhancements to your printing workflow.
  • CONTRAST - By using this function in combination with the Digital Lens Optimizer included in Digital Photo Professional, you can print sharp, high-definition images without losing any of the qualities present when the image was photographed.
  • SOFT PROOFING - Allows for visual proofing of the final print, taking into account for color reproduction for a specific paper type.
  • IMPROVED UI - Enjoy intuitive operation and settings such as Favorites, History, and several Color Adjustment Functions.
  • SEAMLESS INTEGRATION - Seamlessly works with leading image editing software programs.
  • 16-BIT WORKFLOW - Allows for 16-bit processing of images to dramatically improve your final output.
Photo in Editing Software
PRINTER MANAGEMENT SOLUTIONS
Every detail in your print must be perfect, why not have the same obsession for your workflow? The imagePROGRAF PRO-1000 is precisely managed with these powerful management tools.
  • QUICK UTILITY TOOL BOX - Provides quick access to all the Printer Management Tools.
  • MEDIA CONFIGURATION TOOL - Enables complete customization of the media menu in both the driver and the printer by re-arranging paper types, hiding unused media, and even creating a custom set of printer parameters for your preferred media. Adjustments such as print head height and vacuum strength can be manually entered and saved.
  • ACCOUNTING MANAGER - Account for every sheet of paper and the amount of ink that was used. Accounting Manager allows you to accurately assign and track the costs of every single job.
  • DEVICE MANAGEMENT CONSOLE - The Device Management Console allows you to manage multiple printers, all in one convenient place. Monitor, control and calibrate imagePROGRAF PRO-1000 printers regardless of location to ensure the consistency that you demand from your printers.
  • COLOR CALIBRATION TOOL - The Color Calibration Tool enables you to ensure the quality of each and every one of your prints, regardless of which imagePROGRAF PRO-1000 in your studio you are printing on.
Icons of Different Features
Main Unit Specs
Printer Type
Wireless Professional Inkjet Printer
Printing Method
FINE: Full-Photolithography Inkjet Nozzle Engineering
Features
AirPrint4
Mopria® Print Service*
Borderless Printing
Canon PRINT app5
Grayscale Photo Printing
Photo Printing
Wireless PictBridge6
Wireless Printing7
Pro Gallery Print8
PIXMA Cloud Link9
Print Speed (up to)
17" x 22" Bordered Photo (Color):
Approx. 4 minutes 10 seconds3
13" x 19" Bordered Photo (Color):
Approx. 2 minute 30 seconds3
Number of Nozzles
1,536 Nozzles x 12 Inks, Total: 18,432
Nozzle Pitch
600 dpi x 2
Print Resolution (Up to)
Color: Up to 2400 x 1200 dpi4
Black: Up to 2400 x 1200 dpi4
OS Compatibility
Computer Operating Systems:
Mac:16 Mac OS X v10.7.5 - 10.10.x
Windows:17 Windows® 10, Windows® 8, Windows 8.1, Windows 7, Windows 7 SP1, Windows Vista® SP1, Vista SP2, Windows Server 2012,2012 R2, 2008,2008 R2
Mobile Operating Systems: iOS®, Android
Standard Interfaces
Hi-Speed USB 2.0
Ethernet (10/100Base -T/TX)
PictBridge (Wireless LAN)6
Wireless LAN (IEEE 802.11b/g/n)7
Ink Droplet Size
Type: Pigment Based LUCIA PRO Ink Technology
Ink Capacity
80ml
Paper Sizes
17" x 22", 14" x 17", 13" x 19", 11" x 14", 10" x 12", 8.5" x 11", 8" x 10", 5" x 7", 4" x 6"
Maximum Print Length
25.5 Inches"
Media Thickness
Rear Tray: Maximum 0.3 mm
Manual Feed Slot: 0.1 mm - 0.7 mm
Paper Feed Method
Rear Tray and Manual Feed Slot
Genuine Canon Media Compatibility
Plain: Plain Paper
Super High Gloss: Photo Paper Pro Platinum
Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy
Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster
Matte: Matte Photo Paper, Photo Paper Pro Premium Matte
Fine Art: Premium Fine Art Smooth, Premium Fine Art Rough
Other (non-Canon): Hagaki papers, Baryta Photo Paper, Lightweight Photo Paper, Heavyweight Photo Paper, Extra Heavyweight Photo Paper, Heavyweight Fine Art Paper, Washi, Canvas, High Density Fine Art Paper, Recycled paper and chlorine-free paper can be used
Languages
Printer Languages:Printer Language: Swift Graphic Raster
Job Control Language: IVEC
Status Reply: IVEC
Noise Level Approx
41.0 dB(A)12
Physical Dimensions
28.5" (W) x 17.1" (D) x 11.2" (H)
Weight
71.2 lbs.
Power Consumption
Maximum: 37 W13
Standby: 2.5 W
Power Off: 0.4 W
Operating Environment
Temperature: 59 - 86 F° (15 - 30 C°)
Relative Humidity: 10 - 80% (No Condensation)
Warranty
1-Year limited warranty with InstantExchange Program. 1-Year toll-free U.S.-based technical phone support.19
Software Included
Setup Software & Users Guide CD-ROM
imagePROGRAF PRO-1000 Printer Driver
Print Studio Pro v 2.018
Management Tools:
    Quick Utility Toolbox
    Media Configuration Tool
    Accounting Manager
General Features
12 Individual Ink Tanks, Advanced Pattern Print, Index Print, Fine Art Paper Support, L-COA PRO Image Processing Engine, Non-Firing and Compensation Function, Real Time Control of Ink Ejection, Air Feeding System, Color Density Sensor, Calibration Link, Contrast Reproduction
Certifications
Rated EPEAT Silver
Energy Star Certified
RoHS Directive Certification
Printer Memory
1 GB (Standard)
Display
3.0" LCD
Head Configuration
12 Ink Integrated Type (4 Ink Chips x 3)
Storage Environment
Temperature: 32 - 104 F° (0 - 40 C°)
Relative Humidity: 5 - 95% (No Condensation)
Reviews
Resources
File Name
PosterArtist Online Specifications
Date
08.12.22
File Size
0.1 MB
File Name
Large Format Full Line Brochure
Date
09.04.25
File Size
25.6 MB
Intro to Color
Intro to Color
Watch John Thorburn’s “Intro to Color” illustrated presentation of color fundamentals including color in light, color appearance, and color vision. John provides a brief overview of color temperature and warm/cool contrast from the points of view of physics, art instruction, and gray balance in print. The video concludes with a presentation of the CIELab or “Lab” color appearance model, as it relates to color opponency, and as it is used as a predictor of color appearance in color management for print.
Intro to Color
Professional Print and Layout Software Overview
Learn how to access and navigate Canon's Professional Print & Layout Software.
Intro to Color
How To Nest Images In Professional Print & Layout
Learn how to nest images using Canon's Professional Print & Layout Software.
How To Do Basic Prints Using Professional Print & Layout
Learn how to do basic prints using Canon's Professional Print & Layout Software.
How To Create Job Settings In Professional Print & Layout
Learn how to do create job settings using Canon's Professional Print & Layout Software.
How To Create Slots and Templates in Professional Print & Layout
Learn how to create slots and templates using Canon's Professional Print & Layout Software.
How To Use Advanced Digital Image Tools In Professional Print & Layout
Learn how to use advanced digital image tools in Canon's Professional Print & Layout Software.
How To Use Color Management in Professional Print & Layout
Learn how to use color management in Canon's Professional Print & Layout Software.
Introduction to Professional Print & Layout
Canon's Professional Print & Layout (PPL) workflow software for imagePROGRAF PRO Series printers for professional photo printing. PPL offers intuitive operation image preview, custom layouts and color management - all supported in a seamless photo printing experience.
imagePROGRAF Print Plug-In for Adobe Photoshop
See how the imagePROGRAF printers, combined with Canon's Digital Photo Professional and Adobe Photoshop, can help improve the quality of prints with a variety of advanced features. For more videos, check out the "imagePROGRAF Software Tutorials Featuring Eddie Tapp" series on the CDLC: http://learn.usa.canon.com/galleries/...
imagePROGRAF Layout Plug-In (Gallery Wrap)
Learn how to utilize the Layout Plug-in for Photoshop to customize prints for canvases and paper on the imagePROGRAF printer. For more videos, check out the "imagePROGRAF Software Tutorials Featuring Eddie Tapp" series on the CDLC: http://learn.usa.canon.com/galleries/...
Learn How to Calculate a Large-Format Printer's Cost Per Print
How much does your large format print cost? Using Canon Accounting Manager, you can calculate the cost of every print running off your Canon imagePROGRAF large format printer.
Learn how to print and share your large format files using Canon Direct Print & Share
Share content and print large format files using Canon Direct Print & Share.
Learn how to nest and print images using canon imagePROGRAF Free Layout
Need to print multiple images on one page? Then this video is for you. We will walk you through the complete nesting feature of the Canon imagePROGRAF Free Layout tool.
How to Print a Poster from a PDF File using the imagePROGRAF Printer Driver
Learn how to quicly produce a poster from a PDF file.
How to Print a Banner using the imagePROGRAF Print Plug-in for Microsoft® Powerpoint®
Learn how to print banners in no time using Microsoft® Powerpoint®.
How to print on an Canon imagePROGRAF Large Format Printer
Printing on a Canon imagePROGRAF large format printer has never been easier. This video takes a look how to print on an Canon imagePROGRAF large format printer using the Canon Printer Driver.
ImagePrint Red Overview
Introduction to the Colorbyte Software and Graphtec Cutter.
How to Install a blade on the Graphtec Cutter
Learn how to install a blade on the Graphtec Cutter.
How to set the Course Adjustment on the Graphtec Cutter
Learn how to set the course adjustment for the knife on the Graphtec Cutter.
How to set the Course Adjustment on the Graphtec Cutter - Method 2
Learn how to set the course adjustment for the knife on the Graphtec Cutter - Method 2.
How to load paper in the Graphtec Cutter
Learn how to load paper in the Graphtec Cutter.
How to set speed on the Graphtec Cutter
Learn how to set the speed on the Graphtec Cutter.
How to cut using the Graphtec Cutter
Learn how to cut using the Graphtec Cutter.
How to set the fine adjustments on the Graphtec Cutter
Learn how to set the fine adjustments on the Graphtec Cutter.
How to install the cutting pen on the Graphtec Cutter
Learn how to install the cutting pen on the Graphtec Cutter.
Introduction to the online version of PosterArtist
Bring your ideas to life with the online version of PosterArtist. This template-driven, poster creation application makes creating posters, banners and flyers simple..
imagePROGRAF PRO-1000 Compatible Products
Ink
Ink
Product Disclaimer
Specifications are subject to change without notice. All printer output images are simulated.
*Requires Android mobile device with Android 4.4 operating system or later with the Mopria® Print Service pre-loaded with that device and the compatible imagePROGRAF printer on the same wireless network. Mopria® is also available on Android 4.4 mobile devices with a download of the Mopria® Print Service from Google Play. Learn more. 1. Ink droplets can be placed with a pitch of 1/24 inch at minimum. Results may vary depending on printer driver settings. 2. Photo print speed is based on the default setting using ISO/JIS-SCID N2. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. 3. When using Canon Photo Paper Pro Luster (LU-11) . 4. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported. 5. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7. or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 82.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported. 6. DPS over IP compatible device required. 7. Wireless printing requires a working network with wireless 82.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. 8. Requires an Internet connection and the Pro Gallery Print app, available for free on the App Store. Compatible with iPad 2, iPad (3rd/4th generation), iPad Air, iPad Air 2 or later and devices running iOS 7. or later. Compatible with SmugMug and Zenfolio web services. 9. Requires an Internet connection. 1. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity, and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, drying time, display/storage conditions, and environmental factors. 11. Acoustic Noise is measured based on ISO7779 standard. 12. When printing ISO/JIS-SCID N2 pattern on Photo Paper Pro Platinum (PT-11) using default settings. 13. When printing ISO/JIS-SCID N2 pattern on A4 size Photo Paper Pro Platinum (PT-11) using default settings. 14. For the temperature and humidity conditions of papers such as photo paper, refer to the paper’s packaging or the supplied instructions. 15. Support Programs are subject to change without notice. 16. Internet Connection required during software installation. 17. Operation can only be guaranteed on a PC with pre-installed Windows 1, Windows 8.1, Windows 8, Windows 7, Vista or XP. 18. Print Studio Pro v 2. plug-in software is compatible with Adobe Photoshop CS5/CS6/CC/CC(214)/CC(215), Adobe Photoshop Elements 11/12/13, Adobe Photoshop Lightroom 3/4/5/6 and Canon Digital Photo Professional 3.12 or later. 19. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details. Specifications are subject to change without notice. All printer output images are simulated. 1. Ink droplets can be placed with a pitch of 1/24 inch at minimum. Results may vary depending on printer driver settings. 2. Photo print speed is based on the default setting using ISO/JIS-SCID N2. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. 3. When using Canon Photo Paper Pro Luster (LU-11) . 4. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported. 5. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7. or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 82.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported. 6. DPS over IP compatible device required. 7. Wireless printing requires a working network with wireless 82.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. 8. Requires an Internet connection and the Pro Gallery Print app, available for free on the App Store. Compatible with iPad 2, iPad (3rd/4th generation), iPad Air, iPad Air 2 or later and devices running iOS 7. or later. Compatible with SmugMug and Zenfolio web services. 9. Requires an Internet connection. 1. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity, and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, drying time, display/storage conditions, and environmental factors. 11. Acoustic Noise is measured based on ISO7779 standard. 12. When printing ISO/JIS-SCID N2 pattern on Photo Paper Pro Platinum (PT-11) using default settings. 13. When printing ISO/JIS-SCID N2 pattern on A4 size Photo Paper Pro Platinum (PT-11) using default settings. 14. For the temperature and humidity conditions of papers such as photo paper, refer to the paper’s packaging or the supplied instructions. 15. Support Programs are subject to change without notice. 16. Internet Connection required during software installation. 17. Operation can only be guaranteed on a PC with pre-installed Windows 1, Windows 8.1, Windows 8, Windows 7, Vista or XP. 18. Print Studio Pro v 2. plug-in software is compatible with Adobe Photoshop CS5/CS6/CC/CC(214)/CC(215), Adobe Photoshop Elements 11/12/13, Adobe Photoshop Lightroom 3/4/5/6 and Canon Digital Photo Professional 3.12 or later. 19. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details. Receive 2 FREE Pro Paper Sampler Packs - Offer valid April 1, 221 12: a.m. through April 3, 221 11:59 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 5 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
