Add to Cart
imagePROGRAF TA-30 without Stand
TA-30 WOS
As low as $3,105.00
In Stock
  • 36" Large Format Printer
  • 5-Color pigment based ink system
  • Print 104 24x36 posters per hour (31 Sec/D sized print)
  • Wireless printing
  • Over $250 worth of ink included - Print more out of the box
  • Minimize disruption in the workplace
  • Compact design
This printer is designed to be used with Canon ink cartridges; not third party ink.
New
Return Policy
Main Unit Specs
Printer Type
5-Color 36-inch Printer
Number of Nozzles
Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
Nozzle Pitch
1200 dpi
Non-firing nozzle detection and compensation
Print Resolution (Up to)
2400x1200dpi (Max)
OS Compatibility
Windows® 7, 8.1, 10 (32/64bit)
Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit)
Macintosh OS X v10.10.5-v10.12x
Standard Interfaces
USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Ink Droplet Size
Minimum 5 picoliter
Pigment Ink
Ink Capacity
55 ml per color
Color Set
Pigment: Matte Black, Black, Cyan, Magenta, Yellow
Buffer Ram
2 GB (Physical)
Media Width
Cut Sheet - 8”- 17”
Roll Feed - 8” - 36”
Media Thickness
0.07-0.8mm
Maximum Media Roll Diameter
5.9” (150mm)
Borderless Printing Width
8” - 36”
Paper Feed Method
Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Top Loading, Front Output
Languages
SGRaster, HPGL/2, HP-RTL, JPEG
Noise Level Approx
Operation: 42 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 5.8 Bels
Physical Dimensions
18“ x 51“ x 30“ (H x W x D)
Weight
approx.97 lbs (roll holder included, no inks, no print heads)
Power Source
AC 100-240V (50-60Hz)
Power Consumption
Maximum: 59W or less
Standby 3.6W or less
Power Off: 0.3W or less (Compliant with Executive Order)
Operating Environment
Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
  • Print Head (PF-06)
  • Maintenance Cartridge (MC-31)
  • Ink Tanks (PFI-030)
  • Cutter Blade (CT-08)
Software Included
TA Unified Printer Driver, Accounting Manager, Apple AirPrint, Canon Print Service, Device Management Console, Direct Print & Share, Free Layout Tool, Free Layout Plus, imagePROGRAF Printer Driver for Windows®/Mac®, Media Configuration Tool, Optimized Driver for AutoCAD, Canon PRINT Inkjet Selphy, Easy Photo Print Editor
Reviews
Product Disclaimer
Recycled paper and chlorine-free paper can be used with this product.
*Based on information from HP.com for the T130 and Epson.com T3170 as of August 2019.
  1. Plain Paper, Fast (Q5) mode.
  2. Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
  3. Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  4. Your server must be compatible with a WebDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof are based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions.
Canon and imagePROGRAF are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Wi-Fi is a registered trademark of the Wi-Fi Alliance. Android is a trademark of Google Inc. Apple, AirPrint, iPad, iPhone, iPod touch, Mac and TimeCapsule are trademarks of Apple Inc., registered in the United States and other countries. Microsoft, Office, Windows, Outlook, Word, Excel and PowerPoint are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries. Autodesk, the Autodesk logo and AutoCAD are registered trademarks or trademarks of Autodesk, Inc., and/or its subsidiaries and/or affiliates in the USA and/or other countries. All referenced product names and trademarks are the property of their respective owners. Specifications and availability dates are subject to change without notice. Not responsible for typographical errors. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
