imagePROGRAF TC-20
TC-20
As low as $699.00
4 interest free payments of $174.75 with
canon-klarna-paylater-icon
canon-paypal-paylater-icon
Out Of Stock
Estimated ship date
  • 24" desktop roll & cut sheet printer
  • 4-Color pigment bottle ink system
  • Ships standard with 280ml of ink
  • Automatic sheet feeder
  • EPEAT Gold Certified
Show more
Return Policy
Overview
Whatever your office type – small, home, business or temporary
Canon’s got you covered with the 24” imagePROGRAF TC-20. Designed to fit in environments with limited space, this 24” desktop printer is one of the smallest in its class. It combines Canon proven product technology such as ink bottles, an automatic sheet feeder, roll paper feeding and high-precision printing in a compact model that can benefit a variety of settings, including small offices, home offices, temporary workspaces and schools. Perfect for printing large colorful flyers and posters for advertisements, health & safety signage, announcements, as well as CAD renderings and technical documents.
imagePROGRAF TC-20
Performance
  • Automatic Sheet Feeder Included
  • Roll-fed to cut-sheet paper feeds let you easily print documents up to 24-inches wide, as well as automatically feed up to 100 sheets of letter or up to 50 sheets of 11" x 17" paper
  • Touchscreen Operation Panel: Intuitive touchscreen control panel and animated installation guides provide quick-and-easy printer setup
  • Easy to Use: Top and front interior access takes the hassle out of refilling ink tanks, replacing paper roll, and performing routine maintenance
  • 280ml of ink included: High-capacity ink bottles provide 70ml of ink per bottle
  • Excellent Print Quality: 4-color ink bottle system delivers crisp text and vibrant images
image of the imagePROGRAF TC-20
Automatically feed up to 100 sheets of letter or up to 50 sheets of 11” x 17” paper for greater print flexibility.
Media Handling
Media Handling
From roll-fed to cut-sheet paper, you get the versatility to print 24”-wide output as well as letter, 11” x 17”, and more, directly from your home office.
Print More
Print More
The imagePROGRAF TC-20 ships standard with 280 ml of ink – 70 ml per ink bottle – the most in it’s class!
Easy to Fill
Easy to Fill
Ink bottles are keyed so they only fit and fill the intended color ink tank. The design helps to create a spill-free process that makes re-filling a breeze.
Diverse Business Use
Perfect for Small Offices and Businesses
Architecture and Engineering
Classrooms
Classrooms
PosterArtist
Easily create posters and flyers from a free, web-based, template-driven poster creation application.
Bring Your Ideas To life
Large Format Media
Canon inks and media deliver exceptional beauty and longevity to your prints. We offer a wide range of media types including matte, canvas, glossy and adhesive backings.
Image Alt Text
EPEAT® Gold Registered Product
This product is EPEAT® Gold registered in the U.S.A. EPEAT is the world’s premier ecolabel for electronics. EPEAT is owned and operated by the Global Electronics Council® (GEC), a mission-driven non-profit that seeks to create a world with only sustainable electronics. Manufacturers can register products under EPEAT based upon the device’s ability to meet required and optional EPEAT criteria that address impacts across the full product life cycle.
EPEAT Gold Logo
Award-Winning Design
The Canon imagePROGRAF TC Series was recognized by iF International Forum Design GmbH with a 2023 iF Design Award. Established in 1953, the iF Design Awards are recognized internationally as one of the most prestigious awards within the field of design. The compact body size and fully integrated high-capacity ink tanks of the imagePROGRAF TC Series are just two design features which contributed to this recognition.
iF Design Award 2023
Main Unit Specs
Printer Type
4-Color 24-inch Printer
Number of Nozzles
Total: 4,352
MBK: 1,280 nozzles
C, M, Y, BK: 1,024 nozzles each
Nozzle Pitch
1200 dpi
Print Resolution (Up to)
2400×1200dpi (Max)
OS Compatibility
32-bit: Windows® 7, 8.1, 10
64-bit: Windows® 7, 8.1, 10/11, Server 2008 R2, 2012, 2012 R2, 2016, 2019, 2022
Mac: macOS X v10.14.6-v12.x
Standard Interfaces
USB 2.0 High-Speed
10/100 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Ink Capacity
70 ml per color
Ink Types
Pigment Ink
Color Set
Pigment: Black, Cyan, Magenta, Yellow
Buffer Ram
1 GB (Physical)
Media Width
Cut Sheet - 8.3”- 12” / Roll Feed - 12” - 24”
Media Thickness
0.08-0.28mm
Maximum Media Roll Diameter
4.3” (110mm)
Paper Feed Method
Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Automatic Sheet Feeder, Top Loading, Front Output
Languages
SGRaster
Noise Level Approx
Operation: 42.5 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 6 Bels
Physical Dimensions
ASF Opened: 16" x 38" x 22" (H x W x D)
ASF Closed: 10" x 38" x 22" (H x W x D)
Weight
approx. 71 lbs (no ink bottles, print head included)
Power Source
AC 100-240V (50-60Hz)
Power Consumption
Maximum: 28W or less
Standby 1.8W or less
Power Off: 0.3W or less (Compliant with Executive Order)
Operating Environment
Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
Print Head (PF-08)
Maintenance Cartridge (MC-32)
Ink Tanks (PFI-050)
File Name
imagePROGRAF TC-20 Spec Sheet
Date
12.02.24
File Size
2.1 MB
File Name
imagePROGRAF TC-20 Overview Flyer
Date
12.02.24
File Size
2.2 MB
File Name
Large Format Full Line Brochure
Date
04.30.25
File Size
11.5 MB
Sort By:
Untitle Video
Welcoming the new 24" Canon imagePROGRAF TC-20 Large Format printer. This compact printer is designed to provide accessibility and affordability for today’s “do-it-yourself” generation, from graphic designers to architects, engineers, educators, to retail shop owners.
imagePROGRAF TC-20 Compatible Products
Ink
Ink
Large Format Printer Accessories
Paper
Other Accessories
Ink
Product Disclaimer
Recycled paper, chlorine-free paper, and office paper with 100% post-consumer recycled content that meets the paper runnability performance requirements of EN 12281 can be used with this product.
This printer is designed to be used with Canon ink cartridges; not third party ink.
