Add to Cart
imagePROGRAF TC-20M MFP
TC-20M
As low as $995.00
In Stock
  • Print | Scan | Copy
  • 24" desktop roll & cut sheet printer
  • Copy & enlarge smaller originals
  • Scan to cloud or USB drive
  • 4-Color pigment bottle ink system
  • Ships standard with 280ml of ink
  • ENERGY STAR®, EPEAT Gold
  • Chromebook Compatible
  • 1 Year Warranty
New
Return Policy
Main Unit Specs
Printer Type
4-Color 24-inch Printer
Printing Technology
FINE: Full-Photolithography Inkjet Nozzle Engineering
Head Configuration
4-Color Integrated Type x 1 print head
Number of Nozzles
Total: 4,352 nozzles(BK 1,280 nozzles, C/M/Y 1,024 nozzles each)
Nozzle Pitch
1200 dpi
Print Resolution (Up to)
2400×1200dpi (Max)
OS Compatibility
Computer Operating Systems:
32-bit: Windows® 7/8.1/10
64-bit: Windows 7/8.1/10/11, Windows Server
2008 R2, 2012, 2012 R2, 2016, 2019, 2022
Mac: mac0S v10.14.6 - macOS v12.x
Print Software
imagePROGRAF Printer Driver for TC-20M Windows/Mac
Apple Air Print
Mopria
Canon PRINT Inkjet/SELPHY
PIXMA Cloud Link
PosterArtist Online
Free Layout Plus
Direct Print Plus
Media Configuration Tool
Quick Utility Toolbox
WiFi Connection Assistant
Printer Update Utility2
Scan Software
Scan Utility Lite
PIXUS/PIXMA Cloud Link
Printer Language
SGRaster
Standard Interfaces
Hi-Speed USB
Wi-Fi® IEEE802.11n/IEEE802.11g/IEEE802.11b
Wired LAN IEEE802.3u (100BASE-TX)/IEEE802.3(10BASE-T)
Ink Capacity
70 ml per color
Ink Types
Pigment Ink
Color Set
Pigment: Black, Cyan, Magenta, Yellow
Scanner Type
Flatbed
Scanning Method
Contact Image Sensors
Maximum Scan Resolution
Up to 2400 x 1200 dpi
Maximum Scan Document Size
A4/Letter
Media Handling
Roll: One Roll, Top-loading, Front Output
Cut Sheet: Automatic Sheet Feeder, Top-loading, Front Output
Media Width
Roll Feed: 12"- 24” (297 mm - 610 mm)
Cut Sheet: 8.3" - 12" (210 mm - 297 mm)
Maximum Print Length
Roll Feed: 13.1’ (4 m)1
Cut Sheet: 17" (432 mm)1
Media Thickness
0.08 mm - 0.28 mm
Media Core Size
2” Core
Maximum Media Roll Diameter
4.3” (110 mm)
Printable Margins
Roll Feed: All Sides - 0.19” (5 mm)
Acoustic Noise
Operation Approx. 41.5dB
35dB or Less Acoustic Power Approx. 6.0 Bels
Power Supply
AC 100–240 V (50-60 Hz)
Power Consumption
Maximum 26W or Less Standby
0.3W or Less Power Off
Operating Environment
Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
Environmental Certifications
ENERGY STAR®, EPEAT GOLD
Physical Dimensions
38.1 x 21.4 x 16 (W x D x H)
Weight
72.8lbs
User-replaceable items
Print Head (PF-08)
Maintenance Cartridge (MC-32)
Ink Tanks (PFI-050)
Reviews
Product Disclaimer
  1. The maximum printable length varies, depending on the application, OS, and RIP used.
  2. Internet connection required during software installation.
  3. Optional Canon eCarePAK Extended Service Plan is available to support your needs. For more information, call 1-800-423-2366 or visit our shop.usa.canon.com. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  4. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
