imagePROGRAF TC-21 Large Format Printer
7055C002
As low as $784.00
4 interest free payments of $196.00 with
klarna Pay Later
Paypal Pay Later
In Stock
  • 24" desktop roll printer with automatic sheet feeder
  • 4-Color pigment bottle ink system
  • Ships standard with 280ml of ink
  • Adjustable tilt screen operation panel
  • EPEAT Gold Certified
Show more
Auto Replenishment Service to get ink and toner when you need it: Do not Enroll
*By enrolling to Auto Replenishment Service, you automatically agree to the terms and conditions.
Add an eCarePAK Extended Service Plan for added coverage. Learn More
Overview
imagePROGRAF TC-21
24" Large Format Printer
The imagePROGRAF TC-21 printer is designed to provide the versatility that users need to create high-quality posters, banners, CAD drawings, labels, and more. Ideal for education, home offices, grocery stores, healthcare, architectural, construction environments, and more, this all-around and versatile large format printer can print on compatible roll media up to 24” wide or print labels as well as letter/A4 to A1 size prints from the Automatic Sheet Feeder. With the inclusion of 280 ml of ink—four 70 ml per ink bottles—the TC-21 sets itself apart by offering the largest ink capacity in its class, providing users the ability to print more without frequent refills.
imagePROGRAF TC-21 - Front View
  1. Automatic Sheet Feeder
  2. Easy to Fill Ink Tanks and Ships with 280 ml of Ink (70 ml each color)
  3. Prints up to 24" Wide
  4. Tiltable 2.7" LCD Touchscreen
  5. Print from Roll Media
imagePROGRAF TC-21 - Front View with Numbers
Features
Print signs, posters, banners, and more!
Person Getting Printed Poster from the imagePROGRAF TC-21
Person Refilling Paper Roll into the imagePROGRAF TC-21
Feed up to 100 sheets of letter or up to 50 sheets of 11” x 17” paper for greater print flexibility.
Person Using the imagePROGRAF TC-21
Print More
The imagePROGRAF TC-21 ships with 280 ml of ink - 70 ml per ink bottle - the most in its class!
Set of Ink Bottles
Easy to Fill
Ink bottles are keyed so they only fit and fill the intended color ink tank. The design helps to create a spill-free process that makes refilling a breeze.
Person Refilling imagePROGRAF TC-21 Ink Tank With Ink Bottle
Person Tilting the Screen of the imagePROGRAF TC-21
Demo of Tiltable Screen on the imagePROGRAF TC-21
Person Getting Printed Document from the imagePROGRAF TC-21
Person Looking at Printed Document from the imagePROGRAF TC-21
Restaurants
Print menus and special signs for window display or as menu boards.
Person Hanging Up a Printed Menu
Education
Create teaching materials, worksheets, posters, and more!
imagePROGRAF TC-21 on a Table
Retail
Promote clearance sales and new arrival items to help maximize store revenue.
Person Putting up Printed Poster on a Sign
PosterArtist
Easily create posters and flyers from a free, web-based, template-driven poster creation application.
Bring Your Ideas To life
Large Format Media
Canon inks and media deliver exceptional beauty and longevity to your prints. We offer a wide range of media types including matte, canvas, glossy and adhesive backings.
Image Alt Text
EPEAT® Gold Registered Product
This product is EPEAT® Gold registered in the U.S.A. EPEAT is the world’s premier ecolabel for electronics. EPEAT is owned and operated by the Global Electronics Council® (GEC), a mission-driven non-profit that seeks to create a world with only sustainable electronics. Manufacturers can register products under EPEAT based upon the device’s ability to meet required and optional EPEAT criteria that address impacts across the full product life cycle.
EPEAT Gold Logo
View Full Technical Specs PDF
Main Unit Specs
Printer Type
4-Color 24-inch Printer
Number of Nozzles
Total: 4,352
MBK: 1,280 nozzles
C, M, Y, BK: 1,024 nozzles each
Nozzle Pitch
1200 dpi
Print Resolution (Up to)
2400×1200dpi (Max)
Display
2.7" Tilted LCD Touchscreen
OS Compatibility
32-bit: Windows® 7, 8.1, 10
64-bit: Windows® 7, 8.1, 10/11, Server 2008 R2, 2012, 2012 R2, 2016, 2019, 2022, 2025
Mac: macOS X v11.7.10 ~ macOS 15
Standard Interfaces
USB 2.0 High-Speed
10/100 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Ink Capacity
70 ml per color
Ink Types
Pigment Ink
Color Set
Pigment: Black, Cyan, Magenta, Yellow
Buffer Ram
1 GB (Physical)
Media Width
Cut Sheet: 3.5”- 12” / Roll Feed: 12” - 24”
Media Thickness
0.08-0.28mm
Maximum Media Roll Diameter
4.3” (110mm)
Paper Feed Method
Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Automatic Sheet Feeder, Top Loading, Front Output
Languages
SGRaster
Noise Level Approx
Operation: 41.5 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 6 Bels
Physical Dimensions
ASF Opened, Operation Panel Closed: 38" x 21" x 16" (W x D x H)
ASF Closed, Operation Panel Closed: 38" x 21" x 10" (W x D x H)
Weight
approx. 71 lbs (no ink bottles, print head included)
Power Source
AC 100-240V (50-60Hz)
Power Consumption
Maximum: 28W Approx.
Standby 1.7W Approx.
Power Off: 0.07W Approx.
Operating Environment
Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Dew Condensation)
User-replaceable items
Print Head (PF-08)
Maintenance Cartridge (MC-32)
Ink Bottles (PFI-050)
Reviews
File Name
imagePROGRAF TC-21 and TC-21M Flyer
Date
12.16.25
File Size
1.5 MB
File Name
Large Format Full Line Brochure
Date
06.01.26
File Size
5.7 MB
Sort By:
Untitle Video
In this video we will review the features and benefits of, as well as the markets and applications for, the imagePROGRAF TC-21 & TC-21M Large Format Printers.
Untitle Video
In this video we will show you how to unbox and set up your new imagePROGRAF TC-21 Series Large Format printer. The process is the same for setting up the single function TC-21 and the multifunction TC-21M, so follow these steps to quickly get up and running.
Untitle Video
Adding ink and media to your imagePROGRAF TC-21 or TC-21M is quick and easy. Follow the steps in this video to add or replenish ink, load roll media, or load media to the automatic sheet feeder. The process is the same for the single function TC-21 and the multifunction TC-21M.
imagePROGRAF TC-21 Large Format Printer Compatible Products
Ink
Ink
Product Disclaimer
Recycled paper, chlorine-free paper, and office paper with 100% post-consumer recycled content that meets the paper runnability performance requirements of EN 12281 can be used with this product.
This printer is designed to be used with Canon ink cartridges; not third party ink.
