Out Of Stock
imagePROGRAF TM-200 MFP L24ei
TM-200 L24EI
As low as $0.00
Out Of Stock
  • 24" Large Format printer with L24ei entry-level scanner
  • Scan to USB
  • Scan to copy and archive
  • Scan to multipage PDF
  • 5-Color LUCIA TD pigment based ink system
  • Print up to 144 D-sized prints per hour
This printer is designed to be used with Canon ink cartridges; not third party ink.
Set
Return Policy
Main Unit Specs
Printer Type
5-Color 24-inch Printer
Number of Nozzles
Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
Nozzle Pitch
1,200 dpi
Non-firing nozzle detection and compensation
OS Compatibility
Windows® 7, 8.1, 10 (32/64bit)
Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit)
Macintosh OS X v10.10.5-v10.12x
Standard Interfaces
USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Ink Droplet Size
Pigment Ink
Ink Capacity
130 ml or 300ml per color
Color Set
Pigment: Matte Black, Black, Cyan, Magenta, Yellow
Buffer Ram
2 GB (Physical)
Media Width
Cut Sheet - 8"- 24"
Roll Feed - 8" - 24"
Media Thickness
0.07-0.8mm
Maximum Roll Print Length
Roll Feed - 59 (18 meters)
Maximum Media Roll Diameter
5.9" (150mm)
Borderless Printing Width
8", 10", 12", 14", 16" 17", 20", 24" B4 (10.12"/257 mm), A3 (11.69"/297 mm), A3+ (12.95"/329 mm), A2 (16.54"/420 mm), B2 (20.28"/515 mm), A1 (23.39"/594 mm)
Paper Feed Method
Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Top Loading, Front Output
Languages
SGRaster, HPGL/2, HP-RTL, JPEG
Noise Level Approx
Operation: 44 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 6.0 Bels
Physical Dimensions
42.0" x 38" x 34"
Weight
approx.112 lbs (roll holder included, no inks, no print heads)
Power Source
AC-100-240V (50-60Hz)
Power Consumption
Maximum: 69W or less
Standby 3.6W or less
Power Off: 0.3W or less (Compliant with Executive Order)
Operating Environment
Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
Print Head (PF-06)Maintenance Cartridge (MC-31)Ink Tanks (PFI-120/PFI-320)Cutter Blade (CT-08)
Software Included
TM Unified Printer Driver, Accounting Manager, Apple AirPrint, Canon Print Service, Device Management Console, Direct Print & Share, Free Layout Tool, Free Layout Plus, imagePROGRAF Printer Driver for Windows®/Mac®, Media Configuration Tool, PosterArtist Lite for Windows, Optimized Driver for AutoCAD, Canon PRINT Inkjet Selphy, Easy Photo Print Editor †Scanner Type:Contact Image Sensor (CIS) technology
Scan Accuracy: +/- 0.20%
Speed:3 ips monochrome, 1 ips color (Copy, Standard Mode)
Optical Resolutions:600 dpi
Max Resolutions:600 dpi
Max. Document SizeWidth: 26 inch document width (24 inch image width)
Length:109 inch
Thickness:0.5mm
Standard Interface: (Scan to USB)USB 2.0 / (Scan to Network)Gigabit ethernet
Reviews
Product Disclaimer
Recycled paper and chlorine-free paper can be used with this product.
  1. Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof are based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions.
  2. SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
  3. Plain Paper, Fast (Q5) mode.
  4. Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
  5. Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  6. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
  7. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
The imagePROGRAF MFP Lei systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
Canon, CanoScan and imagePROGRAF are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Wi-Fi is a registered trademark of the Wi-Fi Alliance. Android is a trademark of Google Inc. Apple, AirPrint, iPad, iPhone, iPod touch, Mac and Time Capsule are trademarks of Apple Inc., registered in the United States and other countries. Microsoft, Office, Windows, Outlook, Word, Excel and PowerPoint are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries. Autodesk, the Autodesk logo and AutoCAD are registered trademarks or trademarks of Autodesk, Inc., and/or its subsidiaries and/or affiliates in the USA and/or other countries. All referenced product names and trademarks are the property of their respective owners. Specifications and availability dates are subject to change without notice. Not responsible for typographical errors. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
