imagePROGRAF TM-300 MFP Z36
TM300MFP Z36
As low as
$0.00
Out Of Stock
- 36" Large Format printer with Z36 scanner
- Scan to copy/file/share solution
- All-in-one 15.6" touchscreen computer
- 5-Color LUCIA TD pigment based ink system
- SmartWorks MFP Software
- Security Features
Need to order more than 10?
Learn More
Need help making a purchase? Contact a Sales Expert at 800-385-2155>
Return Policy
Main Unit Specs
Printer Type
5-Color 36-inch Printer
Number of Nozzles
Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
MBK: 5,120 nozzles
Nozzle Pitch
1200 dpi
Non-firing nozzle detection and compensation
Print Resolution (Up to)
2400×1200dpi (Max)
OS Compatibility
Windows® 7, 8.1, 10 (32/64bit)
Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit)
Macintosh OS X v10.10.5-v10.12x
Standard Interfaces
USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Direct USB Thumb Drive Printing
Ink Droplet Size
Pigment Ink
Ink Capacity
130 ml or 300ml per color
Color Set
Pigment: Matte Black, Black, Cyan, Magenta, Yellow
Buffer Ram
128 GB (2 GB Physical)
Media Width
Cut Sheet - 8”- 36”
Roll Feed - 8” - 36”
Media Thickness
0.07-0.8mm
Maximum Roll Print Length
Roll Feed - 59 (18 meters)
Maximum Media Roll Diameter
5.9” (150mm)
Borderless Printing Width
8”, 10", 12”, 14", 16” 17", 20”, 24", 36" B4 (10.12"/257 mm), A3 (11.69"/297 mm), A3+ (12.95"/329 mm), A2 (16.54"/420 mm), B2 (20.28"/515 mm), A1 (23.39"/594 mm), B1 (28.66"/ 728 mm), A0 (33.11"/841 mm)
Paper Feed Method
Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Top Loading, Front Output
Languages
SGRaster, HPGL/2, HP-RTL, JPEG
Noise Level Approx
Operation: 44 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 6.0 Bels
Physical Dimensions
42" x 51" x34"
Weight
approx.130 lbs (roll holder included, no inks, no print heads)
Power Source
AC100-240V (50-60Hz)
Power Consumption
Maximum: 69W or less
Standby 3.6W or less
Power Off: 0.3W or less (Compliant with Executive Order)
Operating Environment
Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
- Print Head (PF-06)
- Maintenance Cartridge (MC-31)
- Ink Tanks (PFI-120/PFI-320)
- Cutter Blade (CT-08)
Software Included
TM Unified Printer Driver, Accounting Manager, Canon Print Service, Device Management Console, Direct Print Plus, Free Layout Tool, Free Layout Plus, imagePROGRAF Printer Driver for Windows®/Mac®, Media Configuration Tool, PosterArtist Lite for Windows, Optimized Driver for AutoCAD, Canon PRINT Inkjet Selphy, Easy Photo Print Editor
Scanner Specs
Scanner Type
Contact Image Sensor (CIS) technology
Scan Accuracy
+/- 0.1%
Speed
13 ips monochrome, 6 ips color
Optical Resolutions
1200dpi (Adjustable from 100 dpi to 2,400 dpi)
Max. Resolutions
9600dpi interpolated
Max. Document Size
Width 38 inch document width (36 inch image width) / Length: 315" (JPG or PDF) / 598" (TIFF)
Thickness
0.04in (1mm)
Standard Interface
USB 3.0 (PC connector compatible with USB 2.0 and USB 3.0 sockets)
Reviews
Product Disclaimer
Recycled paper and chlorine-free paper can be used with this product.
- SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
- Plain Paper, Fast (Q5) mode.
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package.
The imagePROGRAF TM Series MFP Z36 systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
