imagePROGRAF TX-3200 MFP Z36
- 36" Printer with 36" Scanner
- Up to 3.3 D-size pages per min*
- Scans up to 13” per second for monochrome prints
- Optional Multifunction Roll Unit
- EPEAT Gold and Energy STAR registered
* 3.3 ANSI D prints/minute speed measured after first print in Fast Q5 mode, using plain paper. Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type, and orientation of paper.
In the box
Overview
WHERE PRECISION MEETS PRODUCTIVITY
With the capability to print both monochrome line drawings and eye-catching full-color posters, the imagePROGRAF 36” TX-3200 MFP Z36 Large Format Printer is designed with production and versatility in mind within the aqueous inkjet market. Scan monochrome documents at up to 13” per second and color documents at up to 6” per second with the Z36 Scanner!
LUCIA TD Ink System
The magenta ink in the imagePROGRAF TX-3200 MFP Z36 is designed to deliver outstanding red color reproduction suitable for a wide range of markets and applications. The use of pigment ink for all colors helps to ensure prints are resistant to fading.
Improved Line Clarity
Image processing improvements and LUCIA TD ink help to enhance CAD drawings, blueprints, AEC documentation, and poster reproductions with a large color gamut and improved text and line quality. This makes output more crisp, defined, and clear.
Color Calibration
Available in the imagePROGRAF TX-3200 MFP Z36, the ability to calibrate your printer helps ensure your output is color consistent over time and across multiple TX-3200/4200 devices.
Z36 Scanner
Workflow is effortless and consistent with Canon’s integration of the scanner with the imagePROGRAF TX Series. Like the previous model, the 36” lightweight Z36 scanner is positioned on top of the device, providing a compact, all-in-one solution for ease of use.
imagePROGRAF eCarePAK Extended Service Plans
Extends service coverage beyond the initial warranty period for up to 5 years total coverage.
PosterArtist
Easily create posters and flyers from a free, web-based, template-driven poster creation application.
Everything Large Format at your Fingertips
The Canon Large Format Printer App gives users access to how to videos, printing and photo events, firmware and software updates.
Large Format Media
Canon inks and media deliver exceptional beauty and longevity to your prints. We offer a wide range of media types including matte, canvas, glossy and adhesive backings.
EPEAT® Gold Registered Product
This product is EPEAT® Gold registered in the U.S.A. EPEAT is the world’s premier ecolabel for electronics. EPEAT is owned and operated by the Global Electronics Council® (GEC), a mission-driven non-profit that seeks to create a world with only sustainable electronics. Manufacturers can register products under EPEAT based upon the device’s ability to meet required and optional EPEAT criteria that address impacts across the full product life cycle.
ENERGY STAR® Certified
Canon imagePROGRAF printers are ENERGY STAR® certified products. Products that earn the ENERGY STAR® label meet strict energy-efficiency specifications set by the U.S. EPA, helping you save energy and money while protecting our planet.
Main Unit Specs
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
M: PFI-111(160ml)
BK/C/Y: PFI-110(160ml)
MBK: PFI-310(330ml)
Replacement:
M: PFI-111(160ml)/PFI-311(330ml)/PFI-711(700ml)
MBK/BK/C/Y: PFI-110(160ml)/PFI-310(330ml)/PFI-710(700ml)
Roll Feed: 6" - 36" (152 mm - 917 mm)
Cut Sheet: 63" (1.6 m)
Front Loading Manual Feed: One Roll, Front Output
Type: Built-in (Hi-speed USB)
Mode: Full Speed (12-Mbit/sec.), High Speed (480-Mbit/sec.), Bulk Transfer Connector Type: Series B (4 Pins)
USB A Port: Direct USB Thumb Drive Printing
Gigabit Ethernet
Type: Built-in
Standard: IEEE 802.3u 100Base-TX/Auto-Negotiation, IEEE 802.3ab 1000Base-T/Auto-Negotiation, IEEE 802.3x Full Duplex
Protocol: SNMP, HTTP, TCP/IP (IPv4/IPv6), FTP
Wireless LAN
Standard: IEEE802.11n/IEEE802.11g/IEEE802.11b4
Security: WEP (64/128-bit), WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES)
Standby: 35 dB (A) or Less
Acoustic Power: Approx 6.9Bels
Standby: Approx. 1.7 W
Power Off: Approx. 0.1 W
C TUVus (U.S.A.), C TUVus (Canada)
Electromagnetic Interface Regulations
FCC Part 15B (U.S.A.), IC (Canada)
Radio Regulations
FCC Part 15C (U.S.A.), IC (Canada)
Environmental Certifications
ENERGY STAR® & EPEAT Gold
Relative Humidity: 10 - 80% (No Condensation)
54.7" x 38.7" x 46"; 231.5 lb (Approx)
With Basket Closed
54.7" x 30.2" x 46"; 231.5 lb (Approx)
With Stacker Opened
54.7" x 46.8" x 46"; 258 lb (Approx)
With Stacker Closed
54.7" x 44.2" x 46"; 258 lb (Approx)
64" x 35.6" x 40.7"; 337 lb (Approx.)
Basket
56" x 21.9" x 8.4"; 20 lb (Approx.)
Stacker
49.2" x 35.7" x 11.5"; 60 lb (Approx.)
Roll Unit
60" x 22.1" x 18.1"; 68.3 lb (Approx.)
• 2"/3" Roll Holder Set (RH2-34)
User-Replaceable Items
• Ink Tank (PFI-110/111, PFI-310/311, PFI-710/711)
• Print Head (PF-06)
• Maintenance Cartridge (MC-30)
• Cutter Blade (CT-07)
• 8-bit Grayscale and Monochrome @ 200 dpi: Up to 13” per second
(SingleSensor Assembly)
• 24-bit RGB
• 16-bit grayscale image capture
• Panchromatic monochrome and black and white
• Bi-directional extra long-life LED light system for
optimum object illumination and instant-on scanning
capability
• Idle: 12.4 W
• Scanning Color/Grayscale at 200 dpi: 22.7 W/23.3 W
• Controller: 35 W
50" x 17" x 19.5", 75 lb. (Approx.)
- Line accuracy repeatability is guaranteed after a user performs the necessary adjustment and under the same environmental conditions. Applies to media for line drawing (Plain Paper, Coated Paper, CAD Translucent Matte Film, and CAD Tracing Paper) only.
- Theoretical value based on data resolution.
- The maximum printable length varies depending on the application, OS, and RIP used.
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- The scan rate is proportional across the full range of resolutions supported by the scanner. Actual scan times will depend on the host system performance. Quoted top speeds may be limited by the effective bandwidth of the USB 2 and is not guaranteed for all media types.
- The quoted scan accuracy may vary depending on the operating environment and the thickness of the media.
Resources
Canon imagePROGRAF TX Series Brochure
12.29.25
4.3 MB
Large Format Full Line Brochure
06.01.26
5.7 MB
Canon imagePROGRAF TX-3200 MFP Z36 Spec Sheet
12.29.25
1.1 MB
Product Disclaimer
Recycled paper, chlorine-free paper, and office paper with 100% post-consumer recycled content that meets the paper runnability performance requirements of EN 12281 can be used with this product.
The imagePROGRAF TX MFP Z36 system contains multiple components, some of which are manufactured by third parties. To the extent that such third-party offerings come with limited warranties, those such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation.
All speed measured on Plain Paper in Fast Q5 mode.
- SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
- Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
- The 700ml ink tank is only available for service authorized partners.
- Plain Paper, Fast (Q5) mode.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package.
