imagePROGRAF TX-4200
- 44" Printer
- Up to 3.3 D-size pages per min*
- LUCIA TD 5-Color Pigment Ink System
- Optional Multifunction Roll Unit
- EPEAT Gold and Energy STAR registered
* 3.3 ANSI D prints/minute speed measured after first print in Fast Q5 mode, using plain paper. Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type, and orientation of paper.
In the box
Overview
With the capability to print both monochrome line drawings and eye-catching full-color posters, the imagePROGRAF TX large-format printer series is designed with production and versatility in mind within the aqueous inkjet market.
imagePROGRAF eCarePAK Extended Service Plans
Extends service coverage beyond the initial warranty period for up to 5 years total coverage.
PosterArtist
Easily create posters and flyers from a free, web-based, template-driven poster creation application.
Everything Large Format at your Fingertips
The Canon Large Format Printer App gives users access to how to videos, printing and photo events, firmware and software updates.
Large Format Media
Canon inks and media deliver exceptional beauty and longevity to your prints. We offer a wide range of media types including matte, canvas, glossy and adhesive backings.
EPEAT® Gold Registered Product
This product is EPEAT® Gold registered in the U.S.A. EPEAT is the world’s premier ecolabel for electronics. EPEAT is owned and operated by the Global Electronics Council® (GEC), a mission-driven non-profit that seeks to create a world with only sustainable electronics. Manufacturers can register products under EPEAT based upon the device’s ability to meet required and optional EPEAT criteria that address impacts across the full product life cycle.
ENERGY STAR® Certified
Canon imagePROGRAF printers are ENERGY STAR® certified products. Products that earn the ENERGY STAR® label meet strict energy-efficiency specifications set by the U.S. EPA, helping you save energy and money while protecting our planet.
Main Unit Specs
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
MBK/BK/C/Y/M: 330 ml
Replacement:
M: PFI-111(160ml)/PFI-311(330ml)/PFI-711(700ml)
MBK/BK/C/Y: PFI-110(160ml)/PFI-310(330ml)/PFI-710(700ml)
Roll Feed: 6”-44” (152 mm - 1118 mm)
Front Loading Manual Feed: One Roll, Front Output
Windows 11 (64-bit), Windows Server 2008R2, 2012, 2012R2, 2016, 2019,
2022 (64-bit), MacOS v10.15.7- MacOS 14
Type: Built-in (Hi-speed USB)
Mode: Full Speed (12-Mbit/sec.), High Speed (480-Mbit/sec.), Bulk Transfer Connector Type: Series B (4 Pins)
USB A Port: Direct USB Thumb Drive Printing
Gigabit Ethernet
Type: Built-in
Standard: IEEE 802.3u 100Base-TX/Auto-Negotiation, IEEE 802.3ab 1000Base-T/Auto-Negotiation, IEEE 802.3x Full Duplex
Protocol: SNMP, HTTP, TCP/IP (IPv4/IPv6), FTP
Wireless LAN
Standard: IEEE802.11n/IEEE802.11g/IEEE802.11b4
Security: WEP (64/128-bit), WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES)
Standby: 35 dB (A) or Less
Acoustic Power: Approx 6.9Bels
Standby: Approx. 1.7 W
Power Off: Approx. 0.1 W
C TUVus (U.S.A.), C TUVus (Canada)
Electromagnetic Interface Regulations
FCC Part 15B (U.S.A.), IC (Canada)
Radio Regulations
FCC Part 15C (U.S.A.), IC (Canada)
Environmental Certifications
ENERGY STAR® & EPEAT Gold
Relative Humidity: 10 - 80% (No Condensation)
With Basket Closed: 63” x 31” x 46”; 247 lb. (Approx.)
With Stacker Opened: 63” x 47” x 46”; 273 lb. (Approx.)
With Stacker Closed: 63” x 45” x 46”; 273 lb. (Approx.)
Basket: 56” x 21.9” x 8.4”; 20 lb. (Approx.)
Stacker: 49.2” x 35.7” x 11.5”; 60 lb. (Approx.)
Roll Unit: 68” x 23” x 19”; 75 lb. (Approx.)
• 2"/3" Roll Holder Set (RH2-46)
User-Replaceable Items
• Ink Tank (PFI-110/111, PFI-310/311, PFI-710/711)
• Print Head (PF-06)
• Maintenance Cartridge (MC-30)
• Cutter Blade (CT-07)
- Line accuracy repeatability is guaranteed after a user performs the necessary adjustment and under the same environmental conditions. Applies to media for line drawing (Plain Paper, Coated Paper, CAD Translucent Matte Film, and CAD Tracing Paper) only.
- Theoretical value based on data resolution.
- The maximum printable length varies depending on the application, OS, and RIP used.
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
Resources
Canon imagePROGRAF TX Series Brochure
12.29.25
4.3 MB
Large Format Full Line Brochure
06.01.26
5.7 MB
Canon imagePROGRAF TX-4200 Spec Sheet
12.29.25
0.6 MB
Product Disclaimer
Recycled paper, chlorine-free paper, and office paper with 100% post-consumer recycled content that meets the paper runnability performance requirements of EN 12281 can be used with this product.
- The 700ml ink tank is only available for service authorized dealers.
- Plain Paper, Fast (Q5) mode.
- Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
